[mpich-discuss] Credentials rejected
    Alejandro Allievi
    alejandro.allievi at gmail.com
    Thu Mar  8 16:05:42 CST 2012
I have admin. rights. I have tried installing as "just me" and "everyone"
with identical ill fate. When I run wmpiconfig I see "ace.eggnog: MPICH2
not installed or unable to query the host", where ace.eggnog is the name of
my computer. The wierd thing is that it was running just fine a couple of
days ago.
Thank you for your help.
Alex
On Thu, Mar 8, 2012 at 6:11 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
>  Do you have an admin account on the machine? Did you install MPICH2 for
> "Everyone" (the default option during install process)?
> Regards,
> Jayesh
> From: "Alejandro Allievi" <alejandro.allievi at gmail.com>
> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Thursday, March 8, 2012 2:42:12 PM
> Subject: Re: [mpich-discuss] Credentials rejected
> Hi Jayesh,
> Thanks for your help. I did register but I get this
> D:\Canada_Laptop\Teaching\ParallelComputing\Books\IntroToParallelProgramming_Pacheco\MyExamples\Hello>mpiexec
> -n 4 Helloworld_MPI
> launch failed: CreateProcess(Helloworld_MPI) on ' ACE-eggnog.wds.mun.ca '
> failed, error 5 - Access is denied.
> Error posting writev, An established connection was aborted by the
> software in your host machine.(10053)
> unable to post a write for the next command,
> sock error: Error = 10053
> unable to post a write of the close command to tear down the job tree as
> part of the abort process.
> unable to post an abort command.
> Alex
> On Thu, Mar 8, 2012 at 5:00 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> You should register a valid Windows username/password with mpiexec.
> Regards,
> Jayesh
> From: "Alejandro Allievi" < alejandro.allievi at gmail.com >
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, March 8, 2012 2:08:20 PM
> Subject: [mpich-discuss] Credentials rejected
> Hi,
> I'm trying to run an MPI simple code but get this error
> -n 4 Helloworld_MPI
> Credentials for MEMORIAL\aallievi rejected connecting to
> Aborting: Unable to connect to ACE-eggnog.wds.mun.ca
> Which password do I need to enter here as my credentials?? The one I
> created when I installed MPICH2 or my own Windows password??
> Thank you.
> Alex
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
> Dr Alejandro Allievi, PhD, PEng
> "Tenez, mon ami, si vous y pensez bien, vous trouverez qu'en tout, notre
> véritable sentiment n'est pas celui dans lequel nous n'avons jamais
> vacillé; mais celui auquel nous sommes le plus habituellement revenus".
> Denis Diderot.
> This email and its attachments are for the sole use of the addressee and
> may contain information which is confidential and/or legally privileged.
> This email and its attachments are subject to copyright and should not be
> partly or wholly reproduced without the consent of the copyright owner. If
> you receive this email in error, please immediately delete it from your
> system and notify the sender by return email.
*Dr Alejandro Allievi, PhD, PEng*
*"Tenez, mon ami, si vous y pensez bien, vous trouverez qu'en tout, notre
Denis Diderot.*
*This email and its attachments are for the sole use of the addressee and
system and notify the sender by return email.*
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120308/f7db830d/attachment.htm>
