[mpich-discuss] MPICH error
Pavan Balaji
balaji at mcs.anl.gov
Fri Mar 16 16:31:05 CDT 2012
This doesn't look like an MPI error. Looks like your application
terminated badly.
-- Pavan
On 01/23/2012 10:13 AM, sc Deng wrote:
> Hello all,
> I meet a MPI error now. I modified my previous code (the previous is F77
> and OK ) to F90 and the error is given as follows (using 27
> processes,but just get 26 or less processes' information):
> rank=: 0 1780 6
> rank=: 2 656 6
> rank=: 4 1825 6
> rank=: 8 425 6
> rank=: 16 1233 6
> rank=: 12 1859 6
> rank=: 6 1171 6
> rank=: 20 434 6
> rank=: 5 668 6
> rank=: 14 688 6
> rank=: 21 1208 6
> rank=: 18 1174 6
> rank=: 24 779 6
> rank=: 7 1186 6
> rank=: 10 1841 6
> rank=: 17 433 6
> rank=: 11 688 6
> rank=: 22 1216 6
> rank=: 19 1189 6
> rank=: 25 792 6
> rank=: 3 1808 6
> rank=: 15 1213 6
> rank=: 13 1895 6
> rank=: 1 1788 6
> rank=: 9 1815 6
> rank=: 23 441 6
> [mpiexec at fn-148-148] ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP
> APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15)
> it is a particle simulation program, and the corresponding code is:
> !send to upper and receive from bottom
> num = 0 ; num_tmp = 0
> do i = 0 , nx+1
> do j = 0 , ny+1
> p = last_particle_in_cell(i,j,nz)
> do while(p>0)
> num = num + 1
> if(num > num_send) print*, 'Please enlarge the number
> of sent ghost - "num_send"' , num , num_send
> send_ghost(num) = particle_vector(p)%basic_particle
> p = particle_pointer(p)
> end do
> end do
> end do
> write(*,*) 'rank=:' , rank , num , 6
> if(mod(cpu_coords(1)+cpu_coords(2)+cpu_coords(3),2) == 0) then
> call MPI_SEND(num , 1 , MPI_INTEGER , upper_nbr , tag_tmp6
> , GRID_COMM , ierror)
> call MPI_RECV(num_tmp , 1 , MPI_INTEGER , bottom_nbr , tag_tmp6
> , GRID_COMM , stat , ierror)
> end if
> if(mod(cpu_coords(1)+cpu_coords(2)+cpu_coords(3),2) == 1) then
> end if
> call MPI_BARRIER(GRID_COMM , ierror)
> ! if(num > 0) call MPI_SEND(send_ghost , num , ghost_data_mpi ,
> upper_nbr , upper_tag , GRID_COMM , ierror)
> call MPI_SEND(send_ghost , num , ghost_data_mpi , upper_nbr ,
> ! if(num_tmp > 0) call MPI_RECV(recv_ghost , num_tmp ,
> ghost_data_mpi , &
> ! bottom_nbr , upper_tag , GRID_COMM , stat , ierror)
> call MPI_RECV(recv_ghost , num_tmp , ghost_data_mpi , &
> end if
> ghost_data_mpi , &
> end if
> if(num_tmp > 0) then
> do i = 1 , num_tmp
> particle_vector(ghost_pointer+i-1)%basic_particle =
> recv_ghost(i)
> end do
> end if
> ghost_pointer = ghost_pointer + num_tmp
> write(*,*) 'rank =: ',rank,upper_nbr,' num =: ' , num , ' num_tmp
> =:' , num_tmp
> if(ghost_pointer > max_num_particle_per_cpu+max_num_ghost_per_cpu) then
> print*, 'should enlarge "max_num_ghost_per_cpu" and/or
> "max_num_particle_per_cpu"',ghost_pointer,num_tmp
> end if
> left = 1 ; right = 1
> i = ghost_pointer-num_tmp
> do while(i <= ghost_pointer-1)
> if(particle_vector(i)%basic_particle%global_index /= 0) then
> call
> get_index(particle_vector(i)%basic_particle%coor(1),rmax,coor_box(1,1),coor_box(1,2),ind(1))
> call
> get_index(particle_vector(i)%basic_particle%coor(2),rmax,coor_box(2,1),coor_box(2,2),ind(2))
> call
> get_index(particle_vector(i)%basic_particle%coor(3),rmax,coor_box(3,1),coor_box(3,2),ind(3))
> if(ind(3) ==0 .and. ind(1)>=0 .and. ind(1)<=nx+1
> .and. ind(2)>=0 .and. ind(2)<=ny+1) then
> call
> add_cell_link(max_num_particle_per_cpu+max_num_ghost_per_cpu,nx,ny,nz,left,right,
> ind(1), ind(2), ind(3) , &
> i,particle_pointer,last_particle_in_cell)
> end if
> end if
> i = i + 1
> end do
> end if
> Please someone help me to fix it. Thank you very much.
> Your sincerely,
> Sc Deng
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Pavan Balaji
http://www.mcs.anl.gov/~balaji
