[mpich-discuss] Poor scaling of MPI_WIN_CREATE?
    Jed Brown
    jedbrown at mcs.anl.gov
    Wed May 30 10:36:17 CDT 2012
On Wed, May 30, 2012 at 10:29 AM, Timothy Stitt <Timothy.Stitt.9 at nd.edu>wrote:
> Hi all,
> I am currently trying to improve the scaling of a CFD code on some Cray
> machines at NERSC (I believe Cray systems leverage mpich2 for their MPI
> communications, hence the posting to this list) and I am running into some
> scalability issues with the MPI_WIN_CREATE() routine.
> To cut a long story short, the CFD code requires each process to receive
> values from some neighborhood processes. Unfortunately, each process
> doesn't know who its neighbors should be in advance.
How often do the neighbors change? By what mechanism?
> To overcome this we exploit the one-sided MPI_PUT() routine to communicate
> data from neighbors directly.
> Recent profiling at 256, 512 and 1024 processes shows that the
> MPI_WIN_CREATE routine is starting to dominate the walltime and reduce our
> scalability quite rapidly. For instance the %walltime for MPI_WIN_CREATE
> over various process sizes increases as follows:
> 256 cores - 4.0%
> 512 cores - 9.8%
> 1024 cores - 24.3%
The current implementation of MPI_Win_create uses an Allgather which is
synchronizing and relatively expensive.
> I was wondering if anyone in the MPICH2 community had any advice on how
> one can improve the performance of MPI_WIN_CREATE? Or maybe someone has a
> better strategy for communicating the data that bypasses the (poorly
> scaling?) MPI_WIN_CREATE routine.
> Thanks in advance for any help you can provide.
> Regards,
> Tim.
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120530/856e45a7/attachment.html>
