[mpich-discuss] make[7]: *** [all-postamble] Error 1
    Jonathan Perkins
    perkinjo at cse.ohio-state.edu
    Mon Nov  5 19:39:13 CST 2012
Hi, I'm cc'ing this to the mvapich-discuss list since its related to
MVAPICH.  What options are you using for the build at configure time?
This could be something that was resolved for the 1.8 release.  Can you
try downloading the latest stable release and see if this problem still
persists?
https://mvapich.cse.ohio-state.edu/download/mvapich2/
On Tue, Nov 06, 2012 at 09:05:20AM +0800, Haoyan Liu wrote:
> Hi,
> I am building mvapich2-1.8a1p1 with pgi-10.6-0 64-bit on x86-64 Linux. I
> get Errors when "make" and the information is as follows:
> make all-postamble
> make[7]: Entering directory
> `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid/ch3/channels/mrail/src'
> test "xyes" = "xno" ||\
>             { ar crv
> /home/hyliu/software/mvapich2/mvapich2-1.8a1p1/lib/libmpich.a hwloc/src/*.o
> && ar crv /home/hyliu/software/mvapich2/mvapich2-1.8a1p1/lib/libmpich.lahwloc/src/.libs/*.o;
> a - hwloc/src/bind.o
> a - hwloc/src/cpuset.o
> a - hwloc/src/distances.o
> a - hwloc/src/misc.o
> a - hwloc/src/topology-libpci.o
> a - hwloc/src/topology-linux.o
> a - hwloc/src/topology.o
> a - hwloc/src/topology-synthetic.o
> a - hwloc/src/topology-x86.o
> a - hwloc/src/topology-xml.o
> a - hwloc/src/traversal.o
> ar: hwloc/src/.libs/*.o: No such file or directory
> make[7]: Leaving directory
> make[6]: *** [all-redirect] Error 2
> make[6]: Leaving directory
> make[5]: *** [all-redirect] Error 2
> make[5]: Leaving directory
> `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid/ch3/channels/mrail'
> make[4]: *** [all-redirect] Error 1
> make[4]: Leaving directory
> `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid/ch3/channels'
> make[3]: *** [all-redirect] Error 2
> make[3]: Leaving directory
> `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid/ch3'
> make[2]: *** [all-redirect] Error 1
> make[2]: Leaving directory
> `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src/mpid'
> make[1]: *** [all-redirect] Error 2
> make[1]: Leaving directory
> `/home/hyliu/software/mvapich2/mvapich2-1.8a1p1/src'
> make: *** [all-redirect] Error 2
> My environment variable:
> export CC=pgcc
> export CXX=pgCC
> export FC=pgf90
> export F77=pgf77
> export F90=pgf90
> export LD=pgf90
> export CPP="pgCC -E"
> export CXXFLAGS"=-mcmodel=medium"
> export FCFLAGS="-mcmodel=medium"
> export CFLAGS="-mcmodel=medium"
> export FFLAGS="-mcmodel=medium"
> export LDFLAGS="-mcmodel=medium"
> How can I solve that?
> Thanks a lot.
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Jonathan Perkins
http://www.cse.ohio-state.edu/~perkinjo
