[mpich-discuss] Can't run an MPI-Programm on more than one	host
    Andreas Hauffe
    Andreas.Hauffe at tu-dresden.de
    Tue Oct 16 12:42:12 CDT 2012
Here the output:
  mpiexec -v -f machinefile -n 4 hostname
host: mlr114u
host: mlr113u
mpiexec options:
   Base path: /mnt/appl/lft/mpich/mpich2-1.5.0p0_64bit/bin/
   Launcher: (null)
   Debug level: 1
   Enable X: -1
   Global environment:
     LANG=de_DE
     USER=hauffe
     LOGNAME=hauffe
     HOME=/home/lft/mitarbeiter/hauffe
PATH=/mnt/appl/lft/mpich/mpich2-1.5.0p0_64bit/bin:/w/appl/lft/jdk1.7.0_07-linux-x64/bin:/mnt/appl/lft/composer_xe_2011_sp1.8.273/mpirt/bin/intel64:/mnt/appl/lft/composer_xe_2011_sp1.8.273/bin/intel64:/w/appl/lft/Modules/3.2.8/bin:/usr/NX/bin:/usr/lib64/mpi/gcc/openmpi/bin:/home/lft/mitarbeiter/hauffe/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/w/appl/lft/bin
     MAIL=/var/mail/hauffe
     SHELL=/usr/bin/tcsh
     SSH_CLIENT=141.30.52.234 53502 22
     SSH_CONNECTION=141.30.52.234 53502 141.30.156.114 22
     SSH_TTY=/dev/pts/0
     TERM=xterm
     XDG_SESSION_ID=144
     XDG_RUNTIME_DIR=/run/user/hauffe
NLSPATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib/intel64/locale/en_US:/usr/share/locale/%L/LC_MESSAGES/%N.cat
     HOSTTYPE=x86_64
     VENDOR=suse
     OSTYPE=linux
     MACHTYPE=x86_64-suse-linux
     SHLVL=1
     PWD=/btmpl/Software
     GROUP=lftuser
     HOST=mlr114u
     CSHEDIT=emacs
     CPU=x86_64
     HOSTNAME=mlr114u.mw.tu-dresden.de
     INPUTRC=/home/lft/mitarbeiter/hauffe/.inputrc
     LESS=-M -I -R
     LESSOPEN=lessopen.sh %s
     LESSCLOSE=lessclose.sh %s %s
     LESS_ADVANCED_PREPROCESSOR=no
     LESSKEY=/etc/lesskey.bin
     PAGER=less
     MORE=-sl
     MINICOM=-c on
MANPATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/man/en_US:/w/appl/lft/Modules/3.2.8/share/man:/usr/lib64/mpi/gcc/openmpi/man:/usr/share/man:/usr/local/man
     XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB
     XNLSPATH=/usr/share/X11/nls
     COLORTERM=1
     SSH_SENDS_LOCALE=yes
     JAVA_BINDIR=/usr/lib64/jvm/jre/bin
     JAVA_ROOT=/usr/lib64/jvm/jre
     JAVA_HOME=/usr/lib64/jvm/jre
     JRE_HOME=/usr/lib64/jvm/jre
     CVS_RSH=ssh
     XCURSOR_THEME=DMZ
     QT_SYSTEM_DIR=/usr/share/desktop-data
LD_LIBRARY_PATH=/w/appl/lft/jdk1.7.0_07-linux-x64/jre/lib/amd64:/mnt/appl/lft/composer_xe_2011_sp1.8.273/mpirt/lib/intel64:/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib/intel64:/usr/lib64/mpi/gcc/openmpi/lib64:/w/appl/x86_64/paraview/3.14.1_batch/bin
     NXDIR=/usr/NX
     FROM_HEADER=
     NNTPSERVER=news
     WINDOWMANAGER=/usr/bin/kde4
     ALSA_CONFIG_PATH=/etc/alsa-pulse.conf
     SDL_AUDIODRIVER=pulse
     PYTHONSTARTUP=/etc/pythonstart
     XDG_DATA_DIRS=/usr/local/share:/usr/share:/usr/share/gnome/help
     XDG_CONFIG_DIRS=/etc/xdg
     G_BROKEN_FILENAMES=1
     G_FILENAME_ENCODING=@locale,UTF-8,ISO-8859-1,CP1252
     CSHRCREAD=true
LS_COLORS=no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=41;33;01:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.lzma=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.xz=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.wmv=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:
     LS_OPTIONS=-N --color=tty -T 0
     GPG_TTY=/dev/pts/0
     MODULE_VERSION=3.2.8
     MODULE_VERSION_STACK=3.2.8
     MODULESHOME=/w/appl/lft/Modules/3.2.8
MODULEPATH=/w/appl/lft/Modules/versions:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/lft-apps:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/compilers:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/debuggers:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/libraries:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/applications
LOADEDMODULES=modules:lft:nedit/5.5:ifc/11.8.273:paraview/3.14.1:jdk/1.7.0_u7:netbeans/7.2:paraview/3.14.1_batch:mpich2/1.5.0p0
_LMFILES_=/w/appl/lft/Modules/default/modulefiles/modules:/w/appl/lft/Modules/default/modulefiles/lft:/w/appl/lft/Modules/3.2.8/modulefiles/applications/nedit/5.5:/w/appl/lft/Modules/3.2.8/modulefiles/compilers/ifc/11.8.273:/w/appl/lft/Modules/3.2.8/modulefiles/applications/paraview/3.14.1:/w/appl/lft/Modules/3.2.8/modulefiles/applications/jdk/1.7.0_u7:/w/appl/lft/Modules/3.2.8/modulefiles/applications/netbeans/7.2:/w/appl/lft/Modules/3.2.8/modulefiles/applications/paraview/3.14.1_batch:/w/appl/lft/Modules/3.2.8/modulefiles/libraries/mpich2/1.5.0p0
     INTEL_LICENSE_FILE=28518 at mlr25s
     LIBRARY_PATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib/intel64
PYTHONPATH=/w/appl/x86_64/paraview/3.14.1_batch/Utilities/VTKPythonWrapping/site-packages:/w/appl/x86_64/paraview/3.14.1_batch/bin
     BSTINPUTS=/home/lft/mitarbeiter/hauffe/myLatex/styles/BibTeX//:
     BIBINPUTS=/home/lft/mitarbeiter/hauffe/Documents/Bibliographien/:.:
     SSH_AUTH_SOCK=/tmp/ssh-rjXtIUUZ6349/agent.6349
     SSH_AGENT_PID=6350
   Hydra internal environment:
     GFORTRAN_UNBUFFERED_PRECONNECTED=y
     Proxy information:
       [1] proxy: mlr114u (1 cores)
       Exec list: hostname (1 processes);
       [2] proxy: mlr113u (3 cores)
       Exec list: hostname (3 processes);
[mpiexec at mlr114u] Timeout set to -1 (-1 means infinite)
[mpiexec at mlr114u] Got a control port string of mlr114u:46425
Proxy launch args:
/mnt/appl/lft/mpich/mpich2-1.5.0p0_64bit/bin/hydra_pmi_proxy
--control-port mlr114u:46425 --debug --rmk user --launcher ssh --demux
poll --pgid 0 --retries 10 --usize -2 --proxy-id
Arguments being passed to proxy 0:
--version 1.5 --iface-ip-env-name MPICH_INTERFACE_HOSTNAME --hostname
mlr114u --global-core-map 0,1,4 --pmi-id-map 0,0
--global-process-count 4 --auto-cleanup 1 --pmi-kvsname kvs_6389_0
--pmi-process-mapping (vector,(0,1,1),(1,1,3)) --ckpoint-num -1
--global-inherited-env 75 'LANG=de_DE' 'USER=hauffe' 'LOGNAME=hauffe'
'HOME=/home/lft/mitarbeiter/hauffe'
'PATH=/mnt/appl/lft/mpich/mpich2-1.5.0p0_64bit/bin:/w/appl/lft/jdk1.7.0_07-linux-x64/bin:/mnt/appl/lft/composer_xe_2011_sp1.8.273/mpirt/bin/intel64:/mnt/appl/lft/composer_xe_2011_sp1.8.273/bin/intel64:/w/appl/lft/Modules/3.2.8/bin:/usr/NX/bin:/usr/lib64/mpi/gcc/openmpi/bin:/home/lft/mitarbeiter/hauffe/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/w/appl/lft/bin' 'MAIL=/var/mail/hauffe' 'SHELL=/usr/bin/tcsh' 'SSH_CLIENT=141.30.52.234 53502 22' 'SSH_CONNECTION=141.30.52.234 53502 141.30.156.114 22' 'SSH_TTY=/dev/pts/0' 'TERM=xterm' 'XDG_SESSION_ID=144' 'XDG_RUNTIME_DIR=/run/user/hauffe' 'NLSPATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib/intel64/locale/en_US:/usr/share/locale/%L/LC_MESSAGES/%N.cat' 'HOSTTYPE=x86_64' 'VENDOR=suse' 'OSTYPE=linux' 'MACHTYPE=x86_64-suse-linux' 'SHLVL=1' 'PWD=/btmpl/Software' 'GROUP=lftuser' 'HOST=mlr114u' 'CSHEDIT=emacs' 'CPU=x86_64' 'HOSTNAME=mlr114u.mw.tu-dresden.de' 'INPUTRC=/home/lft/mitarbeiter/hauffe/.inputrc' 'LESS=-M -I -R' 'LESSOPEN=lessopen.sh %s' 'LESSCLOSE=lessclose.sh %s %s' 'LESS_ADVANCED_PREPROCESSOR=no' 'LESSKEY=/etc/lesskey.bin' 'PAGER=less' 'MORE=-sl' 'MINICOM=-c on' 'MANPATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/man/en_US:/w/appl/lft/Modules/3.2.8/share/man:/usr/lib64/mpi/gcc/openmpi/man:/usr/share/man:/usr/local/man' 'XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB' 'XNLSPATH=/usr/share/X11/nls' 'COLORTERM=1' 'SSH_SENDS_LOCALE=yes' 'JAVA_BINDIR=/usr/lib64/jvm/jre/bin' 'JAVA_ROOT=/usr/lib64/jvm/jre' 'JAVA_HOME=/usr/lib64/jvm/jre' 'JRE_HOME=/usr/lib64/jvm/jre' 'CVS_RSH=ssh' 'XCURSOR_THEME=DMZ' 'QT_SYSTEM_DIR=/usr/share/desktop-data' 'LD_LIBRARY_PATH=/w/appl/lft/jdk1.7.0_07-linux-x64/jre/lib/amd64:/mnt/appl/lft/composer_xe_2011_sp1.8.273/mpirt/lib/intel64:/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib/intel64:/usr/lib64/mpi/gcc/openmpi/lib64:/w/appl/x86_64/paraview/3.14.1_batch/bin' 'NXDIR=/usr/NX' 'FROM_HEADER=' 'NNTPSERVER=news' 'WINDOWMANAGER=/usr/bin/kde4' 'ALSA_CONFIG_PATH=/etc/alsa-pulse.conf' 'SDL_AUDIODRIVER=pulse' 'PYTHONSTARTUP=/etc/pythonstart' 'XDG_DATA_DIRS=/usr/local/share:/usr/share:/usr/share/gnome/help' 'XDG_CONFIG_DIRS=/etc/xdg' 'G_BROKEN_FILENAMES=1' 'G_FILENAME_ENCODING=@locale,UTF-8,ISO-8859-1,CP1252' 'CSHRCREAD=true' 'LS_COLORS=no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=41;33;01:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.lzma=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.xz=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.wmv=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:' 'LS_OPTIONS=-N --color=tty -T 0' 'GPG_TTY=/dev/pts/0' 'MODULE_VERSION=3.2.8' 'MODULE_VERSION_STACK=3.2.8' 'MODULESHOME=/w/appl/lft/Modules/3.2.8' 'MODULEPATH=/w/appl/lft/Modules/versions:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/lft-apps:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/compilers:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/debuggers:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/libraries:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/applications' 'LOADEDMODULES=modules:lft:nedit/5.5:ifc/11.8.273:paraview/3.14.1:jdk/1.7.0_u7:netbeans/7.2:paraview/3.14.1_batch:mpich2/1.5.0p0' '_LMFILES_=/w/appl/lft/Modules/default/modulefiles/modules:/w/appl/lft/Modules/default/modulefiles/lft:/w/appl/lft/Modules/3.2.8/modulefiles/applications/nedit/5.5:/w/appl/lft/Modules/3.2.8/modulefiles/compilers/ifc/11.8.273:/w/appl/lft/Modules/3.2.8/modulefiles/applications/paraview/3.14.1:/w/appl/lft/Modules/3.2.8/modulefiles/applications/jdk/1.7.0_u7:/w/appl/lft/Modules/3.2.8/modulefiles/applications/netbeans/7.2:/w/appl/lft/Modules/3.2.8/modulefiles/applications/paraview/3.14.1_batch:/w/appl/lft/Modules/3.2.8/modulefiles/libraries/mpich2/1.5.0p0' 'INTEL_LICENSE_FILE=28518 at mlr25s' 'LIBRARY_PATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib/intel64' 'PYTHONPATH=/w/appl/x86_64/paraview/3.14.1_batch/Utilities/VTKPythonWrapping/site-packages:/w/appl/x86_64/paraview/3.14.1_batch/bin' 'BSTINPUTS=/home/lft/mitarbeiter/hauffe/myLatex/styles/BibTeX//:' 'BIBINPUTS=/home/lft/mitarbeiter/hauffe/Documents/Bibliographien/:.:' 'SSH_AUTH_SOCK=/tmp/ssh-rjXtIUUZ6349/agent.6349' 'SSH_AGENT_PID=6350' --global-user-env 0 --global-system-env 1 'GFORTRAN_UNBUFFERED_PRECONNECTED=y' --proxy-core-count 1 --exec --exec-appnum 0 --exec-proc-count 1 --exec-local-env 0 --exec-wdir /btmpl/Software --exec-args 1
hostname
Arguments being passed to proxy 1:
mlr113u --global-core-map 0,3,4 --pmi-id-map 0,1
'PATH=/mnt/appl/lft/mpich/mpich2-1.5.0p0_64bit/bin:/w/appl/lft/jdk1.7.0_07-linux-x64/bin:/mnt/appl/lft/composer_xe_2011_sp1.8.273/mpirt/bin/intel64:/mnt/appl/lft/composer_xe_2011_sp1.8.273/bin/intel64:/w/appl/lft/Modules/3.2.8/bin:/usr/NX/bin:/usr/lib64/mpi/gcc/openmpi/bin:/home/lft/mitarbeiter/hauffe/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/w/appl/lft/bin' 'MAIL=/var/mail/hauffe' 'SHELL=/usr/bin/tcsh' 'SSH_CLIENT=141.30.52.234 53502 22' 'SSH_CONNECTION=141.30.52.234 53502 141.30.156.114 22' 'SSH_TTY=/dev/pts/0' 'TERM=xterm' 'XDG_SESSION_ID=144' 'XDG_RUNTIME_DIR=/run/user/hauffe' 'NLSPATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib/intel64/locale/en_US:/usr/share/locale/%L/LC_MESSAGES/%N.cat' 'HOSTTYPE=x86_64' 'VENDOR=suse' 'OSTYPE=linux' 'MACHTYPE=x86_64-suse-linux' 'SHLVL=1' 'PWD=/btmpl/Software' 'GROUP=lftuser' 'HOST=mlr114u' 'CSHEDIT=emacs' 'CPU=x86_64' 'HOSTNAME=mlr114u.mw.tu-dresden.de' 'INPUTRC=/home/lft/mitarbeiter/hauffe/.inputrc' 'LESS=-M -I -R' 'LESSOPEN=lessopen.sh %s' 'LESSCLOSE=lessclose.sh %s %s' 'LESS_ADVANCED_PREPROCESSOR=no' 'LESSKEY=/etc/lesskey.bin' 'PAGER=less' 'MORE=-sl' 'MINICOM=-c on' 'MANPATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/man/en_US:/w/appl/lft/Modules/3.2.8/share/man:/usr/lib64/mpi/gcc/openmpi/man:/usr/share/man:/usr/local/man' 'XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB' 'XNLSPATH=/usr/share/X11/nls' 'COLORTERM=1' 'SSH_SENDS_LOCALE=yes' 'JAVA_BINDIR=/usr/lib64/jvm/jre/bin' 'JAVA_ROOT=/usr/lib64/jvm/jre' 'JAVA_HOME=/usr/lib64/jvm/jre' 'JRE_HOME=/usr/lib64/jvm/jre' 'CVS_RSH=ssh' 'XCURSOR_THEME=DMZ' 'QT_SYSTEM_DIR=/usr/share/desktop-data' 'LD_LIBRARY_PATH=/w/appl/lft/jdk1.7.0_07-linux-x64/jre/lib/amd64:/mnt/appl/lft/composer_xe_2011_sp1.8.273/mpirt/lib/intel64:/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib/intel64:/usr/lib64/mpi/gcc/openmpi/lib64:/w/appl/x86_64/paraview/3.14.1_batch/bin' 'NXDIR=/usr/NX' 'FROM_HEADER=' 'NNTPSERVER=news' 'WINDOWMANAGER=/usr/bin/kde4' 'ALSA_CONFIG_PATH=/etc/alsa-pulse.conf' 'SDL_AUDIODRIVER=pulse' 'PYTHONSTARTUP=/etc/pythonstart' 'XDG_DATA_DIRS=/usr/local/share:/usr/share:/usr/share/gnome/help' 'XDG_CONFIG_DIRS=/etc/xdg' 'G_BROKEN_FILENAMES=1' 'G_FILENAME_ENCODING=@locale,UTF-8,ISO-8859-1,CP1252' 'CSHRCREAD=true' 'LS_COLORS=no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=41;33;01:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.lzma=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.xz=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.wmv=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:' 'LS_OPTIONS=-N --color=tty -T 0' 'GPG_TTY=/dev/pts/0' 'MODULE_VERSION=3.2.8' 'MODULE_VERSION_STACK=3.2.8' 'MODULESHOME=/w/appl/lft/Modules/3.2.8' 'MODULEPATH=/w/appl/lft/Modules/versions:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/lft-apps:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/compilers:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/debuggers:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/libraries:/w/appl/lft/Modules/$MODULE_VERSION/modulefiles/applications' 'LOADEDMODULES=modules:lft:nedit/5.5:ifc/11.8.273:paraview/3.14.1:jdk/1.7.0_u7:netbeans/7.2:paraview/3.14.1_batch:mpich2/1.5.0p0' '_LMFILES_=/w/appl/lft/Modules/default/modulefiles/modules:/w/appl/lft/Modules/default/modulefiles/lft:/w/appl/lft/Modules/3.2.8/modulefiles/applications/nedit/5.5:/w/appl/lft/Modules/3.2.8/modulefiles/compilers/ifc/11.8.273:/w/appl/lft/Modules/3.2.8/modulefiles/applications/paraview/3.14.1:/w/appl/lft/Modules/3.2.8/modulefiles/applications/jdk/1.7.0_u7:/w/appl/lft/Modules/3.2.8/modulefiles/applications/netbeans/7.2:/w/appl/lft/Modules/3.2.8/modulefiles/applications/paraview/3.14.1_batch:/w/appl/lft/Modules/3.2.8/modulefiles/libraries/mpich2/1.5.0p0' 'INTEL_LICENSE_FILE=28518 at mlr25s' 'LIBRARY_PATH=/mnt/appl/lft/composer_xe_2011_sp1.8.273/compiler/lib/intel64' 'PYTHONPATH=/w/appl/x86_64/paraview/3.14.1_batch/Utilities/VTKPythonWrapping/site-packages:/w/appl/x86_64/paraview/3.14.1_batch/bin' 'BSTINPUTS=/home/lft/mitarbeiter/hauffe/myLatex/styles/BibTeX//:' 'BIBINPUTS=/home/lft/mitarbeiter/hauffe/Documents/Bibliographien/:.:' 'SSH_AUTH_SOCK=/tmp/ssh-rjXtIUUZ6349/agent.6349' 'SSH_AGENT_PID=6350' --global-user-env 0 --global-system-env 1 'GFORTRAN_UNBUFFERED_PRECONNECTED=y' --proxy-core-count 3 --exec --exec-appnum 0 --exec-proc-count 3 --exec-local-env 0 --exec-wdir /btmpl/Software --exec-args 1
hostname
[mpiexec at mlr114u] Launch arguments:
poll --pgid 0 --retries 10 --usize -2 --proxy-id 0
[mpiexec at mlr114u] Launch arguments: /usr/bin/ssh -x mlr113u
"/mnt/appl/lft/mpich/mpich2-1.5.0p0_64bit/bin/hydra_pmi_proxy"
poll --pgid 0 --retries 10 --usize -2 --proxy-id 1
mlr114u
[mpiexec at mlr114u] control_cb (./pm/pmiserv/pmiserv_cb.c:201): assert
(!closed) failed
[mpiexec at mlr114u] HYDT_dmxu_poll_wait_for_event
(./tools/demux/demux_poll.c:77): callback returned error status
[mpiexec at mlr114u] HYD_pmci_wait_for_completion
(./pm/pmiserv/pmiserv_pmci.c:196): error waiting for event
[mpiexec at mlr114u] main (./ui/mpich/mpiexec.c:325): process manager
error waiting for completion
Zitat von Dave Goodell <goodell at mcs.anl.gov>:
> Please also send us the output of "mpiexec -v -f machinefile -n 4
> hostname" (note the "-v" addition).  This will give us a better idea
>  of why hydra is having trouble launching the hostname program.
> -Dave
> On Oct 15, 2012, at 2:50 AM CDT, Andreas Hauffe wrote:
>> Hi,
>> I need help to run a MPI-Program with MPICH2 1.5 on more than one host. If I
>> try the install example:
>> mpiexec -f machinefile -n <number> hostname
>> I get the following output:
>> host> mpiexec -f machinefile -n 4 hostname
>> mlr114u
>> assert (!closed)
>> failed
>> [mpiexec at mlr114u] main (./ui/mpich/mpiexec.c:325): process manager error
>> I attachted all files but there was no
>> mpich2-1.5/src/pm/hydra/tools/topo/hwloc/hwloc/config.log
>> The command "mpiexec -info":
>> HYDRA build details:
>>    Version:                                 1.5
>>    Release Date:                            Mon Oct  8 14:00:48 CDT 2012
>>    CC:                              gcc
>>    CXX:                             c++
>>    F77:                             ifort
>>    F90:                             ifort
>>    Configure options:                       '--disable-option-checking' '--
>> prefix=/w/appl/lft/mpich/mpich2-1.5.0p0_64bit' '--cache-file=/dev/null' '--
>> srcdir=.' 'CC=gcc' 'CFLAGS= -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread '
>>  'CPPFLAGS=
>> -I/btmpl/Software/mpich2-1.5/src/mpl/include -
>> I/btmpl/Software/mpich2-1.5/src/openpa/src -
>> I/btmpl/Software/mpich2-1.5/src/mpi/romio/include'
>>    Process Manager:                         pmi
>>    Launchers available:                     ssh rsh fork slurm ll lsf sge
>> manual persist
>>    Topology libraries available:            hwloc
>>    Resource management kernels available:   user slurm ll lsf sge pbs
>>    Checkpointing libraries available:
>>    Demux engines available:                 poll select
>> Viele Grüße
>> Andreas Hauffe
>> Leiter der Arbeitsgruppe "Auslegungsmethoden für Luftfahrzeuge"
>> Technische Universität Dresden
>> Institut für Luft- und Raumfahrttechnik / Institute of Aerospace Engineering
>> Lehrstuhl für Luftfahrzeugtechnik / Chair of Aircraft Engineering
>> D-01062 Dresden
>> Germany
>> phone : +49 (351) 463 38496
>> fax :  +49 (351) 463 37263
>> mail : andreas.hauffe at tu-dresden.de
>> Website : http://tu-dresden.de/mw/ilr/lft
>> ----------------------------------------------------------------------------------------------------<files.tar.gz>_______________________________________________
>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
