[mpich-discuss] MPICH@ over SDP
    Pavan Balaji
    balaji at mcs.anl.gov
    Mon Mar 26 07:18:29 CDT 2012
Hi Mahesh,
Did you configure SDP to go over any specific IP addresses (e.g.,
tf08ib, tf09ib)?  If yes, you need to make sure that your machine file
uses a different set of IPs (e.g., tf08 and tf09).  This is because the
initial setup of the processes happens over ssh and presumably on your
machine the ssh server (sshd) is not launched over SDP.
  -- Pavan
On 03/26/2012 04:26 AM, Mahesh Chaudhari wrote:
> Hi All,
> had anyone tried MPICH2 over SDP
> was trying MPICH2-1.4.1 over SDP .
> setup the mpich environment according to installation n user guide
> then
> on executing calculation of PI example on the setup i.e.
> mpiexec -genv LD_PRELOAD /usr/local/ofed/lib64/libsdp.so -l -f
> machinefile -iface ib0 -n 4 -debug ./cpi
> it
> hangs after printing
> [proxy:0:0 at tf08] forwarding command (cmd=barrier_in) upstream
> PMI response: cmd=barrier_out
> [proxy:0:0 at tf08] PMI response: cmd=barrier_out
> [1] Process 1 of 4 is on tf09
> [3] Process 3 of 4 is on tf09
> [0] Process 0 of 4 is on tf08
> [2] Process 2 of 4 is on tf08
> [proxy:0:0 at tf08] got pmi command (from 4): get
> kvsname=kvs_4346_0 key=P1-businesscard
> [mpiexec at tf09] [pgid: 0] got PMI command: cmd=get kvsname=kvs_4346_0
> key=P1-businesscard
> [mpiexec at tf09] PMI response to fd 9 pid 4: cmd=get_result rc=0
> msg=success value=description#$port#44706$ifname#192.150.1.209$
> [proxy:0:0 at tf08] forwarding command (cmd=get kvsname=kvs_4346_0
> key=P1-businesscard) upstream
> [proxy:0:0 at tf08] we don't understand the response get_result; forwarding
> downstream
> where cat machinefile ==> tf08ib
> tf09ib
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Pavan Balaji
http://www.mcs.anl.gov/~balaji
