[mpich-discuss] MPICH2 uses network to communicate instead of	share memory on this NUMA architecture
    Rajeev Thakur
    thakur at mcs.anl.gov
    Wed Oct 31 13:15:56 CDT 2012
Did you specify placement of processes using a hostfile as described here: http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
On Oct 31, 2012, at 3:14 AM, CLARK wrote:
> the architecture of CPU is:
> <2CF9F3FD at 30170568.CADD9050>
> this CPU has 8 cores,2 nodes,node 0 and node 1,each node has 4 cores,only one node‘s Memory Controller connected memory. I think it is an NUMA architecture. the node in the right accessing memory is slower than the left one.
> In this architecture,i config mpich2 1.5:./configure --prefix=XXX --with-device=ch3:nemesis --with-shared-memory=mmap, then make and make install.
> I found that,when running 2 processes on this CPU,network card lo has sended and received data,but in other NUMA architecture,network card lo has no sended and received data.
> I donot know why,maybe mpich cannot identity this architecture,or is there anything wrong with my OS?
> And,which codes and conditions are nemesis used to choose the way to communicate?
> thank you.
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
