[mpich-discuss] Hydra process affinity
Martin Cuma martin.cuma at utah.edu
Fri May 25 09:10:03 CDT 2012
Hi Guillaume,
sure, I agree that the meaing may be different, though I would encourage
MPICH2 and OpenMPI to coordinate in matters like this. Furthermore, I
would argue that the point of binding to socket is to then launch multiple
threads on that socket from the MPI process it's on, so, spanning multiple
cores on that socket is desireable. If you want to bind the process to a
single core, then use the -binding cpu:cores instead.
Perhaps the thinking was to use the cpu:sockets to round-robin between the
sockets while cpu:cores would distribute the processes consecutively?
That's fine, but in that case it would still be useful to have another
option to allow processes to bind to multiple cores.
I have thought that -binding cache:l3 would do that, i.e. pick all the
cores on the socket, as they share the L3. However, that is not the case:
/uufs/chpc.utah.edu/sys/pkg/mpich2/1.5b1/bin/mpirun -binding cache:l3 -np
2 /uufs/chpc.utah.edu/sys/pkg/hwloc/1.4.2/bin/hwloc-bind --get
0x00000002
0x00000001
It seems to me that you basically don't consider the possibility of the
single process to run more than one thread when binding is in place. While
this is useful for single-threaded processes, it's not good for
multi-threading.
MC
On Fri, 25 May 2012, Guillaume Mercier wrote:
> Hello,
> Pavan will probably confirm this point, but my guess is that the meaning of
> "binding to sockets"
> differs from one implementation to the other.
> If you take a look at the Hydra documentation, you will see that the
> behaviour you're experiencing
> seems to be correct.  But I agree that it's not the one you want, though.
> Regards
> Guillaume
> On 05/25/2012 01:14 AM, Martin Cuma wrote:
>>  Hello,
>>  I am trying to get consistent performance on dual socket multi-core nodes
>>  which requires process binding to the socket. The core generally runs one
>>  process per socket and launches multiple OpenMP threads to fill up the
>>  socket's cores.
>>  I find a problem with the -binding cpu:sockets in the Hydra's mpirun
>>  implementation - it binds the process to the first core on the socket,
>>  rather than having it access all the socket's cores.
>>  For example, on a dual socket, 6 core CPU (12 cores total) node, I get:
>>  /uufs/chpc.utah.edu/sys/pkg/mpich2/1.5b1/bin/mpirun -binding cpu:sockets
>>  -np 2 /uufs/chpc.utah.edu/sys/pkg/hwloc/1.4.2/bin/hwloc-bind --get
>>  0x00000001
>>  0x00000002
>>  /uufs/chpc.utah.edu/sys/pkg/hwloc/1.4.2/bin/hwloc-calc -p --hierarchical
>>  socket.core 0x00000001
>>  Socket:0.Core:0
>>  socket.core 0x00000002
>>  Socket:1.Core:0
>>  I am using hwloc to report the binding and then calculating the "physical"
>>  location. Notice that only single core is reported for each socket, rather
>>  than reporting all 6 cores. This is verified by running with 6 OpenMP
>>  threads per process and getting only 100% CPU load, rather than 600%.
>>  Now, OpenMPI 1.6.1a1 (just added in today) is doing the affinity right as:
>>  /uufs/ember.arches/sys/pkg/openmpi/1.6.1a1i/bin/mpirun --bysocket
>>  --bind-to-socket -np 2
>>  0x00aaaaaa
>>  0x00555555
>>  socket.core 0x00aaaaaa
>> Socket: 1.Core:0 Socket:1.Core:1 Socket:1.Core:2 Socket:1.Core:8 1.Core:9
>> Socket: Socket:1.Core:10
>>  socket.core 0x00555555
>> Socket: 0.Core:0 Socket:0.Core:1 Socket:0.Core:2 Socket:0.Core:8 0.Core:9
>> Socket: Socket:0.Core:10
>>  I have a suspicion that other binding options may be broken as well, for
>>  example, I was trying to run -binding cache:l3, which should have the same
>>  efect as cpu:sockets on this machine, and it only ran on one core as well
>>  (100% load).
>>  I would appreciate if someone could comment on this and if this is a bug,
>>  I'd be happy to work with the developers to get this fixed. This shows up
>>  both in 1.4.1p1 and 1.5b1.
>>  Thanks,
>>  MC
Martin Cuma
Center for High Performance Computing
University of Utah
