[mpich-discuss] MPICH2 Win 7 installation
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Mar  2 13:22:35 CST 2012
 You should explicitly specify the include and lib directories when you compile your code with gcc (There is no equivalent to mpicc with MPICH2 on Windows. mpicc is a script that captures the paths_to_compiler+libs+flags etc) on Windows.
(PS: "gcc -I.... -L.... -o mpi.exe mpi.c -lmpi")
Jayesh
----- Original Message -----
From: "Alejandro Allievi" <alejandro.allievi at gmail.com>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Friday, March 2, 2012 11:59:59 AM
Subject: Re: [mpich-discuss] MPICH2 Win 7 installation
Hi Jayesh,
Thanks for your reply.
I DID use "Run as Administrator". When I use the command "msiexec /I mpich2-1.4.1p1-win-x86-64.msi" a series of windows come up. They are shown in attached file MPICH2_Install.pdf. As you can see, at no time there is a configuration setting option and installation is succesful. Then, when I run the MPICH2 examples they do fine, see attached MPICH2_Example.pdf . I do not see any configuartion settings. Am I missing something here??
The problem is when I use gcc. When I run my own Helloworld_MPI.c example, see attached Helloworld_MPI.pdf, it cannot find mpi.h (it's in the PATH and have no way to include it in gcc as far as I know) . I have run my code in Unix using "mpicc" and it runs just fine. Any suggestions?? What compiler do you use to be able to include mpi.h??
Kind regards.
Alejandro
On Fri, Mar 2, 2012 at 1:48 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
Please uninstall MPICH2 and re-install it following the instructions in Section 9.4 (NOT 9.1) of the MPICH2 installer's guide ( http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs ).
Jayesh
From: "Alejandro Allievi" < alejandro.allievi at gmail.com >
Sent: Wednesday, February 29, 2012 1:12:42 PM
Subject: [mpich-discuss] MPICH2 Win 7 installation
Hi. I just installed MPICH2 64 on Win 7. I'm running the following test with the results shown. Can somebody give me a hand?? Thank you. Alex
C:\Users\aallievi>mpiexec -n 2 m2
Error while connecting to host, No connection could be made because the target machine actively refused it. (10061)
Connect on sock (host= ACE-eggnog.wds.mun.ca , port=8676) failed, exhaused all end points
Unable to connect to ' ACE-eggnog.wds.mun.ca:8676 ',
sock error: Error = -1
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
Dr Alejandro Allievi, PhD, PEng
"Tenez, mon ami, si vous y pensez bien, vous trouverez qu'en tout, notre véritable sentiment n'est pas celui dans lequel nous n'avons jamais vacillé; mais celui auquel nous sommes le plus habituellement revenus". Denis Diderot.
This email and its attachments are for the sole use of the addressee and may contain information which is confidential and/or legally privileged. This email and its attachments are subject to copyright and should not be partly or wholly reproduced without the consent of the copyright owner. If you receive this email in error, please immediately delete it from your system and notify the sender by return email.
