[mpich-discuss] MPICH2 Errors running MCNPX-SMPDU connect	failed?
    Ju JiaJia
    jujj603 at gmail.com
    Mon May  7 19:00:09 CDT 2012
I don't think your testcpi is giving the right answer. there should be 20
processes running and process info should be printed, something like this:
Process 0 of 1 is on m1.
Please run with -v to get more informations.
On Tue, May 8, 2012 at 5:53 AM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
>  You might also want to check with the mcnpx developers if they have seen
> the error message (You should mention that you can run cpi.exe with the
> same command).
> Regards,
> Jayesh
> From: "Celestino Abrego" <Celestino.Abrego at parsons.com>
> To: mpich-discuss at mcs.anl.gov
>  Sent: Monday, May 7, 2012 4:40:11 PM
> Subject: Re: [mpich-discuss] MPICH2 Errors running MCNPX-SMPDU connect
>  failed?
> Jayesh
> -It is a 32 bit Windows XP Pro system and I am only trying to run on the
> local system.
> -I read through the manual and found that MPICH2 only uses TCP protocols
> so I briefly allowed all TCP ports and IP addresses. But I still had the
> same errors when I executed MCNPX.
> -CPI and MCNPX have the same privileges, except I could not modify
> MCNPX's by click on the check boxes- they were grayed out.  But the same
> boxes were checked for each group or user name.  At minimum all users
> could read & execute applications.
> -My firewall only allows me to make exceptions for particular protocols
> like TCP, UDP, etc., so I could not explicitly allow MCNPX exe file
> through firewall.
> Just to give you a bit more information in the hopes that it may trigger
> new ideas:
> -Desktop computer is setup with to be on a the parsons.com Domain but is
> not actively on the "Parsons" network (since I work remotely).  I
> mention this because the error I receive is "PMI_ConnectToHost failed:
> unable to post a connect to PBRFPNM1.Parsons.com<http://pbrfpnm1.parsons.com/>
> -Computer receives internet connection from a router with its own
> firewall that I have assumed does not affect what I am doing.
> -I am getting a new firewall program tomorrow!
> Anything else I should try?
> Celestino Abrego
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jayesh Krishna
> Sent: Monday, May 07, 2012 1:58 PM
> To: Abrego, Celestino
> Cc: mpich-discuss at mcs.anl.gov
> failed?
> Hi,
> # Is your machine 32-bit or 64-bit (You seem to be running a 32-bit
> version of mcnp)?
> # Try adding an exception for the executable
> (C:\MCNP\mcnp5\bin\MCNPX27mpi_Win32.exe) in your firewall.
> # Do the executables "C:\Documents and
> Settings\p0038192\Desktop\Testcpi" and
> "C:\MCNP\mcnp5\bin\MCNPX27mpi_Win32.exe" have different privileges?
> # For more information on how MPICH2 can work with firewalls see Section
> 9.5 of the Windows developer's guide
> (http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php
> ?s=docs).
> Regards,
> Jayesh
> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>, mpich-discuss at mcs.anl.gov
> Sent: Monday, May 7, 2012 12:05:04 PM
> Subject: RE: [mpich-discuss] MPICH2 Errors running MCNPX-SMPDU connect
> failed?
> I have not been able to disable firewalls yet but here are the results
> of your other requests.  Commands give similar results.  What exactly
> needs to go through the firewalls?  I can add exceptions and  modify
> both of the firewalls.  I just have not figured out how to temporarily
> disable them for testings.  I have request with our IT department for
> that.  Any other ideas?  Thanks for the fast response!!!
> c:\mcnp\mcnp5\bin>TestMCNPXrunMPI_27
> c:\mcnp\mcnp5\bin>rem ++++++Validates MPICH2 USERNAME AND PW
> registration+++++++
> c:\mcnp\mcnp5\bin>"C:\Program Files\MPICH2\bin\mpiexec.exe" -validate
> SUCCESS
> c:\mcnp\mcnp5\bin>rem +++++Renamed MPICH2 example Cpi and moved to
> Desktop for T
> esting++++++
> c:\mcnp\mcnp5\bin>"C:\Program Files\MPICH2\bin\mpiexec.exe" -hosts 1
> 192.168.1.3
>  20 C:\Documents and Settings\p0038192\Desktop\Testcpi Enter the number
> of intervals: (0 quits) 10000000000000000000000000000000 pi is
> approximately -0.0000000000000000, Error is 3.1415926535897931 wall
> clock time = 0.000069 Enter the number of intervals: (0 quits) 0
> c:\mcnp\mcnp5\bin>rem ++++++++Test MCNP Run with HOST name using MCNPX
> Win32_MPI
> 192.168.1.3
>  2 C:\MCNP\mcnp5\bin\MCNPX27mpi_Win32.exe i=beam0 [01:396]..ERROR:Error
> creating a socket, A system call that should never fail ha s failed.
> (10107) [01:396]..ERROR:Error creating a socket SMPDU_Sock_post_connect
> failed.
> [1] PMI_ConnectToHost failed: unable to post a connect to
> PBRFPNM1.Parsons.com <http://pbrfpnm1.parsons.com/> 1
> 92.168.1.3 192.168.79.1 192.168.102.1 :4345, error: Unknown error class,
> error s
> tack:
> (unknown)(): Invalid buffer pointer
> uPMI_ConnectToHost returning PMI_FAIL
> [1] PMI_Init failed.
> Fatal error in MPI_Init: Other MPI error, error stack:
> MPIR_Init_thread(388):
> MPID_Init(107).......: channel initialization failed
> MPID_Init(367).......: PMI_Init returned -1 [01:7480]..ERROR:Error
> creating a socket, A system call that should never fail h as failed.
> (10107) [01:7480]..ERROR:Error creating a socket SMPDU_Sock_post_connect
> failed.
> [0] PMI_ConnectToHost failed: unable to post a connect to
> 92.168.1.3 192.168.79.1 192.168.102.1 :4352, error: Unknown error class,
> error s
> tack:
> [0] PMI_Init failed.
> c:\mcnp\mcnp5\bin>pause
> Press any key to continue . . .
> c:\mcnp\mcnp5\bin>^A
> Celestino Abrego
> From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
> Sent: Monday, May 07, 2012 11:50 AM
> Cc: Abrego, Celestino
> failed?
> Hi,
>  Some suggestions,
> # Make sure that any firewall running on the machine is turned off # In
> the step where Testcpi is run (c:\mcnp\mcnp5\bin>"C:\Program
> Files\MPICH2\bin\mpiexec.exe" -hosts 1 PBRFPNM1 20 C:\Documents and
> Settings\p0038192\Desktop\Testcpi ), try specifying a "number of
> intervals" other than 0 and see if it works.
> # Try specifying the ipaddress of "PBRFPNM1" in the mpiexec command
> (instead of "PBRFPNM1").
>  Let us know the results.
> Regards,
> Jayesh
> Sent: Monday, May 7, 2012 11:37:18 AM
> Subject: [mpich-discuss] MPICH2 Errors running MCNPX-SMPDU connect
> failed?
> I am in the process of trying to run a version of software that has is
> widely distributed and was compiled to be run with MPICH2. I have been
> running around in circles trying to figure out why I am not having
> success running the software with multiple processors and I though this
> group might be able to help me. Below are the results of a series of
> commands that I copied and pasted from the DOS window. Everything seems
> to be working as expected until I try to execute the MCNPX software. CPI
> examples ramps up to nearly 100% CPU usage.
> I have tried uninstalling and reinstalling MPICH2, using an admin
> command prompt. SMPD and MPIEXEC.exe have been added as exceptions
> through the windows firewall although I am not sure how much windows is
> actually blocking because my company uses Trend MICRO Officescan and it
> has its own firewall. I have found that adding SMPD and MPIEXEC as
> exceptions through the windows firewall does not have an effect on the
> errors I am receiving. I am running low on ideas right now, and any
> help?
> Here are the results from the command prompt. Thanks in advanced!
> ________________________________________________________________________
> _______
> c:\mcnp\mcnp5\bin>testmcnpxrunmpi_27
> registration+++++++
> SUCCESS
> Desktop for T
> esting++++++
> PBRFPNM1 20
> Win32_MPI
> PBRFPNM1 2
> [01:7788]..ERROR:Error creating a socket, A system call that should
> never fail h
> as failed. (10107)
> SMPDU_Sock_post_connect failed.
> 92.168.1.3 192.168.79.1 192.168.102.1 :3130, error: Unknown error class,
> error s
> tack:
> [01:484]..ERROR:Error creating a socket, A system call that should never
> fail ha
> s failed. (10107)
> 92.168.1.3 192.168.79.1 192.168.102.1 :3137, error: Unknown error class,
> error s
> tack:
> c:\mcnp\mcnp5\bin>path
> PATH=C:\MCNP\mcnp5\bin;C:\Program Files\Common Files\Microsoft
> Shared\Windows Li
> ve;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\PROGRA~1\I
> BM\CLIEN
> T~1;C:\PROGRA~1\IBM\CLIENT~1\Shared;C:\PROGRA~1\IBM\CLIENT~1\Emulator;C:
> \Program
> Files\Common Files\Roxio
> Shared\DLLShared\;C:\WINDOWS\system32\WindowsPowerShel
> l\v1.0;C:\Program Files\Windows Imaging\;C:\MCNP\bin;C:\Program
> Files\MATLAB\R20
> 10b\bin;c:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program
> Files\Qu
> ickTime\QTSystem\;C:\Program Files\7-Zip;C:\Program
> Files\MPICH2\bin;C:\Program
> Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files\7-Zip
> c:\mcnp\mcnp5\bin>ipconfig
> Windows IP Configuration
> Ethernet adapter VMware Network Adapter VMnet8:
> Connection-specific DNS Suffix . :
> IP Address. . . . . . . . . . . . : 192.168.102.1
> Subnet Mask . . . . . . . . . . . : 255.255.255.0
> Default Gateway . . . . . . . . . :
> Ethernet adapter VMware Network Adapter VMnet1:
> IP Address. . . . . . . . . . . . : 192.168.79.1
> Ethernet adapter Local Area Connection:
> IP Address. . . . . . . . . . . . : 192.168.1.3
> Default Gateway . . . . . . . . . : 192.168.1.1
> Celestino Abrego
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120508/4823dd9b/attachment-0001.htm>
