[mpich-discuss] MPICH2 Errors running MCNPX-SMPDU connectfailed?
Abrego, Celestino
Celestino.Abrego at parsons.com
Tue May 8 10:33:37 CDT 2012
Thanks for the tip but -v does not come up as an option for mpiexec. Do
you think the testcpi is not running correctly? When it executes my cpu
usage goes up to around 80% which is exactly where it should be.
C:\Documents and Settings\p0038192>"c:\Program
files\MPICH2\bin\mpiexec.exe" -help2
All options to mpiexec:
-n x
-np x
launch x processes
-localonly x
-n x -localonly
launch x processes on the local machine
-machinefile filename
use a file to list the names of machines to launch on
-host hostname
-hosts n host1 host2 ... hostn
-hosts n host1 m1 host2 m2 ... hostn mn
launch on the specified hosts
In the second version the number of processes = m1 + m2 + ... + mn
-binding proc_binding_scheme
Set the proc binding for each of the launched processes to a single
core.
Currently "auto" and "user" are supported as the proc_binding_schemes
-map drive:\\host\share
map a drive on all the nodes
this mapping will be removed when the processes exit
-mapall
map all of the current network drives
(Available currently only on windows)
-dir drive:\my\working\directory
-wdir /my/working/directory
launch processes in the specified directory
-env var val
set environment variable before launching the processes
-logon
prompt for user account and password
-pwdfile filename
read the account and password from the file specified
put the account on the first line and the password on the second
-nompi
launch processes without the mpi startup mechanism
-nopopup_debug
disable the system popup dialog if the process crashes
-exitcodes
print the process exit codes when each process exits.
-noprompt
prevent mpiexec from prompting for user credentials.
-priority class[:level]
set the process startup priority class and optionally level.
class = 0,1,2,3,4 = idle, below, normal, above, high
level = 0,1,2,3,4,5 = idle, lowest, below, normal, above, highest
the default is -priority 1:3
-localroot
launch the root process directly from mpiexec if the host is local.
(This allows the root process to create windows and be debugged.)
-port port
-p port
specify the port that smpd is listening on.
-phrase passphrase
specify the passphrase to authenticate connections to smpd with.
-smpdfile filename
specify the file where the smpd options are stored including the
passphrase.
-path search_path
search path for executable, ; separated
-register [-user n]
encrypt a user name and password to the Windows registry.
optionally specify a user slot index
-remove [-user n]
delete the encrypted credentials from the Windows registry.
If no user index is specified then all entries are removed.
-validate [-user n] [-host hostname]
validate the encrypted credentials for the current or specified host.
A specific user index can be specified otherwise index 0 is the
default.
-user n
use the registered user credentials from slot n to launch the job.
-timeout seconds
timeout for the job.
-plaintext
don't encrypt the data on the wire.
-delegate
use passwordless delegation to launch processes
-impersonate
use passwordless authentication to launch processes
-add_job <job_name> <domain\user>
-add_job <job_name> <domain\user> -host <hostname>
add a job key for the specified domain user on the local or specified
host
requires administrator privileges
-remove_job <name>
-remove_job <name> -host <hostname>
remove a job key from the local or specified host
-associate_job <name>
-associate_job <name> -host <hostname>
associate the current user's token with the specified job on the local
or spec
ified host
-job <name>
launch the processes in the context of the specified job
-whomai
print the current user name
-l
prefix output with the process number. (This option is a lowercase L
not the n
umber one)
Celestino Abrego
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Ju JiaJia
Sent: Monday, May 07, 2012 8:31 PM
Subject: Re: [mpich-discuss] MPICH2 Errors running MCNPX-SMPDU
connectfailed?
mpiexec has an option -verbose, abbr -v. You can see it with mpiexec
-help2.
I'm using linux, it should be the same on windows.
On Tue, May 8, 2012 at 8:59 AM, Abrego, Celestino
<Celestino.Abrego at parsons.com> wrote:
Thanks for the info. What do you mean by run with -v? It does not
appear to be an option for either cpi or mpiexe.
Celestino Abrego
Sent: Monday, May 07, 2012 7:00 PM
connectfailed?
I don't think your testcpi is giving the right answer. there should be
20 processes running and process info should be printed, something like
this:
Process 0 of 1 is on m1.
Please run with -v to get more informations.
On Tue, May 8, 2012 at 5:53 AM, Jayesh Krishna <jayesh at mcs.anl.gov>
wrote:
You might also want to check with the mcnpx developers if they have
seen the error message (You should mention that you can run cpi.exe with
the same command).
Jayesh
----- Original Message -----
From: "Celestino Abrego" <Celestino.Abrego at parsons.com>
Sent: Monday, May 7, 2012 4:40:11 PM
Subject: Re: [mpich-discuss] MPICH2 Errors running MCNPX-SMPDU connect
failed?
Jayesh
-It is a 32 bit Windows XP Pro system and I am only trying to run on the
local system.
-I read through the manual and found that MPICH2 only uses TCP protocols
so I briefly allowed all TCP ports and IP addresses. But I still had the
same errors when I executed MCNPX.
-CPI and MCNPX have the same privileges, except I could not modify
MCNPX's by click on the check boxes- they were grayed out. But the same
boxes were checked for each group or user name. At minimum all users
could read & execute applications.
-My firewall only allows me to make exceptions for particular protocols
like TCP, UDP, etc., so I could not explicitly allow MCNPX exe file
through firewall.
Just to give you a bit more information in the hopes that it may trigger
new ideas:
-Desktop computer is setup with to be on a the parsons.com
<http://parsons.com/> Domain but is
not actively on the "Parsons" network (since I work remotely). I
mention this because the error I receive is "PMI_ConnectToHost failed:
unable to post a connect to PBRFPNM1.Parsons.com
<http://pbrfpnm1.parsons.com/> "
-Computer receives internet connection from a router with its own
firewall that I have assumed does not affect what I am doing.
-I am getting a new firewall program tomorrow!
Anything else I should try?
Celestino Abrego
-----Original Message-----
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
Sent: Monday, May 07, 2012 1:58 PM
To: Abrego, Celestino
Cc: mpich-discuss at mcs.anl.gov
failed?
# Is your machine 32-bit or 64-bit (You seem to be running a 32-bit
version of mcnp)?
# Try adding an exception for the executable
(C:\MCNP\mcnp5\bin\MCNPX27mpi_Win32.exe) in your firewall.
# Do the executables "C:\Documents and
Settings\p0038192\Desktop\Testcpi" and
"C:\MCNP\mcnp5\bin\MCNPX27mpi_Win32.exe" have different privileges?
# For more information on how MPICH2 can work with firewalls see Section
9.5 of the Windows developer's guide
(http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php
?s=docs).
Jayesh
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>, mpich-discuss at mcs.anl.gov
Sent: Monday, May 7, 2012 12:05:04 PM
Subject: RE: [mpich-discuss] MPICH2 Errors running MCNPX-SMPDU connect
failed?
I have not been able to disable firewalls yet but here are the results
of your other requests. Commands give similar results. What exactly
needs to go through the firewalls? I can add exceptions and modify
both of the firewalls. I just have not figured out how to temporarily
disable them for testings. I have request with our IT department for
that. Any other ideas? Thanks for the fast response!!!
c:\mcnp\mcnp5\bin>TestMCNPXrunMPI_27
c:\mcnp\mcnp5\bin>rem ++++++Validates MPICH2 USERNAME AND PW
registration+++++++
c:\mcnp\mcnp5\bin>"C:\Program Files\MPICH2\bin\mpiexec.exe" -validate
SUCCESS
c:\mcnp\mcnp5\bin>rem +++++Renamed MPICH2 example Cpi and moved to
Desktop for T
esting++++++
c:\mcnp\mcnp5\bin>"C:\Program Files\MPICH2\bin\mpiexec.exe" -hosts 1
192.168.1.3
20 C:\Documents and Settings\p0038192\Desktop\Testcpi Enter the number
of intervals: (0 quits) 10000000000000000000000000000000 pi is
approximately -0.0000000000000000, Error is 3.1415926535897931 wall
clock time = 0.000069 Enter the number of intervals: (0 quits) 0
c:\mcnp\mcnp5\bin>rem ++++++++Test MCNP Run with HOST name using MCNPX
Win32_MPI
192.168.1.3
2 C:\MCNP\mcnp5\bin\MCNPX27mpi_Win32.exe i=beam0 [01:396]..ERROR:Error
creating a socket, A system call that should never fail ha s failed.
(10107) [01:396]..ERROR:Error creating a socket SMPDU_Sock_post_connect
failed.
[1] PMI_ConnectToHost failed: unable to post a connect to
PBRFPNM1.Parsons.com <http://pbrfpnm1.parsons.com/> 1
92.168.1.3 192.168.79.1 192.168.102.1 :4345, error: Unknown error class,
error s
tack:
(unknown)(): Invalid buffer pointer
uPMI_ConnectToHost returning PMI_FAIL
[1] PMI_Init failed.
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(388):
MPID_Init(107).......: channel initialization failed
MPID_Init(367).......: PMI_Init returned -1 [01:7480]..ERROR:Error
creating a socket, A system call that should never fail h as failed.
(10107) [01:7480]..ERROR:Error creating a socket SMPDU_Sock_post_connect
failed.
[0] PMI_ConnectToHost failed: unable to post a connect to
92.168.1.3 192.168.79.1 192.168.102.1 :4352, error: Unknown error class,
error s
tack:
[0] PMI_Init failed.
c:\mcnp\mcnp5\bin>pause
Press any key to continue . . .
c:\mcnp\mcnp5\bin>^A
Celestino Abrego
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Monday, May 07, 2012 11:50 AM
Cc: Abrego, Celestino
failed?
Some suggestions,
# Make sure that any firewall running on the machine is turned off # In
the step where Testcpi is run (c:\mcnp\mcnp5\bin>"C:\Program
Files\MPICH2\bin\mpiexec.exe" -hosts 1 PBRFPNM1 20 C:\Documents and
Settings\p0038192\Desktop\Testcpi ), try specifying a "number of
intervals" other than 0 and see if it works.
# Try specifying the ipaddress of "PBRFPNM1" in the mpiexec command
(instead of "PBRFPNM1").
Let us know the results.
Jayesh
Sent: Monday, May 7, 2012 11:37:18 AM
Subject: [mpich-discuss] MPICH2 Errors running MCNPX-SMPDU connect
failed?
I am in the process of trying to run a version of software that has is
widely distributed and was compiled to be run with MPICH2. I have been
running around in circles trying to figure out why I am not having
success running the software with multiple processors and I though this
group might be able to help me. Below are the results of a series of
commands that I copied and pasted from the DOS window. Everything seems
to be working as expected until I try to execute the MCNPX software. CPI
examples ramps up to nearly 100% CPU usage.
I have tried uninstalling and reinstalling MPICH2, using an admin
command prompt. SMPD and MPIEXEC.exe have been added as exceptions
through the windows firewall although I am not sure how much windows is
actually blocking because my company uses Trend MICRO Officescan and it
has its own firewall. I have found that adding SMPD and MPIEXEC as
exceptions through the windows firewall does not have an effect on the
errors I am receiving. I am running low on ideas right now, and any
help?
Here are the results from the command prompt. Thanks in advanced!
________________________________________________________________________
_______
c:\mcnp\mcnp5\bin>testmcnpxrunmpi_27
registration+++++++
SUCCESS
Desktop for T
esting++++++
PBRFPNM1 20
Win32_MPI
PBRFPNM1 2
[01:7788]..ERROR:Error creating a socket, A system call that should
never fail h
as failed. (10107)
SMPDU_Sock_post_connect failed.
92.168.1.3 192.168.79.1 192.168.102.1 :3130, error: Unknown error class,
error s
tack:
[01:484]..ERROR:Error creating a socket, A system call that should never
fail ha
s failed. (10107)
92.168.1.3 192.168.79.1 192.168.102.1 :3137, error: Unknown error class,
error s
tack:
c:\mcnp\mcnp5\bin>path
PATH=C:\MCNP\mcnp5\bin;C:\Program Files\Common Files\Microsoft
Shared\Windows Li
ve;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\PROGRA~1\I
BM\CLIEN
T~1;C:\PROGRA~1\IBM\CLIENT~1\Shared;C:\PROGRA~1\IBM\CLIENT~1\Emulator;C:
\Program
Files\Common Files\Roxio
Shared\DLLShared\;C:\WINDOWS\system32\WindowsPowerShel
l\v1.0;C:\Program Files\Windows Imaging\;C:\MCNP\bin;C:\Program
Files\MATLAB\R20
10b\bin;c:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program
Files\Qu
ickTime\QTSystem\;C:\Program Files\7-Zip;C:\Program
Files\MPICH2\bin;C:\Program
Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files\7-Zip
c:\mcnp\mcnp5\bin>ipconfig
Windows IP Configuration
Ethernet adapter VMware Network Adapter VMnet8:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.102.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
Ethernet adapter VMware Network Adapter VMnet1:
IP Address. . . . . . . . . . . . : 192.168.79.1
Ethernet adapter Local Area Connection:
IP Address. . . . . . . . . . . . : 192.168.1.3
Default Gateway . . . . . . . . . : 192.168.1.1
Celestino Abrego
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120508/2e964bfa/attachment-0001.htm>
