[mpich-discuss] Faster MPI_Attr_get?
Jeff Hammond
jhammond at alcf.anl.gov
Fri May 11 16:20:52 CDT 2012
> I benchmarked an example using the PETSc ThreadComm. For a micro-benchmark
> that doesn't use pthreads, I would just call MPI_Attr_get() in a loop. I can
> prepare that if you like.
that's probably greatly underestimating the cost of this function
since i assume in this test every time the function is called, both
the dcache and icache hit every time.
>> Also, please send me the configure options that you are using for your
>> MPICH2 under petsc. The absolute performance is going to vary substantially
>> depending on whether error checking is enabled and your choice of a few
>> other options.
> I tested these two configurations, what do you suggest I use if I want that
> function to be fast?
> MPICH2 Version: 1.4
> MPICH2 Release date: Thu Jun 16 16:41:08 CDT 2011
> MPICH2 Device: ch3:nemesis
> MPICH2 configure: --prefix=/opt/mpich2 --enable-shared
> --enable-sharedlibs=gcc --enable-error-checking=runtime
> --enable-error-messages=all --enable-timer-type=clock_gettime
> --with-python=python2
> MPICH2 CC: gcc -march=native -O1 -pipe -O2
> MPICH2 CXX: c++ -march=native -O1 -pipe -O2
> MPICH2 F77: gfortran -O2
> MPICH2 FC: gfortran -O2
Is "-O2" a suboption to "-pipe" or are you giving the compiler
conflicting flags?
> MPICH2 Version: 1.5b1
> MPICH2 Release date: unreleased development copy
> MPICH2 configure: --prefix=/homes/jedbrown/usr/mpich-intel --enable-shared
> --enable-error-checking=runtime --enable-error-messages=all
> --enable-timer-type=clock_gettime CC=icc CXX=icpc --enable-fc=0
> --enable-f77=0 FC= F77=
> MPICH2 CC: icc -O2
> MPICH2 CXX: icpc -O2
> MPICH2 FC: gfortran
"--enable-error-checking=runtime --enable-error-messages=all" would
seem to be the kind of thing Dave is talking about that affect
performance.
Jeff
Jeff Hammond
Argonne Leadership Computing Facility
University of Chicago Computation Institute
jhammond at alcf.anl.gov / (630) 252-5381
http://www.linkedin.com/in/jeffhammond
https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond (in-progress)
https://wiki.alcf.anl.gov/old/index.php/User:Jhammond (deprecated)
https://wiki-old.alcf.anl.gov/index.php/User:Jhammond(deprecated)
