[mpich-discuss] mpich-discuss Digest, Vol 44, Issue 36
    Rajeev Thakur
    thakur at mcs.anl.gov
    Fri May 25 12:39:44 CDT 2012
Albert,
           The sendbuf can be passed as MPI_IN_PLACE only on the root. On other ranks, the real buffer must be passed as the sendbuf (the recvbuf is ignored).
Rajeev
On May 25, 2012, at 8:21 AM, Albert Spade wrote:
> Thanks Rajeev and Darius,
> I tried to use MPI_IN_PLACE but not getting the desired results. Can you please tell me how to make it working.
> This is the previous code :
>          //MPI::COMM_WORLD.Gatherv((const void*)(Data+StartFrom[nStages-1][rank]), Count[rank], MPI::CHAR, (void*)(Data), Count, Displ, MPI::CHAR, 0);
> And this is how I changed it.
>  MPI::COMM_WORLD.Gatherv(MPI_IN_PLACE, Count[rank], MPI::CHAR, (void*)(Data), Count, Displ, MPI::CHAR, 0);
> Am I doing it wrong?
> Thanks.
> My output after making above changes.
> [root at beowulf programs]# mpiexec -n 1 ./output
> Time taken for 16 elements using 1 processors = 2.81334e-05 seconds
> [root at beowulf programs]# mpiexec -n 2 ./output
> Fatal error in PMPI_Gatherv: Invalid buffer pointer, error stack:
> PMPI_Gatherv(398): MPI_Gatherv failed(sbuf=MPI_IN_PLACE, scount=64, MPI_CHAR, rbuf=0x879d500, rcnts=0x879d6b8, displs=0x879d6c8, MPI_CHAR, root=0, MPI_COMM_WORLD) failed
> PMPI_Gatherv(335): sendbuf cannot be MPI_IN_PLACE
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   EXIT CODE: 256
> =   CLEANING UP REMAINING PROCESSES
> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> *** glibc detected *** mpiexec: double free or corruption (fasttop): 0x094fb038 ***
> ======= Backtrace: =========
> /lib/libc.so.6[0x7d4a31]
> mpiexec[0x8077b11]
> mpiexec[0x8053c7f]
> mpiexec[0x8053e73]
> mpiexec[0x805592a]
> mpiexec[0x8077186]
> mpiexec[0x807639e]
> mpiexec[0x80518f8]
> mpiexec[0x804ad65]
> /lib/libc.so.6(__libc_start_main+0xe6)[0x77cce6]
> mpiexec[0x804a061]
> ======= Memory map: ========
> 00547000-00548000 r-xp 00000000 00:00 0          [vdso]
> 0054b000-0068f000 r-xp 00000000 fd:00 939775     /usr/lib/libxml2.so.2.7.6
> 0068f000-00694000 rw-p 00143000 fd:00 939775     /usr/lib/libxml2.so.2.7.6
> 00694000-00695000 rw-p 00000000 00:00 0
> 00740000-0075e000 r-xp 00000000 fd:00 2105890    /lib/ld-2.12.so
> 0075e000-0075f000 r--p 0001d000 fd:00 2105890    /lib/ld-2.12.so
> 0075f000-00760000 rw-p 0001e000 fd:00 2105890    /lib/ld-2.12.so
> 00766000-008ef000 r-xp 00000000 fd:00 2105891    /lib/libc-2.12.so
> 008ef000-008f0000 ---p 00189000 fd:00 2105891    /lib/libc-2.12.so
> 008f0000-008f2000 r--p 00189000 fd:00 2105891    /lib/libc-2.12.so
> 008f2000-008f3000 rw-p 0018b000 fd:00 2105891    /lib/libc-2.12.so
> 008f3000-008f6000 rw-p 00000000 00:00 0
> 008f8000-008fb000 r-xp 00000000 fd:00 2105893    /lib/libdl-2.12.so
> 008fb000-008fc000 r--p 00002000 fd:00 2105893    /lib/libdl-2.12.so
> 008fc000-008fd000 rw-p 00003000 fd:00 2105893    /lib/libdl-2.12.so
> 008ff000-00916000 r-xp 00000000 fd:00 2105900    /lib/libpthread-2.12.so
> 00916000-00917000 r--p 00016000 fd:00 2105900    /lib/libpthread-2.12.so
> 00917000-00918000 rw-p 00017000 fd:00 2105900    /lib/libpthread-2.12.so
> 00918000-0091a000 rw-p 00000000 00:00 0
> 0091c000-0092e000 r-xp 00000000 fd:00 2105904    /lib/libz.so.1.2.3
> 0092e000-0092f000 r--p 00011000 fd:00 2105904    /lib/libz.so.1.2.3
> 0092f000-00930000 rw-p 00012000 fd:00 2105904    /lib/libz.so.1.2.3
> 00932000-0095a000 r-xp 00000000 fd:00 2098429    /lib/libm-2.12.so
> 0095a000-0095b000 r--p 00027000 fd:00 2098429    /lib/libm-2.12.so
> 0095b000-0095c000 rw-p 00028000 fd:00 2098429    /lib/libm-2.12.so
> 00bb0000-00bcd000 r-xp 00000000 fd:00 2105914    /lib/libgcc_s-4.4.6-20110824.so.1
> 00bcd000-00bce000 rw-p 0001d000 fd:00 2105914    /lib/libgcc_s-4.4.6-20110824.so.1
> 00c18000-00c24000 r-xp 00000000 fd:00 2098123    /lib/libnss_files-2.12.so
> 00c24000-00c25000 r--p 0000b000 fd:00 2098123    /lib/libnss_files-2.12.so
> 00c25000-00c26000 rw-p 0000c000 fd:00 2098123    /lib/libnss_files-2.12.so
> 00ce9000-00d00000 r-xp 00000000 fd:00 2105929    /lib/libnsl-2.12.so
> 00d00000-00d01000 r--p 00016000 fd:00 2105929    /lib/libnsl-2.12.so
> 00d01000-00d02000 rw-p 00017000 fd:00 2105929    /lib/libnsl-2.12.so
> 00d02000-00d04000 rw-p 00000000 00:00 0
> 08048000-080a0000 r-xp 00000000 fd:00 656990     /opt/mpich2-1.4.1p1/bin/bin/mpiexec.hydra
> 080a0000-080a1000 rw-p 00058000 fd:00 656990     /opt/mpich2-1.4.1p1/bin/bin/mpiexec.hydra
> 080a1000-080a3000 rw-p 00000000 00:00 0
> 094ee000-0950f000 rw-p 00000000 00:00 0          [heap]
> b7893000-b7896000 rw-p 00000000 00:00 0
> b78a4000-b78a7000 rw-p 00000000 00:00 0
> bff80000-bff95000 rw-p 00000000 00:00 0          [stack]
> Aborted (core dumped)
> On Tue, May 22, 2012 at 10:30 PM, <mpich-discuss-request at mcs.anl.gov> wrote:
> Send mpich-discuss mailing list submissions to
>        mpich-discuss at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
>        https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        mpich-discuss-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of mpich-discuss digest..."
> Today's Topics:
>   1.  Unable to run program parallely on cluster... Its running
>      properly on single machine... (Albert Spade)
>   2.  Not able to run program parallely on cluster... (Albert Spade)
>   3. Re:  Unable to run program parallely on cluster...        Its
>      running properly on single machine... (Darius Buntinas)
>   4. Re:  Not able to run program parallely on cluster...
>      (Rajeev Thakur)
>   5.  replication of mpi applications (Thomas Ropars)
> Message: 1
> Date: Tue, 22 May 2012 00:12:24 +0530
> From: Albert Spade <albert.spade at gmail.com>
> To: mpich-discuss at mcs.anl.gov
> Subject: [mpich-discuss] Unable to run program parallely on cluster...
>        Its running properly on single machine...
> Message-ID:
>        <CAP2uaQopgOwaFNfCF49gcnW9REw8CQtWGMgf0U8RyNYStTFw1A at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi everybody,
> I am using mpich2-1.4.1p1 and mpiexec from hydra-1.5b1
> I have a cluster of 5 machines.
> When I am trying to run the program for parallel fast fourier transform on
> single machine it runs correctly but on a cluster it gives error.
> Can you please tell me why its happening.
> Thanks.
> Here is my sample output:
> [root at beowulf programs]# mpiexec -n 1 ./Radix2
> Time taken for 16 elements using 1 processors = 2.7895e-05 seconds
> [root at beowulf programs]# mpiexec -n 4 ./Radix2
> [mpiexec at beowulf.master] control_cb (./pm/pmiserv/pmiserv_cb.c:197): assert
> (!closed) failed
> [mpiexec at beowulf.master] HYDT_dmxu_poll_wait_for_event
> (./tools/demux/demux_poll.c:77): callback returned error status
> [mpiexec at beowulf.master] HYD_pmci_wait_for_completion
> (./pm/pmiserv/pmiserv_pmci.c:205): error waiting for event
> [mpiexec at beowulf.master] main (./ui/mpich/mpiexec.c:437): process manager
> error waiting for completion
> [root at beowulf programs]# mpiexec -n 2 ./Radix2
> (!closed) failed
> (!closed) failed
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120522/25975b06/attachment-0001.html>
> Message: 2
> Date: Tue, 22 May 2012 00:59:27 +0530
> Subject: [mpich-discuss] Not able to run program parallely on
>        cluster...
> Message-ID:
>        <CAP2uaQpiMV0yqHsHfsWpgAQ=_K3M_ZGxsCm-S5BPvzbxH+Z9zQ at mail.gmail.com>
> This is my new error after making few changes...
> Results are quite similar... No succes with cluster...
> Sample run
> [root at beowulf testing]# mpiexec -n 1 ./Radix
> Time taken for 16 elements using 1 processors = 4.72069e-05 seconds
> [root at beowulf testing]# mpiexec -n 2 ./Radix
> Fatal error in PMPI_Gatherv: Internal MPI error!, error stack:
> PMPI_Gatherv(398).....: MPI_Gatherv failed(sbuf=0x97d0500, scount=64,
> MPI_CHAR, rbuf=0x97d0500, rcnts=0x97d06b8, displs=0x97d06c8, MPI_CHAR,
> MPIR_Gatherv_impl(210):
> MPIR_Gatherv(104).....:
> MPIR_Localcopy(357)...: memcpy arguments alias each other, dst=0x97d0500
> src=0x97d0500 len=64
> =   EXIT CODE: 256
> [proxy:0:1 at beowulf.node1] HYD_pmcd_pmip_control_cmd_cb
> (./pm/pmiserv/pmip_cb.c:927): assert (!closed) failed
> [proxy:0:1 at beowulf.node1] HYDT_dmxu_poll_wait_for_event
> [proxy:0:1 at beowulf.node1] main (./pm/pmiserv/pmip.c:221): demux engine
> [mpiexec at beowulf.master] HYDT_bscu_wait_for_completion
> (./tools/bootstrap/utils/bscu_wait.c:77): one of the processes terminated
> badly; aborting
> [mpiexec at beowulf.master] HYDT_bsci_wait_for_completion
> (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for
> completion
> (./pm/pmiserv/pmiserv_pmci.c:225): launcher returned error waiting for
> completion
> URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120522/7b1db8c0/attachment-0001.html>
> Message: 3
> Date: Tue, 22 May 2012 03:36:44 +0800
> From: Darius Buntinas <buntinas at mcs.anl.gov>
> Subject: Re: [mpich-discuss] Unable to run program parallely on
>        cluster...      Its running properly on single machine...
> Message-ID: <B411B6C1-CB5A-4A1C-AEBB-71680C9AF8C5 at mcs.anl.gov>
> Content-Type: text/plain; charset=us-ascii
> It may be that one of your processes is failing, but also check to make sure every process is calling MPI_Finalize before exiting.
> -d
> On May 22, 2012, at 2:42 AM, Albert Spade wrote:
> > Hi everybody,
> > When I am trying to run the program for parallel fast fourier transform on single machine it runs correctly but on a cluster it gives error.
> > Thanks.
> > [mpiexec at beowulf.master] control_cb (./pm/pmiserv/pmiserv_cb.c:197): assert (!closed) failed
> > [mpiexec at beowulf.master] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
> > [mpiexec at beowulf.master] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:205): error waiting for event
> > [mpiexec at beowulf.master] main (./ui/mpich/mpiexec.c:437): process manager error waiting for completion
> > _______________________________________________
> > mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> Message: 4
> Date: Mon, 21 May 2012 20:14:35 -0500
> From: Rajeev Thakur <thakur at mcs.anl.gov>
> Subject: Re: [mpich-discuss] Not able to run program parallely on
>        cluster...
> Message-ID: <8C80534E-3611-40D7-BBAF-F66110D25EE1 at mcs.anl.gov>
> You are passing the same buffer as the sendbuf and recvbuf to MPI_Gatherv, which is not allowed in MPI. Use MPI_IN_PLACE as described in the standard.
> > Sample run
> > PMPI_Gatherv(398).....: MPI_Gatherv failed(sbuf=0x97d0500, scount=64, MPI_CHAR, rbuf=0x97d0500, rcnts=0x97d06b8, displs=0x97d06c8, MPI_CHAR, root=0, MPI_COMM_WORLD) failed
> > MPIR_Localcopy(357)...: memcpy arguments alias each other, dst=0x97d0500 src=0x97d0500 len=64
> > =   EXIT CODE: 256
> > [proxy:0:1 at beowulf.node1] HYD_pmcd_pmip_control_cmd_cb (./pm/pmiserv/pmip_cb.c:927): assert (!closed) failed
> > [proxy:0:1 at beowulf.node1] HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback returned error status
> > [proxy:0:1 at beowulf.node1] main (./pm/pmiserv/pmip.c:221): demux engine error waiting for event
> > [mpiexec at beowulf.master] HYDT_bscu_wait_for_completion (./tools/bootstrap/utils/bscu_wait.c:77): one of the processes terminated badly; aborting
> > [mpiexec at beowulf.master] HYDT_bsci_wait_for_completion (./tools/bootstrap/src/bsci_wait.c:23): launcher returned error waiting for completion
> > [mpiexec at beowulf.master] HYD_pmci_wait_for_completion (./pm/pmiserv/pmiserv_pmci.c:225): launcher returned error waiting for completion
> Message: 5
> Date: Tue, 22 May 2012 17:21:09 +0200
> From: Thomas Ropars <thomas.ropars at epfl.ch>
> Subject: [mpich-discuss] replication of mpi applications
> Message-ID: <4FBBAEE5.5070000 at epfl.ch>
> Content-Type: text/plain; charset=UTF-8; format=flowed
> Dear all,
> We are starting studying replication for MPI applications. A few papers
> have been published in the last months on this topic.
> We were wondering if anybody has already started working on providing
> process replication in MPICH ? And if yes, is there some code available ?
> Best regards,
> Thomas Ropars
> End of mpich-discuss Digest, Vol 44, Issue 36
