[mpich-discuss] Poor scaling of MPI_WIN_CREATE?
Timothy Stitt Timothy.Stitt.9 at nd.edu
Wed May 30 10:48:49 CDT 2012
Thanks Jeff...you provided some good suggestions. I'll consult the DMAPP documentation and also go back to the code to see if I can reuse window buffers in some way.
Would you happen to have links to the DMAPP docs on-hand? I couldn't seem to find any tutorials etc. after a quick browse.
Cheers,
Tim.
On May 30, 2012, at 11:40 AM, Jeff Hammond wrote:
If you don't care about portability, translating from MPI-2 RMA to
DMAPP is mostly trivial and you can eliminate collective window
creation altogether.  However, I will note that my experience getting
MPI and DMAPP to inter-operate properly on XE6 (Hopper, in fact) was
terrible.  And yes, I did everything the NERSC documentation and Cray
told me to do.
I wonder if you can reduce the time spent in MPI_WIN_CREATE by calling
it less often.  Can you not allocate the window once and keep reusing
it?  You might need to restructure your code to reuse the underlying
local buffers but that isn't that complicated in some cases.
Best,
Jeff
On Wed, May 30, 2012 at 10:36 AM, Jed Brown <jedbrown at mcs.anl.gov<mailto:jedbrown at mcs.anl.gov>> wrote:
On Wed, May 30, 2012 at 10:29 AM, Timothy Stitt <Timothy.Stitt.9 at nd.edu<mailto:Timothy.Stitt.9 at nd.edu>>
wrote:
Hi all,
I am currently trying to improve the scaling of a CFD code on some Cray
machines at NERSC (I believe Cray systems leverage mpich2 for their MPI
communications, hence the posting to this list) and I am running into some
scalability issues with the MPI_WIN_CREATE() routine.
To cut a long story short, the CFD code requires each process to receive
values from some neighborhood processes. Unfortunately, each process doesn't
know who its neighbors should be in advance.
How often do the neighbors change? By what mechanism?
To overcome this we exploit the one-sided MPI_PUT() routine to communicate
data from neighbors directly.
Recent profiling at 256, 512 and 1024 processes shows that the
MPI_WIN_CREATE routine is starting to dominate the walltime and reduce our
scalability quite rapidly. For instance the %walltime for MPI_WIN_CREATE
over various process sizes increases as follows:
256 cores - 4.0%
512 cores - 9.8%
1024 cores - 24.3%
The current implementation of MPI_Win_create uses an Allgather which is
synchronizing and relatively expensive.
I was wondering if anyone in the MPICH2 community had any advice on how
one can improve the performance of MPI_WIN_CREATE? Or maybe someone has a
better strategy for communicating the data that bypasses the (poorly
scaling?) MPI_WIN_CREATE routine.
Thanks in advance for any help you can provide.
Tim.
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov<mailto:mpich-discuss at mcs.anl.gov>
To manage subscription options or unsubscribe:
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov<mailto:jhammond at alcf.anl.gov> / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
Tim Stitt PhD (User Support Manager).
Center for Research Computing | University of Notre Dame |
P.O. Box 539, Notre Dame, IN 46556 | Phone:  574-631-5287 | Email: tstitt at nd.edu<mailto:tstitt at nd.edu>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120530/69224d2b/attachment.html>
