[mpich-discuss] do not get mpif90 after building mpich2 in linux
Gus Correa gus at ldeo.columbia.edu
Thu Nov 8 11:55:19 CST 2012
Hi Michael
Besides Reuti's suggestion:
Make sure you set up the Intel compiler environment correctly,
before you configure MPICH2.
The easy way is to source the appropriate script that comes with the
compiler, such as compilervars.[csh,sh], or iccvars.[csh,sh] and
ifortvars[csh,sh] depending on the release you have.
The script may take the computer architecture (intel64 or ia32)
as a parameter also.
It is not enough to set only the PATH.
Check the compiler documentation for details.
A faulty environment can cause linking problems
Also, start over from a fresh tarball.
Avoid mixing the old and the new builds.
Old object files may also cause linking problems.
I hope this helps,
Gus Correa
On 11/08/2012 08:43 AM, Reuti wrote:
> Am 08.11.2012 um 14:27 schrieb Michael Seman:
>> On 8/11/2012 2:00 AM, mpich-discuss-request at mcs.anl.gov wrote:
>>> From: Gus Correa<gus at ldeo.columbia.edu>
>>> To: Mpich Discuss<mpich-discuss at mcs.anl.gov>
>>> Subject: Re: [mpich-discuss] do not get mpif90 after building mpich2
>>> 	in linux
>>> Hi Michael
>>> Besides Dave's recommendation of moving up to 1.5:
>>> Did you set the C++ compiler to Intel icpc?
>>> I.e., export CXX=icpc.
>>> You may be using g++ inadvertently.
>>> I kind of remember that this was needed to get the
>>> F90 interface right, but it may have been in another MPI, not sure
> You also defined the Intel Fortran compiler?
> -- Reuti
>>> I hope this helps,
>>> Gus Correa
>>> On 11/07/2012 10:07 AM, Dave Goodell wrote:
>>>> Please try the latest version of MPICH2, 1.5.
>>>> -Dave
>> I tried adding CXX=icpc, but that did not help.
>> Also I tried mpich2 version 1.5, but the install falters with message
>> "Could not determine a way to link a Fortran test program"
>> Same problem if I tried version 1.4, so 1.3 appears to be best bet at the moment.
>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
