[mpich-discuss] Issue: mpiexec errors on Win 7 64-bit
Rohan Mittal
rohan.mittal at gmail.com
Thu Mar 8 00:32:54 CST 2012
Hello,
I figured this out! The issue is that on Win 7 Pro 64-bit, there is no
option to run "
http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/1.4.1p1/mpich2-1.4.1p1-win-x86-64.msi"
as an administrator by right-clicking the .msi file.
Hence, one has to first run the Start -> All Programs -> Accessories ->
Command Prompt as an administrator by right-clicking and selecting "Run as
administrator". Following that, change the path on the command prompt to
the location where the .msi (above) was downloaded. Then, execute "msiexec
/i mpich2-1.4.1p1-win-x86-64.msi" on the command prompt and follow through
the installation.
Once done, you can execute "smpd -status" and check if it is running. After
a system reboot, it should automatically start. The output should read
something like "smpd running on machinename". This is actually how I
figured this out. smpd was not running on my machine and when I tried to
execute "smpd -start" it returned an "access denied error". That's when I
re-installed MPICH2 using the procedure above and it fixed the problem.
Rohan
Sent from Cyclotron Rd., Berkeley, California, United States of America
On Wed, Mar 7, 2012 at 19:57, Rohan Mittal <rohan.mittal at gmail.com> wrote:
> Hello,
> I recently configured Visual Studio 2010 on Win 7 Pro 64-bit for compiling
> MPI programs. The latest release of MPICH2 for Windows EM64T/AMD64 is
> installed on the system.
> I am able to compile in Visual Studio. However, when I use "mpiexec -n 2
> helloWorld.exe" on the command prompt, it gives an error (snapshot
> attached). The error reads:
> "Error while connection to host, No connection could be made because the
> target machine actively refused it. (10061)
> Connect on sock (host=Dream, port=8676) failed, exhaused all end points
> Unable to connect to 'Dream:8676',
> sock error: Error = -1"
> Thanks for your help.
> Regards,
> Rohan
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120307/483f870a/attachment.htm>
