[mpich-discuss] MPICH2 Errors running MCNPX-SMPDU connect failed?
Abrego, Celestino
Celestino.Abrego at parsons.com
Mon May 7 11:37:18 CDT 2012
I am in the process of trying to run a version of software that has is
widely distributed and was compiled to be run with MPICH2. I have been
running around in circles trying to figure out why I am not having
success running the software with multiple processors and I though this
group might be able to help me. Below are the results of a series of
commands that I copied and pasted from the DOS window. Everything seems
to be working as expected until I try to execute the MCNPX software.
CPI examples ramps up to nearly 100% CPU usage.
I have tried uninstalling and reinstalling MPICH2, using an admin
command prompt. SMPD and MPIEXEC.exe have been added as exceptions
through the windows firewall although I am not sure how much windows is
actually blocking because my company uses Trend MICRO Officescan and it
has its own firewall. I have found that adding SMPD and MPIEXEC as
exceptions through the windows firewall does not have an effect on the
errors I am receiving. I am running low on ideas right now, and any
help?
Here are the results from the command prompt. Thanks in advanced!
________________________________________________________________________
_______
c:\mcnp\mcnp5\bin>testmcnpxrunmpi_27
c:\mcnp\mcnp5\bin>rem ++++++Validates MPICH2 USERNAME AND PW
registration+++++++
c:\mcnp\mcnp5\bin>"C:\Program Files\MPICH2\bin\mpiexec.exe" -validate
SUCCESS
c:\mcnp\mcnp5\bin>rem +++++Renamed MPICH2 example Cpi and moved to
Desktop for T
esting++++++
c:\mcnp\mcnp5\bin>"C:\Program Files\MPICH2\bin\mpiexec.exe" -hosts 1
PBRFPNM1 20
C:\Documents and Settings\p0038192\Desktop\Testcpi
Enter the number of intervals: (0 quits) 0
c:\mcnp\mcnp5\bin>rem ++++++++Test MCNP Run with HOST name using MCNPX
Win32_MPI
PBRFPNM1 2
C:\MCNP\mcnp5\bin\MCNPX27mpi_Win32.exe i=beam0
[01:7788]..ERROR:Error creating a socket, A system call that should
never fail h
as failed. (10107)
SMPDU_Sock_post_connect failed.
[1] PMI_ConnectToHost failed: unable to post a connect to
PBRFPNM1.Parsons.com 1
92.168.1.3 192.168.79.1 192.168.102.1 :3130, error: Unknown error class,
error s
tack:
(unknown)(): Invalid buffer pointer
uPMI_ConnectToHost returning PMI_FAIL
[1] PMI_Init failed.
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(388):
MPID_Init(107).......: channel initialization failed
MPID_Init(367).......: PMI_Init returned -1
[01:484]..ERROR:Error creating a socket, A system call that should never
fail ha
s failed. (10107)
[0] PMI_ConnectToHost failed: unable to post a connect to
92.168.1.3 192.168.79.1 192.168.102.1 :3137, error: Unknown error class,
error s
tack:
[0] PMI_Init failed.
c:\mcnp\mcnp5\bin>pause
Press any key to continue . . .
c:\mcnp\mcnp5\bin>path
PATH=C:\MCNP\mcnp5\bin;C:\Program Files\Common Files\Microsoft
Shared\Windows Li
ve;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\PROGRA~1\I
BM\CLIEN
T~1;C:\PROGRA~1\IBM\CLIENT~1\Shared;C:\PROGRA~1\IBM\CLIENT~1\Emulator;C:
\Program
Files\Common Files\Roxio
Shared\DLLShared\;C:\WINDOWS\system32\WindowsPowerShel
l\v1.0;C:\Program Files\Windows Imaging\;C:\MCNP\bin;C:\Program
Files\MATLAB\R20
10b\bin;c:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program
Files\Qu
ickTime\QTSystem\;C:\Program Files\7-Zip;C:\Program
Files\MPICH2\bin;C:\Program
Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files\7-Zip
c:\mcnp\mcnp5\bin>ipconfig
Windows IP Configuration
Ethernet adapter VMware Network Adapter VMnet8:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.102.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
Ethernet adapter VMware Network Adapter VMnet1:
IP Address. . . . . . . . . . . . : 192.168.79.1
Ethernet adapter Local Area Connection:
IP Address. . . . . . . . . . . . : 192.168.1.3
Default Gateway . . . . . . . . . : 192.168.1.1
Celestino Abrego
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120507/f78fc20d/attachment-0001.htm>
