[mpich-discuss] linking error in moab
Dave Goodell
goodell at mcs.anl.gov
Mon Jun 4 23:18:35 CDT 2012
On Jun 4, 2012, at 7:49 PM CDT, Iulian Grindeanu wrote:
> p3.cpp
> iulian at T520-iuli:~/tmp$ more p3.cpp
> #include <mpi.h>
> int main (int argc, char * argv[] )
> MPI::Init(argc, argv);
> MPI::Finalize();
> return 0;
That's a pretty simple test program in which I can't see anything obviously wrong.
> If I am using my built version of mpich2, I get the same linking error. Although, in MOAB, we are not using MPI:: style, only MPI_xxx (c style)
> mpicxx p3.cpp
> /home/iulian/3rdparty/lib/mpich2/lib/libmpich.so: undefined reference to `MPL_trfree'
[snip]
> `MPL_trDebugLevel'
This Debian bug seems related: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=653616
> /home/iulian/3rdparty/lib/mpich2/lib/libmpich.so: undefined reference to `MPL_trid'
> collect2: ld returned 1 exit status
> iulian at T520-iuli:~/tmp$ mpich2version
> MPICH2 Version: 1.4.1p1
> MPICH2 Release date: Thu Sep 1 13:53:02 CDT 2011
> MPICH2 Device: ch3:nemesis
> MPICH2 configure: --enable-sharedlibs=gcc --enable-shared --with-pm=mpd:gforker --enable-totalview --enable-mpe --enable-fc --enable-f77 --enable-cxx --prefix=/home/iulian/3rdparty/lib/mpich2
> MPICH2 CC: gcc -O2
> MPICH2 CXX: g++ -O2
> MPICH2 F77: gfortran -O2
> MPICH2 FC: f95 -O2
I'd rather debug this build, since it has a much simpler configuration than the earlier one you posted. I don't see anything odd here.
> iulian at T520-iuli:~/tmp$ mpicxx -show
> g++ -I/home/iulian/3rdparty/lib/mpich2/include -L/home/iulian/3rdparty/lib/mpich2/lib -Wl,-rpath -Wl,/home/iulian/3rdparty/lib/mpich2/lib -lmpichcxx -lmpich -lopa -lmpl -lrt -lpthread
Same here, nothing obviously out of place. What output do you get from "ldd $HOME/3rdparty/lib/mpich2/lib/*.so"?
Does reconfiguring mpich2 with "--enable-lib-depend" fix the problem? I think this option was removed in 1.5a1 and later, but should still be present in 1.4.1p1.
What output do you get from "mpicxx -Wl,--version"? I have no idea which distributions may have started using the gold linker by default, or possibly you've chosen to install it instead. A non-GNU-ld linker might be the reason that I can't reproduce this on my end.
What does "env | grep '^LD'" give you?
-Dave
