[mpich-discuss] Can't run an MPI-Programm on more than one	host
    Andreas Hauffe
    andreas.hauffe at tu-dresden.de
    Wed Oct 24 13:11:04 CDT 2012
I wanted to try to use bash. But I'm at home and not at work so I had to login
via ssh. In this case other environtment variables are set. This time I got
the following error which solves the problem:
[proxy:0:1 at mlr113u] launch_procs (./pm/pmiserv/pmip_cb.c:651): unable to
change wdir to /btmpl/Software (No such file or directory)
[proxy:0:1 at mlr113u] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:890):
launch_procs returned error
[proxy:0:1 at mlr113u] HYDT_dmxu_poll_wait_for_event
(./tools/demux/demux_poll.c:77): callback returned error status
[proxy:0:1 at mlr113u] main (./pm/pmiserv/pmip.c:210): demux engine error waiting
for event
[mpiexec at mlr114u] control_cb (./pm/pmiserv/pmiserv_cb.c:201): assert (!closed)
failed
[mpiexec at mlr114u] HYDT_dmxu_poll_wait_for_event
[mpiexec at mlr114u] HYD_pmci_wait_for_completion
(./pm/pmiserv/pmiserv_pmci.c:196): error waiting for event
[mpiexec at mlr114u] main (./ui/mpich/mpiexec.c:325): process manager error
waiting for completion
My working/starting directory was not available on the other machines. This is
completely right cause it's a local directory. Sorry Guys!!
But now it works.
Thanks for your help!!
Andreas
Am Mittwoch, 24. Oktober 2012, 09:24:44 schrieb Dave Goodell:
> I don't see any obvious problems in the output that you sent.  Pavan
> suggested offline that this could be related to a bad interaction that
> hydra sometimes has with csh/tcsh.  Perhaps try running under bash or zsh
> just to check if this is the case?
> I'm sorry that I don't have any other suggestions for you at this time.
> -Dave
> On Oct 16, 2012, at 12:42 PM CDT, Andreas Hauffe wrote:
> > Here the output:
> > mpiexec -v -f machinefile -n 4 hostname
> > host: mlr114u
> > host: mlr113u
> > ========================== mpiexec options:
> >  Base path: /mnt/appl/lft/mpich/mpich2-1.5.0p0_64bit/bin/
> >  Launcher: (null)
> >  Debug level: 1
> >  Enable X: -1
> >  Global environment:
> >    LANG=de_DE
> >    USER=hauffe
> >    LOGNAME=hauffe
> >    HOME=/home/lft/mitarbeiter/hauffe
> >    PATH=/mnt/appl/lft/mpich/mpich2-1.5.0p0_64bit/bin:/w/appl/lft/jdk1
> >    .7.0_07-linux-x64/bin:/mnt/appl/lft/composer_xe_2011_sp1.8.273/mpi
> >    rt/bin/intel64:/mnt/appl/lft/composer_xe_2011_sp1.8.273/bin/intel6
> >    4:/w/appl/lft/Modules/3.2.8/bin:/usr/NX/bin:/usr/lib64/mpi/gcc/ope
> >    nmpi/bin:/home/lft/mitarbeiter/hauffe/bin:/usr/bin:/bin:/usr/sbin:
> >    /sbin:/usr/local/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/l
> >    ib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/w/appl/lft/bi
> >    n MAIL=/var/mail/hauffe
> >    SHELL=/usr/bin/tcsh
> >    SSH_CLIENT=141.30.52.234 53502 22
> >    SSH_CONNECTION=141.30.52.234 53502 141.30.156.114 22
> >    SSH_TTY=/dev/pts/0
> >    TERM=xterm
> >    XDG_SESSION_ID=144
> >    XDG_RUNTIME_DIR=/run/user/hauffe
> >    NLSPATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib/inte
> >    l64/locale/en_US:/usr/share/locale/%L/LC_MESSAGES/%N.cat
> >    HOSTTYPE=x86_64
> >    VENDOR=suse
> >    OSTYPE=linux
> >    MACHTYPE=x86_64-suse-linux
> >    SHLVL=1
> >    PWD=/btmpl/Software
> >    GROUP=lftuser
> >    HOST=mlr114u
> >    CSHEDIT=emacs
> >    CPU=x86_64
> >    HOSTNAME=mlr114u.mw.tu-dresden.de
> >    INPUTRC=/home/lft/mitarbeiter/hauffe/.inputrc
> >    LESS=-M -I -R
> >    LESSOPEN=lessopen.sh %s
> >    LESSCLOSE=lessclose.sh %s %s
> >    LESS_ADVANCED_PREPROCESSOR=no
> >    LESSKEY=/etc/lesskey.bin
> >    PAGER=less
> >    MORE=-sl
> >    MINICOM=-c on
> >    MANPATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/man/en_US:/w/appl
> >    /lft/Modules/3.2.8/share/man:/usr/lib64/mpi/gcc/openmpi/man:/usr/s
> >    hare/man:/usr/local/man XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB
> >    XNLSPATH=/usr/share/X11/nls
> >    COLORTERM=1
> >    SSH_SENDS_LOCALE=yes
> >    JAVA_BINDIR=/usr/lib64/jvm/jre/bin
> >    JAVA_ROOT=/usr/lib64/jvm/jre
> >    JAVA_HOME=/usr/lib64/jvm/jre
> >    JRE_HOME=/usr/lib64/jvm/jre
> >    CVS_RSH=ssh
> >    XCURSOR_THEME=DMZ
> >    QT_SYSTEM_DIR=/usr/share/desktop-data
> >    LD_LIBRARY_PATH=/w/appl/lft/jdk1.7.0_07-linux-x64/jre/lib/amd64:/m
> >    nt/appl/lft/composer_xe_2011_sp1.8.273/mpirt/lib/intel64:/mnt/appl
> >    /lft/composer_xe_2011_sp1.8.273/compiler/lib/intel64:/usr/lib64/mp
> >    i/gcc/openmpi/lib64:/w/appl/x86_64/paraview/3.14.1_batch/bin
> >    NXDIR=/usr/NX
> >    FROM_HEADER=
> >    NNTPSERVER=news
> >    WINDOWMANAGER=/usr/bin/kde4
> >    ALSA_CONFIG_PATH=/etc/alsa-pulse.conf
> >    SDL_AUDIODRIVER=pulse
> >    PYTHONSTARTUP=/etc/pythonstart
> >    XDG_DATA_DIRS=/usr/local/share:/usr/share:/usr/share/gnome/help
> >    XDG_CONFIG_DIRS=/etc/xdg
> >    G_BROKEN_FILENAMES=1
> >    G_FILENAME_ENCODING=@locale,UTF-8,ISO-8859-1,CP1252
> >    CSHRCREAD=true
> >    LS_COLORS=no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35
> >    :bd=40;33;01:cd=40;33;01:or=41;33;01:ex=00;32:*.cmd=00;32:*.exe=01
> >    ;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.
> >    tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00
> >    ;31:*.lzh=00;31:*.lzma=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z
> >    =00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31
> >    :*.xz=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=
> >    01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35
> >    :*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif
> >    =01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.wmv=01;35:*
> >    .aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=0
> >    0;32:*.wav=00;32: LS_OPTIONS=-N --color=tty -T 0
> >    GPG_TTY=/dev/pts/0
> >    MODULE_VERSION=3.2.8
> >    MODULE_VERSION_STACK=3.2.8
> >    MODULESHOME=/w/appl/lft/Modules/3.2.8
> >    MODULEPATH=/w/appl/lft/Modules/versions:/w/appl/lft/Modules/$MODUL
> >    E_VERSION/modulefiles/lft-apps:/w/appl/lft/Modules/$MODULE_VERSION
> >    /modulefiles/compilers:/w/appl/lft/Modules/$MODULE_VERSION/modulef
> >    iles/debuggers:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/lib
> >    raries:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/application
> >    s
> >    LOADEDMODULES=modules:lft:nedit/5.5:ifc/11.8.273:paraview/3.14.1:
> >    jdk/1.7.0_u7:netbeans/7.2:paraview/3.14.1_batch:mpich2/1.5.0p0
> >    _LMFILES_=/w/appl/lft/Modules/default/modulefiles/modules:/w/appl
> >    /lft/Modules/default/modulefiles/lft:/w/appl/lft/Modules/3.2.8/mod
> >    ulefiles/applications/nedit/5.5:/w/appl/lft/Modules/3.2.8/modulefi
> >    les/compilers/ifc/11.8.273:/w/appl/lft/Modules/3.2.8/modulefiles/a
> >    pplications/paraview/3.14.1:/w/appl/lft/Modules/3.2.8/modulefiles/
> >    applications/jdk/1.7.0_u7:/w/appl/lft/Modules/3.2.8/modulefiles/ap
> >    plications/netbeans/7.2:/w/appl/lft/Modules/3.2.8/modulefiles/appl
> >    ications/paraview/3.14.1_batch:/w/appl/lft/Modules/3.2.8/modulefil
> >    es/libraries/mpich2/1.5.0p0 INTEL_LICENSE_FILE=28518 at mlr25s
> >    LIBRARY_PATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib
> >    /intel64
> >    PYTHONPATH=/w/appl/x86_64/paraview/3.14.1_batch/Utilities/VTKPyth
> >    onWrapping/site-packages:/w/appl/x86_64/paraview/3.14.1_batch/bin
> >    BSTINPUTS=/home/lft/mitarbeiter/hauffe/myLatex/styles/BibTeX//:
> >    BIBINPUTS=/home/lft/mitarbeiter/hauffe/Documents/Bibliographien/:
> >    .: SSH_AUTH_SOCK=/tmp/ssh-rjXtIUUZ6349/agent.6349
> >    SSH_AGENT_PID=6350
> >  Hydra internal environment:
> >    GFORTRAN_UNBUFFERED_PRECONNECTED=y
> >    Proxy information:
> >      [1] proxy: mlr114u (1 cores)
> >      Exec list: hostname (1 processes);
> >      [2] proxy: mlr113u (3 cores)
> >      Exec list: hostname (3 processes);
> > [mpiexec at mlr114u] Timeout set to -1 (-1 means infinite)
> > [mpiexec at mlr114u] Got a control port string of mlr114u:46425
> > Proxy launch args:
> > /mnt/appl/lft/mpich/mpich2-1.5.0p0_64bit/bin/hydra_pmi_proxy
> > --control-port mlr114u:46425 --debug --rmk user --launcher ssh --demux
> > poll --pgid 0 --retries 10 --usize -2 --proxy-id
> > Arguments being passed to proxy 0:
> > --version 1.5 --iface-ip-env-name MPICH_INTERFACE_HOSTNAME --hostname
> > mlr114u --global-core-map 0,1,4 --pmi-id-map 0,0 --global-process-count
> > 4 --auto-cleanup 1 --pmi-kvsname kvs_6389_0 --pmi-process-mapping
> > (vector,(0,1,1),(1,1,3)) --ckpoint-num -1 --global-inherited-env 75
> > 'LANG=de_DE' 'USER=hauffe' 'LOGNAME=hauffe'
> > 'HOME=/home/lft/mitarbeiter/hauffe'
> > 'PATH=/mnt/appl/lft/mpich/mpich2-1.5.0p0_64bit/bin:/w/appl/lft/jdk1.7.0
> > _07-linux-x64/bin:/mnt/appl/lft/composer_xe_2011_sp1.8.273/mpirt/bin/int
> > el64:/mnt/appl/lft/composer_xe_2011_sp1.8.273/bin/intel64:/w/appl/lft/Mo
> > dules/3.2.8/bin:/usr/NX/bin:/usr/lib64/mpi/gcc/openmpi/bin:/home/lft/mit
> > arbeiter/hauffe/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/bi
> > n/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:
> > /usr/lib/mit/sbin:/w/appl/lft/bin' 'MAIL=/var/mail/hauffe'
> > 'SHELL=/usr/bin/tcsh' 'SSH_CLIENT=141.30.52.234 53502 22'
> > 'SSH_CONNECTION=141.30.52.234 53502 141.30.156.114 22'
> > 'SSH_TTY=/dev/pts/0' 'TERM=xterm' 'XDG_SESSION_ID=144'
> > 'XDG_RUNTIME_DIR=/run/user/hauffe'
> > 'NLSPATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib/intel64/
> > locale/en_US:/usr/share/locale/%L/LC_MESSAGES/%N.cat' 'HOSTTYPE=x86_64'
> > 'VENDOR=suse' 'OSTYPE=linux' 'MACHTYPE=x86_64-suse-linux' 'SHLVL=1'
> > 'PWD=/btmpl/Software' 'GROUP=lftuser' 'HOST=mlr114u' 'CSHEDIT=emacs'
> > 'CPU=x86_64' 'HOSTNAME=mlr114u.mw.tu-dresden.de'
> > 'INPUTRC=/home/lft/mitarbeiter/hauffe/.inputrc' 'LESS=-M -I -R'
> > 'LESSOPEN=lessopen.sh %s' 'LESSCLOSE=lessclose.sh %s %s'
> > 'LESS_ADVANCED_PREPROCESSOR=no' 'LESSKEY=/etc/lesskey.bin' 'PAGER=less'
> > 'MORE=-sl' 'MINICOM=-c on'
> > 'MANPATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/man/en_US:/w/appl/lft
> > /Modules/3.2.8/share/man:/usr/lib64/mpi/gcc/openmpi/man:/usr/share/man:/
> > usr/local/man' 'XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB'
> > 'XNLSPATH=/usr/share/X11/nls' 'COLORTERM=1' 'SSH_SENDS_LOCALE=yes'
> > 'JAVA_BINDIR=/usr/lib64/jvm/jre/bin' 'JAVA_ROOT=/usr/lib64/jvm/jre'
> > 'JAVA_HOME=/usr/lib64/jvm/jre' 'JRE_HOME=/usr/lib64/jvm/jre'
> > 'CVS_RSH=ssh' 'XCURSOR_THEME=DMZ'
> > 'QT_SYSTEM_DIR=/usr/share/desktop-data'
> > 'LD_LIBRARY_PATH=/w/appl/lft/jdk1.7.0_07-linux-x64/jre/lib/amd64:/mnt/a
> > ppl/lft/composer_xe_2011_sp1.8.273/mpirt/lib/intel64:/mnt/appl/lft/compo
> > ser_xe_2011_sp1.8.273/compiler/lib/intel64:/usr/lib64/mpi/gcc/openmpi/li
> > b64:/w/appl/x86_64/paraview/3.14.1_batch/bin' 'NXDIR=/usr/NX'
> > 'FROM_HEADER=' 'NNTPSERVER=news' 'WINDOWMANAGER=/usr/bin/kde4'
> > 'ALSA_CONFIG_PATH=/etc/alsa-pulse.conf' 'SDL_AUDIODRIVER=pulse'
> > 'PYTHONSTARTUP=/etc/pythonstart'
> > 'XDG_DATA_DIRS=/usr/local/share:/usr/share:/usr/share/gnome/help'
> > 'XDG_CONFIG_DIRS=/etc/xdg' 'G_BROKEN_FILENAMES=1'
> > 'G_FILENAME_ENCODING=@locale,UTF-8,ISO-8859-1,CP1252' 'CSHRCREAD=true'
> > 'LS_COLORS=no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=
> > 40;33;01:cd=40;33;01:or=41;33;01:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=
> > 01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=
> > 00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.lzma
> > =00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;3
> > 1:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.xz=00;31:*.avi=01;35:*.bmp=01;3
> > 5:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;
> > 35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;
> > 35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35
> > :*.wmv=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32
> > :*.voc=00;32:*.wav=00;32:' 'LS_OPTIONS=-N --color=tty -T 0'
> > 'GPG_TTY=/dev/pts/0' 'MODULE_VERSION=3.2.8'
> > 'MODULE_VERSION_STACK=3.2.8' 'MODULESHOME=/w/appl/lft/Modules/3.2.8'
> > 'MODULEPATH=/w/appl/lft/Modules/versions:/w/appl/lft/Modules/$MODULE_VE
> > RSION/modulefiles/lft-apps:/w/appl/lft/Modules/$MODULE_VERSION/modulefil
> > es/compilers:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/debuggers:/
> > w/appl/lft/Modules/$MODULE_VERSION/modulefiles/libraries:/w/appl/lft/Mod
> > ules/$MODULE_VERSION/modulefiles/applications'
> > 'LOADEDMODULES=modules:lft:nedit/5.5:ifc/11.8.273:paraview/3.14.1:jdk/1
> > .7.0_u7:netbeans/7.2:paraview/3.14.1_batch:mpich2/1.5.0p0'
> > '_LMFILES_=/w/appl/lft/Modules/default/modulefiles/modules:/w/appl/lft/
> > Modules/default/modulefiles/lft:/w/appl/lft/Modules/3.2.8/modulefiles/ap
> > plications/nedit/5.5:/w/appl/lft/Modules/3.2.8/modulefiles/compilers/ifc
> > /11.8.273:/w/appl/lft/Modules/3.2.8/modulefiles/applications/paraview/3.
> > 14.1:/w/appl/lft/Modules/3.2.8/modulefiles/applications/jdk/1.7.0_u7:/w/
> > appl/lft/Modules/3.2.8/modulefiles/applications/netbeans/7.2:/w/appl/lft
> > /Modules/3.2.8/modulefiles/applications/paraview/3.14.1_batch:/w/appl/lf
> > t/Modules/3.2.8/modulefiles/libraries/mpich2/1.5.0p0'
> > 'INTEL_LICENSE_FILE=28518 at mlr25s'
> > 'LIBRARY_PATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib/int
> > el64'
> > 'PYTHONPATH=/w/appl/x86_64/paraview/3.14.1_batch/Utilities/VTKPythonWra
> > pping/site-packages:/w/appl/x86_64/paraview/3.14.1_batch/bin'
> > 'BSTINPUTS=/home/lft/mitarbeiter/hauffe/myLatex/styles/BibTeX//:'
> > 'BIBINPUTS=/home/lft/mitarbeiter/hauffe/Documents/Bibliographien/:.:'
> > 'SSH_AUTH_SOCK=/tmp/ssh-rjXtIUUZ6349/agent.6349' 'SSH_AGENT_PID=6350'
> > --global-user-env 0 --global-system-env 1
> > 'GFORTRAN_UNBUFFERED_PRECONNECTED=y' --proxy-core-count 1 --exec
> > --exec-appnum 0 --exec-proc-count 1 --exec-local-env 0 --exec-wdir
> > /btmpl/Software --exec-args 1 hostname
> > Arguments being passed to proxy 1:
> > mlr113u --global-core-map 0,3,4 --pmi-id-map 0,1 --global-process-count
> > el64'
> > 'GFORTRAN_UNBUFFERED_PRECONNECTED=y' --proxy-core-count 3 --exec
> > --exec-appnum 0 --exec-proc-count 3 --exec-local-env 0 --exec-wdir
> > [mpiexec at mlr114u] Launch arguments:
> > poll --pgid 0 --retries 10 --usize -2 --proxy-id 0 [mpiexec at mlr114u]
> > Launch arguments: /usr/bin/ssh -x mlr113u
> > "/mnt/appl/lft/mpich/mpich2-1.5.0p0_64bit/bin/hydra_pmi_proxy"
> > poll --pgid 0 --retries 10 --usize -2 --proxy-id 1 mlr114u
> > (!closed) failed [mpiexec at mlr114u] HYDT_dmxu_poll_wait_for_event
> > error waiting for completion>
> > Zitat von Dave Goodell <goodell at mcs.anl.gov>:
> >> Please also send us the output of "mpiexec -v -f machinefile -n 4
> >> hostname" (note the "-v" addition).  This will give us a better idea
> >> of why hydra is having trouble launching the hostname program.
> >> -Dave
> >> On Oct 15, 2012, at 2:50 AM CDT, Andreas Hauffe wrote:
> >>> Hi,
> >>> I need help to run a MPI-Program with MPICH2 1.5 on more than one
> >>> host. If I try the install example:
> >>> mpiexec -f machinefile -n <number> hostname
> >>> I get the following output:
> >>> host> mpiexec -f machinefile -n 4 hostname
> >>> mlr114u
> >>> assert (!closed) failed
> >>> I attachted all files but there was no
> >>> mpich2-1.5/src/pm/hydra/tools/topo/hwloc/hwloc/config.log
> >>> The command "mpiexec -info":
> >>> HYDRA build details:
> >>>   Version:                                 1.5
> >>>   Release Date:                            Mon Oct  8 14:00:48 CDT
> >>>   2012
> >>>   CC:                              gcc
> >>>   CXX:                             c++
> >>>   F77:                             ifort
> >>>   F90:                             ifort
> >>>   Configure options:
> >>>   '--disable-option-checking' '-->>>
> >>> prefix=/w/appl/lft/mpich/mpich2-1.5.0p0_64bit'
> >>> '--cache-file=/dev/null' '-- srcdir=.' 'CC=gcc' 'CFLAGS= -O2'
> >>> 'LDFLAGS= ' 'LIBS=-lrt -lpthread '  'CPPFLAGS=
> >>> -I/btmpl/Software/mpich2-1.5/src/mpl/include -
> >>> I/btmpl/Software/mpich2-1.5/src/openpa/src -
> >>> I/btmpl/Software/mpich2-1.5/src/mpi/romio/include'
> >>>   Process Manager:                         pmi
> >>>   Launchers available:                     ssh rsh fork slurm ll
> >>>   lsf sge>>>
> >>> manual persist
> >>>   Topology libraries available:            hwloc
> >>>   Resource management kernels available:   user slurm ll lsf sge
> >>>   pbs
> >>>   Checkpointing libraries available:
> >>>   Demux engines available:                 poll select
> >>> Viele Grüße
> >>> Andreas Hauffe
> >>> Leiter der Arbeitsgruppe "Auslegungsmethoden für Luftfahrzeuge"
> >>> -------------------------------- Technische Universität Dresden
> >>> Institut für Luft- und Raumfahrttechnik / Institute of Aerospace
> >>> Engineering Lehrstuhl für Luftfahrzeugtechnik / Chair of Aircraft
> >>> Engineering
> >>> D-01062 Dresden
> >>> Germany
> >>> phone : +49 (351) 463 38496
> >>> fax :  +49 (351) 463 37263
> >>> mail : andreas.hauffe at tu-dresden.de
> >>> Website : http://tu-dresden.de/mw/ilr/lft
> >>> --------------------------------<files.tar.gz>______________________
> >>> _________________________ mpich-discuss mailing list
> >>> mpich-discuss at mcs.anl.gov
> >>> To manage subscription options or unsubscribe:
> >>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> >> _______________________________________________
> >> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
Viele Grüße
Andreas Hauffe
Institut für Luft- und Raumfahrttechnik / Institute of Aerospace Engineering
Lehrstuhl für Luftfahrzeugtechnik / Chair of Aircraft Engineering
D-01062 Dresden
Germany
