[mpich-discuss] Fwd: Windows and mpicc
Jayesh Krishna jayesh at mcs.anl.gov
Mon Nov 12 10:32:23 CST 2012
 Looks like you have compile time errors for mpe because of DOS characters. If you are not planning to use MPE you can disable it (Specify "--disable-mpe" during configure time).
 The error that stopped the build looks like a Cygwin error (Unable to allocate enough memory for the linker). I have seen these errors when packages are updated (A "rebase" sometimes solves the problem). I would recommend posting your issue on a Cygwin forum.
 Can you try running the build again (after disabling MPE at compile time) after you fix the Cygwin issue?
Jayesh
----- Original Message -----
Sent: Friday, November 9, 2012 2:58:06 PM
Subject: [mpich-discuss] Fwd:  Windows and mpicc
FYI
----- Forwarded Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Friday, November 9, 2012 10:25:19 AM
Subject: RE: [mpich-discuss] Windows and mpicc
Hi Jayesh,
Thanks.  I did as you suggested.  On the configure stage, I had to convert all the configure-related files to change the end of line characters to UNIX rather than DOS.  The Cygwin version of BASH seems to be very picky about this.
Eventually I managed to persuade the ./configure to work (output attached).  However, the make stage failed with various errors (output attached).
I have also included a list of the environmental variables, which may be relevant.
Any advice on how to proceed would be much appreciated.
John Mole
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: 07 November 2012 15:50
To: Mole, John
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] Windows and mpicc
 There are two ways to install MPICH2 on Windows  - (1) Using the Windows installers (2) Downloading MPICH2 source and compiling it under Cygwin.
 If you install MPICH2 using the Windows msi installers mpicc is not installed (Users typically compile their programs using Visual Studio, Intel Windows compilers etc).
 Since you are working in the Cygwin environment please uninstall MPICH2 and download the MPICH2 source from the link below and install (configure/make/make install - like you would install software on a unix-like/cygwin system) it.
Jayesh
Sent: Wednesday, November 7, 2012 6:49:59 AM
Hi Jayesh,
I have already downloaded and installed the Windows version but there is no sign of mpicc (or the Fortran equivalent) in the /bin folder hence my original query.
John Mole
Sent: 06 November 2012 15:27
Cc: Mole, John
 mpicc is the compiler wrapper that is installed with MPICH2 (or an MPI library suite). You can download the source and install MPICH2 from the MPICH2 website (http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads).
Jayesh
Sent: Monday, November 5, 2012 4:40:58 PM
Subject: [mpich-discuss] Windows and mpicc
I am currently porting a mathematical modelling application from Ubuntu to Windows. I am fairly new to Linux. I am mostly working in Cygwin which emulates the Linux environment in Windows. I have installed MPICH2 on Windows and have set the necessary paths.
In trying to make Parmetis in Cygwin I get the error ‘mpicc not found’. So I am trying to track down mpicc. I don’t know where it comes from. Is it from GNU or MPICH or where? How do I get hold of it?
I would be most grateful if someone could provide guidance.
John Mole
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
