[mpich-discuss] MPICH2 64-bit installation on Window 7 64-bit OS
    Sam Liao
    sliao at pharmaxresearch.com
    Mon Jun  4 16:52:21 CDT 2012
Hi:
I tried to install MPICH2 64-bit on Window 7 64-bit OS.  The installation
indicated successful.  However, the log file indicated unexpected error on
page 2 (see log below my email).   Can some help to resolve this problem?
Sam Liao
PharMax Research Inc.
PO Box 15661
Newport Beach, CA 92659
Phone: (201)-988-2043
Fax: (720)-294-6783
=== Logging started: 6/4/2012  8:46:23 ===
Action 8:46:23: INSTALL.
Action start 8:46:23: INSTALL.
Action 8:46:23: DIRCA_CheckFX.
Action start 8:46:23: DIRCA_CheckFX.
Action ended 8:46:24: DIRCA_CheckFX. Return value 1.
Action 8:46:24: AppSearch. Searching for installed applications
Action start 8:46:24: AppSearch.
AppSearch: Property: VSRUNTIMELIBEXISTS, Signature:
_1D1E69A8B74440B5BE6D0036E548EA67
Action ended 8:46:24: AppSearch. Return value 1.
Action 8:46:24: VSDCA_VsdLaunchConditions.
Action start 8:46:24: VSDCA_VsdLaunchConditions.
Action ended 8:46:24: VSDCA_VsdLaunchConditions. Return value 1.
Action 8:46:24: LaunchConditions. Evaluating launch conditions
Action start 8:46:24: LaunchConditions.
Action ended 8:46:24: LaunchConditions. Return value 1.
Action 8:46:24: CCPSearch. Searching for qualifying products
Action start 8:46:24: CCPSearch.
Action ended 8:46:24: CCPSearch. Return value 1.
Action 8:46:24: RMCCPSearch. Searching for qualifying products
Action start 8:46:24: RMCCPSearch.
Action ended 8:46:24: RMCCPSearch. Return value 0.
Action 8:46:24: ValidateProductID.
Action start 8:46:24: ValidateProductID.
Action ended 8:46:24: ValidateProductID. Return value 1.
Action 8:46:24: CustomTextA_SetProperty_EDIT1.
Action start 8:46:24: CustomTextA_SetProperty_EDIT1.
Action ended 8:46:24: CustomTextA_SetProperty_EDIT1. Return value 1.
Action 8:46:24: CustomTextA_SetProperty_EDIT2.
Action start 8:46:24: CustomTextA_SetProperty_EDIT2.
Action ended 8:46:24: CustomTextA_SetProperty_EDIT2. Return value 1.
Action 8:46:24: CustomTextA_SetProperty_EDIT3.
Action start 8:46:24: CustomTextA_SetProperty_EDIT3.
Action ended 8:46:24: CustomTextA_SetProperty_EDIT3. Return value 1.
Action 8:46:24: CustomTextA_SetProperty_EDIT4.
Action start 8:46:24: CustomTextA_SetProperty_EDIT4.
Action ended 8:46:24: CustomTextA_SetProperty_EDIT4. Return value 1.
Action 8:46:24: DIRCA_TARGETDIR.
Action start 8:46:24: DIRCA_TARGETDIR.
Action ended 8:46:24: DIRCA_TARGETDIR. Return value 1.
Action 8:46:24: CostInitialize. Computing space requirements
Action start 8:46:24: CostInitialize.
Action ended 8:46:24: CostInitialize. Return value 1.
Action 8:46:24: FileCost. Computing space requirements
Action start 8:46:24: FileCost.
Action ended 8:46:24: FileCost. Return value 1.
Action 8:46:24: IsolateComponents.
Action start 8:46:24: IsolateComponents.
Action ended 8:46:24: IsolateComponents. Return value 1.
Action 8:46:24: WelcomeForm.
Action start 8:46:24: WelcomeForm.
Info 2898.For VSI_MS_Sans_Serif13.0_0_0 textstyle, the system created a 'MS
Sans Serif' font, in 0 character set, of 13 pixels height.
Info 2898.For VSI_MS_Sans_Serif16.0_1_0 textstyle, the system created a 'MS
Sans Serif' font, in 0 character set, of 20 pixels height.
DEBUG: Error 2826:  Control BannerBmp on dialog WelcomeForm extends beyond
the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package.
This may indicate a problem with this package. The error code is 2826. The
arguments are: WelcomeForm, BannerBmp, to the right
DEBUG: Error 2888:  Executing the Binary view failed
This may indicate a problem with this package. The error code is 2888. The
arguments are: Binary, ,
Info 2898.For VsdDefaultUIFont.524F4245_5254_5341_4C45_534153783400
textstyle, the system created a 'MS Sans Serif' font, in 0 character set, of
13 pixels height.
DEBUG: Error 2826:  Control Line1 on dialog WelcomeForm extends beyond the
arguments are: WelcomeForm, Line1, to the right
DEBUG: Error 2826:  Control Line2 on dialog WelcomeForm extends beyond the
arguments are: WelcomeForm, Line2, to the right
Action 8:46:24: WelcomeForm. Dialog created
DEBUG: Error 2826:  Control BannerBmp on dialog ReadmeForm extends beyond
arguments are: ReadmeForm, BannerBmp, to the right
DEBUG: Error 2826:  Control Line1 on dialog ReadmeForm extends beyond the
arguments are: ReadmeForm, Line1, to the right
DEBUG: Error 2826:  Control Line2 on dialog ReadmeForm extends beyond the
arguments are: ReadmeForm, Line2, to the right
Action 8:46:41: ReadmeForm. Dialog created
DEBUG: Error 2826:  Control BannerBmp on dialog EulaForm extends beyond the
arguments are: EulaForm, BannerBmp, to the right
DEBUG: Error 2826:  Control Line1 on dialog EulaForm extends beyond the
arguments are: EulaForm, Line1, to the right
DEBUG: Error 2826:  Control Line2 on dialog EulaForm extends beyond the
arguments are: EulaForm, Line2, to the right
Action 8:46:45: EulaForm. Dialog created
DEBUG: Error 2826:  Control BannerBmp on dialog CustomTextA extends beyond
arguments are: CustomTextA, BannerBmp, to the right
DEBUG: Error 2826:  Control Control273 on dialog CustomTextA extends beyond
arguments are: CustomTextA, Control273, to the right
DEBUG: Error 2826:  Control Control278 on dialog CustomTextA extends beyond
arguments are: CustomTextA, Control278, to the right
Action 8:46:49: CustomTextA. Dialog created
Action ended 8:46:55: WelcomeForm. Return value 1.
Action 8:46:55: CostFinalize. Computing space requirements
Action start 8:46:55: CostFinalize.
Action ended 8:46:55: CostFinalize. Return value 1.
Action 8:46:55: FolderForm.
Action start 8:46:55: FolderForm.
DEBUG: Error 2826:  Control BannerBmp on dialog FolderForm extends beyond
arguments are: FolderForm, BannerBmp, to the right
DEBUG: Error 2826:  Control Line1 on dialog FolderForm extends beyond the
arguments are: FolderForm, Line1, to the right
DEBUG: Error 2826:  Control Line2 on dialog FolderForm extends beyond the
arguments are: FolderForm, Line2, to the right
Info 2898.For VSI_MS_Shell_Dlg13.0_0_0 textstyle, the system created a 'MS
Shell Dlg' font, in 0 character set, of 13 pixels height.
Action 8:46:55: FolderForm. Dialog created
Action 8:47:01: FindRelatedProducts. Searching for related applications
Action start 8:47:01: FindRelatedProducts.
Action ended 8:47:01: FindRelatedProducts. Return value 1.
DEBUG: Error 2826:  Control BannerBmp on dialog ConfirmInstallForm extends
beyond the boundaries of the dialog to the right by 3 pixels
arguments are: ConfirmInstallForm, BannerBmp, to the right
DEBUG: Error 2826:  Control Line1 on dialog ConfirmInstallForm extends
arguments are: ConfirmInstallForm, Line1, to the right
DEBUG: Error 2826:  Control Line2 on dialog ConfirmInstallForm extends
arguments are: ConfirmInstallForm, Line2, to the right
Action 8:47:01: ConfirmInstallForm. Dialog created
Action ended 8:47:08: FolderForm. Return value 1.
Action 8:47:08: ProgressForm.
Action start 8:47:08: ProgressForm.
DEBUG: Error 2826:  Control BannerBmp on dialog ProgressForm extends beyond
arguments are: ProgressForm, BannerBmp, to the right
DEBUG: Error 2826:  Control Line1 on dialog ProgressForm extends beyond the
arguments are: ProgressForm, Line1, to the right
DEBUG: Error 2826:  Control Line2 on dialog ProgressForm extends beyond the
arguments are: ProgressForm, Line2, to the right
Action 8:47:08: ProgressForm. Dialog created
Action ended 8:47:08: ProgressForm. Return value 1.
Action 8:47:08: ExecuteAction.
Action start 8:47:08: ExecuteAction.
Action 8:47:08: INSTALL.
Action start 8:47:08: INSTALL.
Action 8:47:08: DIRCA_CheckFX.
Action start 8:47:08: DIRCA_CheckFX.
Action ended 8:47:09: DIRCA_CheckFX. Return value 1.
Action 8:47:09: AppSearch. Searching for installed applications
Action start 8:47:09: AppSearch.
Action ended 8:47:09: AppSearch. Return value 0.
Action 8:47:09: FindRelatedProducts. Searching for related applications
Action start 8:47:09: FindRelatedProducts.
Action ended 8:47:09: FindRelatedProducts. Return value 0.
Action 8:47:09: VSDCA_VsdLaunchConditions.
Action start 8:47:09: VSDCA_VsdLaunchConditions.
Action ended 8:47:09: VSDCA_VsdLaunchConditions. Return value 1.
Action 8:47:09: LaunchConditions. Evaluating launch conditions
Action start 8:47:09: LaunchConditions.
Action ended 8:47:09: LaunchConditions. Return value 1.
Action 8:47:09: CCPSearch. Searching for qualifying products
Action start 8:47:09: CCPSearch.
Action ended 8:47:09: CCPSearch. Return value 0.
Action 8:47:09: RMCCPSearch. Searching for qualifying products
Action start 8:47:09: RMCCPSearch.
Action ended 8:47:09: RMCCPSearch. Return value 0.
Action 8:47:09: ValidateProductID.
Action start 8:47:09: ValidateProductID.
Action ended 8:47:09: ValidateProductID. Return value 1.
Action 8:47:09: CustomTextA_SetProperty_EDIT1.
Action start 8:47:09: CustomTextA_SetProperty_EDIT1.
Action ended 8:47:09: CustomTextA_SetProperty_EDIT1. Return value 0.
Action 8:47:09: CustomTextA_SetProperty_EDIT2.
Action start 8:47:09: CustomTextA_SetProperty_EDIT2.
Action ended 8:47:09: CustomTextA_SetProperty_EDIT2. Return value 0.
Action 8:47:09: CustomTextA_SetProperty_EDIT3.
Action start 8:47:09: CustomTextA_SetProperty_EDIT3.
Action ended 8:47:09: CustomTextA_SetProperty_EDIT3. Return value 0.
Action 8:47:09: CustomTextA_SetProperty_EDIT4.
Action start 8:47:09: CustomTextA_SetProperty_EDIT4.
Action ended 8:47:09: CustomTextA_SetProperty_EDIT4. Return value 0.
Action 8:47:09: CostInitialize. Computing space requirements
Action start 8:47:09: CostInitialize.
Action ended 8:47:09: CostInitialize. Return value 1.
Action 8:47:09: FileCost. Computing space requirements
Action start 8:47:09: FileCost.
Action ended 8:47:09: FileCost. Return value 1.
Action 8:47:09: IsolateComponents.
Action start 8:47:09: IsolateComponents.
Action ended 8:47:09: IsolateComponents. Return value 1.
Action 8:47:09: CostFinalize. Computing space requirements
Action start 8:47:09: CostFinalize.
Action ended 8:47:09: CostFinalize. Return value 1.
Action 8:47:09: SetODBCFolders. Initializing ODBC directories
Action start 8:47:09: SetODBCFolders.
Action ended 8:47:09: SetODBCFolders. Return value 1.
Action 8:47:09: InstallValidate. Validating install
Action start 8:47:09: InstallValidate.
Action ended 8:47:09: InstallValidate. Return value 1.
Action 8:47:09: InstallInitialize.
Action start 8:47:09: InstallInitialize.
Action ended 8:47:09: InstallInitialize. Return value 1.
Action 8:47:09: RemoveExistingProducts. Removing applications
Action start 8:47:09: RemoveExistingProducts.
Action ended 8:47:09: RemoveExistingProducts. Return value 1.
Action 8:47:09: AllocateRegistrySpace. Allocating registry space
Action start 8:47:09: AllocateRegistrySpace.
Action ended 8:47:09: AllocateRegistrySpace. Return value 1.
Action 8:47:09: ProcessComponents. Updating component registration
Action start 8:47:09: ProcessComponents.
Action 8:47:09: GenerateScript. Generating script operations for action:
GenerateScript: Updating component registration
Action ended 8:47:09: ProcessComponents. Return value 1.
Action 8:47:09: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 8:47:09: MsiUnpublishAssemblies.
Action ended 8:47:09: MsiUnpublishAssemblies. Return value 1.
Action 8:47:09: UnpublishComponents. Unpublishing Qualified Components
Action start 8:47:09: UnpublishComponents.
Action ended 8:47:09: UnpublishComponents. Return value 1.
Action 8:47:09: UnpublishFeatures. Unpublishing Product Features
Action start 8:47:09: UnpublishFeatures.
Action ended 8:47:09: UnpublishFeatures. Return value 1.
Action 8:47:09: StopServices. Stopping services
Action start 8:47:09: StopServices.
Action ended 8:47:09: StopServices. Return value 1.
Action 8:47:09: DeleteServices. Deleting services
Action start 8:47:09: DeleteServices.
Action ended 8:47:09: DeleteServices. Return value 1.
Action 8:47:09: UnregisterComPlus. Unregistering COM+ Applications and
Components
Action start 8:47:09: UnregisterComPlus.
Action ended 8:47:09: UnregisterComPlus. Return value 1.
Action 8:47:09: SelfUnregModules. Unregistering modules
Action start 8:47:09: SelfUnregModules.
Action ended 8:47:09: SelfUnregModules. Return value 1.
Action 8:47:09: UnregisterTypeLibraries. Unregistering type libraries
Action start 8:47:09: UnregisterTypeLibraries.
Action ended 8:47:09: UnregisterTypeLibraries. Return value 1.
Action 8:47:09: RemoveODBC. Removing ODBC components
Action start 8:47:09: RemoveODBC.
RemoveODBC:
Action ended 8:47:09: RemoveODBC. Return value 1.
Action 8:47:09: UnregisterFonts. Unregistering fonts
Action start 8:47:09: UnregisterFonts.
Action ended 8:47:09: UnregisterFonts. Return value 1.
Action 8:47:09: RemoveRegistryValues. Removing system registry values
Action start 8:47:09: RemoveRegistryValues.
Action ended 8:47:09: RemoveRegistryValues. Return value 1.
Action 8:47:09: UnregisterClassInfo. Unregister Class servers
Action start 8:47:09: UnregisterClassInfo.
Action ended 8:47:09: UnregisterClassInfo. Return value 1.
Action 8:47:09: UnregisterExtensionInfo. Unregistering extension servers
Action start 8:47:09: UnregisterExtensionInfo.
Action ended 8:47:09: UnregisterExtensionInfo. Return value 1.
Action 8:47:09: UnregisterProgIdInfo. Unregistering program identifiers
Action start 8:47:09: UnregisterProgIdInfo.
Action ended 8:47:09: UnregisterProgIdInfo. Return value 1.
Action 8:47:09: UnregisterMIMEInfo. Unregistering MIME info
Action start 8:47:09: UnregisterMIMEInfo.
Action ended 8:47:09: UnregisterMIMEInfo. Return value 1.
Action 8:47:09: RemoveIniValues. Removing INI files entries
Action start 8:47:09: RemoveIniValues.
Action ended 8:47:09: RemoveIniValues. Return value 1.
Action 8:47:09: RemoveShortcuts. Removing shortcuts
Action start 8:47:09: RemoveShortcuts.
Action ended 8:47:09: RemoveShortcuts. Return value 1.
Action 8:47:09: RemoveEnvironmentStrings. Updating environment strings
Action start 8:47:09: RemoveEnvironmentStrings.
Action ended 8:47:09: RemoveEnvironmentStrings. Return value 1.
Action 8:47:09: RemoveDuplicateFiles. Removing duplicated files
Action start 8:47:09: RemoveDuplicateFiles.
Action ended 8:47:09: RemoveDuplicateFiles. Return value 1.
Action 8:47:09: RemoveFiles. Removing files
Action start 8:47:09: RemoveFiles.
Action ended 8:47:09: RemoveFiles. Return value 1.
Action 8:47:09: RemoveFolders. Removing folders
Action start 8:47:09: RemoveFolders.
Action ended 8:47:09: RemoveFolders. Return value 1.
Action 8:47:09: CreateFolders. Creating folders
Action start 8:47:09: CreateFolders.
Action ended 8:47:09: CreateFolders. Return value 1.
Action 8:47:09: MoveFiles. Moving files
Action start 8:47:09: MoveFiles.
Action ended 8:47:09: MoveFiles. Return value 1.
Action 8:47:09: InstallFiles. Copying new files
Action start 8:47:09: InstallFiles.
InstallFiles: File: Copying new files,  Directory: ,  Size:
Action ended 8:47:09: InstallFiles. Return value 1.
Action 8:47:09: PatchFiles. Patching files
Action start 8:47:09: PatchFiles.
Action ended 8:47:09: PatchFiles. Return value 1.
Action 8:47:09: DuplicateFiles. Creating duplicate files
Action start 8:47:09: DuplicateFiles.
Action ended 8:47:09: DuplicateFiles. Return value 1.
Action 8:47:09: BindImage. Binding executables
Action start 8:47:09: BindImage.
Action ended 8:47:09: BindImage. Return value 1.
Action 8:47:09: CreateShortcuts. Creating shortcuts
Action start 8:47:09: CreateShortcuts.
CreateShortcuts: Shortcut: Creating shortcuts
Action ended 8:47:09: CreateShortcuts. Return value 1.
Action 8:47:09: RegisterClassInfo. Registering Class servers
Action start 8:47:09: RegisterClassInfo.
Action ended 8:47:09: RegisterClassInfo. Return value 1.
Action 8:47:09: RegisterExtensionInfo. Registering extension servers
Action start 8:47:09: RegisterExtensionInfo.
Action ended 8:47:09: RegisterExtensionInfo. Return value 1.
Action 8:47:09: RegisterProgIdInfo. Registering program identifiers
Action start 8:47:09: RegisterProgIdInfo.
Action ended 8:47:09: RegisterProgIdInfo. Return value 1.
Action 8:47:09: RegisterMIMEInfo. Registering MIME info
Action start 8:47:09: RegisterMIMEInfo.
Action ended 8:47:09: RegisterMIMEInfo. Return value 1.
Action 8:47:09: WriteRegistryValues. Writing system registry values
Action start 8:47:09: WriteRegistryValues.
Action ended 8:47:09: WriteRegistryValues. Return value 1.
Action 8:47:09: WriteIniValues. Writing INI files values
Action start 8:47:09: WriteIniValues.
Action ended 8:47:09: WriteIniValues. Return value 1.
Action 8:47:09: WriteEnvironmentStrings. Updating environment strings
Action start 8:47:09: WriteEnvironmentStrings.
Action ended 8:47:09: WriteEnvironmentStrings. Return value 1.
Action 8:47:09: RegisterFonts. Registering fonts
Action start 8:47:09: RegisterFonts.
Action ended 8:47:09: RegisterFonts. Return value 1.
Action 8:47:09: InstallODBC. Installing ODBC components
Action start 8:47:09: InstallODBC.
Action ended 8:47:09: InstallODBC. Return value 0.
Action 8:47:09: RegisterTypeLibraries. Registering type libraries
Action start 8:47:09: RegisterTypeLibraries.
Action ended 8:47:09: RegisterTypeLibraries. Return value 1.
Action 8:47:09: SelfRegModules. Registering modules
Action start 8:47:09: SelfRegModules.
Action ended 8:47:09: SelfRegModules. Return value 1.
Action 8:47:09: RegisterComPlus. Registering COM+ Applications and
Components
Action start 8:47:09: RegisterComPlus.
Action ended 8:47:09: RegisterComPlus. Return value 1.
Action 8:47:09: InstallServices. Installing new services
Action start 8:47:09: InstallServices.
Action ended 8:47:09: InstallServices. Return value 1.
Action 8:47:09: StartServices. Starting services
Action start 8:47:09: StartServices.
Action ended 8:47:09: StartServices. Return value 1.
Action 8:47:09: _7B602BF0_0D9A_41F1_9287_1A035FB87175.SetProperty.
Action start 8:47:09: _7B602BF0_0D9A_41F1_9287_1A035FB87175.SetProperty.
Action ended 8:47:09: _7B602BF0_0D9A_41F1_9287_1A035FB87175.SetProperty.
Return value 1.
_7B602BF0_0D9A_41F1_9287_1A035FB87175:
Action ended 8:47:09: _7B602BF0_0D9A_41F1_9287_1A035FB87175. Return value 1.
Action 8:47:09: RegisterUser. Registering user
Action start 8:47:09: RegisterUser.
Action ended 8:47:09: RegisterUser. Return value 1.
Action 8:47:09: RegisterProduct. Registering product
Action start 8:47:09: RegisterProduct.
RegisterProduct: Registering product
Action ended 8:47:09: RegisterProduct. Return value 1.
Action 8:47:09: PublishComponents. Publishing Qualified Components
Action start 8:47:09: PublishComponents.
Action ended 8:47:09: PublishComponents. Return value 1.
Action 8:47:09: MsiPublishAssemblies. Publishing assembly information
Action start 8:47:09: MsiPublishAssemblies.
MsiPublishAssemblies: Application Context:Publishing assembly information,
Assembly Name:
Action ended 8:47:09: MsiPublishAssemblies. Return value 1.
Action 8:47:09: PublishFeatures. Publishing Product Features
Action start 8:47:09: PublishFeatures.
PublishFeatures: Feature: Publishing Product Features
Action ended 8:47:09: PublishFeatures. Return value 1.
Action 8:47:09: PublishProduct. Publishing product information
Action start 8:47:09: PublishProduct.
PublishProduct:
Action ended 8:47:09: PublishProduct. Return value 1.
Action 8:47:09: InstallFinalize.
Action start 8:47:09: InstallFinalize.
1: {B91EB9DA-98D2-4241-87EA-3D889B58D564} 2:
{0B2E260E-0559-4BA7-0E7C-895D6B17182A} 3: C:\Program
Files\MPICH2\lib\cxx.lib
{377F7EA5-53A5-D038-7A57-80538B1E44F2} 3: C:\Program
Files\MPICH2\examples\examples.sln
{11CD2E8E-C0F1-2807-BA7D-ADF34D406A18} 3: C:\Program
Files\MPICH2\bin\clog2TOslog2.jar
{D94AA0EB-95F3-1377-8AE9-047507D32F3D} 3: C:\Program
Files\MPICH2\lib\fmpich2g.lib
{BC57862F-3B65-90B8-3C46-1B09C024EC4A} 3: C:\Program
Files\MPICH2\include\clog_inttypes.h
{D767F506-5E39-9927-67D8-D1C45FABA4F4} 3:
C:\windows\system32\mpich2nemesisp.dll
{9E971F96-835C-A20C-CB55-110F66432E21} 3: C:\Program
Files\MPICH2\include\mpe_misc.h
{09BBBA84-0563-2219-ACD9-0C46282A4C48} 3: C:\Program
Files\MPICH2\include\mpi_constants.mod
{427ACCC7-57B0-E441-0016-256816DB6EE4} 3: C:\Program
Files\MPICH2\lib\libmpicxx.a
{09396970-EB86-BE36-E15C-DB0A308B5EF1} 3: C:\windows\system32\mpich2mpe.dll
{172ECD54-74BD-FEE1-D81F-DF45862072AC} 3: C:\Program
Files\MPICH2\bin\wmpiregister.exe
{3235E6FF-130F-6CE1-EC4E-B9E2A20E9784} 3: C:\windows\system32\mpe.dll
{80BB7D01-DA72-F301-B319-0595A822EA7F} 3: C:\Program
Files\MPICH2\lib\libmpi.a
{A8E12F2B-4C08-160E-4AD6-57602F1D1FD1} 3: C:\Program
Files\MPICH2\bin\smpd.exe
{52645022-7960-4D56-E5C8-00114AC98372} 3: C:\Program
Files\MPICH2\bin\wmpiexec.exe
{626590B6-A4EC-2C9B-808A-481B911C96BB} 3: C:\Program
Files\MPICH2\include\mpe_log.h
{BED9D96A-E0D5-CDA0-67B2-B9BDC1F2F3DA} 3: C:\Program
Files\MPICH2\include\mpi.mod
{845B5980-B10B-0C77-2396-E3A5A6EC9432} 3: C:\Program
Files\MPICH2\include\mpif.h
{F52533F4-764B-EF9D-D34D-69C43B647F23} 3: C:\Program
Files\MPICH2\examples\fpi.f
{A027FA4F-6058-852B-2B1B-0BC409E10080} 3: C:\windows\system32\mpich2mt.dll
{E6180C2D-5015-BA8A-DAE0-4BEA96E6DDF7} 3: C:\Program
Files\MPICH2\lib\TraceInput.lib
{4E7A44B9-B178-2246-9ABD-61ECAA1C04AD} 3: C:\Program
Files\MPICH2\bin\jumpshot_launcher.jar
{AF36B41C-D39E-0C78-825F-F8F1A47C3E1B} 3: C:\Program
Files\MPICH2\include\mpe.h
{2EAE76CB-CF36-EC1E-FE79-C176F63508B9} 3: C:\Program
Files\MPICH2\include\mpi_base.mod
{85B8070F-A3A1-9D12-BA20-F0B7A7C1B2F3} 3: C:\Program Files\MPICH2\setup.jpg
{7094A366-B358-8324-4E39-AB0F6957E9F9} 3: C:\Program
Files\MPICH2\lib\rlog.lib
{A6439F5F-E43F-6FB9-BCFE-5588D3842208} 3: C:\Program
Files\MPICH2\examples\cxxpi.cxx
{DE616448-6A5B-A2C3-E6D6-64626CB5BA93} 3:
C:\windows\system32\mpich2nemesis.dll
{354C076C-752D-E6DE-AC09-8C54B51C73AB} 3: C:\Program
Files\MPICH2\lib\mpi.lib
{8BD99ED2-6FB4-09F1-F769-36EBC5CBD902} 3: C:\windows\system32\fmpich2.dll
{42389D89-464C-D40A-B674-CAB83866F452} 3: C:\Program
Files\MPICH2\include\mpicxx.h
{6337169C-5A81-C60A-E25C-02E162A2650E} 3: C:\Program
Files\MPICH2\lib\irlog2rlog.lib
{2A386E76-EBAF-D453-2C29-F865B3A7D9AC} 3: C:\Program
Files\MPICH2\bin\irlog2rlog.exe
{A3426275-8272-39AF-4474-C0477027E10C} 3: C:\Program
Files\MPICH2\include\clog_const.h
{C0C07408-F505-E57C-BE26-6B8E0C0488E7} 3: C:\windows\system32\mpich2mtp.dll
{A80DA15A-F7DE-14F8-D3C5-BDF39D9BCA11} 3: C:\windows\system32\mpich2mpi.dll
{C3E5D6EB-8258-CAB0-7F0A-A1A6F978C920} 3: C:\windows\system32\mpich2p.dll
{E5786443-E433-D4B2-9743-5DB4BE83D7AC} 3: C:\Program
Files\MPICH2\COPYRIGHT.rtf
{A7D1678F-E143-9BB9-413A-11F3E85FE41F} 3: C:\Program
Files\MPICH2\README.winbin.rtf
{A5C92A4F-0E0A-D23B-852A-8457A11313DA} 3: C:\windows\system32\TraceInput.dll
{5CCBB9F7-75F0-7E9C-5A72-6A2BA46E3184} 3: C:\Program
Files\MPICH2\lib\fmpich2.lib
{C653DBB5-8B1D-902E-8BBE-600E76C990F9} 3: C:\Program
Files\MPICH2\bin\mpiexec.exe
{C0EFAD0B-6F99-CB15-3CB5-512F1CFCCD5B} 3: C:\Program
Files\MPICH2\bin\jumpshot.jar
{D7ADF4BA-C22C-99C3-6919-B507C14AE293} 3: C:\Program
Files\MPICH2\include\mpio.h
{21DCEC83-D3E9-9B71-EB8D-C53434EFA844} 3: C:\Program
Files\MPICH2\include\mpi_sizeofs.mod
{192A5E68-8018-D271-038F-B2EE2F5F4144} 3: C:\Program
Files\MPICH2\include\clog_commset.h
{BC762AF4-3626-E416-88CC-8FD38240A7F6} 3: C:\Program
Files\MPICH2\examples\cpi.exe
{6C93D22F-B390-5AB6-F03B-4A98CAF0F55C} 3: C:\windows\system32\fmpich2g.dll
{C0F88752-27FE-0F87-0D32-517F83FF04BB} 3: C:\Program
Files\MPICH2\include\mpe_logf.h
{5AA8792B-499D-5FA5-8B11-EE99D2DB3ABD} 3: C:\Program
Files\MPICH2\examples\icpi.c
{2327389C-558E-C1D9-A4F5-EA3595128CBF} 3: C:\Program
Files\MPICH2\examples\fpi.vfproj
{E1D179A6-36C9-E437-E6B0-159B9A7CDA56} 3: C:\Program
Files\MPICH2\lib\mpe.lib
{6553A06B-4C7A-F506-914F-DE0930921774} 3: C:\Program
Files\MPICH2\include\mpi.h
{1A7ACB47-47C0-8024-0DC9-431CE9B371EE} 3: C:\windows\system32\mpich2.dll
{2416FDD0-33B1-08AB-7325-6C2B46502983} 3: C:\Program
Files\MPICH2\include\clog_uuid.h
{EB02857F-DF89-4306-68E4-3DB8704EB81D} 3: C:\Program
Files\MPICH2\examples\cpi.vcproj
{438A3621-E0F3-3767-9263-5890A20E3B8E} 3: C:\Program
Files\MPICH2\examples\cxxpi.vcproj
{4095982A-3F88-9DE5-3CBD-56EB4A4A750B} 3: C:\Program
Files\MPICH2\lib\libfmpich2g.a
{56860D72-E23C-8947-5A1C-FAADCED1B37E} 3: C:\Program
Files\MPICH2\bin\wmpiconfig.exe
{5EBDFA66-B26B-CB1F-7435-CA58D78A7AC5} 3: C:\Program
Files\MPICH2\bin\traceTOslog2.jar
{B91EB9DA-98D2-4241-87EA-3D889B58D564} 3: C:\Program Files\MPICH2\
InstallFiles: File: cxx.lib,  Directory: C:\Program Files\MPICH2\lib\,
InstallFiles: File: examples.sln,  Directory: C:\Program
Files\MPICH2\examples\,  Size: 2709
InstallFiles: File: clog2TOslog2.jar,  Directory: C:\Program
Files\MPICH2\bin\,  Size: 183747
InstallFiles: File: fmpich2g.lib,  Directory: C:\Program Files\MPICH2\lib\,
InstallFiles: File: clog_inttypes.h,  Directory: C:\Program
Files\MPICH2\include\,  Size: 731
InstallFiles: File: mpich2nemesisp.dll,  Directory: C:\windows\system32\,
InstallFiles: File: mpe_misc.h,  Directory: C:\Program
Files\MPICH2\include\,  Size: 1322
InstallFiles: File: mpi_constants.mod,  Directory: C:\Program
Files\MPICH2\include\,  Size: 36141
InstallFiles: File: libmpicxx.a,  Directory: C:\Program Files\MPICH2\lib\,
InstallFiles: File: mpich2mpe.dll,  Directory: C:\windows\system32\,  Size:
169472
InstallFiles: File: wmpiregister.exe,  Directory: C:\Program
Files\MPICH2\bin\,  Size: 24576
InstallFiles: File: mpe.dll,  Directory: C:\windows\system32\,  Size: 155136
InstallFiles: File: libmpi.a,  Directory: C:\Program Files\MPICH2\lib\,
InstallFiles: File: smpd.exe,  Directory: C:\Program Files\MPICH2\bin\,
InstallFiles: File: wmpiexec.exe,  Directory: C:\Program Files\MPICH2\bin\,
InstallFiles: File: mpe_log.h,  Directory: C:\Program Files\MPICH2\include\,
InstallFiles: File: mpi.mod,  Directory: C:\Program Files\MPICH2\include\,
InstallFiles: File: mpif.h,  Directory: C:\Program Files\MPICH2\include\,
InstallFiles: File: fpi.f,  Directory: C:\Program Files\MPICH2\examples\,
InstallFiles: File: mpich2mt.dll,  Directory: C:\windows\system32\,  Size:
1690112
InstallFiles: File: TraceInput.lib,  Directory: C:\Program
Files\MPICH2\lib\,  Size: 4644
InstallFiles: File: jumpshot_launcher.jar,  Directory: C:\Program
Files\MPICH2\bin\,  Size: 7140
InstallFiles: File: mpe.h,  Directory: C:\Program Files\MPICH2\include\,
InstallFiles: File: mpi_base.mod,  Directory: C:\Program
Files\MPICH2\include\,  Size: 90551
InstallFiles: File: setup.jpg,  Directory: C:\Program Files\MPICH2\,  Size:
4698
InstallFiles: File: rlog.lib,  Directory: C:\Program Files\MPICH2\lib\,
InstallFiles: File: cxxpi.cxx,  Directory: C:\Program
Files\MPICH2\examples\,  Size: 1497
InstallFiles: File: mpich2nemesis.dll,  Directory: C:\windows\system32\,
InstallFiles: File: mpi.lib,  Directory: C:\Program Files\MPICH2\lib\,
InstallFiles: File: fmpich2.dll,  Directory: C:\windows\system32\,  Size:
185856
InstallFiles: File: mpicxx.h,  Directory: C:\Program Files\MPICH2\include\,
InstallFiles: File: irlog2rlog.lib,  Directory: C:\Program
Files\MPICH2\lib\,  Size: 1936
InstallFiles: File: irlog2rlog.exe,  Directory: C:\Program
Files\MPICH2\bin\,  Size: 744448
InstallFiles: File: clog_const.h,  Directory: C:\Program
Files\MPICH2\include\,  Size: 696
InstallFiles: File: mpich2mtp.dll,  Directory: C:\windows\system32\,  Size:
1940480
InstallFiles: File: mpich2mpi.dll,  Directory: C:\windows\system32\,  Size:
230912
InstallFiles: File: mpich2p.dll,  Directory: C:\windows\system32\,  Size:
1883136
InstallFiles: File: COPYRIGHT.rtf,  Directory: C:\Program Files\MPICH2\,
InstallFiles: File: README.winbin.rtf,  Directory: C:\Program Files\MPICH2\,
InstallFiles: File: TraceInput.dll,  Directory: C:\windows\system32\,  Size:
762368
InstallFiles: File: fmpich2.lib,  Directory: C:\Program Files\MPICH2\lib\,
InstallFiles: File: mpiexec.exe,  Directory: C:\Program Files\MPICH2\bin\,
InstallFiles: File: jumpshot.jar,  Directory: C:\Program Files\MPICH2\bin\,
InstallFiles: File: mpio.h,  Directory: C:\Program Files\MPICH2\include\,
InstallFiles: File: mpi_sizeofs.mod,  Directory: C:\Program
Files\MPICH2\include\,  Size: 8417
InstallFiles: File: clog_commset.h,  Directory: C:\Program
Files\MPICH2\include\,  Size: 4857
InstallFiles: File: cpi.exe,  Directory: C:\Program Files\MPICH2\examples\,
InstallFiles: File: fmpich2g.dll,  Directory: C:\windows\system32\,  Size:
177152
InstallFiles: File: mpe_logf.h,  Directory: C:\Program
Files\MPICH2\include\,  Size: 1833
InstallFiles: File: icpi.c,  Directory: C:\Program Files\MPICH2\examples\,
InstallFiles: File: fpi.vfproj,  Directory: C:\Program
Files\MPICH2\examples\,  Size: 4769
InstallFiles: File: mpe.lib,  Directory: C:\Program Files\MPICH2\lib\,
InstallFiles: File: mpi.h,  Directory: C:\Program Files\MPICH2\include\,
InstallFiles: File: mpich2.dll,  Directory: C:\windows\system32\,  Size:
1624064
InstallFiles: File: clog_uuid.h,  Directory: C:\Program
Files\MPICH2\include\,  Size: 1353
InstallFiles: File: cpi.vcproj,  Directory: C:\Program
Files\MPICH2\examples\,  Size: 7948
InstallFiles: File: cxxpi.vcproj,  Directory: C:\Program
Files\MPICH2\examples\,  Size: 8001
InstallFiles: File: libfmpich2g.a,  Directory: C:\Program Files\MPICH2\lib\,
InstallFiles: File: wmpiconfig.exe,  Directory: C:\Program
Files\MPICH2\bin\,  Size: 57344
InstallFiles: File: traceTOslog2.jar,  Directory: C:\Program
Files\MPICH2\bin\,  Size: 124160
CreateShortcuts: Shortcut: _1A72A7A9B31D3268ADA44D.exe
CreateShortcuts: Shortcut: _A95E1C5CA15927931738DD.exe
CreateShortcuts: Shortcut: _0C3D3CDE1A03DC9ACF3C29.exe
CreateShortcuts: Shortcut: _6DFEE413436AA4645545C2.exe
CreateShortcuts: Shortcut: _F694F6283077EDDE193631.exe
CreateShortcuts: Shortcut: WMPICO~1|wmpiconfig
CreateShortcuts: Shortcut: WMPIRE~1|wmpiregister
CreateShortcuts: Shortcut: README|README
CreateShortcuts: Shortcut: JUMPSHOT|Jumpshot
CreateShortcuts: Shortcut: WMPIEXEC|wmpiexec
Action 8:47:10: RegisterProduct. Registering product
RegisterProduct: {B91EB9DA-98D2-4241-87EA-3D889B58D564}
Action 8:47:10: MsiPublishAssemblies. Publishing assembly information
MsiPublishAssemblies: Application Context:C:|Program
Files|MPICH2|bin|wmpiregister.exe, Assembly
ecture="MSIL"
Files|MPICH2|bin|wmpiexec.exe, Assembly
re="MSIL"
Files|MPICH2|bin|wmpiconfig.exe, Assembly
ture="MSIL"
Action 8:47:10: PublishFeatures. Publishing Product Features
PublishFeatures: Feature: DefaultFeature
Action 8:47:10: PublishProduct. Publishing product information
Action 8:47:10: RollbackCleanup. Removing backup files
Action ended 8:47:10: InstallFinalize. Return value 1.
Action ended 8:47:10: INSTALL. Return value 1.
Property(S): UpgradeCode = {41CCEB45-5BE3-4FF2-B71D-A418475B1DA8}
Property(S): _7B602BF0_0D9A_41F1_9287_1A035FB87175 = /install
/phrase=behappy
Property(S): TARGETDIR = C:\Program Files\MPICH2\
Property(S): _77F9D1A44492419B8EA01D818793C7CA = C:\Program
Files\MPICH2\lib\
Property(S): _15B081C07B80455AA965AC7E9A659F74 = C:\Program
Property(S): _BF9ED70B3DDE44248765F4866DCC194E = C:\Program
Files\MPICH2\bin\
Property(S): _D9EB9C14165A4573993ACC376ED0CA0F = C:\Program
Property(S): System64Folder = C:\windows\system32\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start
Menu\Programs\
Property(S): _CF76DBB4C22C469F8CE5EB5E6718C2EE =
C:\Users\Sam\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\MPICH2\
Property(S): SourceDir = C:\Users\Sam\
Property(S): VSRUNTIMELIBEXISTS =
C:\windows\WinSxS\amd64_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4940_n
one_88df89932faf0bf6\MSVCR80.DLL
Property(S): AdminUser = 1
Property(S): VSDFXAvailable = TRUE
Property(S): VSDFrameworkVersion = 2.0.50727
Property(S): VSDAllowLaterFrameworkVersions = False
Property(S): ProductName = MPICH2 64-bit
Property(S): ProductCode = {B91EB9DA-98D2-4241-87EA-3D889B58D564}
Property(S): ProductVersion = 1.4.1
Property(S): Manufacturer = Argonne National Laboratory
Property(S): ARPHELPLINK = www.mcs.anl.gov/mpi/mpich2
Property(S): ARPCONTACT = Argonne National Laboratory
Property(S): ARPURLINFOABOUT = www.mcs.anl.gov/mpi/mpich2
Property(S): ProductLanguage = 1033
Property(S): SecureCustomProperties =
PREVIOUSVERSIONSINSTALLED;NEWERPRODUCTFOUND
Property(S): RedirectedDllSupport = 2
Property(S): VersionNT = 601
Property(S): VSDNETURLMSG = This setup requires the .NET Framework version
2.0.50727.  Please install the .NET Framework and run this setup again.  The
.NET Framework can be obtained from the web.  Would you like to do this now?
Property(S): VSDIISMSG = This setup requires Internet Information Server 4.0
or higher and Windows NT 4.0, Windows 2000 or higher.  This setup cannot be
installed on Windows 95, Windows 98, or Windows Me.  Please install Internet
Information Server and run this setup again.
Property(S): VSDUIANDADVERTISED = This advertised application will not be
installed because it might be unsafe. Contact your administrator to change
the installation user interface option of the package to basic.
Property(S): VSDNETMSG = This setup requires the .NET Framework version
Property(S): VSDINVALIDURLMSG = The specified path '[2]' is unavailable. The
Internet Information Server might not be running or the path exists and is
redirected to another machine. Please check the status of this virtual
directory in the Internet Services Manager.
Property(S): VSDVERSIONMSG = Unable to install because a newer version of
this product is already installed.
Property(S): AdminEulaForm_Property = No
Property(S): MaintenanceForm_Action = Repair
Property(S): ErrorDialog = ErrorDialog
Property(S): SFF_UpFldrBtn = UpFldrBtn
Property(S): SFF_NewFldrBtn = NewFldrBtn
Property(S): EulaForm_Property = No
Property(S): EDITA1 = 1
Property(S): PHRASE = behappy
Property(S): FolderForm_AllUsers = ME
Property(S): FolderForm_AllUsersVisible = 1
Property(S): AdminMaintenanceForm_Action = Repair
Property(S): DefaultUIFont =
Property(S): AdminWelcomeForm_NextArgs = AdminReadmeForm
Property(S): AdminReadmeForm_PrevArgs = AdminWelcomeForm
Property(S): AdminReadmeForm_NextArgs = AdminEulaForm
Property(S): AdminEulaForm_PrevArgs = AdminReadmeForm
Property(S): AdminEulaForm_NextArgs = AdminFolderForm
Property(S): AdminFolderForm_PrevArgs = AdminEulaForm
Property(S): AdminFolderForm_NextArgs = AdminConfirmInstallForm
Property(S): AdminConfirmInstallForm_PrevArgs = AdminFolderForm
Property(S): WelcomeForm_NextArgs = ReadmeForm
Property(S): ReadmeForm_PrevArgs = WelcomeForm
Property(S): ReadmeForm_NextArgs = EulaForm
Property(S): EulaForm_PrevArgs = ReadmeForm
Property(S): EulaForm_NextArgs = CustomTextA
Property(S): CustomTextA_PrevArgs = EulaForm
Property(S): FolderForm_NextArgs = ConfirmInstallForm
Property(S): ConfirmInstallForm_PrevArgs = FolderForm
Property(S): MsiLogFileLocation =
C:\Users\Sam\mpich2-1.4.1p1-win-x86-64-install.log
Property(S): PackageCode = {8A8D8D33-4A69-47E5-A7C8-77FF5792F242}
Property(S): ALLUSERS = 1
Property(S): ProductState = -1
Property(S): PackagecodeChanging = 1
Property(S): CURRENTDIRECTORY = C:\Users\Sam
Property(S): CLIENTUILEVEL = 0
Property(S): CLIENTPROCESSID = 5388
Property(S): USERNAME = Sam
Property(S): VersionDatabase = 200
Property(S): ACTION = INSTALL
Property(S): EXECUTEACTION = INSTALL
Property(S): ROOTDRIVE = C:\
Property(S): INSTALLLEVEL = 1
Property(S): SECONDSEQUENCE = 1
Property(S): ADDLOCAL = DefaultFeature
Property(S): MsiSystemRebootPending = 1
Property(S): VersionMsi = 5.00
Property(S): VersionNT64 = 601
Property(S): WindowsBuild = 7601
Property(S): ServicePackLevel = 1
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): WindowsFolder = C:\windows\
Property(S): WindowsVolume = C:\
Property(S): SystemFolder = C:\windows\SysWOW64\
Property(S): RemoteAdminTS = 1
Property(S): TempFolder = C:\Users\Sam\AppData\Local\Temp\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): AppDataFolder = C:\Users\Sam\AppData\Roaming\
Property(S): FavoritesFolder = C:\Users\Sam\Favorites\
Property(S): NetHoodFolder =
C:\Users\Sam\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): PersonalFolder = C:\Users\Sam\Documents\
Property(S): PrintHoodFolder =
C:\Users\Sam\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): RecentFolder =
C:\Users\Sam\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): SendToFolder =
C:\Users\Sam\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): LocalAppDataFolder = C:\Users\Sam\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Sam\Pictures\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start
Menu\Programs\Administrative Tools\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start
Menu\Programs\Startup\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): FontsFolder = C:\windows\Fonts\
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): MsiAMD64 = 6
Property(S): Msix64 = 6
Property(S): Intel = 6
Property(S): PhysicalMemory = 12269
Property(S): VirtualMemory = 21542
Property(S): MsiTrueAdminUser = 1
Property(S): LogonUser = Sam
Property(S): UserSID = S-1-5-21-528498831-319965440-437876355-1001
Property(S): UserLanguageID = 1033
Property(S): ComputerName = SAM-LENOVO
Property(S): SystemLanguageID = 1033
Property(S): ScreenX = 1024
Property(S): ScreenY = 768
Property(S): CaptionHeight = 22
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 16
Property(S): TextInternalLeading = 3
Property(S): ColorBits = 32
Property(S): TTCSupport = 1
Property(S): Time = 8:47:10
Property(S): Date = 6/4/2012
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): MsiWin32AssemblySupport = 6.1.7601.17514
Property(S): MsiRunningElevated = 1
Property(S): Privileged = 1
Property(S): DATABASE = C:\windows\Installer\1d7cd29b.msi
Property(S): OriginalDatabase = C:\Users\Sam\mpich2-1.4.1p1-win-x86-64.msi
Property(S): UILevel = 5
Property(S): Preselected = 1
Property(S): VSDFxConfigFile = C:\Users\Sam\AppData\Local\Temp\CFG22B7.tmp
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): SOURCEDIR = C:\Users\Sam\
Property(S): SourcedirProduct = {B91EB9DA-98D2-4241-87EA-3D889B58D564}
Property(S): ProductToBeRegistered = 1
Action ended 8:47:10: ExecuteAction. Return value 1.
Action 8:47:10: FinishedForm.
Action start 8:47:10: FinishedForm.
DEBUG: Error 2826:  Control BannerBmp on dialog FinishedForm extends beyond
arguments are: FinishedForm, BannerBmp, to the right
DEBUG: Error 2826:  Control Line1 on dialog FinishedForm extends beyond the
arguments are: FinishedForm, Line1, to the right
DEBUG: Error 2826:  Control Line2 on dialog FinishedForm extends beyond the
arguments are: FinishedForm, Line2, to the right
Action 8:47:10: FinishedForm. Dialog created
Action ended 8:47:16: FinishedForm. Return value 1.
Action ended 8:47:16: INSTALL. Return value 1.
Property(C): UpgradeCode = {41CCEB45-5BE3-4FF2-B71D-A418475B1DA8}
Property(C): TARGETDIR = C:\Program Files\MPICH2\
Property(C): _77F9D1A44492419B8EA01D818793C7CA = C:\Program
Files\MPICH2\lib\
Property(C): _15B081C07B80455AA965AC7E9A659F74 = C:\Program
Property(C): _BF9ED70B3DDE44248765F4866DCC194E = C:\Program
Files\MPICH2\bin\
Property(C): _D9EB9C14165A4573993ACC376ED0CA0F = C:\Program
Property(C): System64Folder = C:\windows\system32\
Property(C): DesktopFolder = C:\Users\Public\Desktop\
Property(C): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start
Menu\Programs\
Property(C): _CF76DBB4C22C469F8CE5EB5E6718C2EE =
Property(C): SourceDir = C:\Users\Sam\
Property(C): VSRUNTIMELIBEXISTS =
Property(C): AdminUser = 1
Property(C): VSDFXAvailable = TRUE
Property(C): VSDFrameworkVersion = 2.0.50727
Property(C): VSDAllowLaterFrameworkVersions = False
Property(C): ProductName = MPICH2 64-bit
Property(C): ProductCode = {B91EB9DA-98D2-4241-87EA-3D889B58D564}
Property(C): ProductVersion = 1.4.1
Property(C): Manufacturer = Argonne National Laboratory
Property(C): ARPHELPLINK = www.mcs.anl.gov/mpi/mpich2
Property(C): ARPCONTACT = Argonne National Laboratory
Property(C): ARPURLINFOABOUT = www.mcs.anl.gov/mpi/mpich2
Property(C): ProductLanguage = 1033
Property(C): SecureCustomProperties =
Property(C): RedirectedDllSupport = 2
Property(C): VersionNT = 601
Property(C): VSDNETURLMSG = This setup requires the .NET Framework version
Property(C): VSDIISMSG = This setup requires Internet Information Server 4.0
Property(C): VSDUIANDADVERTISED = This advertised application will not be
Property(C): VSDNETMSG = This setup requires the .NET Framework version
Property(C): VSDINVALIDURLMSG = The specified path '[2]' is unavailable. The
Property(C): VSDVERSIONMSG = Unable to install because a newer version of
Property(C): AdminEulaForm_Property = No
Property(C): MaintenanceForm_Action = Repair
Property(C): ErrorDialog = ErrorDialog
Property(C): SFF_UpFldrBtn = UpFldrBtn
Property(C): SFF_NewFldrBtn = NewFldrBtn
Property(C): EulaForm_Property = Yes
Property(C): EDITA1 = 1
Property(C): PHRASE = behappy
Property(C): FolderForm_AllUsers = ALL
Property(C): FolderForm_AllUsersVisible = 1
Property(C): AdminMaintenanceForm_Action = Repair
Property(C): DefaultUIFont =
Property(C): AdminWelcomeForm_NextArgs = AdminReadmeForm
Property(C): AdminReadmeForm_PrevArgs = AdminWelcomeForm
Property(C): AdminReadmeForm_NextArgs = AdminEulaForm
Property(C): AdminEulaForm_PrevArgs = AdminReadmeForm
Property(C): AdminEulaForm_NextArgs = AdminFolderForm
Property(C): AdminFolderForm_PrevArgs = AdminEulaForm
Property(C): AdminFolderForm_NextArgs = AdminConfirmInstallForm
Property(C): AdminConfirmInstallForm_PrevArgs = AdminFolderForm
Property(C): WelcomeForm_NextArgs = ReadmeForm
Property(C): ReadmeForm_PrevArgs = WelcomeForm
Property(C): ReadmeForm_NextArgs = EulaForm
Property(C): EulaForm_PrevArgs = ReadmeForm
Property(C): EulaForm_NextArgs = CustomTextA
Property(C): CustomTextA_PrevArgs = EulaForm
Property(C): FolderForm_NextArgs = ConfirmInstallForm
Property(C): ConfirmInstallForm_PrevArgs = FolderForm
Property(C): MsiLogFileLocation =
Property(C): PackageCode = {8A8D8D33-4A69-47E5-A7C8-77FF5792F242}
Property(C): ProductState = -1
Property(C): PackagecodeChanging = 1
Property(C): CURRENTDIRECTORY = C:\Users\Sam
Property(C): CLIENTUILEVEL = 0
Property(C): CLIENTPROCESSID = 5388
Property(C): MsiSystemRebootPending = 1
Property(C): VersionDatabase = 200
Property(C): VersionMsi = 5.00
Property(C): VersionNT64 = 601
Property(C): WindowsBuild = 7601
Property(C): ServicePackLevel = 1
Property(C): ServicePackLevelMinor = 0
Property(C): MsiNTProductType = 1
Property(C): MsiNTSuitePersonal = 1
Property(C): WindowsFolder = C:\windows\
Property(C): WindowsVolume = C:\
Property(C): SystemFolder = C:\windows\SysWOW64\
Property(C): RemoteAdminTS = 1
Property(C): TempFolder = C:\Users\Sam\AppData\Local\Temp\
Property(C): ProgramFilesFolder = C:\Program Files (x86)\
Property(C): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(C): ProgramFiles64Folder = C:\Program Files\
Property(C): CommonFiles64Folder = C:\Program Files\Common Files\
Property(C): AppDataFolder = C:\Users\Sam\AppData\Roaming\
Property(C): FavoritesFolder = C:\Users\Sam\Favorites\
Property(C): NetHoodFolder =
Property(C): PersonalFolder = C:\Users\Sam\Documents\
Property(C): PrintHoodFolder =
Property(C): RecentFolder =
Property(C): SendToFolder =
Property(C): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(C): CommonAppDataFolder = C:\ProgramData\
Property(C): LocalAppDataFolder = C:\Users\Sam\AppData\Local\
Property(C): MyPicturesFolder = C:\Users\Sam\Pictures\
Property(C): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start
Property(C): StartupFolder = C:\ProgramData\Microsoft\Windows\Start
Property(C): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(C): FontsFolder = C:\windows\Fonts\
Property(C): GPTSupport = 1
Property(C): OLEAdvtSupport = 1
Property(C): ShellAdvtSupport = 1
Property(C): MsiAMD64 = 6
Property(C): Msix64 = 6
Property(C): Intel = 6
Property(C): PhysicalMemory = 12269
Property(C): VirtualMemory = 21540
Property(C): MsiTrueAdminUser = 1
Property(C): LogonUser = Sam
Property(C): UserSID = S-1-5-21-528498831-319965440-437876355-1001
Property(C): UserLanguageID = 1033
Property(C): ComputerName = SAM-LENOVO
Property(C): SystemLanguageID = 1033
Property(C): ScreenX = 1280
Property(C): ScreenY = 768
Property(C): CaptionHeight = 22
Property(C): BorderTop = 1
Property(C): BorderSide = 1
Property(C): TextHeight = 16
Property(C): TextInternalLeading = 3
Property(C): ColorBits = 32
Property(C): TTCSupport = 1
Property(C): Time = 8:47:16
Property(C): Date = 6/4/2012
Property(C): MsiNetAssemblySupport = 4.0.30319.1
Property(C): MsiWin32AssemblySupport = 6.1.7601.17514
Property(C): MsiRunningElevated = 1
Property(C): Privileged = 1
Property(C): USERNAME = Sam
Property(C): DATABASE = C:\Users\Sam\mpich2-1.4.1p1-win-x86-64.msi
Property(C): OriginalDatabase = C:\Users\Sam\mpich2-1.4.1p1-win-x86-64.msi
Property(C): SOURCEDIR = C:\Users\Sam\
Property(C): VersionHandler = 5.00
Property(C): UILevel = 5
Property(C): ACTION = INSTALL
Property(C): EXECUTEACTION = INSTALL
Property(C): VSDFxConfigFile = C:\Users\Sam\AppData\Local\Temp\CFG72E8.tmp
Property(C): ROOTDRIVE = C:\
Property(C): CostingComplete = 1
Property(C): OutOfDiskSpace = 0
Property(C): INSTALLLEVEL = 1
Property(C): PrimaryVolumeSpaceRemaining = 0
Property(C): PrimaryVolumeSpaceRequired = 0
Property(C): PrimaryVolumeSpaceAvailable = 0
Property(C): OutOfNoRbDiskSpace = 0
Property(C): ALLUSERS = 2
=== Logging stopped: 6/4/2012  8:47:16 ===
MSI (c) (0C:00) [08:47:16:634]: Product: MPICH2 64-bit -- Installation
completed successfully.
MSI (c) (0C:00) [08:47:16:634]: Windows Installer installed the product.
Product Name: MPICH2 64-bit. Product Version: 1.4.1. Product Language: 1033.
Manufacturer: Argonne National Laboratory. Installation success or error
status: 0.
[mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Sam Liao
Sent: Monday, June 04, 2012 2:18 PM
Subject: [mpich-discuss] MPICH2 64-bit installation on Window 7 64-bit OS
Hi:
page 2 (see file attached).   Can some help to resolve this problem?
Sam Liao
PO Box 15661
Fax: (720)-294-6783
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120604/488bc4e8/attachment-0001.html>
