[mpich-discuss] About using g95 to compile MPICH2 problem
    謝奇哲
    991546107 at stu.nkmu.edu.tw
    Mon Oct  1 08:30:54 CDT 2012
Dear MPICH2 users,
I'm sorry if I'm asking too many times.
My case will need using mpi_init, so I install the MPICH2-1.4.1p1
I'm using WindosXP, Cygwin, and g95 to compile.
And I Used the command
User at 980622-05 /cygdrive/c/cygwin/mpich2-1.4.1p1
$./configure F77=g95 FC=g95 --prefix=/MPICH2/ 2>&1 | tee c.txt
$make 2>&1 | tee m.txt
$make install 2>&1 | tee mi.txt
I added right path in cygwin/etc/prfile
MPI_BINDIR=/MPICH2/bin
export MPI_BINDIR
MPI_INCDIR=/MPICH2/include
export MPI_INCDIR
MPI_LIBDIR=/MPICH2/lib
export MPI_LIBDIR
Then, I try to run the examples hellw and cpi
User at 980622-05 /cygdrive/c/cygwin/mpich2-1.4.1p1/examples
$ make hellow
  CC              hellow.c
../bin/mpicc   -o hellow hellow.o
$ mpirun -n 5 ./hellow
Hello world from process 0 of 5
Hello world from process 1 of 5
Hello world from process 2 of 5
Hello world from process 3 of 5
Hello world from process 4 of 5
$ mpirun -n 5 ./cpi
Process 0 of 5 is on 980622-05
Process 1 of 5 is on 980622-05
Process 2 of 5 is on 980622-05
Process 3 of 5 is on 980622-05
Process 4 of 5 is on 980622-05
pi is approximately 3.1415926544231230, Error is 0.0000000008333298
wall clock time = 0.000000
I thought that I finish installing.
And then, I compiled my program, set build.bash
USE_MPI = on
USE_MPIF90 = on
I got some undefined reference about MPI (detail saved in
make_sh_mpif90_on_0928.txt)
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build;
/MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math master.f90
mpif90 -fno-second-underscore -O3 -ffast-math
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.o
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_coupler.o
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/propagator.o -o
/cygdrive/d/ROMS_for_Square_Harbor/trunk/oceanM.exe
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libNLM.a
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libANA.a
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libICE.a
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libMODS.a -L/usr/local/lib
-lnetcdf
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o:master.f90:(.text+0xe):
undefined reference to `mpi_init_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o:master.f90:(.text+0x34):
undefined reference to `mpi_comm_rank_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o:master.f90:(.text+0x5d):
undefined reference to `mpi_finalize_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.o:ocean_control.f90:(.text+0x3e6):
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.o:ocean_control.f90:(.text+0x3fd):
undefined reference to `mpi_comm_size_'
Can anyone give me some advices to solved this problem?
Best regards,
Chi-Che Hsieh
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20121001/d9fa3cb6/attachment-0001.html>
rm -f -r core *.ipo /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build Compilers/make_macros.mk
makefile:233: INCLUDING FILE Compilers/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
make: svnversion: Command not found
cp -f /usr/local/include/netcdf.mod /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build
cp -f /usr/local/include/typesizes.mod /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build
./ROMS/Bin/sfmakedepend --cpp --fext=f90 --file=- --objdir=/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build -DROMS_HEADER="inlet_sh.h" -I ROMS/Include -I ROMS/Nonlinear -I ROMS/SeaIce -I ROMS/Utility -I ROMS/Drivers -I /cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -I ROMS/Functionals -I /cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -I Master -I Compilers --silent --moddir /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build  ROMS/Nonlinear/bbl.F ROMS/Nonlinear/bc_2d.F ROMS/Nonlinear/bc_3d.F ROMS/Nonlinear/biology.F ROMS/Nonlinear/bulk_flux.F ROMS/Nonlinear/bvf_mix.F ROMS/Nonlinear/conv_2d.F ROMS/Nonlinear/conv_3d.F ROMS/Nonlinear/diag.F ROMS/Nonlinear/exchange_2d.F ROMS/Nonlinear/exchange_3d.F ROMS/Nonlinear/forcing.F ROMS/Nonlinear/get_data.F ROMS/Nonlinear/get_idata.F ROMS/Nonlinear/gls_corstep.F ROMS/Nonlinear/gls_prestep.F ROMS/Nonlinear/ini_fields.F ROMS/Nonlinear/initial.F ROMS/Nonlinear/interp_floats.F ROMS/Nonlinear/lmd_bkpp.F ROMS/Nonlinear/lmd_skpp.F ROMS/Nonlinear/lmd_swfrac.F ROMS/Nonlinear/lmd_vmix.F ROMS/Nonlinear/main2d.F ROMS/Nonlinear/main3d.F ROMS/Nonlinear/mpdata_adiff.F ROMS/Nonlinear/my25_corstep.F ROMS/Nonlinear/my25_prestep.F ROMS/Nonlinear/obc_volcons.F ROMS/Nonlinear/omega.F ROMS/Nonlinear/output.F ROMS/Nonlinear/pre_step3d.F ROMS/Nonlinear/prsgrd.F ROMS/Nonlinear/radiation_stress.F ROMS/Nonlinear/rho_eos.F ROMS/Nonlinear/rhs3d.F ROMS/Nonlinear/sediment.F ROMS/Nonlinear/set_avg.F ROMS/Nonlinear/set_data.F ROMS/Nonlinear/set_depth.F ROMS/Nonlinear/set_massflux.F ROMS/Nonlinear/set_tides.F ROMS/Nonlinear/set_vbc.F ROMS/Nonlinear/set_zeta.F ROMS/Nonlinear/step2d.F ROMS/Nonlinear/step3d_t.F ROMS/Nonlinear/step3d_uv.F ROMS/Nonlinear/step_floats.F ROMS/Nonlinear/t3dbc_im.F ROMS/Nonlinear/t3dmix.F ROMS/Nonlinear/tkebc_im.F ROMS/Nonlinear/u2dbc_im.F ROMS/Nonlinear/u3dbc_im.F ROMS/Nonlinear/uv3dmix.F ROMS/Nonlinear/v2dbc_im.F ROMS/Nonlinear/v3dbc_im.F ROMS/Nonlinear/wvelocity.F ROMS/Nonlinear/zetabc.F ROMS/Functionals/analytical.F ROMS/SeaIce/seaice.F ROMS/Utility/back_cost.F ROMS/Utility/back_cov.F ROMS/Utility/back_step.F ROMS/Utility/cgradient.F ROMS/Utility/checkdefs.F ROMS/Utility/checkvars.F ROMS/Utility/close_io.F ROMS/Utility/congrad.F ROMS/Utility/cost_grad.F ROMS/Utility/cost_norm.F ROMS/Utility/def_avg.F ROMS/Utility/def_diags.F ROMS/Utility/def_floats.F ROMS/Utility/def_gst.F ROMS/Utility/def_hessian.F ROMS/Utility/def_his.F ROMS/Utility/def_impulse.F ROMS/Utility/def_info.F ROMS/Utility/def_ini.F ROMS/Utility/def_mod.F ROMS/Utility/def_norm.F ROMS/Utility/def_rst.F ROMS/Utility/def_station.F ROMS/Utility/def_tides.F ROMS/Utility/def_var.F ROMS/Utility/descent.F ROMS/Utility/distribute.F ROMS/Utility/dotproduct.F ROMS/Utility/downhill.F ROMS/Utility/extract_obs.F ROMS/Utility/extract_sta.F ROMS/Utility/frc_adjust.F ROMS/Utility/gasdev.F ROMS/Utility/get_2dfld.F ROMS/Utility/get_2dfldr.F ROMS/Utility/get_3dfld.F ROMS/Utility/get_3dfldr.F ROMS/Utility/get_bounds.F ROMS/Utility/get_cycle.F ROMS/Utility/get_date.F ROMS/Utility/get_grid.F ROMS/Utility/get_gst.F ROMS/Utility/get_ngfld.F ROMS/Utility/get_ngfldr.F ROMS/Utility/get_state.F ROMS/Utility/get_varcoords.F ROMS/Utility/grid_coords.F ROMS/Utility/impulse.F ROMS/Utility/ini_adjust.F ROMS/Utility/inp_par.F ROMS/Utility/interpolate.F ROMS/Utility/lubksb.F ROMS/Utility/ludcmp.F ROMS/Utility/metrics.F ROMS/Utility/mp_exchange.F ROMS/Utility/mp_routines.F ROMS/Utility/nf_fread2d.F ROMS/Utility/nf_fread3d.F ROMS/Utility/nf_fread4d.F ROMS/Utility/nf_fwrite2d.F ROMS/Utility/nf_fwrite3d.F ROMS/Utility/nf_fwrite4d.F ROMS/Utility/normalization.F ROMS/Utility/nrutil.F ROMS/Utility/obs_cost.F ROMS/Utility/obs_depth.F ROMS/Utility/obs_initial.F ROMS/Utility/obs_read.F ROMS/Utility/obs_scale.F ROMS/Utility/obs_write.F ROMS/Utility/oi_update.F ROMS/Utility/opencdf.F ROMS/Utility/packing.F ROMS/Utility/ran1.F ROMS/Utility/ran_state.F ROMS/Utility/regrid.F ROMS/Utility/set_2dfld.F ROMS/Utility/set_2dfldr.F ROMS/Utility/set_3dfld.F ROMS/Utility/set_3dfldr.F ROMS/Utility/set_diags.F ROMS/Utility/set_ngfld.F ROMS/Utility/set_ngfldr.F ROMS/Utility/set_scoord.F ROMS/Utility/set_weights.F ROMS/Utility/shapiro.F ROMS/Utility/state_addition.F ROMS/Utility/state_copy.F ROMS/Utility/state_dotprod.F ROMS/Utility/state_initialize.F ROMS/Utility/state_scale.F ROMS/Utility/stats_modobs.F ROMS/Utility/stiffness.F ROMS/Utility/timers.F ROMS/Utility/utility.F ROMS/Utility/white_noise.F ROMS/Utility/wpoints.F ROMS/Utility/wrt_avg.F ROMS/Utility/wrt_diags.F ROMS/Utility/wrt_floats.F ROMS/Utility/wrt_gst.F ROMS/Utility/wrt_hessian.F ROMS/Utility/wrt_his.F ROMS/Utility/wrt_info.F ROMS/Utility/wrt_ini.F ROMS/Utility/wrt_rst.F ROMS/Utility/wrt_station.F ROMS/Utility/wrt_tides.F ROMS/Modules/mod_arrays.F ROMS/Modules/mod_average.F ROMS/Modules/mod_bbl.F ROMS/Modules/mod_biology.F ROMS/Modules/mod_boundary.F ROMS/Modules/mod_clima.F ROMS/Modules/mod_coupling.F ROMS/Modules/mod_diags.F ROMS/Modules/mod_eclight.F ROMS/Modules/mod_eoscoef.F ROMS/Modules/mod_floats.F ROMS/Modules/mod_forces.F ROMS/Modules/mod_fourdvar.F ROMS/Modules/mod_grid.F ROMS/Modules/mod_iounits.F ROMS/Modules/mod_kinds.F ROMS/Modules/mod_mixing.F ROMS/Modules/mod_ncparam.F ROMS/Modules/mod_nesting.F ROMS/Modules/mod_netcdf.F ROMS/Modules/mod_obs.F ROMS/Modules/mod_ocean.F ROMS/Modules/mod_parallel.F ROMS/Modules/mod_param.F ROMS/Modules/mod_scalars.F ROMS/Modules/mod_sediment.F ROMS/Modules/mod_sources.F ROMS/Modules/mod_stepping.F ROMS/Modules/mod_storage.F ROMS/Modules/mod_strings.F ROMS/Modules/mod_tides.F Master/master.F Master/ocean_control.F Master/ocean_coupler.F Master/propagator.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/MakeDepend
cp -p /cygdrive/d/ROMS_for_Square_Harbor/trunk/Compilers/make_macros.mk /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build
makefile:229: INCLUDING FILE /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/bbl.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bbl.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bbl.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/bc_2d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bc_2d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bc_2d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/exchange_2d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/exchange_2d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/exchange_2d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_param.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_param.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_param.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_kinds.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_kinds.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_kinds.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_kinds.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_param.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math exchange_2d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_grid.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_grid.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_grid.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_grid.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_scalars.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_scalars.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_scalars.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_scalars.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math bc_2d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_bbl.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_bbl.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_bbl.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_bbl.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_forces.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_forces.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_forces.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_forces.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_ocean.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_ocean.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_ocean.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_sediment.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_sediment.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_sediment.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_sediment.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_ocean.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_parallel.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_parallel.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_parallel.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_iounits.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_iounits.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_iounits.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_iounits.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"' -DMY_OS='"CYGWIN"' -DMY_CPU='"i686"' -DMY_FORT='"g95"' -DMY_FC='"/MPICH2/bin/mpif90"' -DMY_FFLAGS='"-fno-second-underscore -O3 -ffast-math -ffree-form -ffree-line-length-huge"'  ROMS/Modules/mod_strings.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_strings.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_strings.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math -ffree-form -ffree-line-length-huge mod_strings.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_parallel.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_stepping.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_stepping.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_stepping.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_stepping.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/mp_exchange.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mp_exchange.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mp_exchange.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mp_exchange.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math bbl.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/bc_3d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bc_3d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bc_3d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/exchange_3d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/exchange_3d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/exchange_3d.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math exchange_3d.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math bc_3d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/biology.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/biology.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/biology.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_biology.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_biology.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_biology.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_eclight.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_eclight.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_eclight.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_eclight.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_biology.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_diags.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_diags.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_diags.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_diags.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_ncparam.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_ncparam.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_ncparam.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math -ffree-form -ffree-line-length-huge mod_ncparam.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math biology.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/bulk_flux.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bulk_flux.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bulk_flux.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_mixing.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_mixing.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_mixing.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_mixing.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math bulk_flux.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/bvf_mix.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bvf_mix.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bvf_mix.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math bvf_mix.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/conv_2d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/conv_2d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/conv_2d.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math conv_2d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/conv_3d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/conv_3d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/conv_3d.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math conv_3d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/diag.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/diag.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/diag.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Functionals/analytical.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/analytical.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/analytical.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/distribute.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/distribute.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/distribute.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_netcdf.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_netcdf.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_netcdf.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math -ffree-form -ffree-line-length-huge mod_netcdf.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math -ffree-form -ffree-line-length-huge distribute.f90
In file distribute.f90:1758
      CALL mpi_allgather (Asend, Asize, MP_FLOAT,                       &
                          1
In file distribute.f90:1135
      CALL mpi_allgather (my_bounds, 2, MPI_INTEGER, Abounds, 2,        &
                          2
Warning (155): Inconsistent types (REAL(8)/INTEGER(4)) in actual argument lists at (1) and (2)
In file distribute.f90:2108
      CALL mpi_bcast (A, Asize, MP_FLOAT, MyMaster, OCN_COMM_WORLD,     &
                      1
In file distribute.f90:594
      CALL mpi_bcast (A, Asize, MPI_BYTE, MyMaster, OCN_COMM_WORLD,     &
                      2
Warning (155): Inconsistent types (REAL(8)/CHARACTER(1)) in actual argument lists at (1) and (2)
                      1
In file distribute.f90:528
      CALL mpi_bcast (A, Asize, MPI_LOGICAL, MyMaster, OCN_COMM_WORLD,  &
                      2
Warning (155): Inconsistent types (REAL(8)/LOGICAL(4)) in actual argument lists at (1) and (2)
                      1
In file distribute.f90:462
      CALL mpi_bcast (A, 1, MPI_LOGICAL, MyMaster, OCN_COMM_WORLD,      &
                      2
                      1
In file distribute.f90:395
      CALL mpi_bcast (A, Asize, MPI_INTEGER, MyMaster, OCN_COMM_WORLD,  &
                      2
                      1
In file distribute.f90:330
      CALL mpi_bcast (A, 1, MPI_INTEGER, MyMaster, OCN_COMM_WORLD,      &
                      2
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_boundary.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_boundary.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_boundary.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math -ffree-form -ffree-line-length-huge mod_boundary.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_clima.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_clima.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_clima.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math -ffree-form -ffree-line-length-huge mod_clima.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_sources.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_sources.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_sources.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math -ffree-form -ffree-line-length-huge mod_sources.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math -ffree-form -ffree-line-length-huge analytical.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math diag.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/forcing.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/forcing.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/forcing.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_coupling.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_coupling.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_coupling.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_coupling.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math forcing.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/get_data.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_data.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_data.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_obs.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_obs.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_obs.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_obs.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_data.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/get_idata.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_idata.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_idata.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_tides.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_tides.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_tides.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_tides.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_idata.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/gls_corstep.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/gls_corstep.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/gls_corstep.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/tkebc_im.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/tkebc_im.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/tkebc_im.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math tkebc_im.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math gls_corstep.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/gls_prestep.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/gls_prestep.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/gls_prestep.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math gls_prestep.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/ini_fields.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ini_fields.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ini_fields.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/set_depth.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_depth.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_depth.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_depth.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/t3dbc_im.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/t3dbc_im.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/t3dbc_im.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math t3dbc_im.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/u2dbc_im.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/u2dbc_im.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/u2dbc_im.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math u2dbc_im.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/u3dbc_im.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/u3dbc_im.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/u3dbc_im.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math u3dbc_im.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/v2dbc_im.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/v2dbc_im.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/v2dbc_im.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math v2dbc_im.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/v3dbc_im.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/v3dbc_im.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/v3dbc_im.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math v3dbc_im.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/zetabc.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/zetabc.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/zetabc.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math zetabc.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math ini_fields.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/initial.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/initial.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/initial.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/ini_adjust.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ini_adjust.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ini_adjust.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_fourdvar.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_fourdvar.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_fourdvar.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_fourdvar.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math ini_adjust.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/metrics.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/metrics.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/metrics.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math metrics.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  Master/ocean_coupler.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_coupler.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_coupler.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math ocean_coupler.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/omega.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/omega.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/omega.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math omega.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/rho_eos.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/rho_eos.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/rho_eos.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_eoscoef.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_eoscoef.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_eoscoef.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_eoscoef.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math rho_eos.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/set_massflux.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_massflux.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_massflux.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_massflux.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/stiffness.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/stiffness.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/stiffness.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math stiffness.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/wpoints.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wpoints.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wpoints.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_storage.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_storage.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_storage.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_storage.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wpoints.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math initial.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/interp_floats.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/interp_floats.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/interp_floats.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math interp_floats.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/lmd_bkpp.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lmd_bkpp.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lmd_bkpp.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/shapiro.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/shapiro.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/shapiro.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math shapiro.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math lmd_bkpp.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/lmd_skpp.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lmd_skpp.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lmd_skpp.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math lmd_skpp.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/lmd_swfrac.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lmd_swfrac.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lmd_swfrac.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math lmd_swfrac.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/lmd_vmix.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lmd_vmix.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lmd_vmix.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math lmd_vmix.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/main2d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/main2d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/main2d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/dotproduct.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/dotproduct.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/dotproduct.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math dotproduct.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/frc_adjust.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/frc_adjust.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/frc_adjust.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math frc_adjust.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/oi_update.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/oi_update.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/oi_update.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math oi_update.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/radiation_stress.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/radiation_stress.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/radiation_stress.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math radiation_stress.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/set_avg.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_avg.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_avg.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_average.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_average.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_average.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_average.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_avg.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/set_tides.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_tides.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_tides.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_tides.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/set_vbc.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_vbc.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_vbc.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_vbc.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/step2d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/step2d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/step2d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/obc_volcons.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obc_volcons.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obc_volcons.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math obc_volcons.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math step2d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/step_floats.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/step_floats.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/step_floats.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_floats.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_floats.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_floats.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_floats.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/utility.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/utility.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/utility.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math utility.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math step_floats.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math main2d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/main3d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/main3d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/main3d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/my25_corstep.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/my25_corstep.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/my25_corstep.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math my25_corstep.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/my25_prestep.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/my25_prestep.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/my25_prestep.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math my25_prestep.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/rhs3d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/rhs3d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/rhs3d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/pre_step3d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/pre_step3d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/pre_step3d.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math pre_step3d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/prsgrd.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/prsgrd.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/prsgrd.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math prsgrd.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/t3dmix.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/t3dmix.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/t3dmix.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math t3dmix.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/uv3dmix.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/uv3dmix.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/uv3dmix.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math uv3dmix.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math rhs3d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/sediment.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/sediment.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/sediment.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math sediment.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/set_zeta.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_zeta.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_zeta.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_zeta.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/step3d_t.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/step3d_t.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/step3d_t.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/mpdata_adiff.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mpdata_adiff.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mpdata_adiff.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mpdata_adiff.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math step3d_t.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/step3d_uv.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/step3d_uv.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/step3d_uv.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math step3d_uv.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/wvelocity.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wvelocity.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wvelocity.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wvelocity.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math main3d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/output.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/output.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/output.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math output.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Nonlinear/set_data.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_data.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_data.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/set_2dfld.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_2dfld.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_2dfld.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_2dfld.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/set_3dfld.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_3dfld.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_3dfld.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_3dfld.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_data.f90
ar -r /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libNLM.a /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bbl.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bc_2d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bc_3d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/biology.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bulk_flux.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/bvf_mix.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/conv_2d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/conv_3d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/diag.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/exchange_2d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/exchange_3d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/forcing.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_data.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_idata.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/gls_corstep.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/gls_prestep.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ini_fields.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/initial.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/interp_floats.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lmd_bkpp.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lmd_skpp.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lmd_swfrac.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lmd_vmix.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/main2d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/main3d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mpdata_adiff.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/my25_corstep.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/my25_prestep.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obc_volcons.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/omega.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/output.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/pre_step3d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/prsgrd.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/radiation_stress.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/rho_eos.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/rhs3d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/sediment.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_avg.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_data.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_depth.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_massflux.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_tides.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_vbc.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_zeta.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/step2d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/step3d_t.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/step3d_uv.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/step_floats.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/t3dbc_im.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/t3dmix.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/tkebc_im.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/u2dbc_im.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/u3dbc_im.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/uv3dmix.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/v2dbc_im.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/v3dbc_im.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wvelocity.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/zetabc.o
ar: creating /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libNLM.a
ranlib /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libNLM.a
ar -r /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libANA.a /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/analytical.o
ar: creating /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libANA.a
ranlib /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libANA.a
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/SeaIce/seaice.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/seaice.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/seaice.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math seaice.f90
ar -r /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libICE.a /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/seaice.o
ar: creating /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libICE.a
ranlib /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libICE.a
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/back_cost.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/back_cost.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/back_cost.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math back_cost.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/back_cov.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/back_cov.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/back_cov.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math back_cov.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/back_step.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/back_step.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/back_step.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math back_step.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/cgradient.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/cgradient.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/cgradient.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/state_addition.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_addition.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_addition.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math state_addition.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/state_copy.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_copy.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_copy.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math state_copy.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/state_dotprod.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_dotprod.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_dotprod.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math state_dotprod.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/state_initialize.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_initialize.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_initialize.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math state_initialize.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/state_scale.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_scale.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_scale.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math state_scale.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math cgradient.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/checkdefs.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/checkdefs.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/checkdefs.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math checkdefs.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/checkvars.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/checkvars.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/checkvars.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math checkvars.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/close_io.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/close_io.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/close_io.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math close_io.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/congrad.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/congrad.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/congrad.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math congrad.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/cost_grad.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/cost_grad.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/cost_grad.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math cost_grad.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/cost_norm.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/cost_norm.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/cost_norm.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math cost_norm.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_avg.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_avg.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_avg.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_avg.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_diags.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_diags.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_diags.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_diags.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_floats.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_floats.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_floats.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_floats.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_gst.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_gst.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_gst.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_gst.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_hessian.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_hessian.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_hessian.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_hessian.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_his.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_his.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_his.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_his.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_impulse.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_impulse.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_impulse.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_impulse.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_info.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_info.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_info.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_info.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_ini.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_ini.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_ini.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_ini.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_mod.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_mod.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_mod.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_mod.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_norm.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_norm.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_norm.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_norm.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_rst.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_rst.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_rst.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_rst.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_station.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_station.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_station.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_station.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_tides.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_tides.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_tides.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_tides.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/def_var.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_var.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_var.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math def_var.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/descent.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/descent.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/descent.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math descent.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/downhill.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/downhill.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/downhill.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math downhill.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/extract_obs.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/extract_obs.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/extract_obs.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math extract_obs.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/extract_sta.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/extract_sta.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/extract_sta.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math extract_sta.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/gasdev.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/gasdev.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/gasdev.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/nrutil.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nrutil.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nrutil.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math nrutil.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math gasdev.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_2dfld.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_2dfld.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_2dfld.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_2dfld.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_2dfldr.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_2dfldr.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_2dfldr.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_2dfldr.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_3dfld.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_3dfld.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_3dfld.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_3dfld.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_3dfldr.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_3dfldr.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_3dfldr.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_3dfldr.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_bounds.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_bounds.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_bounds.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_bounds.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_cycle.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_cycle.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_cycle.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_cycle.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_date.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_date.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_date.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_date.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_grid.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_grid.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_grid.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_grid.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_gst.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_gst.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_gst.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_gst.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_ngfld.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_ngfld.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_ngfld.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_ngfld.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_ngfldr.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_ngfldr.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_ngfldr.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_ngfldr.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_state.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_state.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_state.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_state.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/get_varcoords.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_varcoords.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_varcoords.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math get_varcoords.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/grid_coords.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/grid_coords.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/grid_coords.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/interpolate.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/interpolate.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/interpolate.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math interpolate.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math grid_coords.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/impulse.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/impulse.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/impulse.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math impulse.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/inp_par.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/inp_par.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/inp_par.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/ran_state.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ran_state.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ran_state.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math ran_state.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math inp_par.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/lubksb.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lubksb.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lubksb.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math lubksb.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/ludcmp.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ludcmp.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ludcmp.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math ludcmp.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/mp_routines.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mp_routines.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mp_routines.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mp_routines.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/nf_fread2d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fread2d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fread2d.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math nf_fread2d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/nf_fread3d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fread3d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fread3d.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math nf_fread3d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/nf_fread4d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fread4d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fread4d.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math nf_fread4d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/nf_fwrite2d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fwrite2d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fwrite2d.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math nf_fwrite2d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/nf_fwrite3d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fwrite3d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fwrite3d.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math nf_fwrite3d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/nf_fwrite4d.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fwrite4d.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fwrite4d.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math nf_fwrite4d.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/normalization.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/normalization.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/normalization.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/white_noise.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/white_noise.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/white_noise.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math white_noise.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math normalization.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/obs_cost.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_cost.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_cost.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math obs_cost.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/obs_depth.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_depth.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_depth.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math obs_depth.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/obs_initial.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_initial.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_initial.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math obs_initial.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/obs_read.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_read.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_read.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math obs_read.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/obs_scale.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_scale.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_scale.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math obs_scale.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/obs_write.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_write.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_write.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math obs_write.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/opencdf.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/opencdf.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/opencdf.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math opencdf.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/packing.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/packing.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/packing.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math packing.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/ran1.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ran1.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ran1.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math ran1.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/regrid.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/regrid.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/regrid.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math regrid.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/set_2dfldr.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_2dfldr.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_2dfldr.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_2dfldr.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/set_3dfldr.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_3dfldr.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_3dfldr.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_3dfldr.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/set_diags.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_diags.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_diags.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_diags.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/set_ngfld.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_ngfld.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_ngfld.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_ngfld.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/set_ngfldr.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_ngfldr.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_ngfldr.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_ngfldr.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/set_scoord.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_scoord.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_scoord.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_scoord.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/set_weights.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_weights.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_weights.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math set_weights.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/stats_modobs.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/stats_modobs.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/stats_modobs.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math stats_modobs.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/timers.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/timers.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/timers.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math timers.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/wrt_avg.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_avg.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_avg.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wrt_avg.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/wrt_diags.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_diags.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_diags.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wrt_diags.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/wrt_floats.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_floats.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_floats.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wrt_floats.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/wrt_gst.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_gst.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_gst.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wrt_gst.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/wrt_hessian.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_hessian.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_hessian.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wrt_hessian.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/wrt_his.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_his.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_his.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wrt_his.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/wrt_info.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_info.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_info.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wrt_info.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/wrt_ini.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_ini.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_ini.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wrt_ini.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/wrt_rst.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_rst.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_rst.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wrt_rst.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/wrt_station.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_station.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_station.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wrt_station.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Utility/wrt_tides.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_tides.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_tides.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math wrt_tides.f90
ar -r /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/back_cost.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/back_cov.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/back_step.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/cgradient.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/checkdefs.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/checkvars.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/close_io.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/congrad.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/cost_grad.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/cost_norm.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_avg.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_diags.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_floats.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_gst.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_hessian.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_his.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_impulse.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_info.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_ini.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_mod.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_norm.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_rst.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_station.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_tides.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/def_var.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/descent.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/distribute.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/dotproduct.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/downhill.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/extract_obs.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/extract_sta.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/frc_adjust.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/gasdev.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_2dfld.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_2dfldr.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_3dfld.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_3dfldr.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_bounds.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_cycle.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_date.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_grid.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_gst.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_ngfld.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_ngfldr.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_state.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/get_varcoords.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/grid_coords.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/impulse.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ini_adjust.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/inp_par.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/interpolate.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/lubksb.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ludcmp.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/metrics.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mp_exchange.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mp_routines.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fread2d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fread3d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fread4d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fwrite2d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fwrite3d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nf_fwrite4d.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/normalization.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/nrutil.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_cost.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_depth.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_initial.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_read.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_scale.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/obs_write.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/oi_update.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/opencdf.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/packing.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ran1.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ran_state.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/regrid.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_2dfld.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_2dfldr.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_3dfld.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_3dfldr.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_diags.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_ngfld.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_ngfldr.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_scoord.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/set_weights.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/shapiro.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_addition.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_copy.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_dotprod.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_initialize.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/state_scale.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/stats_modobs.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/stiffness.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/timers.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/utility.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/white_noise.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wpoints.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_avg.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_diags.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_floats.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_gst.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_hessian.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_his.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_info.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_ini.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_rst.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_station.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/wrt_tides.o
ar: creating /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a
ranlib /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_arrays.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_arrays.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_arrays.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_arrays.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  ROMS/Modules/mod_nesting.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_nesting.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_nesting.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math mod_nesting.f90
ar -r /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libMODS.a /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_arrays.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_average.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_bbl.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_biology.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_boundary.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_clima.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_coupling.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_diags.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_eclight.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_eoscoef.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_floats.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_forces.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_fourdvar.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_grid.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_iounits.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_kinds.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_mixing.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_ncparam.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_nesting.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_netcdf.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_obs.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_ocean.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_parallel.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_param.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_scalars.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_sediment.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_sources.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_stepping.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_storage.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_strings.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/mod_tides.o
ar: creating /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libMODS.a
ranlib /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libMODS.a
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  Master/master.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  Master/ocean_control.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.f90
/usr/bin/cpp -P -traditional -DMPI -DCYGWIN -DI686 -DG95 -D'ROOT_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk"' -Dinlet_sh -D'HEADER="inlet_sh.h"' -D'ROMS_HEADER="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include/inlet_sh.h"' -DNestedGrids=1 -D'ANALYTICAL_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals"' -D'MY_ANALYTICAL="on"' -D'SVN_REV=""' -IROMS/Include -IROMS/Nonlinear -IROMS/SeaIce -IROMS/Utility -IROMS/Drivers -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Functionals -IROMS/Functionals -I/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include -IMaster -ICompilers -D'HEADER_DIR="/cygdrive/d/ROMS_for_Square_Harbor/trunk/User/Include"'  Master/propagator.F > /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/propagator.f90
ROMS/Bin/cpp_clean /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/propagator.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math propagator.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math ocean_control.f90
cd /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build; /MPICH2/bin/mpif90 -c -fno-second-underscore -O3 -ffast-math master.f90
mpif90 -fno-second-underscore -O3 -ffast-math  /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_coupler.o /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/propagator.o -o /cygdrive/d/ROMS_for_Square_Harbor/trunk/oceanM.exe  /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libNLM.a /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libANA.a /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libICE.a /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a /cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libMODS.a -L/usr/local/lib -lnetcdf
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o:master.f90:(.text+0xe): undefined reference to `mpi_init_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o:master.f90:(.text+0x34): undefined reference to `mpi_comm_rank_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/master.o:master.f90:(.text+0x5d): undefined reference to `mpi_finalize_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.o:ocean_control.f90:(.text+0x3e6): undefined reference to `mpi_comm_rank_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/ocean_control.o:ocean_control.f90:(.text+0x3fd): undefined reference to `mpi_comm_size_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x8f3): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x915): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x9a0): undefined reference to `mpi_bcast_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0xa75): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0xb8d): undefined reference to `mpi_isend_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0xba3): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0xbe4): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0xc87): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x1359): undefined reference to `mpi_bcast_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x1675): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x192a): undefined reference to `mpi_allgather_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x1b9e): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x1d58): undefined reference to `mpi_allgather_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x1edd): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x2282): undefined reference to `mpi_gather_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x24fe): undefined reference to `mpi_isend_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x2528): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x26d0): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x26e9): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x2804): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x2921): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x2a11): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x2d83): undefined reference to `mpi_gather_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x3098): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x30b1): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x31d3): undefined reference to `mpi_isend_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x31ef): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x32d6): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x33dc): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x34db): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x3770): undefined reference to `mpi_allgather_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x3856): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x386f): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x38b5): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x3a04): undefined reference to `mpi_isend_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x3a1d): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x3a66): undefined reference to `mpi_bcast_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x3acc): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x3c18): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x3ce2): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x485a): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x48c5): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x4c08): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x4d32): undefined reference to `mpi_isend_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x4d45): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x4d81): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x5587): undefined reference to `mpi_allreduce_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x55c0): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x596c): undefined reference to `mpi_allreduce_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x5ad7): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x5c0d): undefined reference to `mpi_bcast_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x5c46): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x5da6): undefined reference to `mpi_bcast_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x5ddf): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x5f4d): undefined reference to `mpi_bcast_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x5f86): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x60e6): undefined reference to `mpi_bcast_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x611f): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x628d): undefined reference to `mpi_bcast_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x62c6): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x6436): undefined reference to `mpi_bcast_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x646f): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x65d6): undefined reference to `mpi_bcast_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x660f): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x677d): undefined reference to `mpi_bcast_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x67b6): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(distribute.o):distribute.f90:(.text+0x68c5): undefined reference to `mpi_barrier_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x17e3): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x252f): undefined reference to `mpi_send_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x2581): undefined reference to `mpi_send_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x25a8): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x2842): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x2b2b): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x2dc7): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x2dee): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x3063): undefined reference to `mpi_send_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x30b5): undefined reference to `mpi_send_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x3111): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x316d): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x374b): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x3848): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x38f0): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x3998): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x50b1): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x6444): undefined reference to `mpi_send_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x646b): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x664c): undefined reference to `mpi_send_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x66a5): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x66f5): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x67cb): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x697a): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x6b63): undefined reference to `mpi_send_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x6bb2): undefined reference to `mpi_send_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x6c0e): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x6c67): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x6ca0): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x7d85): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x7e2d): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x7ed5): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x908b): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0x9c5b): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xa016): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xa3d7): undefined reference to `mpi_send_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xa426): undefined reference to `mpi_send_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xa473): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xa4c9): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xa4f0): undefined reference to `mpi_wait_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xa8e2): undefined reference to `mpi_send_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xa934): undefined reference to `mpi_send_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xa990): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xa9ec): undefined reference to `mpi_irecv_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xaa25): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xab23): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xabcb): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libUTIL.a(mp_exchange.o):mp_exchange.f90:(.text+0xac73): undefined reference to `mpi_error_string_'
/cygdrive/d/ROMS_for_Square_Harbor/trunk/Build/libMODS.a(mod_parallel.o):mod_parallel.f90:(.text+0x2b): undefined reference to `mpi_comm_size_'
make: *** [/cygdrive/d/ROMS_for_Square_Harbor/trunk/oceanM.exe] Error 1
