[mpich-discuss] MPICH2 64-bit installation on Window 7 64-bit OS
    Sam Liao
    sliao at pharmaxresearch.com
    Tue Jun  5 13:50:46 CDT 2012
Dear Jayesh:
Thanks for your quick reply.
Yes, I did exactly that.  But the log file showing error code 2888 (see the log file below).
Best regards,
Sam
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Tuesday, June 05, 2012 7:19 AM
Cc: sliao at pharmaxresearch.com
Subject: Re: [mpich-discuss] MPICH2 64-bit installation on Window 7 64-bit OS
 Did you run the installer from an administrator command prompt (See section 9.4, not 9.1, of the MPICH2 installer's guide for details - http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.4.1-installguide.pdf)? Please uninstall MPICH2 and re-install following instruction in sec 9.4.
Jayesh
----- Original Message -----
Sent: Monday, June 4, 2012 4:52:21 PM
Subject: [mpich-discuss] MPICH2 64-bit installation on Window 7 64-bit OS
Hi:
I tried to install MPICH2 64-bit on Window 7 64-bit OS. The installation indicated successful. However, the log file indicated unexpected error on page 2 (see log below my email). Can some help to resolve this problem?
Sam Liao
PharMax Research Inc.
PO Box 15661
Newport Beach, CA 92659
Phone: (201)-988-2043
Fax: (720)-294-6783
=== Logging started: 6/4/2012 8:46:23 ===
Action 8:46:23: INSTALL.
Action start 8:46:23: INSTALL.
Action 8:46:23: DIRCA_CheckFX.
Action start 8:46:23: DIRCA_CheckFX.
Action ended 8:46:24: DIRCA_CheckFX. Return value 1.
Action 8:46:24: AppSearch. Searching for installed applications
Action start 8:46:24: AppSearch.
AppSearch: Property: VSRUNTIMELIBEXISTS, Signature: _1D1E69A8B74440B5BE6D0036E548EA67
Action ended 8:46:24: AppSearch. Return value 1.
Action 8:46:24: VSDCA_VsdLaunchConditions.
Action start 8:46:24: VSDCA_VsdLaunchConditions.
Action ended 8:46:24: VSDCA_VsdLaunchConditions. Return value 1.
Action 8:46:24: LaunchConditions. Evaluating launch conditions
Action start 8:46:24: LaunchConditions.
Action ended 8:46:24: LaunchConditions. Return value 1.
Action 8:46:24: CCPSearch. Searching for qualifying products
Action start 8:46:24: CCPSearch.
Action ended 8:46:24: CCPSearch. Return value 1.
Action 8:46:24: RMCCPSearch. Searching for qualifying products
Action start 8:46:24: RMCCPSearch.
Action ended 8:46:24: RMCCPSearch. Return value 0.
Action 8:46:24: ValidateProductID.
Action start 8:46:24: ValidateProductID.
Action ended 8:46:24: ValidateProductID. Return value 1.
Action 8:46:24: CustomTextA_SetProperty_EDIT1.
Action start 8:46:24: CustomTextA_SetProperty_EDIT1.
Action ended 8:46:24: CustomTextA_SetProperty_EDIT1. Return value 1.
Action 8:46:24: CustomTextA_SetProperty_EDIT2.
Action start 8:46:24: CustomTextA_SetProperty_EDIT2.
Action ended 8:46:24: CustomTextA_SetProperty_EDIT2. Return value 1.
Action 8:46:24: CustomTextA_SetProperty_EDIT3.
Action start 8:46:24: CustomTextA_SetProperty_EDIT3.
Action ended 8:46:24: CustomTextA_SetProperty_EDIT3. Return value 1.
Action 8:46:24: CustomTextA_SetProperty_EDIT4.
Action start 8:46:24: CustomTextA_SetProperty_EDIT4.
Action ended 8:46:24: CustomTextA_SetProperty_EDIT4. Return value 1.
Action 8:46:24: DIRCA_TARGETDIR.
Action start 8:46:24: DIRCA_TARGETDIR.
Action ended 8:46:24: DIRCA_TARGETDIR. Return value 1.
Action 8:46:24: CostInitialize. Computing space requirements
Action start 8:46:24: CostInitialize.
Action ended 8:46:24: CostInitialize. Return value 1.
Action 8:46:24: FileCost. Computing space requirements
Action start 8:46:24: FileCost.
Action ended 8:46:24: FileCost. Return value 1.
Action 8:46:24: IsolateComponents.
Action start 8:46:24: IsolateComponents.
Action ended 8:46:24: IsolateComponents. Return value 1.
Action 8:46:24: WelcomeForm.
Action start 8:46:24: WelcomeForm.
Info 2898.For VSI_MS_Sans_Serif13.0_0_0 textstyle, the system created a 'MS Sans Serif' font, in 0 character set, of 13 pixels height.
Info 2898.For VSI_MS_Sans_Serif16.0_1_0 textstyle, the system created a 'MS Sans Serif' font, in 0 character set, of 20 pixels height.
DEBUG: Error 2826: Control BannerBmp on dialog WelcomeForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: WelcomeForm, BannerBmp, to the right
DEBUG: Error 2888: Executing the Binary view failed
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2888. The arguments are: Binary, ,
Info 2898.For VsdDefaultUIFont.524F4245_5254_5341_4C45_534153783400 textstyle, the system created a 'MS Sans Serif' font, in 0 character set, of 13 pixels height.
DEBUG: Error 2826: Control Line1 on dialog WelcomeForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: WelcomeForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog WelcomeForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: WelcomeForm, Line2, to the right
Action 8:46:24: WelcomeForm. Dialog created
DEBUG: Error 2826: Control BannerBmp on dialog ReadmeForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ReadmeForm, BannerBmp, to the right
DEBUG: Error 2826: Control Line1 on dialog ReadmeForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ReadmeForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog ReadmeForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ReadmeForm, Line2, to the right
Action 8:46:41: ReadmeForm. Dialog created
DEBUG: Error 2826: Control BannerBmp on dialog EulaForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: EulaForm, BannerBmp, to the right
DEBUG: Error 2826: Control Line1 on dialog EulaForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: EulaForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog EulaForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: EulaForm, Line2, to the right
Action 8:46:45: EulaForm. Dialog created
DEBUG: Error 2826: Control BannerBmp on dialog CustomTextA extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: CustomTextA, BannerBmp, to the right
DEBUG: Error 2826: Control Control273 on dialog CustomTextA extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: CustomTextA, Control273, to the right
DEBUG: Error 2826: Control Control278 on dialog CustomTextA extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: CustomTextA, Control278, to the right
Action 8:46:49: CustomTextA. Dialog created
Action ended 8:46:55: WelcomeForm. Return value 1.
Action 8:46:55: CostFinalize. Computing space requirements
Action start 8:46:55: CostFinalize.
Action ended 8:46:55: CostFinalize. Return value 1.
Action 8:46:55: FolderForm.
Action start 8:46:55: FolderForm.
DEBUG: Error 2826: Control BannerBmp on dialog FolderForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FolderForm, BannerBmp, to the right
DEBUG: Error 2826: Control Line1 on dialog FolderForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FolderForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog FolderForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FolderForm, Line2, to the right
Info 2898.For VSI_MS_Shell_Dlg13.0_0_0 textstyle, the system created a 'MS Shell Dlg' font, in 0 character set, of 13 pixels height.
Action 8:46:55: FolderForm. Dialog created
Action 8:47:01: FindRelatedProducts. Searching for related applications
Action start 8:47:01: FindRelatedProducts.
Action ended 8:47:01: FindRelatedProducts. Return value 1.
DEBUG: Error 2826: Control BannerBmp on dialog ConfirmInstallForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ConfirmInstallForm, BannerBmp, to the right
DEBUG: Error 2826: Control Line1 on dialog ConfirmInstallForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ConfirmInstallForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog ConfirmInstallForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ConfirmInstallForm, Line2, to the right
Action 8:47:01: ConfirmInstallForm. Dialog created
Action ended 8:47:08: FolderForm. Return value 1.
Action 8:47:08: ProgressForm.
Action start 8:47:08: ProgressForm.
DEBUG: Error 2826: Control BannerBmp on dialog ProgressForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ProgressForm, BannerBmp, to the right
DEBUG: Error 2826: Control Line1 on dialog ProgressForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ProgressForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog ProgressForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ProgressForm, Line2, to the right
Action 8:47:08: ProgressForm. Dialog created
Action ended 8:47:08: ProgressForm. Return value 1.
Action 8:47:08: ExecuteAction.
Action start 8:47:08: ExecuteAction.
Action 8:47:08: INSTALL.
Action start 8:47:08: INSTALL.
Action 8:47:08: DIRCA_CheckFX.
Action start 8:47:08: DIRCA_CheckFX.
Action ended 8:47:09: DIRCA_CheckFX. Return value 1.
Action 8:47:09: AppSearch. Searching for installed applications
Action start 8:47:09: AppSearch.
Action ended 8:47:09: AppSearch. Return value 0.
Action 8:47:09: FindRelatedProducts. Searching for related applications
Action start 8:47:09: FindRelatedProducts.
Action ended 8:47:09: FindRelatedProducts. Return value 0.
Action 8:47:09: VSDCA_VsdLaunchConditions.
Action start 8:47:09: VSDCA_VsdLaunchConditions.
Action ended 8:47:09: VSDCA_VsdLaunchConditions. Return value 1.
Action 8:47:09: LaunchConditions. Evaluating launch conditions
Action start 8:47:09: LaunchConditions.
Action ended 8:47:09: LaunchConditions. Return value 1.
Action 8:47:09: CCPSearch. Searching for qualifying products
Action start 8:47:09: CCPSearch.
Action ended 8:47:09: CCPSearch. Return value 0.
Action 8:47:09: RMCCPSearch. Searching for qualifying products
Action start 8:47:09: RMCCPSearch.
Action ended 8:47:09: RMCCPSearch. Return value 0.
Action 8:47:09: ValidateProductID.
Action start 8:47:09: ValidateProductID.
Action ended 8:47:09: ValidateProductID. Return value 1.
Action 8:47:09: CustomTextA_SetProperty_EDIT1.
Action start 8:47:09: CustomTextA_SetProperty_EDIT1.
Action ended 8:47:09: CustomTextA_SetProperty_EDIT1. Return value 0.
Action 8:47:09: CustomTextA_SetProperty_EDIT2.
Action start 8:47:09: CustomTextA_SetProperty_EDIT2.
Action ended 8:47:09: CustomTextA_SetProperty_EDIT2. Return value 0.
Action 8:47:09: CustomTextA_SetProperty_EDIT3.
Action start 8:47:09: CustomTextA_SetProperty_EDIT3.
Action ended 8:47:09: CustomTextA_SetProperty_EDIT3. Return value 0.
Action 8:47:09: CustomTextA_SetProperty_EDIT4.
Action start 8:47:09: CustomTextA_SetProperty_EDIT4.
Action ended 8:47:09: CustomTextA_SetProperty_EDIT4. Return value 0.
Action 8:47:09: CostInitialize. Computing space requirements
Action start 8:47:09: CostInitialize.
Action ended 8:47:09: CostInitialize. Return value 1.
Action 8:47:09: FileCost. Computing space requirements
Action start 8:47:09: FileCost.
Action ended 8:47:09: FileCost. Return value 1.
Action 8:47:09: IsolateComponents.
Action start 8:47:09: IsolateComponents.
Action ended 8:47:09: IsolateComponents. Return value 1.
Action 8:47:09: CostFinalize. Computing space requirements
Action start 8:47:09: CostFinalize.
Action ended 8:47:09: CostFinalize. Return value 1.
Action 8:47:09: SetODBCFolders. Initializing ODBC directories
Action start 8:47:09: SetODBCFolders.
Action ended 8:47:09: SetODBCFolders. Return value 1.
Action 8:47:09: InstallValidate. Validating install
Action start 8:47:09: InstallValidate.
Action ended 8:47:09: InstallValidate. Return value 1.
Action 8:47:09: InstallInitialize.
Action start 8:47:09: InstallInitialize.
Action ended 8:47:09: InstallInitialize. Return value 1.
Action 8:47:09: RemoveExistingProducts. Removing applications
Action start 8:47:09: RemoveExistingProducts.
Action ended 8:47:09: RemoveExistingProducts. Return value 1.
Action 8:47:09: AllocateRegistrySpace. Allocating registry space
Action start 8:47:09: AllocateRegistrySpace.
Action ended 8:47:09: AllocateRegistrySpace. Return value 1.
Action 8:47:09: ProcessComponents. Updating component registration
Action start 8:47:09: ProcessComponents.
Action 8:47:09: GenerateScript. Generating script operations for action:
GenerateScript: Updating component registration
Action ended 8:47:09: ProcessComponents. Return value 1.
Action 8:47:09: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 8:47:09: MsiUnpublishAssemblies.
Action ended 8:47:09: MsiUnpublishAssemblies. Return value 1.
Action 8:47:09: UnpublishComponents. Unpublishing Qualified Components
Action start 8:47:09: UnpublishComponents.
Action ended 8:47:09: UnpublishComponents. Return value 1.
Action 8:47:09: UnpublishFeatures. Unpublishing Product Features
Action start 8:47:09: UnpublishFeatures.
Action ended 8:47:09: UnpublishFeatures. Return value 1.
Action 8:47:09: StopServices. Stopping services
Action start 8:47:09: StopServices.
Action ended 8:47:09: StopServices. Return value 1.
Action 8:47:09: DeleteServices. Deleting services
Action start 8:47:09: DeleteServices.
Action ended 8:47:09: DeleteServices. Return value 1.
Action 8:47:09: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 8:47:09: UnregisterComPlus.
Action ended 8:47:09: UnregisterComPlus. Return value 1.
Action 8:47:09: SelfUnregModules. Unregistering modules
Action start 8:47:09: SelfUnregModules.
Action ended 8:47:09: SelfUnregModules. Return value 1.
Action 8:47:09: UnregisterTypeLibraries. Unregistering type libraries
Action start 8:47:09: UnregisterTypeLibraries.
Action ended 8:47:09: UnregisterTypeLibraries. Return value 1.
Action 8:47:09: RemoveODBC. Removing ODBC components
Action start 8:47:09: RemoveODBC.
RemoveODBC:
Action ended 8:47:09: RemoveODBC. Return value 1.
Action 8:47:09: UnregisterFonts. Unregistering fonts
Action start 8:47:09: UnregisterFonts.
Action ended 8:47:09: UnregisterFonts. Return value 1.
Action 8:47:09: RemoveRegistryValues. Removing system registry values
Action start 8:47:09: RemoveRegistryValues.
Action ended 8:47:09: RemoveRegistryValues. Return value 1.
Action 8:47:09: UnregisterClassInfo. Unregister Class servers
Action start 8:47:09: UnregisterClassInfo.
Action ended 8:47:09: UnregisterClassInfo. Return value 1.
Action 8:47:09: UnregisterExtensionInfo. Unregistering extension servers
Action start 8:47:09: UnregisterExtensionInfo.
Action ended 8:47:09: UnregisterExtensionInfo. Return value 1.
Action 8:47:09: UnregisterProgIdInfo. Unregistering program identifiers
Action start 8:47:09: UnregisterProgIdInfo.
Action ended 8:47:09: UnregisterProgIdInfo. Return value 1.
Action 8:47:09: UnregisterMIMEInfo. Unregistering MIME info
Action start 8:47:09: UnregisterMIMEInfo.
Action ended 8:47:09: UnregisterMIMEInfo. Return value 1.
Action 8:47:09: RemoveIniValues. Removing INI files entries
Action start 8:47:09: RemoveIniValues.
Action ended 8:47:09: RemoveIniValues. Return value 1.
Action 8:47:09: RemoveShortcuts. Removing shortcuts
Action start 8:47:09: RemoveShortcuts.
Action ended 8:47:09: RemoveShortcuts. Return value 1.
Action 8:47:09: RemoveEnvironmentStrings. Updating environment strings
Action start 8:47:09: RemoveEnvironmentStrings.
Action ended 8:47:09: RemoveEnvironmentStrings. Return value 1.
Action 8:47:09: RemoveDuplicateFiles. Removing duplicated files
Action start 8:47:09: RemoveDuplicateFiles.
Action ended 8:47:09: RemoveDuplicateFiles. Return value 1.
Action 8:47:09: RemoveFiles. Removing files
Action start 8:47:09: RemoveFiles.
Action ended 8:47:09: RemoveFiles. Return value 1.
Action 8:47:09: RemoveFolders. Removing folders
Action start 8:47:09: RemoveFolders.
Action ended 8:47:09: RemoveFolders. Return value 1.
Action 8:47:09: CreateFolders. Creating folders
Action start 8:47:09: CreateFolders.
Action ended 8:47:09: CreateFolders. Return value 1.
Action 8:47:09: MoveFiles. Moving files
Action start 8:47:09: MoveFiles.
Action ended 8:47:09: MoveFiles. Return value 1.
Action 8:47:09: InstallFiles. Copying new files
Action start 8:47:09: InstallFiles.
InstallFiles: File: Copying new files, Directory: , Size:
Action ended 8:47:09: InstallFiles. Return value 1.
Action 8:47:09: PatchFiles. Patching files
Action start 8:47:09: PatchFiles.
Action ended 8:47:09: PatchFiles. Return value 1.
Action 8:47:09: DuplicateFiles. Creating duplicate files
Action start 8:47:09: DuplicateFiles.
Action ended 8:47:09: DuplicateFiles. Return value 1.
Action 8:47:09: BindImage. Binding executables
Action start 8:47:09: BindImage.
Action ended 8:47:09: BindImage. Return value 1.
Action 8:47:09: CreateShortcuts. Creating shortcuts
Action start 8:47:09: CreateShortcuts.
CreateShortcuts: Shortcut: Creating shortcuts
Action ended 8:47:09: CreateShortcuts. Return value 1.
Action 8:47:09: RegisterClassInfo. Registering Class servers
Action start 8:47:09: RegisterClassInfo.
Action ended 8:47:09: RegisterClassInfo. Return value 1.
Action 8:47:09: RegisterExtensionInfo. Registering extension servers
Action start 8:47:09: RegisterExtensionInfo.
Action ended 8:47:09: RegisterExtensionInfo. Return value 1.
Action 8:47:09: RegisterProgIdInfo. Registering program identifiers
Action start 8:47:09: RegisterProgIdInfo.
Action ended 8:47:09: RegisterProgIdInfo. Return value 1.
Action 8:47:09: RegisterMIMEInfo. Registering MIME info
Action start 8:47:09: RegisterMIMEInfo.
Action ended 8:47:09: RegisterMIMEInfo. Return value 1.
Action 8:47:09: WriteRegistryValues. Writing system registry values
Action start 8:47:09: WriteRegistryValues.
Action ended 8:47:09: WriteRegistryValues. Return value 1.
Action 8:47:09: WriteIniValues. Writing INI files values
Action start 8:47:09: WriteIniValues.
Action ended 8:47:09: WriteIniValues. Return value 1.
Action 8:47:09: WriteEnvironmentStrings. Updating environment strings
Action start 8:47:09: WriteEnvironmentStrings.
Action ended 8:47:09: WriteEnvironmentStrings. Return value 1.
Action 8:47:09: RegisterFonts. Registering fonts
Action start 8:47:09: RegisterFonts.
Action ended 8:47:09: RegisterFonts. Return value 1.
Action 8:47:09: InstallODBC. Installing ODBC components
Action start 8:47:09: InstallODBC.
Action ended 8:47:09: InstallODBC. Return value 0.
Action 8:47:09: RegisterTypeLibraries. Registering type libraries
Action start 8:47:09: RegisterTypeLibraries.
Action ended 8:47:09: RegisterTypeLibraries. Return value 1.
Action 8:47:09: SelfRegModules. Registering modules
Action start 8:47:09: SelfRegModules.
Action ended 8:47:09: SelfRegModules. Return value 1.
Action 8:47:09: RegisterComPlus. Registering COM+ Applications and Components
Action start 8:47:09: RegisterComPlus.
Action ended 8:47:09: RegisterComPlus. Return value 1.
Action 8:47:09: InstallServices. Installing new services
Action start 8:47:09: InstallServices.
Action ended 8:47:09: InstallServices. Return value 1.
Action 8:47:09: StartServices. Starting services
Action start 8:47:09: StartServices.
Action ended 8:47:09: StartServices. Return value 1.
Action 8:47:09: _7B602BF0_0D9A_41F1_9287_1A035FB87175.SetProperty.
Action start 8:47:09: _7B602BF0_0D9A_41F1_9287_1A035FB87175.SetProperty.
Action ended 8:47:09: _7B602BF0_0D9A_41F1_9287_1A035FB87175.SetProperty. Return value 1.
_7B602BF0_0D9A_41F1_9287_1A035FB87175:
Action ended 8:47:09: _7B602BF0_0D9A_41F1_9287_1A035FB87175. Return value 1.
Action 8:47:09: RegisterUser. Registering user
Action start 8:47:09: RegisterUser.
Action ended 8:47:09: RegisterUser. Return value 1.
Action 8:47:09: RegisterProduct. Registering product
Action start 8:47:09: RegisterProduct.
RegisterProduct: Registering product
Action ended 8:47:09: RegisterProduct. Return value 1.
Action 8:47:09: PublishComponents. Publishing Qualified Components
Action start 8:47:09: PublishComponents.
Action ended 8:47:09: PublishComponents. Return value 1.
Action 8:47:09: MsiPublishAssemblies. Publishing assembly information
Action start 8:47:09: MsiPublishAssemblies.
MsiPublishAssemblies: Application Context:Publishing assembly information, Assembly Name:
Action ended 8:47:09: MsiPublishAssemblies. Return value 1.
Action 8:47:09: PublishFeatures. Publishing Product Features
Action start 8:47:09: PublishFeatures.
PublishFeatures: Feature: Publishing Product Features
Action ended 8:47:09: PublishFeatures. Return value 1.
Action 8:47:09: PublishProduct. Publishing product information
Action start 8:47:09: PublishProduct.
PublishProduct:
Action ended 8:47:09: PublishProduct. Return value 1.
Action 8:47:09: InstallFinalize.
Action start 8:47:09: InstallFinalize.
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {0B2E260E-0559-4BA7-0E7C-895D6B17182A} 3: C:\Program Files\MPICH2\lib\cxx.lib
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {377F7EA5-53A5-D038-7A57-80538B1E44F2} 3: C:\Program Files\MPICH2\examples\examples.sln
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {11CD2E8E-C0F1-2807-BA7D-ADF34D406A18} 3: C:\Program Files\MPICH2\bin\clog2TOslog2.jar
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {D94AA0EB-95F3-1377-8AE9-047507D32F3D} 3: C:\Program Files\MPICH2\lib\fmpich2g.lib
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {BC57862F-3B65-90B8-3C46-1B09C024EC4A} 3: C:\Program Files\MPICH2\include\clog_inttypes.h
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {D767F506-5E39-9927-67D8-D1C45FABA4F4} 3: C:\windows\system32\mpich2nemesisp.dll
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {9E971F96-835C-A20C-CB55-110F66432E21} 3: C:\Program Files\MPICH2\include\mpe_misc.h
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {09BBBA84-0563-2219-ACD9-0C46282A4C48} 3: C:\Program Files\MPICH2\include\mpi_constants.mod
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {427ACCC7-57B0-E441-0016-256816DB6EE4} 3: C:\Program Files\MPICH2\lib\libmpicxx.a
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {09396970-EB86-BE36-E15C-DB0A308B5EF1} 3: C:\windows\system32\mpich2mpe.dll
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {172ECD54-74BD-FEE1-D81F-DF45862072AC} 3: C:\Program Files\MPICH2\bin\wmpiregister.exe
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {3235E6FF-130F-6CE1-EC4E-B9E2A20E9784} 3: C:\windows\system32\mpe.dll
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {80BB7D01-DA72-F301-B319-0595A822EA7F} 3: C:\Program Files\MPICH2\lib\libmpi.a
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {A8E12F2B-4C08-160E-4AD6-57602F1D1FD1} 3: C:\Program Files\MPICH2\bin\smpd.exe
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {52645022-7960-4D56-E5C8-00114AC98372} 3: C:\Program Files\MPICH2\bin\wmpiexec.exe
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {626590B6-A4EC-2C9B-808A-481B911C96BB} 3: C:\Program Files\MPICH2\include\mpe_log.h
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {BED9D96A-E0D5-CDA0-67B2-B9BDC1F2F3DA} 3: C:\Program Files\MPICH2\include\mpi.mod
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {845B5980-B10B-0C77-2396-E3A5A6EC9432} 3: C:\Program Files\MPICH2\include\mpif.h
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {F52533F4-764B-EF9D-D34D-69C43B647F23} 3: C:\Program Files\MPICH2\examples\fpi.f
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {A027FA4F-6058-852B-2B1B-0BC409E10080} 3: C:\windows\system32\mpich2mt.dll
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {E6180C2D-5015-BA8A-DAE0-4BEA96E6DDF7} 3: C:\Program Files\MPICH2\lib\TraceInput.lib
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {4E7A44B9-B178-2246-9ABD-61ECAA1C04AD} 3: C:\Program Files\MPICH2\bin\jumpshot_launcher.jar
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {AF36B41C-D39E-0C78-825F-F8F1A47C3E1B} 3: C:\Program Files\MPICH2\include\mpe.h
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {2EAE76CB-CF36-EC1E-FE79-C176F63508B9} 3: C:\Program Files\MPICH2\include\mpi_base.mod
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {85B8070F-A3A1-9D12-BA20-F0B7A7C1B2F3} 3: C:\Program Files\MPICH2\setup.jpg
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {7094A366-B358-8324-4E39-AB0F6957E9F9} 3: C:\Program Files\MPICH2\lib\rlog.lib
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {A6439F5F-E43F-6FB9-BCFE-5588D3842208} 3: C:\Program Files\MPICH2\examples\cxxpi.cxx
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {DE616448-6A5B-A2C3-E6D6-64626CB5BA93} 3: C:\windows\system32\mpich2nemesis.dll
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {354C076C-752D-E6DE-AC09-8C54B51C73AB} 3: C:\Program Files\MPICH2\lib\mpi.lib
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {8BD99ED2-6FB4-09F1-F769-36EBC5CBD902} 3: C:\windows\system32\fmpich2.dll
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {42389D89-464C-D40A-B674-CAB83866F452} 3: C:\Program Files\MPICH2\include\mpicxx.h
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {6337169C-5A81-C60A-E25C-02E162A2650E} 3: C:\Program Files\MPICH2\lib\irlog2rlog.lib
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {2A386E76-EBAF-D453-2C29-F865B3A7D9AC} 3: C:\Program Files\MPICH2\bin\irlog2rlog.exe
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {A3426275-8272-39AF-4474-C0477027E10C} 3: C:\Program Files\MPICH2\include\clog_const.h
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {C0C07408-F505-E57C-BE26-6B8E0C0488E7} 3: C:\windows\system32\mpich2mtp.dll
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {A80DA15A-F7DE-14F8-D3C5-BDF39D9BCA11} 3: C:\windows\system32\mpich2mpi.dll
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {C3E5D6EB-8258-CAB0-7F0A-A1A6F978C920} 3: C:\windows\system32\mpich2p.dll
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {E5786443-E433-D4B2-9743-5DB4BE83D7AC} 3: C:\Program Files\MPICH2\COPYRIGHT.rtf
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {A7D1678F-E143-9BB9-413A-11F3E85FE41F} 3: C:\Program Files\MPICH2\README.winbin.rtf
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {A5C92A4F-0E0A-D23B-852A-8457A11313DA} 3: C:\windows\system32\TraceInput.dll
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {5CCBB9F7-75F0-7E9C-5A72-6A2BA46E3184} 3: C:\Program Files\MPICH2\lib\fmpich2.lib
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {C653DBB5-8B1D-902E-8BBE-600E76C990F9} 3: C:\Program Files\MPICH2\bin\mpiexec.exe
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {C0EFAD0B-6F99-CB15-3CB5-512F1CFCCD5B} 3: C:\Program Files\MPICH2\bin\jumpshot.jar
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {D7ADF4BA-C22C-99C3-6919-B507C14AE293} 3: C:\Program Files\MPICH2\include\mpio.h
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {21DCEC83-D3E9-9B71-EB8D-C53434EFA844} 3: C:\Program Files\MPICH2\include\mpi_sizeofs.mod
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {192A5E68-8018-D271-038F-B2EE2F5F4144} 3: C:\Program Files\MPICH2\include\clog_commset.h
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {BC762AF4-3626-E416-88CC-8FD38240A7F6} 3: C:\Program Files\MPICH2\examples\cpi.exe
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {6C93D22F-B390-5AB6-F03B-4A98CAF0F55C} 3: C:\windows\system32\fmpich2g.dll
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {C0F88752-27FE-0F87-0D32-517F83FF04BB} 3: C:\Program Files\MPICH2\include\mpe_logf.h
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {5AA8792B-499D-5FA5-8B11-EE99D2DB3ABD} 3: C:\Program Files\MPICH2\examples\icpi.c
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {2327389C-558E-C1D9-A4F5-EA3595128CBF} 3: C:\Program Files\MPICH2\examples\fpi.vfproj
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {E1D179A6-36C9-E437-E6B0-159B9A7CDA56} 3: C:\Program Files\MPICH2\lib\mpe.lib
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {6553A06B-4C7A-F506-914F-DE0930921774} 3: C:\Program Files\MPICH2\include\mpi.h
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {1A7ACB47-47C0-8024-0DC9-431CE9B371EE} 3: C:\windows\system32\mpich2.dll
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {2416FDD0-33B1-08AB-7325-6C2B46502983} 3: C:\Program Files\MPICH2\include\clog_uuid.h
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {EB02857F-DF89-4306-68E4-3DB8704EB81D} 3: C:\Program Files\MPICH2\examples\cpi.vcproj
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {438A3621-E0F3-3767-9263-5890A20E3B8E} 3: C:\Program Files\MPICH2\examples\cxxpi.vcproj
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {4095982A-3F88-9DE5-3CBD-56EB4A4A750B} 3: C:\Program Files\MPICH2\lib\libfmpich2g.a
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {56860D72-E23C-8947-5A1C-FAADCED1B37E} 3: C:\Program Files\MPICH2\bin\wmpiconfig.exe
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {5EBDFA66-B26B-CB1F-7435-CA58D78A7AC5} 3: C:\Program Files\MPICH2\bin\traceTOslog2.jar
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 3: C:\Program Files\MPICH2\
InstallFiles: File: cxx.lib, Directory: C:\Program Files\MPICH2\lib\, Size: 324322
InstallFiles: File: examples.sln, Directory: C:\Program Files\MPICH2\examples\, Size: 2709
InstallFiles: File: clog2TOslog2.jar, Directory: C:\Program Files\MPICH2\bin\, Size: 183747
InstallFiles: File: fmpich2g.lib, Directory: C:\Program Files\MPICH2\lib\, Size: 400390
InstallFiles: File: clog_inttypes.h, Directory: C:\Program Files\MPICH2\include\, Size: 731
InstallFiles: File: mpich2nemesisp.dll, Directory: C:\windows\system32\, Size: 2089984
InstallFiles: File: mpe_misc.h, Directory: C:\Program Files\MPICH2\include\, Size: 1322
InstallFiles: File: mpi_constants.mod, Directory: C:\Program Files\MPICH2\include\, Size: 36141
InstallFiles: File: libmpicxx.a, Directory: C:\Program Files\MPICH2\lib\, Size: 210386
InstallFiles: File: mpich2mpe.dll, Directory: C:\windows\system32\, Size: 169472
InstallFiles: File: wmpiregister.exe, Directory: C:\Program Files\MPICH2\bin\, Size: 24576
InstallFiles: File: mpe.dll, Directory: C:\windows\system32\, Size: 155136
InstallFiles: File: libmpi.a, Directory: C:\Program Files\MPICH2\lib\, Size: 474252
InstallFiles: File: smpd.exe, Directory: C:\Program Files\MPICH2\bin\, Size: 1224192
InstallFiles: File: wmpiexec.exe, Directory: C:\Program Files\MPICH2\bin\, Size: 65536
InstallFiles: File: mpe_log.h, Directory: C:\Program Files\MPICH2\include\, Size: 11102
InstallFiles: File: mpi.mod, Directory: C:\Program Files\MPICH2\include\, Size: 3702
InstallFiles: File: mpif.h, Directory: C:\Program Files\MPICH2\include\, Size: 19119
InstallFiles: File: fpi.f, Directory: C:\Program Files\MPICH2\examples\, Size: 2422
InstallFiles: File: mpich2mt.dll, Directory: C:\windows\system32\, Size: 1690112
InstallFiles: File: TraceInput.lib, Directory: C:\Program Files\MPICH2\lib\, Size: 4644
InstallFiles: File: jumpshot_launcher.jar, Directory: C:\Program Files\MPICH2\bin\, Size: 7140
InstallFiles: File: mpe.h, Directory: C:\Program Files\MPICH2\include\, Size: 355
InstallFiles: File: mpi_base.mod, Directory: C:\Program Files\MPICH2\include\, Size: 90551
InstallFiles: File: setup.jpg, Directory: C:\Program Files\MPICH2\, Size: 4698
InstallFiles: File: rlog.lib, Directory: C:\Program Files\MPICH2\lib\, Size: 93844
InstallFiles: File: cxxpi.cxx, Directory: C:\Program Files\MPICH2\examples\, Size: 1497
InstallFiles: File: mpich2nemesis.dll, Directory: C:\windows\system32\, Size: 1794560
InstallFiles: File: mpi.lib, Directory: C:\Program Files\MPICH2\lib\, Size: 132360
InstallFiles: File: fmpich2.dll, Directory: C:\windows\system32\, Size: 185856
InstallFiles: File: mpicxx.h, Directory: C:\Program Files\MPICH2\include\, Size: 100243
InstallFiles: File: irlog2rlog.lib, Directory: C:\Program Files\MPICH2\lib\, Size: 1936
InstallFiles: File: irlog2rlog.exe, Directory: C:\Program Files\MPICH2\bin\, Size: 744448
InstallFiles: File: clog_const.h, Directory: C:\Program Files\MPICH2\include\, Size: 696
InstallFiles: File: mpich2mtp.dll, Directory: C:\windows\system32\, Size: 1940480
InstallFiles: File: mpich2mpi.dll, Directory: C:\windows\system32\, Size: 230912
InstallFiles: File: mpich2p.dll, Directory: C:\windows\system32\, Size: 1883136
InstallFiles: File: COPYRIGHT.rtf, Directory: C:\Program Files\MPICH2\, Size: 8076
InstallFiles: File: README.winbin.rtf, Directory: C:\Program Files\MPICH2\, Size: 20772
InstallFiles: File: TraceInput.dll, Directory: C:\windows\system32\, Size: 762368
InstallFiles: File: fmpich2.lib, Directory: C:\Program Files\MPICH2\lib\, Size: 133560
InstallFiles: File: mpiexec.exe, Directory: C:\Program Files\MPICH2\bin\, Size: 1233920
InstallFiles: File: jumpshot.jar, Directory: C:\Program Files\MPICH2\bin\, Size: 2449314
InstallFiles: File: mpio.h, Directory: C:\Program Files\MPICH2\include\, Size: 16765
InstallFiles: File: mpi_sizeofs.mod, Directory: C:\Program Files\MPICH2\include\, Size: 8417
InstallFiles: File: clog_commset.h, Directory: C:\Program Files\MPICH2\include\, Size: 4857
InstallFiles: File: cpi.exe, Directory: C:\Program Files\MPICH2\examples\, Size: 96256
InstallFiles: File: fmpich2g.dll, Directory: C:\windows\system32\, Size: 177152
InstallFiles: File: mpe_logf.h, Directory: C:\Program Files\MPICH2\include\, Size: 1833
InstallFiles: File: icpi.c, Directory: C:\Program Files\MPICH2\examples\, Size: 1892
InstallFiles: File: fpi.vfproj, Directory: C:\Program Files\MPICH2\examples\, Size: 4769
InstallFiles: File: mpe.lib, Directory: C:\Program Files\MPICH2\lib\, Size: 10430
InstallFiles: File: mpi.h, Directory: C:\Program Files\MPICH2\include\, Size: 57471
InstallFiles: File: mpich2.dll, Directory: C:\windows\system32\, Size: 1624064
InstallFiles: File: clog_uuid.h, Directory: C:\Program Files\MPICH2\include\, Size: 1353
InstallFiles: File: cpi.vcproj, Directory: C:\Program Files\MPICH2\examples\, Size: 7948
InstallFiles: File: cxxpi.vcproj, Directory: C:\Program Files\MPICH2\examples\, Size: 8001
InstallFiles: File: libfmpich2g.a, Directory: C:\Program Files\MPICH2\lib\, Size: 1420022
InstallFiles: File: wmpiconfig.exe, Directory: C:\Program Files\MPICH2\bin\, Size: 57344
InstallFiles: File: traceTOslog2.jar, Directory: C:\Program Files\MPICH2\bin\, Size: 124160
CreateShortcuts: Shortcut: _1A72A7A9B31D3268ADA44D.exe
CreateShortcuts: Shortcut: _A95E1C5CA15927931738DD.exe
CreateShortcuts: Shortcut: _0C3D3CDE1A03DC9ACF3C29.exe
CreateShortcuts: Shortcut: _6DFEE413436AA4645545C2.exe
CreateShortcuts: Shortcut: _F694F6283077EDDE193631.exe
CreateShortcuts: Shortcut: WMPICO~1|wmpiconfig
CreateShortcuts: Shortcut: WMPIRE~1|wmpiregister
CreateShortcuts: Shortcut: README|README
CreateShortcuts: Shortcut: JUMPSHOT|Jumpshot
CreateShortcuts: Shortcut: WMPIEXEC|wmpiexec
Action 8:47:10: RegisterProduct. Registering product
RegisterProduct: {B91EB9DA-98D2-4241-87EA-3D889B58D564}
Action 8:47:10: MsiPublishAssemblies. Publishing assembly information
MsiPublishAssemblies: Application Context:C:|Program Files|MPICH2|bin|wmpiregister.exe, Assembly Name:wmpiregister,Version="1.0.4261.26123",Culture="neutral",ProcessorArchitecture="MSIL"
MsiPublishAssemblies: Application Context:C:|Program Files|MPICH2|bin|wmpiexec.exe, Assembly Name:wmpiexec,Version="1.0.4261.26123",Culture="neutral",ProcessorArchitecture="MSIL"
MsiPublishAssemblies: Application Context:C:|Program Files|MPICH2|bin|wmpiconfig.exe, Assembly Name:wmpiconfig,Version="1.0.4261.26123",Culture="neutral",ProcessorArchitecture="MSIL"
Action 8:47:10: PublishFeatures. Publishing Product Features
PublishFeatures: Feature: DefaultFeature
Action 8:47:10: PublishProduct. Publishing product information
Action 8:47:10: RollbackCleanup. Removing backup files
Action ended 8:47:10: InstallFinalize. Return value 1.
Action ended 8:47:10: INSTALL. Return value 1.
Property(S): UpgradeCode = {41CCEB45-5BE3-4FF2-B71D-A418475B1DA8}
Property(S): _7B602BF0_0D9A_41F1_9287_1A035FB87175 = /install /phrase=behappy
Property(S): TARGETDIR = C:\Program Files\MPICH2\
Property(S): _77F9D1A44492419B8EA01D818793C7CA = C:\Program Files\MPICH2\lib\
Property(S): _15B081C07B80455AA965AC7E9A659F74 = C:\Program Files\MPICH2\examples\
Property(S): _BF9ED70B3DDE44248765F4866DCC194E = C:\Program Files\MPICH2\bin\
Property(S): _D9EB9C14165A4573993ACC376ED0CA0F = C:\Program Files\MPICH2\include\
Property(S): System64Folder = C:\windows\system32\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): _CF76DBB4C22C469F8CE5EB5E6718C2EE = C:\Users\Sam\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\MPICH2\
Property(S): SourceDir = C:\Users\Sam\
Property(S): VSRUNTIMELIBEXISTS = C:\windows\WinSxS\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4940_none_88df89932faf0bf6\MSVCR80.DLL
Property(S): AdminUser = 1
Property(S): VSDFXAvailable = TRUE
Property(S): VSDFrameworkVersion = 2.0.50727
Property(S): VSDAllowLaterFrameworkVersions = False
Property(S): ProductName = MPICH2 64-bit
Property(S): ProductCode = {B91EB9DA-98D2-4241-87EA-3D889B58D564}
Property(S): ProductVersion = 1.4.1
Property(S): Manufacturer = Argonne National Laboratory
Property(S): ARPHELPLINK = www.mcs.anl.gov/mpi/mpich2
Property(S): ARPCONTACT = Argonne National Laboratory
Property(S): ARPURLINFOABOUT = www.mcs.anl.gov/mpi/mpich2
Property(S): ProductLanguage = 1033
Property(S): SecureCustomProperties = PREVIOUSVERSIONSINSTALLED;NEWERPRODUCTFOUND
Property(S): RedirectedDllSupport = 2
Property(S): VersionNT = 601
Property(S): VSDNETURLMSG = This setup requires the .NET Framework version 2.0.50727. Please install the .NET Framework and run this setup again. The .NET Framework can be obtained from the web. Would you like to do this now?
Property(S): VSDIISMSG = This setup requires Internet Information Server 4.0 or higher and Windows NT 4.0, Windows 2000 or higher. This setup cannot be installed on Windows 95, Windows 98, or Windows Me. Please install Internet Information Server and run this setup again.
Property(S): VSDUIANDADVERTISED = This advertised application will not be installed because it might be unsafe. Contact your administrator to change the installation user interface option of the package to basic.
Property(S): VSDNETMSG = This setup requires the .NET Framework version 2.0.50727. Please install the .NET Framework and run this setup again.
Property(S): VSDINVALIDURLMSG = The specified path '[2]' is unavailable. The Internet Information Server might not be running or the path exists and is redirected to another machine. Please check the status of this virtual directory in the Internet Services Manager.
Property(S): VSDVERSIONMSG = Unable to install because a newer version of this product is already installed.
Property(S): AdminEulaForm_Property = No
Property(S): MaintenanceForm_Action = Repair
Property(S): ErrorDialog = ErrorDialog
Property(S): SFF_UpFldrBtn = UpFldrBtn
Property(S): SFF_NewFldrBtn = NewFldrBtn
Property(S): EulaForm_Property = No
Property(S): EDITA1 = 1
Property(S): PHRASE = behappy
Property(S): FolderForm_AllUsers = ME
Property(S): FolderForm_AllUsersVisible = 1
Property(S): AdminMaintenanceForm_Action = Repair
Property(S): DefaultUIFont = VsdDefaultUIFont.524F4245_5254_5341_4C45_534153783400
Property(S): AdminWelcomeForm_NextArgs = AdminReadmeForm
Property(S): AdminReadmeForm_PrevArgs = AdminWelcomeForm
Property(S): AdminReadmeForm_NextArgs = AdminEulaForm
Property(S): AdminEulaForm_PrevArgs = AdminReadmeForm
Property(S): AdminEulaForm_NextArgs = AdminFolderForm
Property(S): AdminFolderForm_PrevArgs = AdminEulaForm
Property(S): AdminFolderForm_NextArgs = AdminConfirmInstallForm
Property(S): AdminConfirmInstallForm_PrevArgs = AdminFolderForm
Property(S): WelcomeForm_NextArgs = ReadmeForm
Property(S): ReadmeForm_PrevArgs = WelcomeForm
Property(S): ReadmeForm_NextArgs = EulaForm
Property(S): EulaForm_PrevArgs = ReadmeForm
Property(S): EulaForm_NextArgs = CustomTextA
Property(S): CustomTextA_PrevArgs = EulaForm
Property(S): FolderForm_NextArgs = ConfirmInstallForm
Property(S): ConfirmInstallForm_PrevArgs = FolderForm
Property(S): MsiLogFileLocation = C:\Users\Sam\mpich2-1.4.1p1-win-x86-64-install.log
Property(S): PackageCode = {8A8D8D33-4A69-47E5-A7C8-77FF5792F242}
Property(S): ALLUSERS = 1
Property(S): ProductState = -1
Property(S): PackagecodeChanging = 1
Property(S): CURRENTDIRECTORY = C:\Users\Sam
Property(S): CLIENTUILEVEL = 0
Property(S): CLIENTPROCESSID = 5388
Property(S): USERNAME = Sam
Property(S): VersionDatabase = 200
Property(S): ACTION = INSTALL
Property(S): EXECUTEACTION = INSTALL
Property(S): ROOTDRIVE = C:\
Property(S): INSTALLLEVEL = 1
Property(S): SECONDSEQUENCE = 1
Property(S): ADDLOCAL = DefaultFeature
Property(S): MsiSystemRebootPending = 1
Property(S): VersionMsi = 5.00
Property(S): VersionNT64 = 601
Property(S): WindowsBuild = 7601
Property(S): ServicePackLevel = 1
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): WindowsFolder = C:\windows\
Property(S): WindowsVolume = C:\
Property(S): SystemFolder = C:\windows\SysWOW64\
Property(S): RemoteAdminTS = 1
Property(S): TempFolder = C:\Users\Sam\AppData\Local\Temp\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): AppDataFolder = C:\Users\Sam\AppData\Roaming\
Property(S): FavoritesFolder = C:\Users\Sam\Favorites\
Property(S): NetHoodFolder = C:\Users\Sam\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): PersonalFolder = C:\Users\Sam\Documents\
Property(S): PrintHoodFolder = C:\Users\Sam\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): RecentFolder = C:\Users\Sam\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): SendToFolder = C:\Users\Sam\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): LocalAppDataFolder = C:\Users\Sam\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Sam\Pictures\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): FontsFolder = C:\windows\Fonts\
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): MsiAMD64 = 6
Property(S): Msix64 = 6
Property(S): Intel = 6
Property(S): PhysicalMemory = 12269
Property(S): VirtualMemory = 21542
Property(S): MsiTrueAdminUser = 1
Property(S): LogonUser = Sam
Property(S): UserSID = S-1-5-21-528498831-319965440-437876355-1001
Property(S): UserLanguageID = 1033
Property(S): ComputerName = SAM-LENOVO
Property(S): SystemLanguageID = 1033
Property(S): ScreenX = 1024
Property(S): ScreenY = 768
Property(S): CaptionHeight = 22
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 16
Property(S): TextInternalLeading = 3
Property(S): ColorBits = 32
Property(S): TTCSupport = 1
Property(S): Time = 8:47:10
Property(S): Date = 6/4/2012
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
Property(S): MsiRunningElevated = 1
Property(S): Privileged = 1
Property(S): DATABASE = C:\windows\Installer\1d7cd29b.msi
Property(S): OriginalDatabase = C:\Users\Sam\mpich2-1.4.1p1-win-x86-64.msi
Property(S): UILevel = 5
Property(S): Preselected = 1
Property(S): VSDFxConfigFile = C:\Users\Sam\AppData\Local\Temp\CFG22B7.tmp
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): SOURCEDIR = C:\Users\Sam\
Property(S): SourcedirProduct = {B91EB9DA-98D2-4241-87EA-3D889B58D564}
Property(S): ProductToBeRegistered = 1
Action ended 8:47:10: ExecuteAction. Return value 1.
Action 8:47:10: FinishedForm.
Action start 8:47:10: FinishedForm.
DEBUG: Error 2826: Control BannerBmp on dialog FinishedForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FinishedForm, BannerBmp, to the right
DEBUG: Error 2826: Control Line1 on dialog FinishedForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FinishedForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog FinishedForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FinishedForm, Line2, to the right
Action 8:47:10: FinishedForm. Dialog created
Action ended 8:47:16: FinishedForm. Return value 1.
Action ended 8:47:16: INSTALL. Return value 1.
Property(C): UpgradeCode = {41CCEB45-5BE3-4FF2-B71D-A418475B1DA8}
Property(C): TARGETDIR = C:\Program Files\MPICH2\
Property(C): _77F9D1A44492419B8EA01D818793C7CA = C:\Program Files\MPICH2\lib\
Property(C): _15B081C07B80455AA965AC7E9A659F74 = C:\Program Files\MPICH2\examples\
Property(C): _BF9ED70B3DDE44248765F4866DCC194E = C:\Program Files\MPICH2\bin\
Property(C): _D9EB9C14165A4573993ACC376ED0CA0F = C:\Program Files\MPICH2\include\
Property(C): System64Folder = C:\windows\system32\
Property(C): DesktopFolder = C:\Users\Public\Desktop\
Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(C): _CF76DBB4C22C469F8CE5EB5E6718C2EE = C:\Users\Sam\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\MPICH2\
Property(C): SourceDir = C:\Users\Sam\
Property(C): VSRUNTIMELIBEXISTS = C:\windows\WinSxS\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4940_none_88df89932faf0bf6\MSVCR80.DLL
Property(C): AdminUser = 1
Property(C): VSDFXAvailable = TRUE
Property(C): VSDFrameworkVersion = 2.0.50727
Property(C): VSDAllowLaterFrameworkVersions = False
Property(C): ProductName = MPICH2 64-bit
Property(C): ProductCode = {B91EB9DA-98D2-4241-87EA-3D889B58D564}
Property(C): ProductVersion = 1.4.1
Property(C): Manufacturer = Argonne National Laboratory
Property(C): ARPHELPLINK = www.mcs.anl.gov/mpi/mpich2
Property(C): ARPCONTACT = Argonne National Laboratory
Property(C): ARPURLINFOABOUT = www.mcs.anl.gov/mpi/mpich2
Property(C): ProductLanguage = 1033
Property(C): SecureCustomProperties = PREVIOUSVERSIONSINSTALLED;NEWERPRODUCTFOUND
Property(C): RedirectedDllSupport = 2
Property(C): VersionNT = 601
Property(C): VSDNETURLMSG = This setup requires the .NET Framework version 2.0.50727. Please install the .NET Framework and run this setup again. The .NET Framework can be obtained from the web. Would you like to do this now?
Property(C): VSDIISMSG = This setup requires Internet Information Server 4.0 or higher and Windows NT 4.0, Windows 2000 or higher. This setup cannot be installed on Windows 95, Windows 98, or Windows Me. Please install Internet Information Server and run this setup again.
Property(C): VSDUIANDADVERTISED = This advertised application will not be installed because it might be unsafe. Contact your administrator to change the installation user interface option of the package to basic.
Property(C): VSDNETMSG = This setup requires the .NET Framework version 2.0.50727. Please install the .NET Framework and run this setup again.
Property(C): VSDINVALIDURLMSG = The specified path '[2]' is unavailable. The Internet Information Server might not be running or the path exists and is redirected to another machine. Please check the status of this virtual directory in the Internet Services Manager.
Property(C): VSDVERSIONMSG = Unable to install because a newer version of this product is already installed.
Property(C): AdminEulaForm_Property = No
Property(C): MaintenanceForm_Action = Repair
Property(C): ErrorDialog = ErrorDialog
Property(C): SFF_UpFldrBtn = UpFldrBtn
Property(C): SFF_NewFldrBtn = NewFldrBtn
Property(C): EulaForm_Property = Yes
Property(C): EDITA1 = 1
Property(C): PHRASE = behappy
Property(C): FolderForm_AllUsers = ALL
Property(C): FolderForm_AllUsersVisible = 1
Property(C): AdminMaintenanceForm_Action = Repair
Property(C): DefaultUIFont = VsdDefaultUIFont.524F4245_5254_5341_4C45_534153783400
Property(C): AdminWelcomeForm_NextArgs = AdminReadmeForm
Property(C): AdminReadmeForm_PrevArgs = AdminWelcomeForm
Property(C): AdminReadmeForm_NextArgs = AdminEulaForm
Property(C): AdminEulaForm_PrevArgs = AdminReadmeForm
Property(C): AdminEulaForm_NextArgs = AdminFolderForm
Property(C): AdminFolderForm_PrevArgs = AdminEulaForm
Property(C): AdminFolderForm_NextArgs = AdminConfirmInstallForm
Property(C): AdminConfirmInstallForm_PrevArgs = AdminFolderForm
Property(C): WelcomeForm_NextArgs = ReadmeForm
Property(C): ReadmeForm_PrevArgs = WelcomeForm
Property(C): ReadmeForm_NextArgs = EulaForm
Property(C): EulaForm_PrevArgs = ReadmeForm
Property(C): EulaForm_NextArgs = CustomTextA
Property(C): CustomTextA_PrevArgs = EulaForm
Property(C): FolderForm_NextArgs = ConfirmInstallForm
Property(C): ConfirmInstallForm_PrevArgs = FolderForm
Property(C): MsiLogFileLocation = C:\Users\Sam\mpich2-1.4.1p1-win-x86-64-install.log
Property(C): PackageCode = {8A8D8D33-4A69-47E5-A7C8-77FF5792F242}
Property(C): ProductState = -1
Property(C): PackagecodeChanging = 1
Property(C): CURRENTDIRECTORY = C:\Users\Sam
Property(C): CLIENTUILEVEL = 0
Property(C): CLIENTPROCESSID = 5388
Property(C): MsiSystemRebootPending = 1
Property(C): VersionDatabase = 200
Property(C): VersionMsi = 5.00
Property(C): VersionNT64 = 601
Property(C): WindowsBuild = 7601
Property(C): ServicePackLevel = 1
Property(C): ServicePackLevelMinor = 0
Property(C): MsiNTProductType = 1
Property(C): MsiNTSuitePersonal = 1
Property(C): WindowsFolder = C:\windows\
Property(C): WindowsVolume = C:\
Property(C): SystemFolder = C:\windows\SysWOW64\
Property(C): RemoteAdminTS = 1
Property(C): TempFolder = C:\Users\Sam\AppData\Local\Temp\
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
