[mpich-discuss] Mpich2 - in Red Hat 7.3
    Gus Correa
    gus at ldeo.columbia.edu
    Wed Oct  3 15:56:33 CDT 2012
On 10/03/2012 01:23 PM, Sandra Guija wrote:
> Thanks Gus and Pavan,
> I am able to use Fedora release 5. Linux 2.6.15 with gcc 4.1.0 (RedHat
> 4.1.0-3)
> if this setup will work for 1.5rc2 or any other one?
> Thanks again,
> Sandra Guija
MPICH2 may install on Fedora 5, but as Pavan said,
that is still old.
I guess it is probably already discontinued by Fedora
(i.e.you can't get RPMs to install stuff, in case you hit any problem
with dependencies when istalling mpich2).
Consider installing the system again,
use a current distribution version:
CentOS, Scientific Linux, Ubuntu, Fedora.
Gus Correa
>  > Date: Wed, 3 Oct 2012 11:16:26 -0400
>  > From: gus at ldeo.columbia.edu
>  > To: mpich-discuss at mcs.anl.gov
>  > Subject: Re: [mpich-discuss] Mpich2 - in Red Hat 7.3
>  > On 10/03/2012 10:48 AM, Pavan Balaji wrote:
>  > > On 10/03/2012 09:47 AM, Sandra Guija wrote:
>  > >> I will work on get a newer compiler.
>  > >> And for installation guide, should I use same as 1.4.p1?
>  > > Are you upgrading to 1.5rc2? It comes with its own installation guide,
>  > > though 1.4.1p1's should also work.
>  > Hi Sandra
>  > It may be more complicated to install a new version of gcc
>  > in your Red Hat 7.3 machine, than to upgrade Linux to something
>  > more up to date.
>  > You may open an endless can of worms of package
>  > and library dependencies will be hard to resolve.
>  > Red hat 7.3 is about 10 years old, a lot has
>  > changed since then.
>  > CentOS and Scientific Linux are free,
>  > and very similar to Red Hat enterprise.
>  > The current version is 6.3:
>  > https://www.centos.org/
>  > https://www.scientificlinux.org/
>  > Another option is to install Ubuntu:
>  > http://www.ubuntu.com/
>  > The current stable version is 12.04.1, I think.
>  > An (admittedly very sketchy) outline of the procedure is:
>  > - backup your /home and any other data that you want to keep,
>  > maybe to a large capacity pen drive, or copy to a DVD perhaps,
>  > - download the ISO images (sites above, pick one),
>  > - burn the ISO images to CDs or DVD (probably several CDs or one DVD),
>  > - put the first CD or DVD on the CD/DVD tray,
>  > - reboot the computer,
>  > - follow the installation instructions,
>  > Once the system is installed:
>  > - add new users (yourself, maybe more), then
>  > - restore the files you need from your backed-up /home,
>  > - add any packages you may need (e.g. gfortran) with yum (CentOS, SL)
>  > or apt-get (Ubuntu).
>  > - install mpich2
>  > I hope this helps,
>  > Gus Correa
>  > _______________________________________________
>  > mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>  > To manage subscription options or unsubscribe:
>  > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
