[mpich-discuss] mpiexec / Windows networking
    Michael Colonno
    mcolonno at stanford.edu
    Tue Jun 19 09:33:26 CDT 2012
	The instructions referenced below were followed to install MPICH2 on the Windows 7 system (uninstalled / reinstalled twice with the same results). Is there any reason the wmpiexec and command line behavior would be different? Perhaps some system-wide post-install setting?
	~Mike C.
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Tuesday, June 19, 2012 7:22 AM
Cc: Michael Colonno
Subject: Re: mpiexec / Windows networking
 The earlier error message (smpd error message) indicates that MPICH2 was not installed correctly on your system. I would recommend the following,
# Uninstall MPICH2 from the system
# Follow instructions in Section 9.4 (NOT 9.1) of the MPICH2 installer's guide (available at http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs) to install MPICH2.
Jayesh
----- Original Message -----
Cc: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Monday, June 18, 2012 6:15:07 PM
Subject: RE: mpiexec / Windows networking
Follow up: I can run the example successfully through the GUI wrapper (wmpiexec.exe) but not from the command line through a console, which seems odd. So the installation works and the relevant service must be running but it doesn’t seem the command line environment can communicate with it. Besides setting the path, is there anything else I can do on this front?
~Mike C.
From: Michael Colonno [mailto:mcolonno at stanford.edu]
Sent: Monday, June 18, 2012 4:06 PM
To: 'mpich-discuss at mcs.anl.gov'
Cc: 'Jayesh Krishna'
Subject: mpiexec / Windows networking
Trying to run the cxxpi.exe example program and I'm hitting a roadblock (seems others have shared this as well) on a Windows 7 x64 system. I have followed the instructions summarized in: http://lists.mcs.anl.gov/pipermail/mpich-discuss/2011-April/009694.html . Checking services, the "MPICH2 Process Manager" is started (I restarted it to confirm). However, checking the status of SMPD:
>smpd -status
no smpd running on mike-studio17
Trying to run a test produces the error in the thread above:
>mpiexec -n 2 hostname
Error while connecting to host, No connection could be made because the target machine actively refused it. (10061)
Connect on sock (host=mike-studio17, port=8678) failed, exhausted all end points
Unable to connect to 'mike-studio17:8678',
sock error: Error = -1
In the menu of wmpiconfig.exe under "error" it says " mike-studio17: MPICH2 not installed or unable to query the host ". I didn’t install to the default path, but other than that there is nothing extraordinary (bin directory added to path of course). If I scan hosts for versions, the wmpiconfig tool does detect the correct version on this host. Using “scan hosts”, I get “ Error: No servers available for this domain ”. It seems like the service simultaneously is and is not running. Anything I can do to debug?
~Mike C.
