[mpich-discuss] Isend Irecv error
    Kenneth Leiter
    kenneth.leiter at gmail.com
    Fri Jun 15 14:32:42 CDT 2012
Hi Darius,
I agree that this is very likely the issue.  In my real code, I put in
sleep statements with some success so that a single node was not
bombarded with many requests at the same time and was able to run with
a larger numbers of processors than I could previously.
I'll definitely be interested in trying out a patch.
Ken Leiter
On Fri, Jun 15, 2012 at 3:26 PM, Darius Buntinas <buntinas at mcs.anl.gov> wrote:
> It looks like your program is having every process send to every other process.  There may be an issue with a node being overloaded with too many simultaneous connection requests.  Currently MPICH doesn't retry after a timeout, but this is something we have on a branch.  Just to test this hypothesis, try putting in a sleep (or usleep) in the right place to slow things down, so that not all of the nodes are hitting the same node at the same time.
> I'll try to get a patch for you to try.
> -d
> On Jun 15, 2012, at 9:35 AM, Kenneth Leiter wrote:
>> Hello,
>> I am stumped by a problem I am having with my code failing when I use
>> a large number of processors.  I have produced a standalone code to
>> demonstrate the error.  I don't see the error with other MPI
>> implementations that are available to me (intel mpi and openmpi).  I
>> am using mpich-1.4.1p1.
>> The test code sends and receives a buffer from all other tasks.  I
>> realize that I should write this as a collective operation (like
>> Bcast), but in my real code I only communicate to a few neighbor tasks
>> and must use point-to-point operations.  This test code demonstrates
>> the same problem I see in my real code.
>> On my machine, everything works fine up to 128 processors (I have 24
>> cores per node on the machine), but fails at 256 processors.  Using
>> other mpi implementations I can get to 1500 processors with no
>> problem.  I have seen the same behavior on two different machines.
>> I get an error in MPI_Waitall:
>> Fatal error in PMPI_Waitall: See the MPI_ERROR field in MPI_Status for
>> the error code
>> When I examine the MPI_Status I get:
>> Task ID | Error code
>> 230 0
>> 231 0
>> 232 0
>> 233 0
>> 234 0
>> 235 0
>> 236 604005647
>> 237 18
>> 238 18
>> 239 18
>> 240 18
>> 241 18
>> 242 18
>> 243 18
>> I have attached the test code to this message.
>> Thanks,
>> Ken Leiter
>> <mpichTest.cxx>_______________________________________________
>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
