[mpich-discuss] MPI profiling
Anthony Chan chan at mcs.anl.gov
Mon Mar 5 14:10:42 CST 2012
I am not sure what went wrong with your installation.
I was able to link homb.c with MPE's MPI profiling tool
and run the code to generate a clog2 file.  Here is what
I did:
<install_mpich2-1.4.1p1_gnu>/bin/mpicc -mpe=mpilog -fopenmp -o homb_mpilog homb.c -lm
<install_mpich2-1.4.1p1_gnu>/bin/mpiexec -n 4 homb_mpilog -NR 1000 -NC 1000 -NITER 100
Writing logfile....
Enabling the Default clock synchronization...
Finished writing logfile homb_mpilog.clog2.
Did you give any argument when running homb ?
A.Chan
----- Original Message -----
> It can also be found at http://sourceforge.net/projects/homb/
> On Fri, Mar 2, 2012 at 11:47 PM, Balaji S <balaji.ceg.13 at gmail.com>
> wrote:
> > Attached sir.
> > On Fri, Mar 2, 2012 at 11:45 PM, Anthony Chan <chan at mcs.anl.gov>
> > wrote:
> >> Can you send me src/homb.c ?
> >> > This is the o/p with
> >> > /home/balaji/mpich2-install/bin/mpicc -mpe=mpilog -o homb.ex -O3
> >> > -show
> >> > -fopenmp src/homb.
> >> > output:
> >> > gcc -I/home/balaji/mpich2-install/include -Wl,--export-dynamic -o
> >> > homb.ex
> >> > -O3 -fopenmp src/homb.c -lm -I/home/balaji/mpich2-install/include
> >> > -L/home/balaji/mpich2-install/lib
> >> > -llmpe
> >> > -lmpe -lmpich -lopa -lmpl -lrt -lpthread
> >> > On Fri, Mar 2, 2012 at 9:14 AM, Anthony Chan <chan at mcs.anl.gov>
> >> > wrote:
> >> > > add -show to the command and send me the output.
> >> > > > -O3
> >> > > > -fopenmp
> >> > > > src/homb.c
> >> > > > It still doesnt work. But no errors
> >> > > > On Tue, Feb 28, 2012 at 11:52 PM, Anthony Chan
> >> > > > wrote:
> >> > > > > mpicc in your path is still mpich2, but it is likely an
> >> > > > > older
> >> > > > > version, do /usr/bin/mpich2version for the version.
> >> > > > > The mpich2-1.4 that you just built is installed in
> >> > > > > /home/balaji/mpich2-install.
> >> > > > > Link your MPI benchmark using fullpath to mpicc as follows
> >> > > > > homb.ex -O3
> >> > > > > -fopenmp
> >> > > > > src/homb.c
> >> > > > > A.Chan
> >> > > > > > which mpicc gives
> >> > > > > > /usr/bin/mpicc
> >> > > > > > while mpicc -show gives,
> >> > > > > > gcc -g -O2 -g -Wall -O2 -Wl,-Bsymbolic-functions
> >> > > > > > -I/usr/include/mpich2
> >> > > > > > -L/usr/lib -L/usr/lib -lmpich -lopa -lpthread -lrt
> >> > > > > > On Tue, Feb 28, 2012 at 11:55 AM, Anthony Chan
> >> > > > > > wrote:
> >> > > > > > > MPICH2 does not have -lmpi. Do you have mpicc from
> >> > > > > > > other MPI implementation (e.g. OpenMPI) on your path,
> >> > > > > > > What is the output of "which mpicc" ? Also, add -show
> >> > > > > > > to your mpicc command and let us know the output ?
> >> > > > > > > A.Chan
> >> > > > > > > > I gave
> >> > > > > > > > mpicc -mpe=mpilog -o homb.ex -O3 -fopenmp -lmpi
> >> > > > > > > > src/homb.c
> >> > > > > > > > while i compiled HOMB benchmark. Please note i don
> >> > > > > > > > get any
> >> > > > > > > > errors,
> >> > > > > > > > just
> >> > > > > > > > that i did not get the .clog2 files.
> >> > > > > > > > On Tue, Feb 28, 2012 at 10:12 PM, Anthony Chan
> >> > > > > > > > wrote:
> >> > > > > > > > > Your installation of mpich2 seems OK. Don't see any
> >> > > > > > > > > error
> >> > > > > > > > > though (your mpich2 isn't the latest). Also, don't
> >> > > > > > > > > move
> >> > > > > > > > > around any files from <mpich2-install-dir>/etc.
> >> > > > > > > > > How do you compile and link with your MPI benchmark
> >> > > > > > > > > A.Chan
> >> > > > > > > > > > I have attached all files,
> >> > > > > > > > > > as specified in the readme file,
> >> > > > > > > > > > mpich2-1.4/c.txt (generated in step 1(d) above)
> >> > > > > > > > > > mpich2-1.4/m.txt (generated in step 1(e) above)
> >> > > > > > > > > > mpich2-1.4/mi.txt (generated in step 1(f) above)
> >> > > > > > > > > > mpich2-1.4/config.log (generated in step 1(d)
> >> > > > > > > > > > above)
> >> > > > > > > > > > mpich2-1.4/src/openpa/config.log (generated in
> >> > > > > > > > > > step
> >> > > > > > > > > > 1(d)
> >> > > > > > > > > > above)
> >> > > > > > > > > > And Btw, mpicc and mpirun works fine for me...
> >> > > > > > > > > > On Sun, Feb 26, 2012 at 3:18 AM, Anthony Chan
> >> > > > > > > > > > wrote:
> >> > > > > > > > > > > It seems something may have gone wrong in your
> >> > > > > > > > > > > installation.
> >> > > > > > > > > > > Send us configure and make outputs as stated in
> >> > > > > > > > > > > the
> >> > > > > > > > > > > README
> >> > > > > > > > > > > file.
> >> > > > > > > > > > > > I copied the mpe_mpilog.conf from
> >> > > > > > > > > > > > mpich2-install/etc
> >> > > > > > > > > > > > to
> >> > > > > > > > > > > > /etc/mpich2
> >> > > > > > > > > > > > Now i
> >> > > > > > > > > > > > get no error. But When after executing, where
> >> > > > > > > > > > > > will
> >> > > > > > > > > > > > i
> >> > > > > > > > > > > > get
> >> > > > > > > > > > > > my
> >> > > > > > > > > > > > clog2
> >> > > > > > > > > > > > file? Its
> >> > > > > > > > > > > > not ther in the current directory.
> >> > > > > > > > > > > > On Sat, Feb 25, 2012 at 11:52 PM, Balaji S
> >> > > > > > > > > > > > wrote:
> >> > > > > > > > > > > > > Sir , When i gave "-mpe=mpilog" i get
> >> > > > > > > > > > > > > Profiling configuration file
> >> > > > > > > > > > > > > mpe_mpilog.conf not
> >> > > > > > > > > > > > > found
> >> > > > > > > > > > > > > in
> >> > > > > > > > > > > > > /etc/mpich2
> >> > > > > > > > > > > > > On Sat, Feb 25, 2012 at 11:41 PM, Anthony
> >> > > > > > > > > > > > > Chan
> >> > > > > > > > > > > > > wrote:
> >> > > > > > > > > > > > >> For MPICH2 and MVAPICH2, link the
> >> > > > > > > > > > > > >> benchmark
> >> > > > > > > > > > > > >> with
> >> > > > > > > > > > > > >> "mpicc -mpe=mpilog" or "mpif90
> >> > > > > > > > > > > > >> -mpe=mpilog".
> >> > > > > > > > > > > > >> For
> >> > > > > > > > > > > > >> OpenMPI, build standalone MPE for it and
> >> > > > > > > > > > > > >> link
> >> > > > > > > > > > > > >> the
> >> > > > > > > > > > > > >> benchmark with "mpecc -mpilog" or "mpefc
> >> > > > > > > > > > > > >> -mpilog".
> >> > > > > > > > > > > > >> A.Chan
> >> > > > > > > > > > > > >> > Can anyone help me on how to create a
> >> > > > > > > > > > > > >> > ".clog2"
> >> > > > > > > > > > > > >> > file
> >> > > > > > > > > > > > >> > from
> >> > > > > > > > > > > > >> > an
> >> > > > > > > > > > > > >> > MPI
> >> > > > > > > > > > > > >> > benchmark?
> >> > > > > > > > > > > > >> > With Regards,
> >> > > > > > > > > > > > >> > Balaji.S
> >> > > > > > > > > > > > >> > _______________________________________________
> >> > > > > > > > > > > > >> > mpich-discuss mailing list
> >> > > > > > > > > > > > >> > mpich-discuss at mcs.anl.gov
> >> > > > > > > > > > > > >> > To manage subscription options or
> >> > > > > > > > > > > > >> > unsubscribe:
> >> > > > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> >> > > > > > > > > > > > >> unsubscribe:
> >> > > > > > > > > > > > > With Regards,
> >> > > > > > > > > > > > >     Balaji.S
> >> > > > > > > > > > > > With Regards,
> >> > > > > > > > > > > > Balaji.S
> >> > > > > > > > > > With Regards,
> >> > > > > > > > > > Balaji.S
> >> > > > > > > > With Regards,
> >> > > > > > > > Balaji.S
> >> > > > > > With Regards,
> >> > > > > > Balaji.S
> >> > > > With Regards,
> >> > > > Balaji.S
> >> > With Regards,
> >> > Balaji.S
> > With Regards,
> >     Balaji.S
> With Regards,
> Balaji.S
