[mpich-discuss] MPI One-Sided Communication,	and indexed datatype
    Jeff Hammond
    jhammond at alcf.anl.gov
    Thu May 31 21:46:06 CDT 2012
just compile with CLANG/LLVM and it will be more than happy to point
out the issues :-)  i suspect they are just artifacts of your skeleton
code though.  there are no serious bugs i couldn't fix in 5 minutes by
taking direction from the compiler warnings and errors.
you can email me a huge tarball off-list and i can put it where the
MPICH folks can grab it quickly if that works for everyone.  GMail can
handle something like 25 MB but my Argonne address should be able to
handle much larger.  please clean before tar+gzip/bzip2-ing (i know
this is obvious to some).
jeff
On Thu, May 31, 2012 at 9:41 PM, Ziaul Haque Olive <mzh.olive at gmail.com> wrote:
> no I don't have right now. but I will create one and let you know. for the
> time being, could you please tell me some of the errors according to C
> standard that you mentioned in your previous email.
> Thanks
> Ziaul
> On Thu, May 31, 2012 at 9:31 PM, Jeff Hammond <jhammond at alcf.anl.gov> wrote:
>> Can't you just put it on the Internet somewhere?  Do you have a
>> world-readable SVN repo?
>> Jeff
>> On Thu, May 31, 2012 at 9:18 PM, Ziaul Haque Olive <mzh.olive at gmail.com>
>> wrote:
>> > Thanks Jeff,
>> > the code is quite large to post here. It is from graph500 benchmark's
>> > mpi
>> > implementation. multiple files are required to build this code. I can
>> > send
>> > the whole directory for debugging. what do you say?
>> > Thanks,
>> > Ziaul.
>> > On Thu, May 31, 2012 at 8:51 PM, Jeff Hammond <jhammond at alcf.anl.gov>
>> > wrote:
>> >> This is an interesting question.
>> >> "Is it okay that I am freeing memory before the closing fence?"
>> >> With respect to the memory associated with the MPI_Accumulate itself,
>> >> the answer is clearly "no".
>> >> MPI-2.2 11.3:
>> >> "The local communication buffer of an RMA call should not be updated,
>> >> and the local communication buffer of a get call should not be
>> >> accessed after the RMA call, until the subsequent synchronization call
>> >> completes."
>> >> Freeing memory is obviously a modification.
>> >> However, it seems you are freeing the MPI_Datatype used in this
>> >> operation and the input arrays associated with it.
>> >> From MPI-2.2 4.1.9:
>> >> "Marks the datatype object associated with datatype for deallocation
>> >> and sets datatype to MPI_DATATYPE_NULL. Any communication that is
>> >> currently using this datatype will complete normally. Freeing a
>> >> datatype does not affect any other datatype that was built from the
>> >> freed datatype. The system behaves as if input datatype arguments to
>> >> derived datatype constructors are passed by value."
>> >> It would seem that your usage is correct.
>> >> I cannot debug your code because it is incomplete and has a few bugs
>> >> according to the C standard.  Can you post the code that actually
>> >> results in the error you're seeing?
>> >> There may be other issues with your code that others may point out.
>> >> My email is not intended to capture all possible sources of error.
>> >> Best,
>> >> Jeff
>> >> On Thu, May 31, 2012 at 6:23 PM, Ziaul Haque Olive
>> >> wrote:
>> >> > Hello,
>> >> > I am not sure, if my code is correct according to MPICH2(v1.4.1p1.).
>> >> > the
>> >> > code is given as follows, I am doing MPI one-sided communication
>> >> > inside
>> >> > a
>> >> > function - data_transfer. this function is being called inside a
>> >> > fence
>> >> > epoch. inside data_transfer, I am allocating memory for
>> >> > non-contiguous
>> >> > data,
>> >> > creating derived data type, using this datatype in MPI_Accumulate,
>> >> > and
>> >> > after
>> >> > calling MPI_Accumulate, freeing the indexed data type and also
>> >> > freeing
>> >> > the
>> >> > memory containing indices for indexed data type. is it okay that I am
>> >> > freeing memory before the closing fence.
>> >> > void data_transfer(void *data, int *sources_disp, int *targets_disp,
>> >> > int
>> >> > *target, int size, int *blength, int func, MPI_Op op, MPI_Win win,
>> >> > MPI_Datatype dtype){
>> >> > int i,j, index;
>> >> > int tmp_target;
>> >> > int *flag;
>> >> > int *source_disp;
>> >> > int *target_disp;
>> >> > MPI_Datatype source_type, target_type;
>> >> > MPI_Alloc_mem( size*sizeof(int), MPI_INFO_NULL, &source_disp);
>> >> > MPI_Alloc_mem( size*sizeof(int), MPI_INFO_NULL, &target_disp);
>> >> > MPI_Alloc_mem( size*sizeof(int), MPI_INFO_NULL, &flag );
>> >> > memset(flag, 0, size*sizeof(int));
>> >> > for(i=0;i<size;i++){
>> >> > if(flag[i]==0){
>> >> > tmp_target = target[i];
>> >> > index = 0;
>> >> > for(j=i; j<size; j++){
>> >> > if(flag[j]==0 && tmp_target == target[j] ){
>> >> > source_disp[index] = sources_disp[j];
>> >> > target_disp[index] = targets_disp[j];
>> >> > //printf("src, target disp %d  %d\n", j, disp[j]);
>> >> > index++;
>> >> > flag[j] = 1;
>> >> > MPI_Type_indexed(index, blength , source_disp, dtype, &source_type);
>> >> > MPI_Type_commit(&source_type);
>> >> > MPI_Type_indexed(index, blength , target_disp, dtype, &target_type);
>> >> > MPI_Type_commit(&target_type);
>> >> > MPI_Accumulate( data, 1, source_type, tmp_target, 0, 1, target_type ,
>> >> > op,
>> >> > win);
>> >> > MPI_Type_free(&source_type);
>> >> > MPI_Type_free(&target_type);
>> >> > MPI_Free_mem(source_disp);
>> >> > MPI_Free_mem(target_disp);
>> >> > MPI_Free_mem(flag);
>> >> > void main(){
>> >> > int i;
>> >> > while(i<N){
>> >> > MPI_Win_fence(MPI_MODE_NOPRECEDE, queue2_win);
>> >> > data_transfer();
>> >> > MPI_Win_fence(MPI_MODE_NOSUCCEED, queue2_win);
>> >> > Thanks
>> >> > Ziaul
>> >> > _______________________________________________
>> >> > mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> >> > To manage subscription options or unsubscribe:
>> >> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>> >> Jeff Hammond
>> >> Argonne Leadership Computing Facility
>> >> University of Chicago Computation Institute
>> >> jhammond at alcf.anl.gov / (630) 252-5381
>> >> http://www.linkedin.com/in/jeffhammond
>> >> https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
>> Jeff Hammond
Jeff Hammond
