[mpich-discuss] Error in MPI_PROBE
Luiz Carlos da Costa Junior
lcjunior at ufrj.br
Fri May 4 09:39:36 CDT 2012
Hi all,
Recently, I implemented a very naive protocol to check for error messages
before actually receive the message. To accomplish this, I used the
MPI_PROBE function.
I have tested and run my program successfully several times, but I got the
following error:
1. Fatal error in MPI_Probe: Invalid communicator, error stack:
2. MPI_Probe(113): MPI_Probe(src=MPI_ANY_SOURCE, tag=MPI_ANY_TAG,
MPI_COMM_WORLD, status=0x8185c80) failed
3. MPI_Probe(85).: Invalid communicator
4. Fatal error in MPI_Send: Other MPI error, error stack:
5. MPI_Send(173)..............: MPI_Send(buf=0xffc98664, count=1,
MPI_INTEGER, dest=0, tag=97, MPI_COMM_WORLD) failed
6. MPID_nem_tcp_connpoll(1826): Communication error with rank 0:
Connection refused
7. Fatal error in MPI_Send: Other MPI error, error stack:
8. MPI_Send(173)..................: MPI_Send(buf=0xfff71364, count=1,
9. MPIDI_EagerContigShortSend(262): failure occurred while attempting to
send an eager message
10. MPIDI_CH3_iStartMsg(36)........: Communication error with rank 0
11. Fatal error in MPI_Send: Other MPI error, error stack:
12. MPI_Send(173)..............: MPI_Send(buf=0xfffc8964, count=1,
13. MPID_nem_tcp_connpoll(1826): Communication error with rank 0:
Connection refused
14. Fatal error in MPI_Send: Other MPI error, error stack:
15. MPI_Send(173)..............: MPI_Send(buf=0xffdb4c64, count=1,
16. MPID_nem_tcp_connpoll(1826): Communication error with rank 0:
Connection refused
17. Fatal error in MPI_Send: Other MPI error, error stack:
18. MPI_Send(173)..............: MPI_Send(buf=0xff9c2f64, count=1,
19. MPID_nem_tcp_connpoll(1826): Communication error with rank 0:
Connection refused
20. Fatal error in MPI_Send: Other MPI error, error stack:
21. MPI_Send(173)..............: MPI_Send(buf=0xfffe1d64, count=1,
22. MPID_nem_tcp_connpoll(1826): Communication error with rank 0:
Connection refused
23. Fatal error in MPI_Send: Other MPI error, error stack:
24. MPI_Send(173)..............: MPI_Send(buf=0xffd5e464, count=1,
25. MPID_nem_tcp_connpoll(1826): Communication error with rank 0:
Connection refused
26. Fatal error in MPI_Send: Other MPI error, error stack:
27. MPI_Send(173)..............: MPI_Send(buf=0xff9ae864, count=1,
28. MPID_nem_tcp_connpoll(1826): Communication error with rank 0:
Connection refused
29. Fatal error in MPI_Send: Other MPI error, error stack:
30. MPI_Send(173)..............: MPI_Send(buf=0xff8df4e4, count=1,
31. MPID_nem_tcp_connpoll(1826): Communication error with rank 0:
Connection refused
32. Fatal error in MPI_Send: Other MPI error, error stack:
33. MPI_Send(173)..............: MPI_Send(buf=0xffc94fe4, count=1,
34. MPID_nem_tcp_connpoll(1826): Communication error with rank 0:
Connection refused
35. Fatal error in MPI_Send: Other MPI error, error stack:
36. MPI_Send(173)..............: MPI_Send(buf=0xff9caae4, count=1,
37. MPID_nem_tcp_connpoll(1826): Communication error with rank 0:
Connection refused
38. Fatal error in MPI_Send: Other MPI error, error stack:
39. MPI_Send(173)..............: MPI_Send(buf=0xfffe7be4, count=1,
40. MPID_nem_tcp_connpoll(1826): Communication error with rank 0:
Connection refused
a) Line 1 says that the communicator is invalid but at line 2 it is
possible to see that the MPI_PROBE function recognized that the
communicator is MPI_COMM_WORLD. In which conditions this can happen?
b) What is the meaning of the numbers right after the mpi functions names
that appear inside the parenthesis on error messages (MPI_Probe(113) for
example)?
I re-run the case and it worked perfectly.
I am using MPICH2 Version: 1.4.1p1.
Thanks in advance,
Luiz
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120504/7688adda/attachment.htm>
