[mpich-discuss] Two different mpif90 (in mpich2) versions	giving different output for same source code
    Darius Buntinas
    buntinas at mcs.anl.gov
    Tue Jun 19 10:45:50 CDT 2012
The -show parameter to mpif90 will show the exact command that's used to compile the program.  From that you can see which version of the fortran compiler is being used by each mpif90 wrapper.  That should help you track down the problem.
-d
On Jun 19, 2012, at 3:45 AM, Shitij Bhargava wrote:
> Hi all !!
> I have a simple code in fortran that reads a file, and outputs it as it is. I have two different versions of mpif90 in my system. When I compile the same program with the two different compilers and examine the output of the resulting two executables, they differ. This is just a toy program of course, actually I am using MPICH2 with PETSc/SLEPc, and I have the mpif90 that is configured with PETSc/SLEPc in  /home/shitij/Lib/MPI/mpich2-1.3.2/bin/. The problem is that this version of mpif90 is giving the wrong output. I am giving the -v outputs of both versions below:
> (this one is configured with PETSc/SLEPc and gives incorrect output)
> shitij at shitij:~/JNCASR2012$ /home/shitij/Lib/MPI/mpich2-1.3.2/bin/mpif90 -v
> mpif90 for MPICH2 version 1.3.2
> Version 11.0
> shitij at shitij:~/JNCASR2012$ mpif90 -v
> Using built-in specs.
> COLLECT_GCC=/usr/bin/gfortran
> COLLECT_LTO_WRAPPER=/usr/lib/x86_64-linux-gnu/gcc/x86_64-linux-gnu/4.5.2/lto-wrapper
> Target: x86_64-linux-gnu
> Configured with: ../src/configure -v --with-pkgversion='Ubuntu/Linaro 4.5.2-8ubuntu4' --with-bugurl=file:///usr/share/doc/gcc-4.5/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --program-suffix=-4.5 --enable-shared --enable-multiarch --with-multiarch-defaults=x86_64-linux-gnu --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib/x86_64-linux-gnu --without-included-gettext --enable-threads=posix --with-gxx-include-dir=/usr/include/c++/4.5 --libdir=/usr/lib/x86_64-linux-gnu --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --enable-plugin --enable-gold --enable-ld=default --with-plugin-ld=ld.gold --enable-objc-gc --disable-werror --with-arch-32=i686 --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
> Thread model: posix
> gcc version 4.5.2 (Ubuntu/Linaro 4.5.2-8ubuntu4)
> The differences in the files I mentioned are varied (and weird), for example some lines are missing (always the same across different runs), some line is read half-way/incorrectly, for example a line:
> ATOM NE2  NR2    -0.70
> is always read as
> ATOM NE2      -0.70
> for some reason.
> This is the first time I am having a problem like this. Is this a problem with installation of MPICH2 ?
> I am also giving the code below:
> program exp4
> implicit none
> 	character(79)::line
> 	open(unit=1,file='top_all27_prot_na_RTF.txt',action='read',ACCESS='STREAM',FORM='FORMATTED')
> 	do
> 	read(1,'(a)',END=10)line   !! Read line as string
> 	write(*,*)line
> 	enddo
> 	10 write(*,*)'Done !!'
> end program exp4
> Thank you for your help in advance !!!
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
