[mpich-discuss] Fail to make install MPICH2
    羅羽蓉
    lo60025 at gmail.com
    Wed May 16 05:01:36 CDT 2012
Sorry for bothering you.
I encountered some problems during makeing install MPICH2.
The error massage is "/usr/bin/install: `lib/libmpich.a' and
`/home/linda/mpich2-install/lib/libmpich.a' are the same file"
I've attached the error massage file.
Thanks.
Best Regards,
Linda Lo
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120516/73f71eaa/attachment.htm>
if [ ! -d /home/linda/mpich2-install ] ; then mkdir -p /home/linda/mpich2-install ; fi
if [ ! -d /home/linda/mpich2-install/share ] ; then mkdir -p /home/linda/mpich2-install/share ; fi
if [ ! -d /home/linda/mpich2-install/share/doc/ ] ; then mkdir -p /home/linda/mpich2-install/share/doc/ ; fi
if [ ! -d /home/linda/mpich2-install/share/man ] ; then mkdir -p /home/linda/mpich2-install/share/man ; fi
if [ ! -d /home/linda/mpich2-install/include ] ; then mkdir -p /home/linda/mpich2-install/include ; fi
if [ ! -d /home/linda/mpich2-install/lib ] ; then mkdir -p /home/linda/mpich2-install/lib ; fi
make install-local
make[1]: Entering directory `/home/linda/mpich2-install'
if [ "no" = "yes" ] ; then \
	    /usr/bin/install -c -m 644 src/mpi/debugger/libtvmpich2.so \
			/home/linda/mpich2-install/lib/libtvmpich2.so ; fi
if [ -n "" ] ; then \
	    for pm in  /dev/null ; do \
		if [ -d src/pm/$pm ] ; then \
		     (cd src/pm/$pm && \
		make DESTDIR= prefix=/home/linda/mpich2-install bindir=/home/linda/mpich2-install/bin install-alt ) ; \
		fi ; \
	    done ; \
	fi
make[1]: Leaving directory `/home/linda/mpich2-install'
/usr/bin/install -c -m 644  src/include/mpi.h /home/linda/mpich2-install/include/mpi.h
/usr/bin/install -c -m 644  /home/linda/library/mpich2-1.4.1p1/src/include/mpix.h /home/linda/mpich2-install/include/mpix.h
/usr/bin/install -c -m 644  lib/libmpich.a /home/linda/mpich2-install/lib/libmpich.a
/usr/bin/install: `lib/libmpich.a' and `/home/linda/mpich2-install/lib/libmpich.a' are the same file
make: *** [install] Error 1
