[mpich-discuss] hydra_pmi_proxy: error while loading shared libraries: libimf.so: cannot open shared object file: No such file or directory
Reuti reuti at staff.uni-marburg.de
Mon Sep 3 13:40:29 CDT 2012
Am 03.09.2012 um 20:33 schrieb Marcelo C. R. Melo:
> Hello to all,
> Has there been any advances in this topic? Any solutions found?
> I am having the exact same problem. When I ask for just one node, my
> software runs fine. If I ask for two or more, even though I just use
> one, I get the "missing library" error.
> I tried an  "ssh node2 ls
> /opt/intel/composerxe-2011.3.174/compiler/lib/intel64/libimf.so >>
> $log_file "  inside my PBS script and the lib exists in a folder that
> the node can see.
Is the LD_LIBRARY_PATH also set in your ~/.bashrc that it can be loaded automatically when you `ssh` to the node?
-- Reuti
> Best regards,
> Marcelo
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
