[mpich-discuss] mpi executable
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Fri Jun 22 11:43:43 CDT 2012
 You might want to check with your system administrator to find the correct Windows username (If you are a domain user you need to include the domain name too) and password.
 When launching from VS it does not go through mpiexec (auth step etc). However you cannot launch your job across different machines using this method.
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Friday, June 22, 2012 11:00:07 AM
Subject: Re: [mpich-discuss] mpi executable
I do it before, but "FAIL" forever.
First time, I used username and password which deference from Windows
username and password. Next, I use it same. They're "FAIL".
By the way. Why from Visual Studio still run well but not from Command Prom?
Thanks.
Titia
On 6/22/12, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
>  You should register (mpiexec -register) a valid Windows username/password
> before launching your job with mpiexec. You can validate (see if it works)
> the registered username/password using "mpiexec -validate".
>  Let us know if it works for you.
> Regards,
> Jayesh
> From: "Titianingrum -" <08.5831 at stis.ac.id>
> Sent: Thursday, June 21, 2012 4:59:42 PM
> This is just simple code:
> #include "stdio.h"
> #include "mpi.h"
> int main(int argc, char *argv[])
> 	int numberOfProcessors;
> 	int rank;
> 	int namelen;
> 	char processor_name[MPI_MAX_PROCESSOR_NAME];
> 	MPI_Init(&argc,&argv);
> 	printf("Hello MPI\r\n");
> 	MPI_Comm_size(MPI_COMM_WORLD,&numberOfProcessors);
> 	printf("Number of processor = %d\r\n",numberOfProcessors);
> 	MPI_Get_processor_name(processor_name,&namelen);
> 	printf("Processor name = %s\r\n",processor_name);
> 	MPI_Comm_rank(MPI_COMM_WORLD,&rank);
> 	printf("Rank = %d\r\n",rank);
> 	MPI_Finalize();
> 	getchar();
> 	return 0;
> When it was run use Visual Studio C++, output :
> Hello MPI
> Number of processor = 1
> Processor name = titia.Titia
> Rank = 0
> * but when it was runed from Command Prom:
> C:\Program Files\MPICH2\bin\>mpiexec "E:\HelloMPI\Debug\HelloMPI.exe" -n 1
> Credentials for titia rejected cennecting to titia.Titia
> Aborting: Unable to connect to titia.Titia
> I have setting like as the other PC which no problem.
> Thanks.
>> Hi,
>>  Can you provide us more details (The command used, output etc) on your
>> problem?
>> Regards,
>> Jayesh
>> To: mpich-discuss at mcs.anl.gov
>> Sent: Thursday, June 21, 2012 3:49:16 AM
>> Subject: [mpich-discuss] mpi executable
>> Hi,
>> I have any problem when run MPI file use cmd,but it's ok when run use
>> visual studio c++.
>> I don't know the problem.
>> thank.
>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> titia
titia
