[mpich-discuss] hydra_pmi_proxy: error while loading shared libraries: libimf.so: cannot open shared object file: No such file or directory (Reuti)
Reuti
reuti at staff.uni-marburg.de
Tue Sep 4 15:28:56 CDT 2012
Am 04.09.2012 um 22:09 schrieb Marcelo C. R. Melo:
> Yes Reuti, the LD_LIBRARY_PATH is configured correctly.
> I can use the software normally when logged into any node.
The environment will be different when started by a queuing system, at least for SGE I know this for sure and I think also for Torque/PBS. To investigate, can you please submit a job with:
#!/bin/sh
echo $LD_LIBRARY_PATH
ldd /path/to/your/application
If we know this, we have to check the processes on the slave nodes of the parallel job. Usually they are not started by an `ssh`, but some builtin mechanism inside the queuingsystem. So, submitting a job with this should show it:
#!/bin/sh
mpiexec echo \$LD_LIBRARY_PATH
It's necessary to escape the $, as we want to get the result from the slave, not where the jobscript is executed.
-- Reuti
> The problem is that when I Spawn another executable from my initial launcher program, the spawned executable does not see the environment that the launcher received.
> Is there any portable way to pass the environment variables to Spawned processes?
> I posted this question on stack overflow a few days ago: http://stackoverflow.com/questions/12252490/why-cant-and-environment-variable-be-seen-by-an-executable-if-it-is-run-on-two/12252584#comment16448588_12252584
> Best regards,
> Marcelo
> On 4 September 2012 14:00, <mpich-discuss-request at mcs.anl.gov> wrote:
> Today's Topics:
> 1. Re: hydra_pmi_proxy: error while loading shared libraries:
> directory (Marcelo C. R. Melo)
> 2. Re: hydra_pmi_proxy: error while loading shared libraries:
> directory (Reuti)
> Message: 1
> Date: Mon, 3 Sep 2012 15:33:03 -0300
> From: "Marcelo C. R. Melo" <melomcr at gmail.com>
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] hydra_pmi_proxy: error while loading
> file or directory
> Message-ID:
> <CAAO08KuiPENRYDY_aUx9KPeaESQZA5MwN18g+FQVjxT39co16w at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Hello to all,
> Has there been any advances in this topic? Any solutions found?
> I am having the exact same problem. When I ask for just one node, my
> software runs fine. If I ask for two or more, even though I just use
> one, I get the "missing library" error.
> I tried an "ssh node2 ls
> /opt/intel/composerxe-2011.3.174/compiler/lib/intel64/libimf.so >>
> $log_file " inside my PBS script and the lib exists in a folder that
> the node can see.
> Best regards,
> Marcelo
> Message: 2
> Date: Mon, 3 Sep 2012 20:40:29 +0200
> From: Reuti <reuti at staff.uni-marburg.de>
> file or directory
> Message-ID:
> <57548BBE-C25F-4447-B33D-E3316DCA60E2 at staff.uni-marburg.de>
> Content-Type: text/plain; charset=us-ascii
> Am 03.09.2012 um 20:33 schrieb Marcelo C. R. Melo:
> > Hello to all,
> > the node can see.
> Is the LD_LIBRARY_PATH also set in your ~/.bashrc that it can be loaded automatically when you `ssh` to the node?
> -- Reuti
> > Best regards,
> > Marcelo
> > _______________________________________________
> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> End of mpich-discuss Digest, Vol 48, Issue 1
