[mpich-discuss] mpich2 compilation with intel only
    David Riethmiller
    rieth at phy.ohiou.edu
    Wed Jun 27 16:09:16 CDT 2012
Hmmm, actually now that I try it, I am not able to compile a "hello
world" program with -no-gcc and #include <stdarg.h> together.
If I remove -no-gcc from my configure shell script, the configure is
successful, which leads me to my next question:
Is this still considered a true Intel build, even if I've used gcc to
build it? From here on will the Intel compilers will run my mpi calls,
or will the GNU compiler set continue to be used?
Dave
On Jun 26, 2012, at 4:48 PM, Dave Goodell wrote:
> Looks like your intel compiler is broken somehow when compiling
> under "-no-gcc".  The "icc" compiler is finding the system-
> installed, gcc-specific stdarg.h which is blowing up with a
> "__MWERKS_" error message.  My guess is that it won't complain if
> you drop "-no-gcc" because this will cause icc to #define "__GNUC__"
> and similar symbols that will make the system header happier.
> Are you *sure* that the "-no-gcc" option is what you want?  Will it
> compile simple C programs that "#include <stdarg.h>" without any
> involvement with MPICH2?
> -Dave
> On Jun 25, 2012, at 4:50 PM MDT, David Riethmiller wrote:
>> Hi -
>> I'm having trouble compiling mpich2 version 1.4.1p1 on a Mac OSX
>> 10.5 system, using only the Intel compilers.  I specifically want
>> to avoid the GNU compilers, in order to match the software
>> available on a supercomputer to which I will port later.
>> When running my configure script, I hit the following error:
>> checking for size of Fortran type integer... configure: WARNING:
>> Unable to compile the C routine for finding the size of a integer
>> checking for size of Fortran type real... configure: WARNING:
>> Unable to compile the C routine for finding the size of a real
>> checking for size of Fortran type double precision... configure:
>> WARNING: Unable to compile the C routine for finding the size of a
>> double precision
>> checking whether integer*1 is supported... yes
>> checking whether integer*2 is supported... yes
>> checking whether integer*4 is supported... yes
>> checking whether integer*8 is supported... yes
>> checking whether integer*16 is supported... no
>> checking whether real*4 is supported... yes
>> checking whether real*8 is supported... yes
>> checking whether real*16 is supported... yes
>> configure: error: Unable to configure with Fortran support because
>> configure could not determine the size of a Fortran INTEGER.
>> Consider setting CROSS_F77_SIZEOF_INTEGER to the length in bytes of
>> a Fortran INTEGER
>> I've saved my configure command as a shell script:
>> #! bin/sh
>> CDIR=/opt/intel/
>> FDIR=/opt/intel/fc/10.1.008/
>> sh ${CDIR}/bin/iccvars.sh ia32
>> sh ${CDIR}/bin/compilervars.sh ia32
>> sh ${FDIR}/bin/ifortvars.sh
>> ./configure \
>>   --prefix=/Volumes/SecondHD/rieth/mpich2_intel \
>>   CC=icc \
>>   CFLAGS="-m32 -no-gcc -I${CDIR}/include -L${DYLD_LIBRARY_PATH}" \
>>   LDFLAGS="-L${CDIR}/lib -L${FDIR}/lib -L${DYLD_LIBRARY_PATH}" \
>>   F77=ifort \
>>   FFLAGS="-m32 -no-gfortran -I${FDIR}/include -L$
>>   CXX=icpc \
>>   CXXFLAGS="-m32 -no-gcc -I${CDIR}/include -L${DYLD_LIBRARY_PATH}" \
>>   2>&1 | tee c.txt
>> I'm attaching the output files.  Can anyone see what I'm doing wrong?
>> Thanks very much,
>> Dave
>> <c.txt><config.log><config.system>
>> David A. Riethmiller
>> Ph.D. Candidate, Astrophysical Institute
>> Ohio University
>> Clippinger Labs 338
>> http://www.phy.ohiou.edu/~rieth/
>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Ohio University
Clippinger Labs 338
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120627/a2cbdb4e/attachment.html>
