On Mar 2, 2012, at 2:52 PM CST, Martin Pokorny wrote: > Yes, indeed. Might I simply be able to replace that call with a reduce/broadcast pair as a possible workaround? I think that's an excellent workaround. If you still encounter the hang, then the problem is probably somewhere else. -Dave
