[mpich-discuss] About using g95 to compile MPICH2 problem
謝奇哲 991546107 at stu.nkmu.edu.tw
Tue Oct 2 04:11:07 CDT 2012
Dear Jayesh:
  I had trying to re-install MPICH2.
  And using the command
  ./configure F77=g95 FC=g95 FFLAGS=-fno-second-underscore
--prefix=/MPICH2/ 2>&1 | tee c.txt
  When I finished installing, I didn't find the mpif90 in bin file.
  What's problem with me?Can anyon give me some advices?
  Best regards,
  Chi-Che Hsieh
2012/10/2 Jayesh Krishna <jayesh at mcs.anl.gov>
> Dear Jayesh:
> In my program compiler opions
> FFLAGS := -fno-second-underscore
> But, when I configured MPICH2 just using F77=g95 FC=g95 --prefix=/MPICH2/
> So, Should I set FFLAGS=-fno-second-underscore when I configure MPICH2?
> Best regards,
> Chi-Che Hsieh
> 2012/10/1 Jayesh Krishna < jayesh at mcs.anl.gov >
> Hi,
> You seem to be using specific compiler options (like
> "-fno-second-underscore") when you are compiling your code. Did you specify
> the same options when building MPICH2 ?
> Regards,
> Jayesh
> From: "謝奇哲" < 991546107 at stu.nkmu.edu.tw >
> To: "Jayesh Krishna" < jayesh at mcs.anl.gov >, mpich-discuss at mcs.anl.gov
> Sent: Monday, October 1, 2012 8:30:54 AM
> Subject: About using g95 to compile MPICH2 problem
> Dear MPICH2 users,
> I'm sorry if I'm asking too many times.
> My case will need using mpi_init, so I install the MPICH2-1.4.1p1
> I'm using WindosXP, Cygwin, and g95 to compile.
> And I Used the command
> User at 980622-05 /cygdrive/c/cygwin/mpich2-1.4.1p1
> $./configure F77=g95 FC=g95 --prefix=/MPICH2/ 2>&1 | tee c.txt
> $make 2>&1 | tee m.txt
> $make install 2>&1 | tee mi.txt
> I added right path in cygwin/etc/prfile
> MPI_BINDIR=/MPICH2/bin
> export MPI_BINDIR
> MPI_INCDIR=/MPICH2/include
> export MPI_INCDIR
> MPI_LIBDIR=/MPICH2/lib
> export MPI_LIBDIR
> Then, I try to run the examples hellw and cpi
> User at 980622-05 /cygdrive/c/cygwin/mpich2-1.4.1p1/examples
> $ make hellow
> CC hellow.c
> ../bin/mpicc -o hellow hellow.o
> $ mpirun -n 5 ./hellow
> Hello world from process 0 of 5
> Hello world from process 1 of 5
> Hello world from process 2 of 5
> Hello world from process 3 of 5
> Hello world from process 4 of 5
> $ mpirun -n 5 ./cpi
> Process 0 of 5 is on 980622-05
> Process 1 of 5 is on 980622-05
> Process 2 of 5 is on 980622-05
> Process 3 of 5 is on 980622-05
> Process 4 of 5 is on 980622-05
> pi is approximately 3.1415926544231230, Error is 0.0000000008333298
> wall clock time = 0.000000
> I thought that I finish installing.
> And then, I compiled my program, set build.bash
> USE_MPI = on
> USE_MPIF90 = on
> I got some undefined reference about MPI (detail saved in
> make_sh_mpif90_on_0928.txt)
> cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build;
> /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math master.f90
> mpif90 -fno-second-underscore -O3 -ffast-math
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.o
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_coupler.o
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/propagator.o -o
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/oceanM.exe
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libNLM.a
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libANA.a
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libICE.a
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libMODS.a -L/usr/local/lib
> -lnetcdf
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o:master.f90:(.text+0xe):
> undefined reference to `mpi_init_'
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o:master.f90:(.text+0x34):
> undefined reference to `mpi_comm_rank_'
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o:master.f90:(.text+0x5d):
> undefined reference to `mpi_finalize_'
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.o:ocean_control.f90:(.text+0x3e6):
> /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.o:ocean_control.f90:(.text+0x3fd):
> undefined reference to `mpi_comm_size_'
> Can anyone give me some advices to solved this problem?
> Best regards,
> Chi-Che Hsieh
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20121002/6bab2fb6/attachment-0001.html>
