[mpich-discuss] do not get mpif90 after building mpich2 in linux
Gus Correa
gus at ldeo.columbia.edu
Wed Nov 7 09:23:30 CST 2012
Hi Michael
Besides Dave's recommendation of moving up to 1.5:
Did you set the C++ compiler to Intel icpc?
I.e., export CXX=icpc.
You may be using g++ inadvertently.
I kind of remember that this was needed to get the
F90 interface right, but it may have been in another MPI, not sure.
I hope this helps,
Gus Correa
On 11/07/2012 10:07 AM, Dave Goodell wrote:
> Please try the latest version of MPICH2, 1.5.
> -Dave
> On Nov 7, 2012, at 3:58 AM CST, Michael Seman wrote:
>> I have built mpich2 version 1.2.1p1 before with gcc in Centos 4.8.
>> No problems arose way back then.
>> Now I see that after that, the configuration flags were changed, dropping "F90" in favour of "FC". I have a certain package that uses mpich2, and changed the relevant parts its build script as follows:
>> FC=ifort
>> F77=ifort
>> CC=icc
>> CFLAGS="-fPIC -O"
>> FFLAGS="-fPIC -fno-second-underscore -O"
>> export FC CC CFLAGS FFLAGS F77
>> FLAGS="--prefix=${BUILD_DIR} --enable-threads --enable-sharedlibs=gcc \
>> --enable-shared --enable-f77 --enable-fc --enable-cxx"
>> ./configure ${FLAGS}&& \
>> make clean&& \
>> make&& \
>> make install
>> But after it finishes, there is no mpif90 command created.
>> If I do 'ls mpi*' in the mpich2 bin subdirectory, I get these:
>> mpic++
>> mpicc
>> mpicxx
>> mpiexec
>> mpiexec.hydra
>> mpif77
>> mpirun
>> I am using Scientific Linux 6 64-bit with Intel compilers version 11.1, and mpich2 version 1.3
>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
