[mpich-discuss] MPI One-Sided Communication, and indexed datatype
Jeff Hammond jhammond at alcf.anl.gov
Thu May 31 20:51:09 CDT 2012
This is an interesting question.
"Is it okay that I am freeing memory before the closing fence?"
With respect to the memory associated with the MPI_Accumulate itself,
the answer is clearly "no".
MPI-2.2 11.3:
"The local communication buffer of an RMA call should not be updated,
and the local communication buffer of a get call should not be
accessed after the RMA call, until the subsequent synchronization call
completes."
Freeing memory is obviously a modification.
However, it seems you are freeing the MPI_Datatype used in this
operation and the input arrays associated with it.
>From MPI-2.2 4.1.9:
"Marks the datatype object associated with datatype for deallocation
and sets datatype to MPI_DATATYPE_NULL. Any communication that is
currently using this datatype will complete normally. Freeing a
datatype does not affect any other datatype that was built from the
freed datatype. The system behaves as if input datatype arguments to
derived datatype constructors are passed by value."
It would seem that your usage is correct.
I cannot debug your code because it is incomplete and has a few bugs
according to the C standard.  Can you post the code that actually
results in the error you're seeing?
There may be other issues with your code that others may point out.
My email is not intended to capture all possible sources of error.
Best,
Jeff
On Thu, May 31, 2012 at 6:23 PM, Ziaul Haque Olive <mzh.olive at gmail.com> wrote:
> Hello,
> I am not sure, if my code is correct according to MPICH2(v1.4.1p1.). the
> code is given as follows, I am doing MPI one-sided communication inside a
> function - data_transfer. this function is being called inside a fence
> epoch. inside data_transfer, I am allocating memory for non-contiguous data,
> creating derived data type, using this datatype in MPI_Accumulate, and after
> calling MPI_Accumulate, freeing the indexed data type and also freeing the
> memory containing indices for indexed data type. is it okay that I am
> freeing memory before the closing fence.
> void data_transfer(void *data, int *sources_disp, int *targets_disp, int
> *target, int size, int *blength, int func, MPI_Op op, MPI_Win win,
> MPI_Datatype dtype){
> int i,j, index;
> int tmp_target;
> int *flag;
> int *source_disp;
> int *target_disp;
> MPI_Datatype source_type, target_type;
> MPI_Alloc_mem( size*sizeof(int), MPI_INFO_NULL, &source_disp);
> MPI_Alloc_mem( size*sizeof(int), MPI_INFO_NULL, &target_disp);
> MPI_Alloc_mem( size*sizeof(int), MPI_INFO_NULL, &flag );
> memset(flag, 0, size*sizeof(int));
> for(i=0;i<size;i++){
> if(flag[i]==0){
> tmp_target = target[i];
> index = 0;
> for(j=i; j<size; j++){
> if(flag[j]==0 && tmp_target == target[j] ){
> source_disp[index] = sources_disp[j];
> target_disp[index] = targets_disp[j];
> //printf("src, target disp %d  %d\n", j, disp[j]);
> index++;
> flag[j] = 1;
> MPI_Type_indexed(index, blength , source_disp, dtype, &source_type);
> MPI_Type_commit(&source_type);
> MPI_Type_indexed(index, blength , target_disp, dtype, &target_type);
> MPI_Type_commit(&target_type);
> MPI_Accumulate( data, 1, source_type, tmp_target, 0, 1, target_type , op,
> win);
> MPI_Type_free(&source_type);
> MPI_Type_free(&target_type);
> MPI_Free_mem(source_disp);
> MPI_Free_mem(target_disp);
> MPI_Free_mem(flag);
> void main(){
> int i;
> while(i<N){
> MPI_Win_fence(MPI_MODE_NOPRECEDE, queue2_win);
> data_transfer();
> MPI_Win_fence(MPI_MODE_NOSUCCEED, queue2_win);
> Thanks
> Ziaul
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
