[mpich-discuss] Compiling mpich2 using Intel Fortran Compilerv12
    Ju JiaJia
    jujj603 at gmail.com
    Thu May  3 04:44:48 CDT 2012
If you use -f to specify hosts to use, the file machinefile in your case
has to be exist.
Use mpiexec to see all options.
On Thu, May 3, 2012 at 5:22 PM, O'Sullivan, Niall (HMRC) <n.osullivan at ucc.ie
> wrote:
> Thank you for your response.
> The file machinefile is not in /temp/hmrc/mpich2-1.4.1p1, see below for
> directory listing:
> hmrc at linuxadmin-Vostro-3550:/tmp/hmrc/mpich2-1.4.1p1$ ls -a
> .   bin         config.status  c.txt  examples   FC=ifort  lib
> mi.txt   mpich2-doxygen  share  test
> ..  config.log  config.system  doc    F77=ifort  include   Makefile
>  .mpich2  m.txt           src
> The command mpiexec -n 5 ./examples/cpi seems to work correctly, as
> follows.
> hmrc at linuxadmin-Vostro-3550:/tmp/hmrc/mpich2-1.4.1p1$ mpiexec -n 5
> ./examples/cpi
> Process 0 of 5 is on linuxadmin-Vostro-3550
> Process 3 of 5 is on linuxadmin-Vostro-3550
> Process 4 of 5 is on linuxadmin-Vostro-3550
> Process 1 of 5 is on linuxadmin-Vostro-3550
> Process 2 of 5 is on linuxadmin-Vostro-3550
> pi is approximately 3.1415926544231230, Error is 0.0000000008333298
> wall clock time = 0.000359
> Does this mean that mpich2 has been installed correctly and appears to be
> working?
> Best regards,
> Niall O'Sullivan
>  -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov on behalf of Ju JiaJia
> Sent: Thu 5/3/2012 9:59 AM
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Compiling mpich2 using Intel Fortran
> Compilerv12
> Do you have file machinefile in your /tmp/hmrc/mpich2-1.4.1p1 ? And what's
> inside?
> Since you run on one node, you can try  this: mpiexec -n 5 ./examples/cpi
> On Thu, May 3, 2012 at 4:38 PM, O'Sullivan, Niall (HMRC) <
> > wrote:
> > Thank you all for your responses.
> > The installer guide instructions in section 2.2 were followed and
> > completed up as far as which mpicc and which mpiexec, these outputs as
> > follows:
> > which mpicc
> > /home/hmrc/mpich2-install/bin/mpicc
> > which mpiexec
> > /home/hmrc/mpich2-install/bin/mpiexec
> > The installation is on a single PC so steps 9 and 10 were skipped.
> > An error arose in response to step 11 after entering the command mpiexec
> > -n 5 -f machinefile ./examples/cpi, see below:
> > hmrc at linuxadmin-Vostro-3550:/tmp/hmrc/mpich2-1.4.1p1$ mpiexec -n 5 -f
> > [mpiexec at linuxadmin-Vostro-3550] HYDU_parse_hostfile
> > (/home/hmrc/Mpich2/mpich2-1.4.1p1/src/pm/hydra/utils/args/args.c:303):
> > unable to open host file: machinefile
> > [mpiexec at linuxadmin-Vostro-3550] mfile_fn
> > (/home/hmrc/Mpich2/mpich2-1.4.1p1/src/pm/hydra/ui/mpich/utils.c:223):
> > error parsing hostfile
> > [mpiexec at linuxadmin-Vostro-3550] match_arg
> > (/home/hmrc/Mpich2/mpich2-1.4.1p1/src/pm/hydra/utils/args/args.c:115):
> > match handler returned error
> > [mpiexec at linuxadmin-Vostro-3550] HYDU_parse_array
> > (/home/hmrc/Mpich2/mpich2-1.4.1p1/src/pm/hydra/utils/args/args.c:140):
> > argument matching returned error
> > [mpiexec at linuxadmin-Vostro-3550] parse_args
> > (/home/hmrc/Mpich2/mpich2-1.4.1p1/src/pm/hydra/ui/mpich/utils.c:1387):
> > error parsing input array
> > [mpiexec at linuxadmin-Vostro-3550] HYD_uii_mpx_get_parameters
> > (/home/hmrc/Mpich2/mpich2-1.4.1p1/src/pm/hydra/ui/mpich/utils.c:1438):
> > unable to parse user arguments
> > The various directories and commands used during the installation are as
> > follows:
> > files unpacked to : /home/hmrc/Mpich2/mpich2-1.4.1p1
> > installation directory : /home/hmrc/mpich2-install
> > build directory : /tmp/hmrc/mpich2-1.4.1p1
> > configure command : /home/hmrc/Mpich2/mpich2-1.4.1p1/configure
> > --prefix=/home/hmrc/mpich2-install |& tee c.txt F77=ifort FC=ifort
> > build mpich2: make 2>&1 | tee m.txt
> > install mpich2 commands: make install 2>&1 | tee mi.txt
> > add bin subdirectory to path: PATH=/home/hmrc/mpich2-install/bin:$PATH ;
> > export PATH
> > All of these completed without error until an attempt was made to run an
> > MPI job with mpiexec, see details above.
> > Any suggestions appreciated.
> > Best regards,
> > Niall O'Sullivan
> > _______________________________________________
> > mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120503/59f395e2/attachment-0001.htm>
