[mpich-discuss] mpich2-1.4.1p1
    Luca Carniato
    l.carniato at tudelft.nl
    Fri Jun  1 16:23:44 CDT 2012
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120601/7ed9cc87/attachment-0001.html>
Configuring MPICH2 version 1.4.1p1 with  '-prefix=/home/luca/mpich2-install'
Running on system: Linux luca-Studio-1537 3.2.0-24-generic-pae #39-Ubuntu SMP Mon May 21 18:54:21 UTC 2012 i686 i686 i386 GNU/Linux
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for grep that handles long lines and -e... /bin/grep
checking for fgrep... /bin/grep -F
Executing mpich2prereq in /home/luca/mpich2-1.4.1p1/src/mpid/ch3 with
Executing mpich2prereq in /home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis
configure: ===== configuring src/mpl =====
configure: executing: /home/luca/mpich2-1.4.1p1/src/mpl/configure  '-prefix=/home/luca/mpich2-install' --disable-option-checking
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for egrep... /bin/grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking for variable argument list macro functionality... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... no
checking valgrind/valgrind.h presence... no
checking for valgrind/valgrind.h... no
checking valgrind/memcheck.h usability... no
checking valgrind/memcheck.h presence... no
checking for valgrind/memcheck.h... no
checking helgrind.h usability... no
checking helgrind.h presence... no
checking for helgrind.h... no
checking valgrind/helgrind.h usability... no
checking valgrind/helgrind.h presence... no
checking for valgrind/helgrind.h... no
checking drd.h usability... no
checking drd.h presence... no
checking for drd.h... no
checking valgrind/drd.h usability... no
checking valgrind/drd.h presence... no
checking for valgrind/drd.h... no
checking whether the valgrind headers are broken or too old... yes
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for strncmp... yes
checking whether strncmp needs a declaration... no
checking for putenv... yes
checking whether putenv needs a declaration... no
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating localdefs
config.status: creating include/config.h
config.status: include/config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h defines
config.status: include/mplconfig.h is unchanged
configure: ===== done with src/mpl configure =====
configure: ===== configuring src/openpa =====
configure: executing: /home/luca/mpich2-1.4.1p1/src/openpa/configure --with-atomic-primitives=auto_allow_emulation '-prefix=/home/luca/mpich2-install' --disable-option-checking
checking for gcc... (cached) gcc
checking whether to enable assertions... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for inline... inline
checking for pthread_create in -lpthread... yes
checking for pthread_yield... yes
checking if 100 threads can be run at once... yes
checking size of void *... 4
checking size of int... 4
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 primitives... yes
checking for support for gcc x86 primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: src/config.h is unchanged
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
config.status: src/opa_config.h is unchanged
configure: ===== done with src/openpa configure =====
sourcing /home/luca/mpich2-1.4.1p1/src/pm/hydra/mpich2prereq
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O2... yes
checking whether C compiler option -O2 works with an invalid prototype program... yes
checking whether routines compiled with -O2 can be linked with ones compiled without -O2... yes
checking for type of weak symbol alias support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute__ ((weak_import)) allowed... yes
checking whether __attribute__((weak,alias(...))) allowed... no
checking for multiple weak symbol support... yes
checking for ifort... no
checking for pgf77... no
checking for af77... no
checking for xlf... no
checking for frt... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for fort... no
checking for ifc... no
checking for efc... no
checking for ftn... no
checking for gfortran... gfortran
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether gfortran accepts -g... yes
checking whether Fortran 77 compiler accepts option -O2... yes
checking how to get verbose linking output from gfortran... -v
checking for Fortran 77 libraries of gfortran...  -L/usr/lib/gcc/i686-linux-gnu/4.6 -L/usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu -L/usr/lib/gcc/i686-linux-gnu/4.6/../../../../lib -L/lib/i386-linux-gnu -L/lib/../lib -L/usr/lib/i386-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/i686-linux-gnu/4.6/../../.. -lgfortran -lm -lquadmath
checking whether gfortran accepts the FLIBS found by autoconf... yes
checking whether gcc links with FLIBS found by autoconf... yes
checking whether Fortran 77 and C objects are compatible... yes
checking for linker for Fortran main program... Use Fortran to link programs
checking for Fortran 77 name mangling... lower uscore
checking for libraries to link Fortran main with C stdio routines... none
checking whether Fortran init will work with C... yes
checking for pgf90... no
checking for pathf90... no
checking for pathf95... no
checking for xlf90... no
checking for xlf95... no
checking for xlf2003... no
checking for f90... no
checking for epcf90... no
checking for f95... f95
checking whether we are using the GNU Fortran compiler... yes
checking whether f95 accepts -g... yes
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (f95    ) works... yes
checking whether the Fortran 90 compiler (f95    ) is a cross-compiler... no
checking whether Fortran 90 compiler works with Fortran 77 compiler... yes
checking whether Fortran 77 accepts ! for comments... yes
checking for include directory flag for Fortran... -I
checking for Fortran 77 flag for library directories... -L
checking whether Fortran 77 compiler processes .F files with C preprocessor... yes
checking whether we are using the GNU Fortran compiler... (cached) yes
checking whether f95 accepts -g... (cached) yes
checking for Fortran 90 module extension... mod
checking for Fortran 90 module include flag... -I
checking whether Fortran 90 compiler accepts option -O2... yes
checking whether Fortran 90 compiler processes .F90 files with C preprocessor... yes
checking what libraries are needed to link Fortran90 programs with C routines that use stdio... none
checking for Fortran 90 compiler vendor... gnu
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking whether the C++ compiler c++ can build an executable... yes
checking whether C++ compiler works with string... yes
checking whether the compiler supports exceptions... yes
checking whether the compiler recognizes bool as a built-in type... yes
checking whether the compiler implements namespaces... yes
checking whether <iostream> available... yes
checking whether the compiler implements the namespace std... yes
checking whether <math> available... no
checking for GNU g++ version... 4 . 6
checking whether C++ compiler accepts option -O2... yes
checking for perl... /usr/bin/perl
checking for killall... killall
checking whether install works... yes
checking whether install breaks libraries... no
checking whether mkdir -p works... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for bash... /bin/bash
checking whether /bin/bash supports arrays... yes
checking for doctext... false
checking for location of doctext style files... unavailable
checking for working volatile... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether gcc supports __func__... yes
Using gcc to determine dependencies
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... four
checking for max C struct floating point alignment... four
checking for max C struct alignment of structs with doubles... four
checking for max C struct floating point alignment with long doubles... four
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking size of char... 1
checking size of unsigned char... 1
checking size of short... 2
checking size of unsigned short... 2
checking size of unsigned int... 4
checking size of long... 4
checking size of unsigned long... 4
checking size of long long... 8
checking size of unsigned long long... 8
checking size of float... 4
checking size of double... 8
checking size of long double... 12
checking for ANSI C header files... (cached) yes
checking size of wchar_t... 4
checking size of float_int... 8
checking size of double_int... 12
checking size of long_int... 8
checking size of short_int... 8
checking size of two_int... 8
checking size of long_double_int... 16
checking sys/bitypes.h usability... yes
checking sys/bitypes.h presence... yes
checking for sys/bitypes.h... yes
checking inttypes.h usability... yes
checking inttypes.h presence... yes
checking stdint.h usability... yes
checking stdint.h presence... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking stdbool.h usability... yes
checking stdbool.h presence... yes
checking for stdbool.h... yes
checking complex.h usability... yes
checking complex.h presence... yes
checking for complex.h... yes
checking size of _Bool... 1
checking size of float _Complex... 8
checking size of double _Complex... 16
checking size of long double _Complex... 24
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking for size of Fortran type integer... 4
checking for size of Fortran type real... 4
checking for size of Fortran type double precision... 8
checking whether integer*1 is supported... yes
checking whether integer*2 is supported... yes
checking whether integer*4 is supported... yes
checking whether integer*8 is supported... yes
checking whether integer*16 is supported... no
checking whether real*4 is supported... yes
checking whether real*8 is supported... yes
checking whether real*16 is supported... yes
checking for C type matching Fortran integer... int
checking for size of MPI_Status... 20
checking for values of Fortran logicals... True is 1 and False is 0
checking for BSD/POSIX style global symbol lister... BSD style,/usr/bin/nm -g -B
checking for multiple __attribute__((alias)) support... yes
checking the minimum alignment of Fortran common block of 1 integers... 16
checking the minimum alignment of Fortran common block of 5 integers... 16, too small! reset to 32
checking for Fortran 90 integer kind for 4-byte integers... 4
checking for Fortran 90 integer kind for 8-byte integers... 8
checking if real*8 is supported in Fortran 90... yes
checking size of bool... 1
checking how to run the C++ preprocessor... c++ -E
checking complex usability... yes
checking complex presence... yes
checking for complex... yes
checking size of Complex... 8
checking size of DoubleComplex... 16
checking size of LongDoubleComplex... 24
checking if char * pointers use byte addresses... yes
checking for alignment restrictions on ... no
checking for alignment restrictions on int32_t... no
checking size of MPIR_Bsend_data_t... 56
checking for gcc __asm__ and pentium cmpxchgl instruction... yes
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... no
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking stdlib.h usability... yes
checking stdlib.h presence... yes
checking sys/types.h usability... yes
checking sys/types.h presence... yes
checking string.h usability... yes
checking string.h presence... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stddef.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking unistd.h usability... yes
checking unistd.h presence... yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/uio.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for strncasecmp... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... no
checking whether strerror_r needs a declaration... no
checking for qsort... yes
checking for va_copy... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for fdopen... yes
checking whether fdopen needs a declaration... yes
checking for clock_gettime... no
checking for clock_getres... no
checking for gethrtime... no
checking for mach_absolute_time... no
checking for gettimeofday... yes
sourcing /home/luca/mpich2-1.4.1p1/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/setup_channel
RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
checking for pthread_key_create in -lpthread... yes
checking for pthread_key_create... yes
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK_NP... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK... yes
checking for thread local storage specifier... __thread
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking for sched_yield... yes
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking for getpid... yes
checking for sched_setaffinity... yes
checking for sched_getaffinity... yes
checking for bindprocessor... no
checking for thread_policy_set... no
checking whether cpu_set_t available... yes
checking whether the CPU_SET and CPU_ZERO macros are defined... no
configure: ===== configuring src/mpid/ch3 =====
configure: executing: /home/luca/mpich2-1.4.1p1/src/mpid/ch3/configure  '-prefix=/home/luca/mpich2-install' --disable-option-checking
RUNNING CONFIGURE FOR CH3 DEVICE
checking for sys/types.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking uuid/uuid.h usability... no
checking uuid/uuid.h presence... no
checking for uuid/uuid.h... no
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for unistd.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking whether CPP accepts variable length argument lists... yes
checking whether we can use struct ifconf... yes
configure: ===== configuring channels/nemesis =====
configure: executing: /home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/configure  '-prefix=/home/luca/mpich2-install' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers' --disable-option-checking
RUNNING CONFIGURE FOR THE NEMESIS CHANNEL
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking for netinet/in.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for signal... yes
checking for rand... yes
checking for srand... yes
checking for OpenPA atomic primitive availability... yes
checking for mmap... yes
checking for munmap... yes
configure: Using a memory-mapped file for shared memory
checking whether struct hostent contains h_addr_list... yes
checking knem_io.h usability... no
checking knem_io.h presence... no
checking for knem_io.h... no
config.status: creating nemesis/Makefile
config.status: creating nemesis/src/Makefile
config.status: creating nemesis/utils/Makefile
config.status: creating nemesis/utils/replacements/Makefile
config.status: creating nemesis/utils/monitor/Makefile
config.status: creating nemesis/netmod/Makefile
config.status: creating nemesis/netmod/elan/Makefile
config.status: creating nemesis/netmod/gm/Makefile
config.status: creating nemesis/netmod/mx/Makefile
config.status: creating nemesis/netmod/tcp/Makefile
config.status: creating nemesis/netmod/psm/Makefile
config.status: creating nemesis/netmod/newmad/Makefile
config.status: creating nemesis/netmod/none/Makefile
config.status: creating nemesis/include/mpid_nem_net_module_defs.h
config.status: creating nemesis/src/mpid_nem_net_array.c
config.status: creating include/mpidi_ch3i_nemesis_conf.h
configure: ===== done with channels/nemesis configure =====
config.status: creating util/Makefile
config.status: creating channels/Makefile
config.status: creating util/ftb/Makefile
config.status: creating include/mpid_thread.h
config.status: creating include/mpidi_ch3_conf.h
config.status: executing default-1 commands
copying ./../common/thread/mpid_thread_mpe.c to src/mpid_thread.c
configure: ===== done with src/mpid/ch3 configure =====
configure: ===== configuring src/mpi/romio =====
configure: executing: /home/luca/mpich2-1.4.1p1/src/mpi/romio/configure  '-prefix=/home/luca/mpich2-install' --disable-option-checking
Configuring with args -prefix=/home/luca/mpich2-install --disable-option-checking
checking for architecture... LINUX
ROMIO home directory is /home/luca/mpich2-1.4.1p1/src/mpi/romio
checking for memalign... yes
checking Fortran external names
Fortran externals have a trailing underscore and are lowercase
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking for int large enough for pointers... yes
checking for Fortran 90 KIND parameter for 8-byte integers...            8
checking that we can use integer*8 to declare MPI_DISPLACMENT_CURRENT... yes
Overriding Array test for MPICH2
checking for weak symbol support... pragma weak
checking that weak symbols are visible to other files... yes
checking that the compiler correctly implements weak symbols... yes
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
configure: WARNING: File locks may not work with NFS.  See the Installation and
users manual for instructions on testing and if necessary fixing this
checking for library containing aio_write... -lrt
checking if aio.h exists and can be compiled... yes
checking if sys/aio.h exists and can be compiled... no
checking whether aio routines can be used... yes
checking for obsolete two-argument aio_write... no
checking for obsolete two-argument aio_suspend... no
checking for aio_fildes member of aiocb structure... yes
checking for aio_whence member of aiocb structure... no
checking for aio_handle member of aiocb structure... no
checking for aio_reqprio member of aiocb structure... yes
checking for aio_sigevent member of aiocb structure... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for large file defines... yes
checking whether off64_t is an scalar type... yes
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... yes
checking whether lseek64 needs a declaration... no
checking spi/kernel_interface.h usability... no
checking spi/kernel_interface.h presence... no
checking for spi/kernel_interface.h... no
checking for Kernel_GetMemorySize... no
setting SYSDEP_INC to
setting CC to gcc
setting F77 to f95
setting TEST_CC to /home/luca/mpich2-1.4.1p1/bin/mpicc
setting TEST_F77 to /home/luca/mpich2-1.4.1p1/bin/mpif77
setting CFLAGS to    -O2  -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_bgl/Makefile
config.status: creating adio/ad_bglockless/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating adio/ad_lustre/Makefile
config.status: creating adio/ad_zoidfs/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating common/dataloop/Makefile
config.status: creating adio/include/romioconf.h
configure: ===== done with src/mpi/romio configure =====
configure: ===== configuring src/pmi/simple =====
configure: executing: /home/luca/mpich2-1.4.1p1/src/pmi/simple/configure  '-prefix=/home/luca/mpich2-install' --disable-option-checking
RUNNING CONFIGURE FOR THE SIMPLE PMI
checking for strings.h... (cached) yes
checking for sys/socket.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
config.status: creating pmiconf.h
configure: ===== done with src/pmi/simple configure =====
configure: ===== configuring src/pm/hydra =====
configure: executing: /home/luca/mpich2-1.4.1p1/src/pm/hydra/configure  '-prefix=/home/luca/mpich2-install' --disable-option-checking
checking for a thread-safe mkdir -p... mkdir -p
checking whether -lc should be explicitly linked in... no
checking whether to build shared libraries... yes
checking for doxygen... no
checking ifaddrs.h usability... yes
checking ifaddrs.h presence... yes
checking for ifaddrs.h... yes
checking poll.h usability... yes
checking poll.h presence... yes
checking for poll.h... yes
checking for netdb.h... (cached) yes
checking winsock2.h usability... no
checking winsock2.h presence... no
checking for winsock2.h... no
checking windows.h usability... no
checking windows.h presence... no
checking for windows.h... no
checking for socket in -lsocket... no
checking for gethostbyname in -lnsl... yes
checking for sigaction... yes
checking for alloca... no
checking for unsetenv... yes
checking for strsignal... yes
checking for getifaddrs... yes
checking for fcntl... yes
checking for isatty... yes
checking for inet_ntop... yes
checking for environ in unistd.h... no
checking for manually declared extern environ... yes
checking bootstrap server... user,ssh,rsh,fork,slurm,ll,lsf,sge,pbs,manual,persist
checking tm.h usability... no
checking tm.h presence... no
checking for tm.h... no
checking for tm_init in -ltorque... no
checking process manager... pmiserv
checking user interface... mpich
checking desired processor topology libraries... hwloc,plpa
configure: ===== configuring tools/topo/hwloc/hwloc =====
configure: executing: /home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/configure --enable-embedded-mode '-prefix=/home/luca/mpich2-install' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2 ' 'LDFLAGS= -lnsl' 'LIBS=' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers' --disable-option-checking
### Configuring hwloc distribution tarball
### Startup tests
checking target system type... i686-pc-linux-gnu
checking how to create a ustar tar archive... gnutar
checking for hwloc version... 1.2.1rc2-1
checking whether gcc and cc understand -c and -o together... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
### Configuring hwloc core
checking hwloc building mode... embedded
configure: hwloc builddir: /home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc
configure: hwloc srcdir: /home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc
checking if want hwloc maintainer support... disabled (embedded mode)
checking for hwloc directory prefix... (none)
checking for hwloc symbol prefix... hwloc_
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking which OS support to include... Linux
checking which CPU support to include... x86_32
checking for __attribute__... yes
checking for __attribute__(aligned)... yes
checking for __attribute__(always_inline)... yes
checking for __attribute__(cold)... yes
checking for __attribute__(const)... yes
checking for __attribute__(deprecated)... yes
checking for __attribute__(format)... yes
checking for __attribute__(hot)... yes
checking for __attribute__(malloc)... yes
checking for __attribute__(may_alias)... yes
checking for __attribute__(no_instrument_function)... yes
checking for __attribute__(nonnull)... no
checking for __attribute__(noreturn)... yes
checking for __attribute__(packed)... yes
checking for __attribute__(pure)... yes
checking for __attribute__(sentinel)... yes
checking for __attribute__(unused)... yes
checking for __attribute__(warn_unused_result)... yes
checking for __attribute__(weak_alias)... yes
checking if gcc supports -fvisibility... yes
checking whether to enable visibility... yes (via -fvisibility=hidden)
configure: WARNING: " -fvisibility=hidden" has been added to the hwloc CFLAGS
checking for inline compatibility keyword... __inline__
checking whether function strncasecmp is declared... yes
checking for strftime... yes
checking for setlocale... yes
checking for KAFFINITY... no
checking for PROCESSOR_CACHE_TYPE... no
checking for CACHE_DESCRIPTOR... no
checking for LOGICAL_PROCESSOR_RELATIONSHIP... no
checking for RelationProcessorPackage... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION... no
checking for GROUP_AFFINITY... no
checking for PROCESSOR_RELATIONSHIP... no
checking for NUMA_NODE_RELATIONSHIP... no
checking for CACHE_RELATIONSHIP... no
checking for PROCESSOR_GROUP_INFO... no
checking for GROUP_RELATIONSHIP... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX... no
checking for PSAPI_WORKING_SET_EX_BLOCK... no
checking for PSAPI_WORKING_SET_EX_INFORMATION... no
checking for main in -lgdi32... no
checking sys/lgrp_user.h usability... no
checking sys/lgrp_user.h presence... no
checking for sys/lgrp_user.h... no
checking kstat.h usability... no
checking kstat.h presence... no
checking for kstat.h... no
checking whether _SC_NPROCESSORS_ONLN is declared... yes
checking whether _SC_NPROCESSORS_CONF is declared... yes
checking whether _SC_NPROC_ONLN is declared... no
checking whether _SC_NPROC_CONF is declared... no
checking whether _SC_LARGE_PAGESIZE is declared... no
checking mach/mach_host.h usability... no
checking mach/mach_host.h presence... no
checking for mach/mach_host.h... no
checking mach/mach_init.h usability... no
checking mach/mach_init.h presence... no
checking for mach/mach_init.h... no
checking for sys/sysctl.h... yes
checking whether CTL_HW is declared... no
checking whether HW_NCPU is declared... no
checking for sysctl... yes
checking for sysctlbyname... no
checking for pthread_t... yes
checking whether function sched_setaffinity is declared... yes
checking for old prototype of sched_setaffinity... no
checking for working CPU_SET... yes
checking for working CPU_SET_S... yes
checking for working _syscall3... no
checking for KERRIGHED... no
checking for lib... no
checking for ffs... yes
checking whether function ffs is declared... yes
checking for ffsl... yes
checking whether function ffsl is declared... yes
checking for fls... no
checking for flsl... no
checking for clz... no
checking for clzl... no
checking for openat... yes
checking for getpagesize... yes
checking for posix_memalign... yes
checking sys/utsname.h usability... yes
checking sys/utsname.h presence... yes
checking for sys/utsname.h... yes
checking for uname... yes
checking numaif.h usability... no
checking numaif.h presence... no
checking for numaif.h... no
checking pthread_np.h usability... no
checking pthread_np.h presence... no
checking for pthread_np.h... no
checking whether pthread_setaffinity_np is declared... yes
checking whether pthread_getaffinity_np is declared... yes
checking for sys/cpuset.h... no
checking for library containing pthread_getthrds_np... no
checking for XML... no
checking for cpuid... yes
checking for X... no
checking whether to build static libraries... no
config.status: creating include/Makefile
config.status: creating include/private/autogen/config.h
config.status: creating include/hwloc/autogen/config.h
configure: ===== done with tools/topo/hwloc/hwloc configure =====
configure: ===== configuring tools/topo/plpa/plpa =====
configure: executing: /home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/configure --enable-included-mode '-prefix=/home/luca/mpich2-install' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2 ' 'LDFLAGS= -lnsl' 'LIBS=' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers' --disable-option-checking
checking for PLPA version... 1.3.2
checking whether to enable "picky" compiler mode... no (default)
checking for flex... no
checking for lex... no
checking for bison... no
checking for byacc... no
checking for syscall... yes
checking sys/syscall.h usability... yes
checking sys/syscall.h presence... yes
checking for sys/syscall.h... yes
checking for __NR_sched_setaffinity... yes
checking for __NR_sched_getaffinity... yes
checking for PLPA building mode... included
checking if want PLPA maintainer support... disabled
checking for PLPA config prefix... .
checking for PLPA symbol prefix... plpa_
configure: WARNING: valgrind.h not found
checking whether to build PLPA executables... no
config.status: creating ./Makefile
config.status: creating ./config/Makefile
config.status: creating ./src/Makefile
config.status: creating ./src/libplpa/Makefile
config.status: creating ./src/plpa-info/Makefile
config.status: creating ./src/plpa-taskset/Makefile
config.status: creating ./src/libplpa/plpa_config.h
config.status: creating ./src/libplpa/plpa.h
configure: ===== done with tools/topo/plpa/plpa configure =====
checking available processor topology libraries...  hwloc plpa
checking checkpointing library... none
checking demux engine... poll,select,port
checking for poll... yes
checking debugging support... none
checking error checking... yes
checking warnings... no
checking profiling... yes
checking libftb.h usability... no
checking libftb.h presence... no
checking for libftb.h... no
checking for FTB_Connect in -lftb... no
checking for strsignal... (cached) yes
checking whether strsignal needs a declaration... no
checking for sigaction... (cached) yes
checking for signal... (cached) yes
checking for sigset... yes
checking for struct sigaction and sa_handler... yes
config.status: creating tools/bootstrap/src/bsci_init.c
config.status: creating hydra-doxygen.cfg
config.status: creating include/hydra_config.h
configure: ===== done with src/pm/hydra configure =====
configure: ===== configuring src/mpe2 =====
configure: executing: /home/luca/mpich2-1.4.1p1/src/mpe2/configure  '-prefix=/home/luca/mpich2-install' --disable-option-checking
Configuring MPE Profiling System with  '-prefix=/home/luca/mpich2-install' '--disable-option-checking' 'MPI_CC=/home/luca/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/home/luca/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2'
checking for current directory name... /home/luca/mpich2-1.4.1p1/src/mpe2
checking gnumake... yes using --no-print-directory
checking BSD 4.4 make... no - whew
checking OSF V3 make... no
This MPE build is part of the MPICH2 build
checking for leftover Makefiles in subpackages ... none
checking whether MPI_CC has been set ... /home/luca/mpich2-1.4.1p1/bin/mpicc
checking whether MPI_F77 has been set ... /home/luca/mpich2-1.4.1p1/bin/mpif77
checking for Fortran 77 libraries of gfortran...  -L/usr/lib/gcc/i686-linux-gnu/4.6 -L/usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu -L/usr/lib/gcc/i686-linux-gnu/4.6/../../../../lib -L/lib/i386-linux-gnu -L/lib/../lib -L/usr/lib/i386-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/i686-linux-gnu/4.6/../../.. -lrt -lpthread -lgfortran -lm -lquadmath
checking whether C can link with  -L/usr/lib/gcc/i686-linux-gnu/4.6 -L/usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu -L/usr/lib/gcc/i686-linux-gnu/4.6/../../../../lib -L/lib/i386-linux-gnu -L/lib/../lib -L/usr/lib/i386-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/i686-linux-gnu/4.6/../../.. -lrt -lpthread -lgfortran -lm -lquadmath... yes
checking for linker for Fortran main programs... Use Fortran to link programs
checking for Fortran 77 name mangling... lower underscore
checking what libraries are needed to link Fortran programs with C routines that use stdio... none
config.status: creating sbin/mpetestlink
config.status: creating sbin/mpetestexec
config.status: creating sbin/mpetestexeclog
config.status: creating sbin/mpeinstall
config.status: creating sbin/mpecheckinstall
config.status: WARNING:  'sbin/mpecheckinstall.in' seems to ignore the --datarootdir setting
config.status: creating sbin/mpecheckbuild
config.status: creating etc/mpe_help.conf
config.status: creating etc/mpe_f77env.conf
config.status: creating mpe_conf.h
=== configuring in src/misc (/home/luca/mpich2-1.4.1p1/src/mpe2/src/misc)
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/home/luca/mpich2-install'  'MPI_CC=/home/luca/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/home/luca/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' --cache-file=/dev/null --srcdir=.
Configuring MPE Miscellaneous Library with  '--disable-option-checking' '--prefix=/home/luca/mpich2-install' 'MPI_CC=/home/luca/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/home/luca/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /home/luca/mpich2-1.4.1p1/src/mpe2/src/misc
checking for dbx... no
checking for gdb... /usr/bin/gdb
checking for sysinfo... yes
checking sys/systeminfo.h usability... no
checking sys/systeminfo.h presence... no
checking for sys/systeminfo.h... no
checking for sighandler_t... no
checking for kill... yes
checking whether kill needs a declaration... no
config.status: creating src/dbxerr.c
config.status: creating mpe_misc_conf.h
=== configuring in src/callstack (/home/luca/mpich2-1.4.1p1/src/mpe2/src/callstack)
Configuring MPE CallStack Library with  '--disable-option-checking' '--prefix=/home/luca/mpich2-install' 'MPI_CC=/home/luca/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/home/luca/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /home/luca/mpich2-1.4.1p1/src/mpe2/src/callstack
checking execinfo.h usability... yes
checking execinfo.h presence... yes
checking for execinfo.h... yes
checking whether <execinfo.h> defines backtrace_symbols_fd() ... yes
checking if <execinfo.h> links with -Wl,--export-dynamic ... yes
checking whether fdopen needs a declaration... no
config.status: creating include/mpe_callstack.h
config.status: creating etc/mpe_callstack_ldflags.conf
config.status: creating bin/bt2line
config.status: creating mpe_callstack_conf.h
=== configuring in src/logging (/home/luca/mpich2-1.4.1p1/src/mpe2/src/logging)
Configuring MPE Logging Library and Tools with  '--disable-option-checking' '--prefix=/home/luca/mpich2-install' 'MPI_CC=/home/luca/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/home/luca/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /home/luca/mpich2-1.4.1p1/src/mpe2/src/logging
checking for header that defines C99 integer types, intXX_t ... <stdint.h>
checking whether <inttypes.h> defines the PRIdXX macros ... yes
checking if <stdint.h> can be behind system headers ... yes
checking for address-sized integer ... CLOG_int32_t
checking for srand48... yes
checking whether srand48 needs a declaration... no
checking for lrand48... yes
checking whether lrand48 needs a declaration... no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... 64
checking for O_LARGEFILE for open() ... needs _LARGEFILE64_SOURCE
checking for O_BINARY for open() ... no
checking for pthread_mutex_lock in -lpthread... yes
config.status: creating include/clog_inttypes.h
config.status: creating include/mpi_null.h
config.status: creating include/mpe_log_thread.h
config.status: creating etc/mpe_log.conf
config.status: creating etc/mpe_nolog.conf
config.status: creating etc/mpe_log_postlib.conf
config.status: creating mpe_logging_conf.h
=== configuring in src/wrappers (/home/luca/mpich2-1.4.1p1/src/mpe2/src/wrappers)
Configuring MPE Wrapper Libraries For MPI with  '--disable-option-checking' '--prefix=/home/luca/mpich2-install' 'MPI_CC=/home/luca/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/home/luca/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /home/luca/mpich2-1.4.1p1/src/mpe2/src/wrappers
checking for stdarg is correct... yes
checking if compiler accepts prototypes ... yes
checking for safe PMPI invocations ... no
checking for the value of MPI_STATUS_SIZE ... 5
config.status: creating etc/mpe_mpilog.conf
config.status: creating etc/mpe_mpitrace.conf
config.status: creating mpe_wrappers_conf.h
=== configuring in src/graphics (/home/luca/mpich2-1.4.1p1/src/mpe2/src/graphics)
Configuring MPE X Graphics Library with  '--disable-option-checking' '--prefix=/home/luca/mpich2-install' 'MPI_CC=/home/luca/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/home/luca/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /home/luca/mpich2-1.4.1p1/src/mpe2/src/graphics
configure: WARNING:  Could not find appropriate X windows libraries.  MPE routines that make use of X11 graphics will NOT be built unless you put X windows libraries in your path and reconfigure!
=== configuring in src/collchk (/home/luca/mpich2-1.4.1p1/src/mpe2/src/collchk)
Configuring MPE Collective and Datatype Checking Library with  '--disable-option-checking' '--prefix=/home/luca/mpich2-install' 'MPI_CC=/home/luca/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/home/luca/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /home/luca/mpich2-1.4.1p1/src/mpe2/src/collchk
config.status: creating etc/mpe_mpicheck.conf
config.status: creating mpe_collchk_conf.h
=== configuring in src/slog2sdk (/home/luca/mpich2-1.4.1p1/src/mpe2/src/slog2sdk)
checking for current directory name... /home/luca/mpich2-1.4.1p1/src/mpe2/src/slog2sdk
Configuring SLOG2SDK with  '--disable-option-checking' '--prefix=/home/luca/mpich2-install' 'MPI_CC=/home/luca/mpich2-1.4.1p1/bin/mpicc' 'MPI_F77=/home/luca/mpich2-1.4.1p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread  ' 'CPPFLAGS= -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking if CLASSPATH is set... no, good to go
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for java in user's PATH... not found
configure: WARNING:  No Java Virtual Machine can be found anywhere!
MPE2:  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/collchk" have been configured
configure: ===== done with src/mpe2 configure =====
checking size of OPA_ptr_t... 4
checking the sizeof MPI_Offset... 8
checking whether the Fortran Offset type works with Fortran 77... yes
checking whether the Fortran Offset type works with Fortran 90... yes
Running Configure for Fortran 90 Type routines
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for grep that handles long lines and -e... /bin/grep
checking for fgrep... /bin/grep -F
checking for the precision and range of reals...  6 , 37
checking for the precision and range of double precision...  15 , 307
checking for the range of integer...  9
checking for available integer kinds...  2 , 1, 4 , 2, 9 , 4, 18 , 8,
checking for available integer ranges...  {  2 , 1 , 1 }, {  4 , 2 , 2 }, {  9 , 4 , 4 }, {  18 , 8 , 8 },
config.status: creating mpif90model.h
config.status: creating src/include/Makefile
config.status: creating src/include/mpich2info.h
config.status: creating mpich2-doxygen
config.status: creating src/include/mpichtimer.h
config.status: creating src/binding/Makefile
config.status: creating src/binding/cxx/Makefile
config.status: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/f77/Makefile
config.status: creating src/binding/f77/mpif.h
config.status: creating src/binding/f77/setbotf.f
config.status: creating src/binding/f77/setbot.c
config.status: creating src/binding/f90/Makefile
config.status: creating src/binding/f90/mpi_sizeofs.f90
config.status: creating src/binding/f90/mpi_base.f90
config.status: creating src/packaging/Makefile
config.status: creating src/packaging/pkgconfig/mpich2-c.pc
config.status: creating src/packaging/pkgconfig/mpich2-cxx.pc
config.status: creating src/packaging/pkgconfig/mpich2-f77.pc
config.status: creating src/packaging/pkgconfig/mpich2-f90.pc
config.status: creating src/packaging/pkgconfig/Makefile
config.status: creating src/packaging/envmods/mpich2.module
config.status: WARNING:  'src/packaging/envmods/mpich2.module.in' seems to ignore the --datarootdir setting
config.status: creating src/packaging/envmods/Makefile
config.status: creating src/env/mpixxx_opts.conf
config.status: creating src/env/mpicc
config.status: creating src/env/mpicc.conf
config.status: creating src/env/mpicc.bash
config.status: creating src/env/mpicxx
config.status: creating src/env/mpicxx.conf
config.status: creating src/env/mpicxx.bash
config.status: creating src/env/mpif77
config.status: creating src/env/mpif77.conf
config.status: creating src/env/mpif77.bash
config.status: creating src/env/mpif90
config.status: creating src/env/mpif90.conf
config.status: creating src/env/mpif90.bash
config.status: creating src/env/Makefile
config.status: creating src/util/createshlib
config.status: creating src/mpi/Makefile
config.status: creating src/mpi/attr/Makefile
config.status: creating src/mpi/coll/Makefile
config.status: creating src/mpi/comm/Makefile
config.status: creating src/mpi/datatype/Makefile
config.status: creating src/mpi/debugger/Makefile
config.status: creating src/mpi/errhan/Makefile
config.status: creating src/mpi/group/Makefile
config.status: creating src/mpi/init/Makefile
config.status: creating src/mpi/misc/Makefile
config.status: creating src/mpi/pt2pt/Makefile
config.status: creating src/mpi/rma/Makefile
config.status: creating src/mpi/spawn/Makefile
config.status: creating src/mpi/timer/Makefile
config.status: creating src/mpi/topo/Makefile
config.status: creating src/mpix/Makefile
config.status: creating src/mpix/comm/Makefile
config.status: creating src/mpid/Makefile
config.status: creating src/mpid/common/Makefile
config.status: creating src/mpid/common/datatype/Makefile
config.status: creating src/mpid/common/datatype/dataloop/Makefile
config.status: creating src/pm/Makefile
config.status: creating src/pmi/Makefile
config.status: creating src/pmi/simple/Makefile
config.status: creating src/nameserv/Makefile
config.status: creating src/nameserv/file/Makefile
config.status: creating src/nameserv/mpd/Makefile
config.status: creating src/nameserv/pmi/Makefile
config.status: creating src/nameserv/test/Makefile
config.status: creating src/util/Makefile
config.status: creating src/util/info/Makefile
config.status: creating src/util/instrm/Makefile
config.status: creating src/util/thread/Makefile
config.status: creating src/util/mem/Makefile
config.status: creating src/util/msgs/Makefile
config.status: creating src/util/param/Makefile
config.status: creating src/util/dbg/Makefile
config.status: creating src/util/dbg/getfuncstack
config.status: creating src/util/osserv/Makefile
config.status: creating src/util/procmap/Makefile
config.status: creating src/util/other/Makefile
config.status: creating src/include/mpi.h
config.status: creating test/util/Makefile
config.status: creating test/basic/Makefile
config.status: creating test/commands/Makefile
config.status: creating test/commands/cmdtests
config.status: creating test/mpid/Makefile
config.status: creating test/mpid/ch3/Makefile
config.status: creating test/util/timer/Makefile
config.status: creating examples/Makefile
config.status: creating examples/f77/Makefile
config.status: creating examples/f90/Makefile
config.status: creating examples/cxx/Makefile
config.status: creating src/util/logging/Makefile
config.status: creating src/util/logging/common/Makefile
config.status: creating doc/Makefile
config.status: creating doc/mansrc/Makefile
config.status: creating doc/mansrc/createhtmlindex
config.status: creating doc/refman/Makefile
config.status: creating doc/installguide/Makefile
config.status: creating doc/userguide/Makefile
config.status: creating doc/logging/Makefile
config.status: creating doc/design/Makefile
config.status: creating doc/smpd/Makefile
config.status: creating doc/windev/Makefile
config.status: creating src/include/mpichconf.h
config.status: executing default-2 commands
config.status: executing default-3 commands
config.status: executing default-4 commands
config.status: executing default-5 commands
config.status: executing default-6 commands
config.status: executing default-7 commands
config.status: executing default-8 commands
config.status: executing default-9 commands
config.status: executing default-10 commands
config.status: executing default-11 commands
config.status: executing default-12 commands
=== configuring in test/mpi (/home/luca/mpich2-1.4.1p1/test/mpi)
configure: running /bin/bash ./configure --disable-option-checking '--prefix=/home/luca/mpich2-install'  --cache-file=/dev/null --srcdir=.
RUNNING CONFIGURE FOR MPI TESTS
checking whether /home/luca/mpich2-1.4.1p1/bin/mpicc accepts -g... yes
checking for /home/luca/mpich2-1.4.1p1/bin/mpicc option to accept ISO C89... none needed
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking how to run the C preprocessor... /home/luca/mpich2-1.4.1p1/bin/mpicc -E
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for library containing pthread_create... -lpthread
checking for library containing pthread_barrier_init... none required
checking for pthread_create... yes
checking for pthread_yield... yes
checking for pthread_barrier_init... yes
checking for pthread_barrier_wait... yes
checking for major version of MPI... 2
checking for minor version of MPI... 2
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether /home/luca/mpich2-1.4.1p1/bin/mpif77 accepts -g... yes
checking how to get verbose linking output from /home/luca/mpich2-1.4.1p1/bin/mpif77... -v
checking for Fortran 77 libraries of /home/luca/mpich2-1.4.1p1/bin/mpif77...  -L/usr/lib/gcc/i686-linux-gnu/4.6 -L/usr/lib/gcc/i686-linux-gnu/4.6/../../../i386-linux-gnu -L/usr/lib/gcc/i686-linux-gnu/4.6/../../../../lib -L/lib/i386-linux-gnu -L/lib/../lib -L/usr/lib/i386-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/i686-linux-gnu/4.6/../../.. -lpthread -lgfortran -lm -lquadmath
checking for Fortran 77 name mangling... lower uscore
checking for Fortran libraries needed for getarg... none needed
checking whether Fortran 77 supports Cray-style pointer... yes
checking for Fortran 77 compiler flag for Cray-style pointer... -fcray-pointer
checking whether we are using the GNU Fortran compiler... yes
checking whether /home/luca/mpich2-1.4.1p1/bin/mpif90 accepts -g... yes
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (/home/luca/mpich2-1.4.1p1/bin/mpif90  -nativelinking  ) works... yes
checking whether the Fortran 90 compiler (/home/luca/mpich2-1.4.1p1/bin/mpif90  -nativelinking  ) is a cross-compiler... no
checking for Fortran flag needed to allow free-form source... none
checking whether Fortran 90 supports Cray-style pointer... yes
checking for Fortran 90 compiler flag for Cray-style pointer... -fcray-pointer
checking whether /home/luca/mpich2-1.4.1p1/bin/mpicxx accepts -g... yes
checking whether MPI_2DOUBLE_COMPLEX is available... no
checking whether MPI_2COMPLEX is available... no
checking size of void *... 4
checking size of int... 4
checking for C integer type of address size... int
configure: creating ./config.status
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating Makefile
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating rma/Makefile
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/errhan/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating threads/init/Makefile
config.status: creating threads/spawn/Makefile
config.status: creating errors/Makefile
config.status: creating errors/attr/Makefile
config.status: creating errors/basic/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/faults/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f90/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating threads/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
config.status: creating include/mpitestconf.h
Configuration completed.
Beginning make
Using variables CC='gcc' CFLAGS='   -O2' LDFLAGS=' ' F77='gfortran' FFLAGS='  -O2' FC='f95' FCFLAGS='  -O2' CXX='c++' CXXFLAGS='  -O2' AR='ar' CPP='gcc -E' CPPFLAGS=' -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers'
make all-local
make[1]: Entering directory `/home/luca/mpich2-1.4.1p1'
make[1]: Leaving directory `/home/luca/mpich2-1.4.1p1'
make[1]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpl'
  CC     mplstr.lo
  CC     mpltrmem.lo
  CC     mplenv.lo
  CCLD   libmpl.la
make[1]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpl'
make[1]: Entering directory `/home/luca/mpich2-1.4.1p1/src/openpa'
Making all in src
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/openpa/src'
make  all-am
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/openpa/src'
/bin/bash ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo opa_primitives.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c opa_primitives.c -o opa_primitives.o
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/bin/bash ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c opa_queue.c -o opa_queue.o
mv -f .deps/opa_queue.Tpo .deps/opa_queue.Plo
/bin/bash ../libtool --tag=CC   --mode=link gcc   -version-info 1:0  -o libopa.la -rpath /home/luca/mpich2-install/lib opa_primitives.lo opa_queue.lo  -lpthread
libtool: link: ar cru .libs/libopa.a  opa_primitives.o opa_queue.o
libtool: link: ranlib .libs/libopa.a
libtool: link: ( cd ".libs" && rm -f "libopa.la" && ln -s "../libopa.la" "libopa.la" )
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/openpa/src'
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/openpa/src'
Making all in test
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/openpa/test'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/openpa/test'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/openpa'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/openpa'
make[1]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/openpa'
make[1]: Entering directory `/home/luca/mpich2-1.4.1p1/src'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpl'
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpl'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/common'
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype'
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype/dataloop'
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dataloop.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c segment.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c segment_packunpack.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c segment_flatten.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c segment_count.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dataloop_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dataloop_create_contig.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dataloop_create_vector.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dataloop_create_blockindexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dataloop_create_indexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dataloop_create_struct.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dataloop_create_pairtype.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c subarray_support.c
gcc -DHAVE_CONFIG_H -I. -I. -I./.. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c darray_support.c
ar cr ../../../../../lib/libmpich.a dataloop.o segment.o segment_packunpack.o segment_flatten.o segment_count.o dataloop_create.o dataloop_create_contig.o dataloop_create_vector.o dataloop_create_blockindexed.o dataloop_create_indexed.o dataloop_create_struct.o dataloop_create_pairtype.o subarray_support.o darray_support.o
ranlib ../../../../../lib/libmpich.a
date > .libstamp0
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype/dataloop'
make all-local
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype'
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_debug.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_segment.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_ext32_segment.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_ext32_datatype.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_dup.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpir_type_get_contig_blocks.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpir_type_flatten.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_commit.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_zerolen.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_vector.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_contiguous.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_create_resized.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_blockindexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_indexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_struct.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_get_envelope.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_datatype_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_datatype_contents.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_get_contents.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_type_create_pairtype.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_contents_support.c
ar cr ../../../../lib/libmpich.a mpid_type_debug.o mpid_segment.o mpid_ext32_segment.o mpid_ext32_datatype.o mpid_type_dup.o mpir_type_get_contig_blocks.o mpir_type_flatten.o mpid_type_commit.o mpid_type_zerolen.o mpid_type_vector.o mpid_type_contiguous.o mpid_type_create_resized.o mpid_type_blockindexed.o mpid_type_indexed.o mpid_type_struct.o mpid_type_get_envelope.o mpid_datatype_free.o mpid_datatype_contents.o mpid_type_get_contents.o mpid_type_create_pairtype.o mpid_contents_support.o
ranlib ../../../../lib/libmpich.a
date > .libstamp0
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype'
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype'
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/common'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3'
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels'
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis'
make[6]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis'
make[7]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/src'
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_alloc.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_queue.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_barrier.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_mpich2.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_ckpt.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_finalize.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_network_poll.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_network.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_debug.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_lmt.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_lmt_shm.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_net_array.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_lmt_dma.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_nem_lmt_vmsplice.c
ar cr ../../../../../../../lib/libmpich.a mpid_nem_alloc.o mpid_nem_init.o mpid_nem_queue.o mpid_nem_barrier.o mpid_nem_mpich2.o mpid_nem_ckpt.o mpid_nem_finalize.o mpid_nem_network_poll.o mpid_nem_network.o mpid_nem_debug.o mpid_nem_lmt.o mpid_nem_lmt_shm.o mpid_nem_net_array.o mpid_nem_lmt_dma.o mpid_nem_lmt_vmsplice.o
ranlib ../../../../../../../lib/libmpich.a
date > .libstamp0
make[7]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/src'
make[7]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[8]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c tcp_finalize.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c tcp_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c tcp_send.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c tcp_utility.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c socksm.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c tcp_getip.c
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c tcp_ckpt.c
ar cr ../../../../../../../../lib/libmpich.a tcp_finalize.o tcp_init.o tcp_send.o tcp_utility.o socksm.o tcp_getip.o tcp_ckpt.o
ranlib ../../../../../../../../lib/libmpich.a
date > .libstamp0
make[8]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[7]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[7]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[8]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c papi_defs.c
ar cr ../../../../../../../../lib/libmpich.a papi_defs.o
date > .libstamp0
make[8]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
make[8]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
gcc -DHAVE_CONFIG_H -I. -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mkstemp.c
ar cr ../../../../../../../../lib/libmpich.a mkstemp.o
date > .libstamp0
make[8]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[7]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[6]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis'
make[6]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/src'
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3_finalize.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3_isend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3_isendv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3_istartmsg.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3_istartmsgv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3_progress.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3_abort.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3i_comm.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3i_eagernoncontig.c
ar cr ../../../../../../lib/libmpich.a ch3_finalize.o ch3_init.o ch3_isend.o ch3_isendv.o ch3_istartmsg.o ch3_istartmsgv.o ch3_progress.o ch3_abort.o ch3i_comm.o ch3i_eagernoncontig.o
ranlib ../../../../../../lib/libmpich.a
date > .libstamp0
make[6]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/src'
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis'
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels'
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/src'
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_buffer.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_comm_spawn_multiple.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_handle_connection.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_handle_recv_pkt.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_handle_recv_req.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_handle_send_req.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_port.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_recvq.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_request.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_rma_ops.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_rma_sync.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_rndv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_eager.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ch3u_eagersync.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_abort.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_cancel_recv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_cancel_send.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_comm_disconnect.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_comm_spawn_multiple.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_finalize.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_get_universe_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_getpname.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_iprobe.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_irecv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_irsend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_isend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_issend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_port.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_probe.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_recv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_rsend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_send.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_ssend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_startall.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_vc.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpid_rma.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpidi_isend_self.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpidi_pg.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpidi_printf.c
ar cr ../../../../lib/libmpich.a ch3u_buffer.o ch3u_comm_spawn_multiple.o ch3u_handle_connection.o ch3u_handle_recv_pkt.o ch3u_handle_recv_req.o ch3u_handle_send_req.o ch3u_port.o ch3u_recvq.o ch3u_request.o ch3u_rma_ops.o ch3u_rma_sync.o ch3u_rndv.o ch3u_eager.o ch3u_eagersync.o mpid_abort.o mpid_cancel_recv.o mpid_cancel_send.o mpid_comm_disconnect.o mpid_comm_spawn_multiple.o mpid_finalize.o mpid_get_universe_size.o mpid_getpname.o mpid_init.o mpid_iprobe.o mpid_irecv.o mpid_irsend.o mpid_isend.o mpid_issend.o mpid_port.o mpid_probe.o mpid_recv.o mpid_rsend.o mpid_send.o mpid_ssend.o mpid_startall.o mpid_vc.o mpid_rma.o mpidi_isend_self.o mpidi_pg.o mpidi_printf.o
ranlib ../../../../lib/libmpich.a
date > .libstamp0
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/src'
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/util'
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3/util'
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid/ch3'
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpid'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/attr'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c attr_delete.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c attr_get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c attr_put.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_create_keyval.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_delete_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_free_keyval.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_get_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_set_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c keyval_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c keyval_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_create_keyval.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_delete_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_free_keyval.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_get_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_set_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_create_keyval.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_delete_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_free_keyval.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_get_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_set_attr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c attrutil.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dup_fn.c
ar cr ../../../lib/libmpich.a attr_delete.o attr_get.o attr_put.o comm_create_keyval.o comm_delete_attr.o comm_free_keyval.o comm_get_attr.o comm_set_attr.o keyval_create.o keyval_free.o type_create_keyval.o type_delete_attr.o type_free_keyval.o type_get_attr.o type_set_attr.o win_create_keyval.o win_delete_attr.o win_free_keyval.o win_get_attr.o win_set_attr.o attrutil.o dup_fn.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/attr'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/coll'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c allreduce.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c barrier.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c op_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c op_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c bcast.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c alltoall.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c alltoallv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c reduce.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c scatter.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c gather.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c scatterv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c gatherv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c scan.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c exscan.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c allgather.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c allgatherv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c red_scat.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c alltoallw.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c reduce_local.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c op_commutative.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c red_scat_block.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c helper_fns.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c opsum.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c opmax.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c opmin.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c opband.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c opbor.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c opbxor.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c opland.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c oplor.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c oplxor.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c opprod.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c opminloc.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c opmaxloc.c
ar cr ../../../lib/libmpich.a allreduce.o barrier.o op_create.o op_free.o bcast.o alltoall.o alltoallv.o reduce.o scatter.o gather.o scatterv.o gatherv.o scan.o exscan.o allgather.o allgatherv.o red_scat.o alltoallw.o reduce_local.o op_commutative.o red_scat_block.o helper_fns.o opsum.o opmax.o opmin.o opband.o opbor.o opbxor.o opland.o oplor.o oplxor.o opprod.o opminloc.o opmaxloc.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/coll'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/comm'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_compare.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_dup.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_get_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_group.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_rank.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_remote_group.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_remote_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_set_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_split.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_test_inter.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c intercomm_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c intercomm_merge.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commutil.c
ar cr ../../../lib/libmpich.a comm_compare.o comm_create.o comm_dup.o comm_free.o comm_get_name.o comm_group.o comm_rank.o comm_size.o comm_remote_group.o comm_remote_size.o comm_set_name.o comm_split.o comm_test_inter.o intercomm_create.o intercomm_merge.o commutil.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/comm'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/datatype'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c address.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_address.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_count.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_elements.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c pack.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c unpack.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c pack_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c status_set_elements.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_get_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_set_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_extent.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_vector.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_commit.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_indexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_hindexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_struct.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_contiguous.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_hvector.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_dup.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_get_envelope.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_get_contents.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_ub.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_lb.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_get_extent.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_get_true_extent.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_match_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_create_struct.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_create_hindexed.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_create_hvector.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c pack_external.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c pack_external_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c unpack_external.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_create_indexed_block.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_create_resized.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_create_darray.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_create_subarray.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typeutil.c
ar cr ../../../lib/libmpich.a address.o get_address.o get_count.o get_elements.o pack.o unpack.o pack_size.o status_set_elements.o type_get_name.o type_set_name.o type_size.o type_extent.o type_vector.o type_commit.o type_indexed.o type_hindexed.o type_struct.o type_contiguous.o type_free.o type_hvector.o type_dup.o type_get_envelope.o type_get_contents.o type_ub.o type_lb.o type_get_extent.o type_get_true_extent.o type_match_size.o type_create_struct.o type_create_hindexed.o type_create_hvector.o pack_external.o pack_external_size.o unpack_external.o type_create_indexed_block.o type_create_resized.o type_create_darray.o type_create_subarray.o typeutil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/datatype'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/errhan'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c add_error_code.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c add_error_class.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c add_error_string.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_call_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_create_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_get_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_set_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c errhandler_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c errhandler_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c errhandler_get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c errhandler_set.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c error_class.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c error_string.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_create_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_get_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_set_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_call_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_create_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_call_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_get_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_set_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c errutil.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dynerrutil.c
ar cr ../../../lib/libmpich.a add_error_code.o add_error_class.o add_error_string.o comm_call_errhandler.o comm_create_errhandler.o comm_get_errhandler.o comm_set_errhandler.o errhandler_create.o errhandler_free.o errhandler_get.o errhandler_set.o error_class.o error_string.o file_create_errhandler.o file_get_errhandler.o file_set_errhandler.o file_call_errhandler.o win_create_errhandler.o win_call_errhandler.o win_get_errhandler.o win_set_errhandler.o errutil.o dynerrutil.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/errhan'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/group'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_compare.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_difference.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_excl.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_incl.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_intersection.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_range_excl.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_range_incl.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_rank.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_size.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_translate_ranks.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_union.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c grouputil.c
ar cr ../../../lib/libmpich.a group_compare.o group_difference.o group_excl.o group_free.o group_incl.o group_intersection.o group_range_excl.o group_range_incl.o group_rank.o group_size.o group_translate_ranks.o group_union.o grouputil.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/group'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/init'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/luca/mpich2-1.4.1p1/src/mpi/spawn -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c abort.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/luca/mpich2-1.4.1p1/src/mpi/spawn -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/luca/mpich2-1.4.1p1/src/mpi/spawn -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c initialized.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/luca/mpich2-1.4.1p1/src/mpi/spawn -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c initthread.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/luca/mpich2-1.4.1p1/src/mpi/spawn -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ismain.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/luca/mpich2-1.4.1p1/src/mpi/spawn -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c finalize.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/luca/mpich2-1.4.1p1/src/mpi/spawn -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c finalized.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/luca/mpich2-1.4.1p1/src/mpi/spawn -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c querythread.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/luca/mpich2-1.4.1p1/src/mpi/spawn -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c initinfo.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I../../../src/mpi/datatype -I/home/luca/mpich2-1.4.1p1/src/mpi/spawn -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c async.c
ar cr ../../../lib/libmpich.a abort.o init.o initialized.o initthread.o ismain.o finalize.o finalized.o querythread.o initinfo.o async.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/init'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/misc'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c getpname.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c pcontrol.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c version.c
ar cr ../../../lib/libmpich.a getpname.o pcontrol.o version.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/misc'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/pt2pt'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c bsend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c bsend_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c bufattach.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c buffree.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cancel.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c greq_start.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c greq_complete.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ibsend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c iprobe.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c irecv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c irsend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c isend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c issend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c probe.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c recv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c recv_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c request_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c request_get_status.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c rsend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c rsend_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c send.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c send_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c sendrecv.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c sendrecv_rep.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c status_set_cancelled.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ssend.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ssend_init.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c start.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c startall.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c test.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c test_cancelled.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c testall.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c testany.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c testsome.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c wait.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c waitall.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c waitany.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c waitsome.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c bsendutil.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpir_request.c
ar cr ../../../lib/libmpich.a bsend.o bsend_init.o bufattach.o buffree.o cancel.o greq_start.o greq_complete.o ibsend.o iprobe.o irecv.o irsend.o isend.o issend.o probe.o recv.o recv_init.o request_free.o request_get_status.o rsend.o rsend_init.o send.o send_init.o sendrecv.o sendrecv_rep.o status_set_cancelled.o ssend.o ssend_init.o start.o startall.o test.o test_cancelled.o testall.o testany.o testsome.o wait.o waitall.o waitany.o waitsome.o bsendutil.o mpir_request.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/pt2pt'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/rma'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c accumulate.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c alloc_mem.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c free_mem.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c put.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_complete.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_fence.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_get_group.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_get_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_lock.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_post.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_set_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_start.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_unlock.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_wait.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_test.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c winutil.c
ar cr ../../../lib/libmpich.a accumulate.o alloc_mem.o free_mem.o get.o put.o win_complete.o win_create.o win_fence.o win_free.o win_get_group.o win_get_name.o win_lock.o win_post.o win_set_name.o win_start.o win_unlock.o win_wait.o win_test.o winutil.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/rma'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/spawn'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_disconnect.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_get_parent.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_join.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_spawn.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_spawn_multiple.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c lookup_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c publish_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c unpublish_name.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c open_port.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c close_port.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_connect.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_accept.c
ar cr ../../../lib/libmpich.a comm_disconnect.o comm_get_parent.o comm_join.o comm_spawn.o comm_spawn_multiple.o lookup_name.o publish_name.o unpublish_name.o open_port.o close_port.o comm_connect.o comm_accept.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/spawn'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/timer'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c wtime.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c wtick.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpidtime.c
ar cr ../../../lib/libmpich.a wtime.o wtick.o mpidtime.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/timer'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/topo'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_coords.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_map.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_rank.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_shift.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_sub.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dims_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c graph_get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c graph_map.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c graph_nbr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c graphcreate.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c graphdimsget.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c graphnbrcnt.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cartdim_get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c topo_test.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dist_gr_create_adj.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dist_gr_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dist_gr_neighb_count.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dist_gr_neighb.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c topoutil.c
ar cr ../../../lib/libmpich.a cart_coords.o cart_create.o cart_get.o cart_map.o cart_rank.o cart_shift.o cart_sub.o dims_create.o graph_get.o graph_map.o graph_nbr.o graphcreate.o graphdimsget.o graphnbrcnt.o cartdim_get.o topo_test.o dist_gr_create_adj.o dist_gr_create.o dist_gr_neighb_count.o dist_gr_neighb.o topoutil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/topo'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio'
make mpiolib
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio'
compiling ROMIO in directory mpi-io
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io'
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c close.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c read.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c open.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c write.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c set_view.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c iread.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c iwrite.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c seek.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_posn.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c delete.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c read_all.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c read_at.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c read_atall.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c iread_at.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c iwrite_at.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c write_all.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_bytoff.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c write_at.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c write_atall.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_view.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_group.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_amode.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_extent.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c fsync.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_atom.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c set_atom.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c set_size.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_size.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c prealloc.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_f2c.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_c2f.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c set_info.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_info.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c rd_atallb.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c rd_atalle.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c read_allb.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c read_alle.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c wr_atallb.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c wr_atalle.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c write_allb.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c write_alle.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_posn_sh.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c iread_sh.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c read_sh.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c write_sh.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c iwrite_sh.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c seek_sh.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c read_ord.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c read_orde.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c write_ordb.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c read_ordb.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c write_ord.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c write_orde.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpiu_greq.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpich2_fileutil.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c register_datarep.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io -I../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpir-mpioinit.c
ar cr /home/luca/mpich2-1.4.1p1/lib/libmpich.a close.o read.o open.o write.o set_view.o iread.o iwrite.o seek.o get_posn.o delete.o read_all.o read_at.o read_atall.o iread_at.o iwrite_at.o write_all.o get_bytoff.o write_at.o write_atall.o get_view.o get_group.o get_amode.o get_extent.o fsync.o get_atom.o set_atom.o set_size.o get_size.o prealloc.o file_f2c.o file_c2f.o set_info.o get_info.o rd_atallb.o rd_atalle.o read_allb.o read_alle.o wr_atallb.o wr_atalle.o write_allb.o write_alle.o get_posn_sh.o iread_sh.o read_sh.o write_sh.o iwrite_sh.o seek_sh.o read_ord.o read_orde.o write_ordb.o read_ordb.o write_ord.o write_orde.o mpiu_greq.o mpich2_fileutil.o register_datarep.o mpir-mpioinit.o
ranlib /home/luca/mpich2-1.4.1p1/lib/libmpich.a
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io'
compiling ROMIO in directory adio/common
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common'
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_close.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_init.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_end.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_open.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c flatten.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c malloc.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_read_coll.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c eof_offset.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_write_coll.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c lock.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_read_str.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_write_str.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c iscontig.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_fp_posn.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_seek.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_delete.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_flush.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_hints.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c error.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_fstype.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_get_sh_fp.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_set_sh_fp.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c shfp_fname.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c byte_offset.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c status_setb.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_aggregate.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cb_config_list.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_read_str_naive.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_set_view.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_iopen.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_write_str_naive.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_resize.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_read.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_write.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_iread.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_iwrite.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_done.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_wait.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c adi_close.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_prealloc.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_fcntl.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_iread_fake.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_iwrite_fake.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_done_fake.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_wait_fake.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_subarray.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_darray.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c strfns.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c greq_fns.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c system_hints.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_write_nolock.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_coll_exch_new.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_coll_build_req_new.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_io_coll.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_aggregate_new.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c heap-sort.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_opencoll.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_opencoll_scalable.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_opencoll_failsafe.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common/../../../../../src/include -I../../../../../src/include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_features.c
ar cr /home/luca/mpich2-1.4.1p1/lib/libmpich.a ad_close.o ad_init.o ad_end.o ad_open.o flatten.o malloc.o ad_read_coll.o eof_offset.o ad_write_coll.o lock.o ad_read_str.o ad_write_str.o iscontig.o get_fp_posn.o ad_seek.o ad_delete.o ad_flush.o ad_hints.o error.o ad_fstype.o ad_get_sh_fp.o ad_set_sh_fp.o shfp_fname.o byte_offset.o status_setb.o ad_aggregate.o cb_config_list.o ad_read_str_naive.o ad_set_view.o ad_iopen.o ad_write_str_naive.o ad_resize.o ad_read.o ad_write.o ad_iread.o ad_iwrite.o ad_done.o ad_wait.o adi_close.o ad_prealloc.o ad_fcntl.o ad_iread_fake.o ad_iwrite_fake.o ad_done_fake.o ad_wait_fake.o ad_subarray.o ad_darray.o strfns.o greq_fns.o system_hints.o ad_write_nolock.o ad_coll_exch_new.o ad_coll_build_req_new.o ad_io_coll.o ad_aggregate_new.o heap-sort.o ad_opencoll.o ad_opencoll_scalable.o ad_opencoll_failsafe.o ad_features.o
ranlib /home/luca/mpich2-1.4.1p1/lib/libmpich.a
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/common'
compiling ROMIO in directory mpi-io/glue/mpich2
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/glue/mpich2'
gcc -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/glue/mpich2/../../../mpi-io -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/glue/mpich2/../../../adio/include -I../../../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/glue/mpich2/../../../../../../src/include -I../../../../../../src/include -DHAVE_MPI_INFO_SRC -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpio_file.c
gcc -I. -I../../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/glue/mpich2/../../../mpi-io -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/glue/mpich2/../../../adio/include -I../../../adio/include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/glue/mpich2/../../../../../../src/include -I../../../../../../src/include -DHAVE_MPI_INFO_SRC -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpio_err.c
ar cr /home/luca/mpich2-1.4.1p1/lib/libmpich.a mpio_file.o mpio_err.o
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio/mpi-io/glue/mpich2'
compiling ROMIO in directory adio/ad_testfs
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs'
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_close.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_read.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_rdcoll.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_wrcoll.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_open.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_write.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_done.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_fcntl.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_iread.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_iwrite.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_wait.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_flush.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_seek.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_resize.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_hints.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs_delete.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_testfs.c
ar cr /home/luca/mpich2-1.4.1p1/lib/libmpich.a ad_testfs_close.o ad_testfs_read.o ad_testfs_rdcoll.o ad_testfs_wrcoll.o ad_testfs_open.o ad_testfs_write.o ad_testfs_done.o ad_testfs_fcntl.o ad_testfs_iread.o ad_testfs_iwrite.o ad_testfs_wait.o ad_testfs_flush.o ad_testfs_seek.o ad_testfs_resize.o ad_testfs_hints.o ad_testfs_delete.o ad_testfs.o
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_testfs'
compiling ROMIO in directory adio/ad_ufs
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_ufs'
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_ufs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_ufs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_ufs_open.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_ufs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_ufs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_ufs.c
ar cr /home/luca/mpich2-1.4.1p1/lib/libmpich.a ad_ufs_open.o ad_ufs.o
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_ufs'
compiling ROMIO in directory adio/ad_nfs
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs'
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs_read.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs_open.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs_write.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs_done.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs_fcntl.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs_iread.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs_iwrite.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs_wait.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs_setsh.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs_getsh.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs_resize.c
gcc -I. -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../include -I../include -I../../include -I/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs/../../../../include -I../../../../include -O2 -DFORTRANUNDERSCORE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DHAVE_ROMIOCONF_H -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ad_nfs_features.c
ar cr /home/luca/mpich2-1.4.1p1/lib/libmpich.a ad_nfs_read.o ad_nfs_open.o ad_nfs_write.o ad_nfs_done.o ad_nfs_fcntl.o ad_nfs_iread.o ad_nfs_iwrite.o ad_nfs_wait.o ad_nfs_setsh.o ad_nfs_getsh.o ad_nfs.o ad_nfs_resize.o ad_nfs_features.o
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio/adio/ad_nfs'
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio'
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio'
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi/romio'
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpi'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpix'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpix/comm'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_comm.c
ar cr ../../../lib/libmpich.a group_comm.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpix/comm'
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpix'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/util'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/util/mem'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c trmem.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c handlemem.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c safestr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c argstr.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c strerror.c
ar cr ../../../lib/libmpich.a trmem.o handlemem.o safestr.o argstr.o strerror.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/util/mem'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/util/info'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c infoutil.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_create.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_delete.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_dup.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_free.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_get.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_getn.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_getnth.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_getvallen.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_set.c
ar cr ../../../lib/libmpich.a infoutil.o info_create.o info_delete.o info_dup.o info_free.o info_get.o info_getn.o info_getnth.o info_getvallen.o info_set.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/util/info'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/util/msgs'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c msgprint.c
ar cr ../../../lib/libmpich.a msgprint.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/util/msgs'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/util/instrm'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c states.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c instr.c
ar cr ../../../lib/libmpich.a states.o instr.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/util/instrm'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/util/thread'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpiu_thread.c
ar cr ../../../lib/libmpich.a mpiu_thread.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/util/thread'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/util/dbg'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dbg_printf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c timelimit.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c exit.c
ar cr ../../../lib/libmpich.a dbg_printf.o timelimit.o exit.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/util/dbg'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/util/param'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c param_vals.c
ar cr ../../../lib/libmpich.a param_vals.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/util/param'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/util/osserv'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dl.c
ar cr ../../../lib/libmpich.a dl.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/util/osserv'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/util/procmap'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c local_proc.c
ar cr ../../../lib/libmpich.a local_proc.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/util/procmap'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/util/other'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c outliers.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c assert.c
ar cr ../../../lib/libmpich.a outliers.o assert.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/util/other'
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/util'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/nameserv'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/nameserv/file'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/mpi/spawn -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_nameserv.c
ar cr ../../../lib/libmpich.a file_nameserv.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/nameserv/file'
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/nameserv'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/binding'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/binding/f77'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wsendf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./sendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wrecvf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./recvf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wget_countf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./get_countf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wbsendf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./bsendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wssendf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./ssendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wrsendf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./rsendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wbufattachf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./bufattachf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wbufdetachf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./bufdetachf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wisendf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./isendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wibsendf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./ibsendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wissendf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./issendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wirsendf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./irsendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wirecvf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./irecvf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwaitf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./waitf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtestf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./testf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wrequest_freef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./request_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwaitanyf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./waitanyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtestanyf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./testanyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwaitallf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./waitallf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtestallf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./testallf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwaitsomef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./waitsomef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtestsomef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./testsomef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wiprobef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./iprobef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wprobef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./probef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcancelf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./cancelf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtestcancelf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./testcancelf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wsend_initf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./send_initf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wbsend_initf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./bsend_initf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wssend_initf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./ssend_initf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wrsend_initf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./rsend_initf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wrecv_initf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./recv_initf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wstartf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./startf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wstartallf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./startallf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wsendrecvf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./sendrecvf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wsndrcvrplf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./sndrcvrplf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypecontigf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typecontigf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_vectorf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_vectorf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_hvectorf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_hvectorf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_indexedf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_indexedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_hindexedf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_hindexedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_structf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_structf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_extentf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_extentf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_sizef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_lbf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_lbf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_ubf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_ubf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_commitf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_commitf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_freef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wget_elementsf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./get_elementsf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wpackf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./packf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wunpackf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./unpackf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wpack_sizef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./pack_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wbarrierf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./barrierf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wbcastf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./bcastf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgatherf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./gatherf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgathervf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./gathervf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wscatterf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./scatterf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wscattervf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./scattervf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wallgatherf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./allgatherf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wallgathervf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./allgathervf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _walltoallf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./alltoallf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _walltoallvf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./alltoallvf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wreducef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./reducef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wop_createf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./op_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wop_freef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./op_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wallreducef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./allreducef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wredscatf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./redscatf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wscanf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./scanf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgroup_sizef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./group_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgroup_rankf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./group_rankf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgrouptranksf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./grouptranksf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgroup_comparef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./group_comparef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_groupf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_groupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgroup_unionf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./group_unionf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgroupinterf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./groupinterf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgroupdifff.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./groupdifff.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgroup_inclf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./group_inclf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgroup_exclf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./group_exclf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgrouprinclf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./grouprinclf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgrouprexclf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./grouprexclf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgroup_freef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./group_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_sizef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_rankf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_rankf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_comparef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_comparef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_dupf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_dupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_createf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_splitf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_splitf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_freef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommtesticf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commtesticf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommrsizef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commrsizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommrgroupf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commrgroupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wiccreatef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./iccreatef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wicmergef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./icmergef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wkeyval_freef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./keyval_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wattr_putf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./attr_putf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wattr_getf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./attr_getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wattr_deletef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./attr_deletef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtopo_testf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./topo_testf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcart_createf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./cart_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wdims_createf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./dims_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgraph_createf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./graph_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgraphdims_getf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./graphdims_getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgraph_getf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./graph_getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcartdim_getf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./cartdim_getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcart_getf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./cart_getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcart_rankf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./cart_rankf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcart_coordsf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./cart_coordsf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgrfnbcountf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./grfnbcountf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgrfnbrsf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./grfnbrsf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcart_shiftf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./cart_shiftf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcart_subf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./cart_subf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcart_mapf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./cart_mapf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgraph_mapf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./graph_mapf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgetpnamef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./getpnamef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wget_versionf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./get_versionf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _werrhcreatef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./errhcreatef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _werrhsetf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./errhsetf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _werrhgetf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./errhgetf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _werrhfreef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./errhfreef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _werror_stringf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./error_stringf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _werror_classf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./error_classf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfinalizef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./finalizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _winitializedf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./initializedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wabortf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./abortf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wclose_portf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./close_portf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_acceptf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_acceptf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_connectf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_connectf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommdiscf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commdiscf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommparentf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commparentf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_joinf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_joinf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_spawnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_spawnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wspawnmultf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./spawnmultf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wlookup_namef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./lookup_namef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wopen_portf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./open_portf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wpublish_namef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./publish_namef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wunpubnamef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./unpubnamef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _waccumulatef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./accumulatef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgetf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wputf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./putf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_completef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_completef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_createf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_fencef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_fencef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_freef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_get_groupf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_get_groupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_lockf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_lockf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_postf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_postf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_startf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_startf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_testf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_testf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_unlockf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_unlockf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_waitf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_waitf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _walltoallwf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./alltoallwf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wexscanf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./exscanf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wadderrclassf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./adderrclassf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wadderrcodef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./adderrcodef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wadderrstringf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./adderrstringf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommcallerrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commcallerrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommnewkeyf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commnewkeyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommdelattrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commdelattrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommfreekeyf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commfreekeyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_get_attrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_get_attrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommgetnamf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commgetnamf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_set_attrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_set_attrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcomm_set_namef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./comm_set_namef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfilecallerrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./filecallerrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgreqcompletef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./greqcompletef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgreqstartf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./greqstartf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wisthrmainf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./isthrmainf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wquery_threadf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./query_threadf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wstatgetclf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./statgetclf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wstatsetelf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./statsetelf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypenewkeyf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typenewkeyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypedelattrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typedelattrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_dupf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_dupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypefreekeyf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typefreekeyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_get_attrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_get_attrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypegetcntsf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typegetcntsf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypegetenvf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typegetenvf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypegnamef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typegnamef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypesetattrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typesetattrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypesetnamef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typesetnamef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtype_match_sizef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./type_match_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwincallerrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./wincallerrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwinnewkeyf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./winnewkeyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwindelattrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./windelattrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwinfreekeyf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./winfreekeyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_get_attrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_get_attrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_get_namef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_get_namef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_set_attrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_set_attrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwin_set_namef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./win_set_namef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _walloc_memf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./alloc_memf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommcreerrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commcreerrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommgeterrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commgeterrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wcommseterrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./commseterrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfilecreerrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./filecreerrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfilegeterrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./filegeterrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfileseterrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./fileseterrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfinalizedf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./finalizedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfree_memf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./free_memf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _winfo_createf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./info_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _winfo_deletef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./info_deletef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _winfo_dupf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./info_dupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _winfo_freef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./info_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _winfo_getf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./info_getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _winfognkf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./infognkf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _winfognthkf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./infognthkf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _winfovallenf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./infovallenf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _winfo_setf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./info_setf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wpack_externalf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./pack_externalf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wpackesizef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./packesizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wreqgetstatf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./reqgetstatf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypedarrayf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typedarrayf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypechindf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typechindf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypechvecf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typechvecf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypecindbf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typecindbf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypecresizef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typecresizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypecstructf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typecstructf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypecsubarrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typecsubarrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypegetextentf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typegetextentf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wtypegtextf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./typegtextf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wunpackextf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./unpackextf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwincreerrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./wincreerrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwingeterrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./wingeterrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwinseterrf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./winseterrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wreduce_localf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./reduce_localf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wop_commutativef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./op_commutativef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wreduce_scatter_blockf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./reduce_scatter_blockf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wdist_graph_create_adjacentf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./dist_graph_create_adjacentf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wdist_graph_createf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./dist_graph_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wdist_graph_neighbors_countf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./dist_graph_neighbors_countf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wdist_graph_neighborsf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./dist_graph_neighborsf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_openf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_openf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_closef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_closef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_deletef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_deletef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_set_sizef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_set_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_preallocatef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_preallocatef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_get_sizef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_get_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_get_groupf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_get_groupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_get_amodef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_get_amodef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_set_infof.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_set_infof.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_get_infof.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_get_infof.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_set_viewf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_set_viewf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_get_viewf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_get_viewf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_read_atf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_read_atf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_read_at_allf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_read_at_allf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_write_atf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_write_atf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_write_at_allf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_write_at_allf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_iread_atf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_iread_atf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_iwrite_atf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_iwrite_atf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_readf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_readf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_read_allf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_read_allf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_writef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_writef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_write_allf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_write_allf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_ireadf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_ireadf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_iwritef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_iwritef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_seekf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_seekf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_get_positionf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_get_positionf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_get_byte_offsetf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_get_byte_offsetf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_read_sharedf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_read_sharedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_write_sharedf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_write_sharedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_iread_sharedf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_iread_sharedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_iwrite_sharedf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_iwrite_sharedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_read_orderedf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_read_orderedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_write_orderedf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_write_orderedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_seek_sharedf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_seek_sharedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_get_position_sharedf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_get_position_sharedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_read_at_all_beginf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_read_at_all_beginf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_read_at_all_endf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_read_at_all_endf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_write_at_all_beginf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_write_at_all_beginf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_write_at_all_endf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_write_at_all_endf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_read_all_beginf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_read_all_beginf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_read_all_endf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_read_all_endf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_write_all_beginf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_write_all_beginf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_write_all_endf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_write_all_endf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_read_ordered_beginf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_read_ordered_beginf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_read_ordered_endf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_read_ordered_endf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_write_ordered_beginf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_write_ordered_beginf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_write_ordered_endf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_write_ordered_endf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_get_type_extentf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_get_type_extentf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wregister_datarepf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./register_datarepf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_set_atomicityf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_set_atomicityf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_get_atomicityf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_get_atomicityf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wfile_syncf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./file_syncf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _winitf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./initf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _winitthreadf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./initthreadf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wpcontrolf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./pcontrolf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _waddressf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./addressf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wgetaddressf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./getaddressf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwtimef.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./wtimef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wwtickf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./wtickf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wkeyval_createf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./keyval_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wdup_fnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./dup_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wnull_del_fnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./null_del_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wnull_copy_fnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./null_copy_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wdup_comm_fnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./dup_comm_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wnull_comm_del_fnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./null_comm_del_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wnull_comm_copy_fnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./null_comm_copy_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wdup_win_fnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./dup_win_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wnull_win_del_fnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./null_win_del_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wnull_win_copy_fnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./null_win_copy_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wdup_type_fnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./dup_type_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wnull_type_del_fnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./null_type_del_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wnull_type_copy_fnf.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./null_type_copy_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wstatusf2c.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./statusf2c.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77  -O2  -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -o _wstatusc2f.o -c -DMPICH_MPI_FROM_PMPI -DUSE_ONLY_MPI_NAMES ./statusc2f.c
ar cr ../../../lib/libfmpich.a _wsendf.o _wrecvf.o _wget_countf.o _wbsendf.o _wssendf.o _wrsendf.o _wbufattachf.o _wbufdetachf.o _wisendf.o _wibsendf.o _wissendf.o _wirsendf.o _wirecvf.o _wwaitf.o _wtestf.o _wrequest_freef.o _wwaitanyf.o _wtestanyf.o _wwaitallf.o _wtestallf.o _wwaitsomef.o _wtestsomef.o _wiprobef.o _wprobef.o _wcancelf.o _wtestcancelf.o _wsend_initf.o _wbsend_initf.o _wssend_initf.o _wrsend_initf.o _wrecv_initf.o _wstartf.o _wstartallf.o _wsendrecvf.o _wsndrcvrplf.o _wtypecontigf.o _wtype_vectorf.o _wtype_hvectorf.o _wtype_indexedf.o _wtype_hindexedf.o _wtype_structf.o _wtype_extentf.o _wtype_sizef.o _wtype_lbf.o _wtype_ubf.o _wtype_commitf.o _wtype_freef.o _wget_elementsf.o _wpackf.o _wunpackf.o _wpack_sizef.o _wbarrierf.o _wbcastf.o _wgatherf.o _wgathervf.o _wscatterf.o _wscattervf.o _wallgatherf.o _wallgathervf.o _walltoallf.o _walltoallvf.o _wreducef.o _wop_createf.o _wop_freef.o _wallreducef.o _wredscatf.o _wscanf.o _wgroup_sizef.o _wgroup_rankf.o _wgrouptranksf.o _wgroup_comparef.o _wcomm_groupf.o _wgroup_unionf.o _wgroupinterf.o _wgroupdifff.o _wgroup_inclf.o _wgroup_exclf.o _wgrouprinclf.o _wgrouprexclf.o _wgroup_freef.o _wcomm_sizef.o _wcomm_rankf.o _wcomm_comparef.o _wcomm_dupf.o _wcomm_createf.o _wcomm_splitf.o _wcomm_freef.o _wcommtesticf.o _wcommrsizef.o _wcommrgroupf.o _wiccreatef.o _wicmergef.o _wkeyval_freef.o _wattr_putf.o _wattr_getf.o _wattr_deletef.o _wtopo_testf.o _wcart_createf.o _wdims_createf.o _wgraph_createf.o _wgraphdims_getf.o _wgraph_getf.o _wcartdim_getf.o _wcart_getf.o _wcart_rankf.o _wcart_coordsf.o _wgrfnbcountf.o _wgrfnbrsf.o _wcart_shiftf.o _wcart_subf.o _wcart_mapf.o _wgraph_mapf.o _wgetpnamef.o _wget_versionf.o _werrhcreatef.o _werrhsetf.o _werrhgetf.o _werrhfreef.o _werror_stringf.o _werror_classf.o _wfinalizef.o _winitializedf.o _wabortf.o _wclose_portf.o _wcomm_acceptf.o _wcomm_connectf.o _wcommdiscf.o _wcommparentf.o _wcomm_joinf.o _wcomm_spawnf.o _wspawnmultf.o _wlookup_namef.o _wopen_portf.o _wpublish_namef.o _wunpubnamef.o _waccumulatef.o _wgetf.o _wputf.o _wwin_completef.o _wwin_createf.o _wwin_fencef.o _wwin_freef.o _wwin_get_groupf.o _wwin_lockf.o _wwin_postf.o _wwin_startf.o _wwin_testf.o _wwin_unlockf.o _wwin_waitf.o _walltoallwf.o _wexscanf.o _wadderrclassf.o _wadderrcodef.o _wadderrstringf.o _wcommcallerrf.o _wcommnewkeyf.o _wcommdelattrf.o _wcommfreekeyf.o _wcomm_get_attrf.o _wcommgetnamf.o _wcomm_set_attrf.o _wcomm_set_namef.o _wfilecallerrf.o _wgreqcompletef.o _wgreqstartf.o _wisthrmainf.o _wquery_threadf.o _wstatgetclf.o _wstatsetelf.o _wtypenewkeyf.o _wtypedelattrf.o _wtype_dupf.o _wtypefreekeyf.o _wtype_get_attrf.o _wtypegetcntsf.o _wtypegetenvf.o _wtypegnamef.o _wtypesetattrf.o _wtypesetnamef.o _wtype_match_sizef.o _wwincallerrf.o _wwinnewkeyf.o _wwindelattrf.o _wwinfreekeyf.o _wwin_get_attrf.o _wwin_get_namef.o _wwin_set_attrf.o _wwin_set_namef.o _walloc_memf.o _wcommcreerrf.o _wcommgeterrf.o _wcommseterrf.o _wfilecreerrf.o _wfilegeterrf.o _wfileseterrf.o _wfinalizedf.o _wfree_memf.o _winfo_createf.o _winfo_deletef.o _winfo_dupf.o _winfo_freef.o _winfo_getf.o _winfognkf.o _winfognthkf.o _winfovallenf.o _winfo_setf.o _wpack_externalf.o _wpackesizef.o _wreqgetstatf.o _wtypedarrayf.o _wtypechindf.o _wtypechvecf.o _wtypecindbf.o _wtypecresizef.o _wtypecstructf.o _wtypecsubarrf.o _wtypegetextentf.o _wtypegtextf.o _wunpackextf.o _wwincreerrf.o _wwingeterrf.o _wwinseterrf.o _wreduce_localf.o _wop_commutativef.o _wreduce_scatter_blockf.o _wdist_graph_create_adjacentf.o _wdist_graph_createf.o _wdist_graph_neighbors_countf.o _wdist_graph_neighborsf.o _wfile_openf.o _wfile_closef.o _wfile_deletef.o _wfile_set_sizef.o _wfile_preallocatef.o _wfile_get_sizef.o _wfile_get_groupf.o _wfile_get_amodef.o _wfile_set_infof.o _wfile_get_infof.o _wfile_set_viewf.o _wfile_get_viewf.o _wfile_read_atf.o _wfile_read_at_allf.o _wfile_write_atf.o _wfile_write_at_allf.o _wfile_iread_atf.o _wfile_iwrite_atf.o _wfile_readf.o _wfile_read_allf.o _wfile_writef.o _wfile_write_allf.o _wfile_ireadf.o _wfile_iwritef.o _wfile_seekf.o _wfile_get_positionf.o _wfile_get_byte_offsetf.o _wfile_read_sharedf.o _wfile_write_sharedf.o _wfile_iread_sharedf.o _wfile_iwrite_sharedf.o _wfile_read_orderedf.o _wfile_write_orderedf.o _wfile_seek_sharedf.o _wfile_get_position_sharedf.o _wfile_read_at_all_beginf.o _wfile_read_at_all_endf.o _wfile_write_at_all_beginf.o _wfile_write_at_all_endf.o _wfile_read_all_beginf.o _wfile_read_all_endf.o _wfile_write_all_beginf.o _wfile_write_all_endf.o _wfile_read_ordered_beginf.o _wfile_read_ordered_endf.o _wfile_write_ordered_beginf.o _wfile_write_ordered_endf.o _wfile_get_type_extentf.o _wregister_datarepf.o _wfile_set_atomicityf.o _wfile_get_atomicityf.o _wfile_syncf.o _winitf.o _winitthreadf.o _wpcontrolf.o _waddressf.o _wgetaddressf.o _wwtimef.o _wwtickf.o _wkeyval_createf.o _wdup_fnf.o _wnull_del_fnf.o _wnull_copy_fnf.o _wdup_comm_fnf.o _wnull_comm_del_fnf.o _wnull_comm_copy_fnf.o _wdup_win_fnf.o _wnull_win_del_fnf.o _wnull_win_copy_fnf.o _wdup_type_fnf.o _wnull_type_del_fnf.o _wnull_type_copy_fnf.o _wstatusf2c.o _wstatusc2f.o
ranlib ../../../lib/libfmpich.a
date > .libstamp0
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c sendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c recvf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_countf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c bsendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ssendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c rsendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c bufattachf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c bufdetachf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c isendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ibsendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c issendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c irsendf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c irecvf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c waitf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c testf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c request_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c waitanyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c testanyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c waitallf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c testallf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c waitsomef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c testsomef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c iprobef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c probef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cancelf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c testcancelf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c send_initf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c bsend_initf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c ssend_initf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c rsend_initf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c recv_initf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c startf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c startallf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c sendrecvf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c sndrcvrplf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typecontigf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_vectorf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_hvectorf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_indexedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_hindexedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_structf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_extentf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_lbf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_ubf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_commitf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_elementsf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c packf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c unpackf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c pack_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c barrierf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c bcastf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c gatherf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c gathervf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c scatterf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c scattervf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c allgatherf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c allgathervf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c alltoallf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c alltoallvf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c reducef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c op_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c op_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c allreducef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c redscatf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c scanf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_rankf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c grouptranksf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_comparef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_groupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_unionf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c groupinterf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c groupdifff.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_inclf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_exclf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c grouprinclf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c grouprexclf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c group_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_rankf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_comparef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_dupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_splitf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commtesticf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commrsizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commrgroupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c iccreatef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c icmergef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c keyval_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c attr_putf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c attr_getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c attr_deletef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c topo_testf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dims_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c graph_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c graphdims_getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c graph_getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cartdim_getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_rankf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_coordsf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c grfnbcountf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c grfnbrsf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_shiftf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_subf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c cart_mapf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c graph_mapf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c getpnamef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c get_versionf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c errhcreatef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c errhsetf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c errhgetf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c errhfreef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c error_stringf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c error_classf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c finalizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c initializedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c abortf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c close_portf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_acceptf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_connectf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commdiscf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commparentf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_joinf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_spawnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c spawnmultf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c lookup_namef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c open_portf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c publish_namef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c unpubnamef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c accumulatef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c putf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_completef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_fencef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_get_groupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_lockf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_postf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_startf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_testf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_unlockf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_waitf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c alltoallwf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c exscanf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c adderrclassf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c adderrcodef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c adderrstringf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commcallerrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commnewkeyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commdelattrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commfreekeyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_get_attrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commgetnamf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_set_attrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c comm_set_namef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c filecallerrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c greqcompletef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c greqstartf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c isthrmainf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c query_threadf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c statgetclf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c statsetelf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typenewkeyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typedelattrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_dupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typefreekeyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_get_attrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typegetcntsf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typegetenvf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typegnamef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typesetattrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typesetnamef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c type_match_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c wincallerrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c winnewkeyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c windelattrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c winfreekeyf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_get_attrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_get_namef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_set_attrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c win_set_namef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c alloc_memf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commcreerrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commgeterrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c commseterrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c filecreerrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c filegeterrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c fileseterrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c finalizedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c free_memf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_deletef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_dupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_freef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_getf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c infognkf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c infognthkf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c infovallenf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c info_setf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c pack_externalf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c packesizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c reqgetstatf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typedarrayf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typechindf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typechvecf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typecindbf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typecresizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typecstructf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typecsubarrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typegetextentf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typegtextf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c unpackextf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c wincreerrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c wingeterrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c winseterrf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c reduce_localf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c op_commutativef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c reduce_scatter_blockf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dist_graph_create_adjacentf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dist_graph_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dist_graph_neighbors_countf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dist_graph_neighborsf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_openf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_closef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_deletef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_set_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_preallocatef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_get_sizef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_get_groupf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_get_amodef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_set_infof.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_get_infof.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_set_viewf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_get_viewf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_read_atf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_read_at_allf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_write_atf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_write_at_allf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_iread_atf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_iwrite_atf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_readf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_read_allf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_writef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_write_allf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_ireadf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_iwritef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_seekf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_get_positionf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_get_byte_offsetf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_read_sharedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_write_sharedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_iread_sharedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_iwrite_sharedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_read_orderedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_write_orderedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_seek_sharedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_get_position_sharedf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_read_at_all_beginf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_read_at_all_endf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_write_at_all_beginf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_write_at_all_endf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_read_all_beginf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_read_all_endf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_write_all_beginf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_write_all_endf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_read_ordered_beginf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_read_ordered_endf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_write_ordered_beginf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_write_ordered_endf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_get_type_extentf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c register_datarepf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_set_atomicityf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_get_atomicityf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c file_syncf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c initf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c initthreadf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c pcontrolf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c addressf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c getaddressf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c wtimef.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c wtickf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c keyval_createf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dup_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c null_del_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c null_copy_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dup_comm_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c null_comm_del_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c null_comm_copy_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dup_win_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c null_win_del_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c null_win_copy_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c dup_type_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c null_type_del_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c null_type_copy_fnf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c statusf2c.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c statusc2f.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -I/home/luca/mpich2-1.4.1p1/src/binding/f77 -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c setbot.c
gfortran -O2 -c setbotf.f
ar cr ../../../lib/libmpich.a sendf.o recvf.o get_countf.o bsendf.o ssendf.o rsendf.o bufattachf.o bufdetachf.o isendf.o ibsendf.o issendf.o irsendf.o irecvf.o waitf.o testf.o request_freef.o waitanyf.o testanyf.o waitallf.o testallf.o waitsomef.o testsomef.o iprobef.o probef.o cancelf.o testcancelf.o send_initf.o bsend_initf.o ssend_initf.o rsend_initf.o recv_initf.o startf.o startallf.o sendrecvf.o sndrcvrplf.o typecontigf.o type_vectorf.o type_hvectorf.o type_indexedf.o type_hindexedf.o type_structf.o type_extentf.o type_sizef.o type_lbf.o type_ubf.o type_commitf.o type_freef.o get_elementsf.o packf.o unpackf.o pack_sizef.o barrierf.o bcastf.o gatherf.o gathervf.o scatterf.o scattervf.o allgatherf.o allgathervf.o alltoallf.o alltoallvf.o reducef.o op_createf.o op_freef.o allreducef.o redscatf.o scanf.o group_sizef.o group_rankf.o grouptranksf.o group_comparef.o comm_groupf.o group_unionf.o groupinterf.o groupdifff.o group_inclf.o group_exclf.o grouprinclf.o grouprexclf.o group_freef.o comm_sizef.o comm_rankf.o comm_comparef.o comm_dupf.o comm_createf.o comm_splitf.o comm_freef.o commtesticf.o commrsizef.o commrgroupf.o iccreatef.o icmergef.o keyval_freef.o attr_putf.o attr_getf.o attr_deletef.o topo_testf.o cart_createf.o dims_createf.o graph_createf.o graphdims_getf.o graph_getf.o cartdim_getf.o cart_getf.o cart_rankf.o cart_coordsf.o grfnbcountf.o grfnbrsf.o cart_shiftf.o cart_subf.o cart_mapf.o graph_mapf.o getpnamef.o get_versionf.o errhcreatef.o errhsetf.o errhgetf.o errhfreef.o error_stringf.o error_classf.o finalizef.o initializedf.o abortf.o close_portf.o comm_acceptf.o comm_connectf.o commdiscf.o commparentf.o comm_joinf.o comm_spawnf.o spawnmultf.o lookup_namef.o open_portf.o publish_namef.o unpubnamef.o accumulatef.o getf.o putf.o win_completef.o win_createf.o win_fencef.o win_freef.o win_get_groupf.o win_lockf.o win_postf.o win_startf.o win_testf.o win_unlockf.o win_waitf.o alltoallwf.o exscanf.o adderrclassf.o adderrcodef.o adderrstringf.o commcallerrf.o commnewkeyf.o commdelattrf.o commfreekeyf.o comm_get_attrf.o commgetnamf.o comm_set_attrf.o comm_set_namef.o filecallerrf.o greqcompletef.o greqstartf.o isthrmainf.o query_threadf.o statgetclf.o statsetelf.o typenewkeyf.o typedelattrf.o type_dupf.o typefreekeyf.o type_get_attrf.o typegetcntsf.o typegetenvf.o typegnamef.o typesetattrf.o typesetnamef.o type_match_sizef.o wincallerrf.o winnewkeyf.o windelattrf.o winfreekeyf.o win_get_attrf.o win_get_namef.o win_set_attrf.o win_set_namef.o alloc_memf.o commcreerrf.o commgeterrf.o commseterrf.o filecreerrf.o filegeterrf.o fileseterrf.o finalizedf.o free_memf.o info_createf.o info_deletef.o info_dupf.o info_freef.o info_getf.o infognkf.o infognthkf.o infovallenf.o info_setf.o pack_externalf.o packesizef.o reqgetstatf.o typedarrayf.o typechindf.o typechvecf.o typecindbf.o typecresizef.o typecstructf.o typecsubarrf.o typegetextentf.o typegtextf.o unpackextf.o wincreerrf.o wingeterrf.o winseterrf.o reduce_localf.o op_commutativef.o reduce_scatter_blockf.o dist_graph_create_adjacentf.o dist_graph_createf.o dist_graph_neighbors_countf.o dist_graph_neighborsf.o file_openf.o file_closef.o file_deletef.o file_set_sizef.o file_preallocatef.o file_get_sizef.o file_get_groupf.o file_get_amodef.o file_set_infof.o file_get_infof.o file_set_viewf.o file_get_viewf.o file_read_atf.o file_read_at_allf.o file_write_atf.o file_write_at_allf.o file_iread_atf.o file_iwrite_atf.o file_readf.o file_read_allf.o file_writef.o file_write_allf.o file_ireadf.o file_iwritef.o file_seekf.o file_get_positionf.o file_get_byte_offsetf.o file_read_sharedf.o file_write_sharedf.o file_iread_sharedf.o file_iwrite_sharedf.o file_read_orderedf.o file_write_orderedf.o file_seek_sharedf.o file_get_position_sharedf.o file_read_at_all_beginf.o file_read_at_all_endf.o file_write_at_all_beginf.o file_write_at_all_endf.o file_read_all_beginf.o file_read_all_endf.o file_write_all_beginf.o file_write_all_endf.o file_read_ordered_beginf.o file_read_ordered_endf.o file_write_ordered_beginf.o file_write_ordered_endf.o file_get_type_extentf.o register_datarepf.o file_set_atomicityf.o file_get_atomicityf.o file_syncf.o initf.o initthreadf.o pcontrolf.o addressf.o getaddressf.o wtimef.o wtickf.o keyval_createf.o dup_fnf.o null_del_fnf.o null_copy_fnf.o dup_comm_fnf.o null_comm_del_fnf.o null_comm_copy_fnf.o dup_win_fnf.o null_win_del_fnf.o null_win_copy_fnf.o dup_type_fnf.o null_type_del_fnf.o null_type_copy_fnf.o statusf2c.o statusc2f.o setbot.o setbotf.o
ranlib ../../../lib/libmpich.a
date > .libstamp2
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/binding/f77'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/binding/f90'
f95 -O2 -I. -c ./mpi_constants.f90
f95 -O2 -I. -c mpi_sizeofs.f90
f95 -O2 -I. -c mpi_base.f90
f95 -O2 -I. -c ./mpi.f90
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c create_f90_int.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c create_f90_real.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c create_f90_complex.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typef90cmplxf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typef90realf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c typef90intf.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c create_f90_util.c
ar cr ../../../lib/libmpich.a create_f90_int.o create_f90_real.o create_f90_complex.o typef90cmplxf.o typef90realf.o typef90intf.o create_f90_util.o
date > .libstamp0
ar cr libmpichf90.a mpi.o mpi_constants.o mpi_sizeofs.o mpi_base.o
ranlib libmpichf90.a
make all-postamble
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/binding/f90'
if [ -s libmpichf90.a ] ; then \
	   cp -p libmpichf90.a ../../../lib ; fi
if [ -s libmpichf90.la ] ; then \
	   cp -p libmpichf90.la ../../../lib ; fi
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/binding/f90'
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/binding/f90'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/binding/cxx'
c++ -DHAVE_CONFIG_H -I. -I. -I../../include -I../../../src/include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c initcxx.cxx
ar cr ../../../lib/libmpichcxx.a initcxx.o
ranlib ../../../lib/libmpichcxx.a
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/binding/cxx'
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/binding'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/env'
gcc -DHAVE_CONFIG_H -I. -I. -I../include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c mpich2version.c
gcc -O2   -o mpich2version mpich2version.o  \
	../../lib/libmpich.a -lrt -lpthread
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/env'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/packaging'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/packaging/pkgconfig'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/packaging/pkgconfig'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/packaging/envmods'
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/packaging/envmods'
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/packaging'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpe2'
make --no-print-directory  build_lib_bin
**** Making src/misc ....
make --no-print-directory  mpe_debug_objs
make --no-print-directory  /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi.a
gcc -I.. -I../include -I../../.. -I../../../include -O2 -DMPI_LINUX  -DMPE_NOMPI -o mpehname.no -c mpehname.c
ar cr /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi.a mpehname.no
ranlib /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi.a
make --no-print-directory  /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe.a
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o decomp.po -c decomp.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o mpe_seq.po -c mpe_seq.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o dbxerr.po -c dbxerr.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o getgrank.po -c getgrank.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o examine.po -c examine.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o privtags.po -c privtags.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o mpehname.po -c mpehname.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o mpe_io.po -c mpe_io.c
ar cr /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe.a decomp.po mpe_seq.po dbxerr.po getgrank.po examine.po privtags.po mpehname.po mpe_io.po
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o decompf.po -c decompf.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o mpe_seqf.po -c mpe_seqf.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I../../.. -I../../../include -DMPI_LINUX  -o getgrankf.po -c getgrankf.c
ranlib /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe.a
**** Making src/callstack ....
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -o iterator.po -c iterator.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -o fancyprint.po -c fancyprint.c
gcc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include -O2  -o iterator.no -c iterator.c
gcc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include -O2  -o fancyprint.no -c fancyprint.c
ar cr /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi.a iterator.no fancyprint.no
ar cr /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe.a iterator.po fancyprint.po
make --no-print-directory  /home/luca/mpich2-1.4.1p1/src/mpe2/bin/check_callstack
gcc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include -O2  -o check_callstack.no -c check_callstack.c
cp -f check_callstack.no mpe2tmp.o
gcc -Wl,--export-dynamic -O2  -o /home/luca/mpich2-1.4.1p1/src/mpe2/bin/check_callstack mpe2tmp.o \
	                         -L/home/luca/mpich2-1.4.1p1/src/mpe2/lib -lmpe_nompi
**** Making src/logging ....
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpi_null.no -c mpi_null.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_util.no -c clog_util.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_timer.no -c clog_timer.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_uuid.no -c clog_uuid.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_commset.no -c clog_commset.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_preamble.no -c clog_preamble.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_record.no -c clog_record.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_sync.no -c clog_sync.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_block.no -c clog_block.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_buffer.no -c clog_buffer.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_merger.no -c clog_merger.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_cache.no -c clog_cache.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_joiner.no -c clog_joiner.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog.no -c clog.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log_thread.no -c mpe_log_thread.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log.no -c mpe_log.c
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log_null.no -c mpe_log_null.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o mpe_log_null.po -c mpe_log_null.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_util.po -c clog_util.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_timer.po -c clog_timer.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_uuid.po -c clog_uuid.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_commset.po -c clog_commset.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_preamble.po -c clog_preamble.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_record.po -c clog_record.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_sync.po -c clog_sync.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_block.po -c clog_block.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_buffer.po -c clog_buffer.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_merger.po -c clog_merger.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_cache.po -c clog_cache.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog_joiner.po -c clog_joiner.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o clog.po -c clog.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o mpe_log_thread.po -c mpe_log_thread.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o mpe_log.po -c mpe_log.c
ar cr /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi.a mpi_null.no clog_util.no clog_timer.no clog_uuid.no clog_commset.no clog_preamble.no clog_record.no clog_sync.no clog_block.no clog_buffer.no clog_merger.no clog_cache.no clog_joiner.no clog.no mpe_log_thread.no mpe_log.no
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_logf.no -c mpe_logf.c
make --no-print-directory  /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi_null.a
ar cr /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi_null.a mpi_null.no mpe_log_null.no
make[8]: `mpe_logf.no' is up to date.
ranlib /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_nompi_null.a
make --no-print-directory  /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_null.a
ar cr /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_null.a mpe_log_null.po
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include   -o mpe_logf.po -c mpe_logf.c
ranlib /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_null.a
ar cr /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe.a clog_util.po clog_timer.po clog_uuid.po clog_commset.po clog_preamble.po clog_record.po clog_sync.po clog_block.po clog_buffer.po clog_merger.po clog_cache.po clog_joiner.po clog.po mpe_log_thread.po mpe_log.po
make[8]: `mpe_logf.po' is up to date.
make --no-print-directory  /home/luca/mpich2-1.4.1p1/src/mpe2/bin/clog2_print /home/luca/mpich2-1.4.1p1/src/mpe2/bin/clog2_join /home/luca/mpich2-1.4.1p1/src/mpe2/bin/clog2_repair
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_print.no -c clog_print.c
cp -f clog_print.no mpe2tmp1.o
gcc  -O2  -o /home/luca/mpich2-1.4.1p1/src/mpe2/bin/clog2_print mpe2tmp1.o \
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_join.no -c clog_join.c
cp -f clog_join.no mpe2tmp2.o
gcc  -O2  -o /home/luca/mpich2-1.4.1p1/src/mpe2/bin/clog2_join mpe2tmp2.o \
gcc -I.. -I../../.. -I../include -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_repair.no -c clog_repair.c
cp -f clog_repair.no mpe2tmp3.o
gcc  -O2  -o /home/luca/mpich2-1.4.1p1/src/mpe2/bin/clog2_repair mpe2tmp3.o \
**** Making src/wrappers ....
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c log_mpi_util.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c log_mpi_core.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c trace_mpi_core.c
make --no-print-directory  /home/luca/mpich2-1.4.1p1/src/mpe2/lib/liblmpe.a
ar cr /home/luca/mpich2-1.4.1p1/src/mpe2/lib/liblmpe.a log_mpi_util.o log_mpi_core.o
ranlib /home/luca/mpich2-1.4.1p1/src/mpe2/lib/liblmpe.a
make --no-print-directory  /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libtmpe.a
ar cr /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libtmpe.a trace_mpi_core.o
ranlib /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libtmpe.a
/home/luca/mpich2-1.4.1p1/bin/mpif77   -c mpi_f2c_consts.f
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c mpe_proff.c
ar cr /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_f2cmpi.a mpi_f2c_consts.o log_mpi_util.o mpe_proff.o
ranlib /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_f2cmpi.a
make --no-print-directory  /home/luca/mpich2-1.4.1p1/src/mpe2/lib/mpe_prof.o
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c mpe_prof.c
make --no-print-directory  linktest_all
make --no-print-directory  linktest_C
make --no-print-directory  linktest_F77
**** Making src/collchk ....
make --no-print-directory  /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_collchk.a
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c begin.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c err_han.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c is_init.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c check_buff.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c check_dims.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c check_graph.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c check_size.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_amode.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_call.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_dtype.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_high_low.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_int.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_local_leader.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_op.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_root.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_tag.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_datarep.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c same_whence.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c allgather.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c allgatherv.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c allreduce.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c alltoall.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c alltoallv.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c barrier.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c bcast.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c cart_create.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c cart_map.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c gather.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c gatherv.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c graph_create.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c graph_map.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c init.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c intercomm_create.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c intercomm_merge.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c reduce.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c reduce_scatter.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c scan.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c scatter.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c scatterv.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c finalize.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c exscan.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c alltoallw.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_open.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_preallocate.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_all_begin.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_all.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_all_end.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_at_all_begin.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_at_all.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_at_all_end.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_ordered_begin.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_ordered.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_read_ordered_end.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_seek_shared.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_set_atomicity.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_set_size.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_set_view.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_all_begin.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_all.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_all_end.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_at_all_begin.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_at_all.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_at_all_end.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_ordered_begin.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_ordered.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c file_write_ordered_end.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c add_fh.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c get_fh.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c win_create.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c win_fence.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c add_win.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c get_win.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_accept.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_connect.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_create.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_disconnect.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_dup.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_spawn.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_spawn_multiple.c
/home/luca/mpich2-1.4.1p1/bin/mpicc -I.. -I../include -I/home/luca/mpich2-1.4.1p1/src/mpe2/include -I../../.. -I../../../include   -c comm_split.c
ar cr /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_collchk.a *.o
ranlib /home/luca/mpich2-1.4.1p1/src/mpe2/lib/libmpe_collchk.a
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpe2'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pmi'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pmi/simple'
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c simple_pmiutil.c
gcc -DHAVE_CONFIG_H -I. -I. -I../../include -I/home/luca/mpich2-1.4.1p1/src/include -O2 -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -c simple_pmi.c
ar cr ../../../lib/libmpich.a simple_pmiutil.o simple_pmi.o
date > .libstamp0
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pmi/simple'
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pmi'
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra'
Making all in ../../mpl
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpl'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpl'
Making all in tools/topo/plpa/plpa
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa'
Making all in src
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src'
Making all in libplpa
make[6]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/libplpa'
make  all-am
make[7]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/libplpa'
depbase=`echo plpa_api_probe.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
	/bin/bash ../../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.   -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers  -O2  -MT plpa_api_probe.lo -MD -MP -MF $depbase.Tpo -c -o plpa_api_probe.lo plpa_api_probe.c &&\
	mv -f $depbase.Tpo $depbase.Plo
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -MT plpa_api_probe.lo -MD -MP -MF .deps/plpa_api_probe.Tpo -c plpa_api_probe.c -o plpa_api_probe.o
depbase=`echo plpa_dispatch.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
	/bin/bash ../../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.   -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers  -O2  -MT plpa_dispatch.lo -MD -MP -MF $depbase.Tpo -c -o plpa_dispatch.lo plpa_dispatch.c &&\
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -MT plpa_dispatch.lo -MD -MP -MF .deps/plpa_dispatch.Tpo -c plpa_dispatch.c -o plpa_dispatch.o
depbase=`echo plpa_runtime.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
	/bin/bash ../../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.   -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers  -O2  -MT plpa_runtime.lo -MD -MP -MF $depbase.Tpo -c -o plpa_runtime.lo plpa_runtime.c &&\
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -MT plpa_runtime.lo -MD -MP -MF .deps/plpa_runtime.Tpo -c plpa_runtime.c -o plpa_runtime.o
depbase=`echo plpa_map.lo | sed 's|[^/]*$|.deps/&|;s|\.lo$||'`;\
	/bin/bash ../../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I.   -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers  -O2  -MT plpa_map.lo -MD -MP -MF $depbase.Tpo -c -o plpa_map.lo plpa_map.c &&\
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/mpl/include -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/openpa/src -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/include -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/datatype -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/common/locks -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -I/home/luca/mpich2-1.4.1p1/src/util/wrappers -O2 -MT plpa_map.lo -MD -MP -MF .deps/plpa_map.Tpo -c plpa_map.c -o plpa_map.o
/bin/bash ../../libtool --tag=CC   --mode=link gcc  -O2   -lnsl -o libplpa_included.la  plpa_api_probe.lo plpa_dispatch.lo plpa_runtime.lo plpa_map.lo  -lrt -lpthread
libtool: link: ar cr .libs/libplpa_included.a  plpa_api_probe.o plpa_dispatch.o plpa_runtime.o plpa_map.o
libtool: link: ranlib .libs/libplpa_included.a
libtool: link: ( cd ".libs" && rm -f "libplpa_included.la" && ln -s "../libplpa_included.la" "libplpa_included.la" )
make[7]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/libplpa'
make[6]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/libplpa'
Making all in plpa-info
make[6]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-info'
make[6]: Nothing to be done for `all'.
make[6]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-info'
Making all in plpa-taskset
make[6]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-taskset'
make[6]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src/plpa-taskset'
make[6]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src'
make[6]: Nothing to be done for `all-am'.
make[6]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src'
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa/src'
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa'
make[5]: Nothing to be done for `all-am'.
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa'
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/plpa/plpa'
Making all in tools/topo/hwloc/hwloc
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc'
Making all in src
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/src'
  CC     topology.lo
  CC     traversal.lo
  CC     distances.lo
  CC     topology-synthetic.lo
  CC     bind.lo
  CC     cpuset.lo
  CC     misc.lo
  CC     topology-linux.lo
topology-linux.c: In function ???hwloc_linux_get_tid_last_cpu_location???:
topology-linux.c:867:8: warning: ignoring return value of ???fgets???, declared with attribute warn_unused_result [-Wunused-result]
  CC     topology-x86.lo
  CCLD   libhwloc_embedded.la
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/src'
Making all in include
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[5]: Nothing to be done for `all'.
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc/include'
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc'
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc'
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra/tools/topo/hwloc/hwloc'
Making all in .
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra'
  CC     alloc.lo
  CC     args.lo
./utils/args/args.c: In function ???HYDU_get_abs_wd???:
./utils/args/args.c:233:10: warning: ignoring return value of ???chdir???, declared with attribute warn_unused_result [-Wunused-result]
./utils/args/args.c:235:10: warning: ignoring return value of ???chdir???, declared with attribute warn_unused_result [-Wunused-result]
  CC     dbg.lo
  CC     env.lo
  CC     launch.lo
  CC     others.lo
  CC     signals.lo
  CC     sock.lo
  CC     string.lo
  CC     topo.lo
  CC     topo_plpa.lo
  CC     topo_hwloc.lo
./tools/topo/hwloc/topo_hwloc.c: In function ???print_obj_info???:
./tools/topo/hwloc/topo_hwloc.c:33:9: warning: format ???%lu??? expects argument of type ???long unsigned int???, but argument 5 has type ???hwloc_uint64_t??? [-Wformat]
./tools/topo/hwloc/topo_hwloc.c:38:13: warning: format ???%lu??? expects argument of type ???long unsigned int???, but argument 5 has type ???hwloc_uint64_t??? [-Wformat]
./tools/topo/hwloc/topo_hwloc.c:38:13: warning: format ???%lu??? expects argument of type ???long unsigned int???, but argument 6 has type ???hwloc_uint64_t??? [-Wformat]
./tools/topo/hwloc/topo_hwloc.c: In function ???hwloc_to_hydra_cpuset_dup???:
./tools/topo/hwloc/topo_hwloc.c:56:9: warning: ???hwloc_cpuset_isset??? is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:49) [-Wdeprecated-declarations]
./tools/topo/hwloc/topo_hwloc.c: In function ???hydra_to_hwloc_cpuset_dup???:
./tools/topo/hwloc/topo_hwloc.c:70:5: warning: ???hwloc_cpuset_zero??? is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:36) [-Wdeprecated-declarations]
./tools/topo/hwloc/topo_hwloc.c:73:13: warning: ???hwloc_cpuset_set??? is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:44) [-Wdeprecated-declarations]
./tools/topo/hwloc/topo_hwloc.c: In function ???get_cache_nbobjs???:
./tools/topo/hwloc/topo_hwloc.c:86:5: warning: ???hwloc_cpuset_compare??? is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:65) [-Wdeprecated-declarations]
./tools/topo/hwloc/topo_hwloc.c: In function ???load_cache_objs???:
./tools/topo/hwloc/topo_hwloc.c:100:5: warning: ???hwloc_cpuset_compare??? is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:65) [-Wdeprecated-declarations]
./tools/topo/hwloc/topo_hwloc.c: In function ???HYDT_topo_hwloc_bind???:
./tools/topo/hwloc/topo_hwloc.c:329:5: warning: ???hwloc_cpuset_alloc??? is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:29) [-Wdeprecated-declarations]
./tools/topo/hwloc/topo_hwloc.c:337:5: warning: ???hwloc_cpuset_free??? is deprecated (declared at ./tools/topo/hwloc/hwloc/include/hwloc/cpuset.h:30) [-Wdeprecated-declarations]
  CC     bsci_init.lo
  CC     bsci_finalize.lo
  CC     bsci_launch.lo
  CC     bsci_query_node_list.lo
  CC     bsci_query_job_id.lo
  CC     bsci_query_proxy_id.lo
  CC     bsci_query_native_int.lo
  CC     bsci_wait.lo
  CC     bsci_env.lo
  CC     bscu_wait.lo
  CC     bscu_cb.lo
  CC     external_common.lo
  CC     external_common_launch.lo
  CC     fork_init.lo
  CC     user_init.lo
  CC     manual_init.lo
  CC     rsh_init.lo
  CC     rsh_env.lo
  CC     ssh_init.lo
  CC     ssh.lo
  CC     ssh_env.lo
  CC     ssh_finalize.lo
  CC     slurm_init.lo
  CC     slurm_launch.lo
  CC     slurm_env.lo
  CC     slurm_query_native_int.lo
  CC     slurm_query_node_list.lo
  CC     slurm_query_proxy_id.lo
  CC     slurm_query_jobid.lo
  CC     ll_init.lo
  CC     ll_launch.lo
  CC     ll_query_native_int.lo
  CC     ll_query_node_list.lo
  CC     ll_query_proxy_id.lo
  CC     ll_env.lo
  CC     lsf_init.lo
  CC     lsf_query_native_int.lo
  CC     lsf_query_node_list.lo
  CC     lsf_env.lo
  CC     sge_init.lo
  CC     sge_query_native_int.lo
  CC     sge_query_node_list.lo
  CC     sge_env.lo
  CC     pbs_init.lo
  CC     pbs_query_native_int.lo
  CC     pbs_query_node_list.lo
  CC     pbs_query_jobid.lo
  CC     persist_init.lo
  CC     persist_launch.lo
  CC     persist_wait.lo
  CC     ckpoint.lo
  CC     demux.lo
  CC     demux_poll.lo
  CC     demux_select.lo
  CC     debugger.lo
  CC     hydt_ftb_dummy.lo
  CC     uiu.lo
  CCLD   libhydra.la
  CC     pmiserv_pmi.lo
  CC     pmiserv_pmi_v1.lo
  CC     pmiserv_pmi_v2.lo
  CC     pmiserv_pmci.lo
  CC     pmiserv_cb.lo
  CC     pmiserv_utils.lo
  CC     common.lo
  CC     pmi_v2_common.lo
  CCLD   libpm.la
  CC     hydra_persist-persist_server.o
  CCLD   hydra_persist
  CC     hydra_nameserver-hydra_nameserver.o
  CCLD   hydra_nameserver
  CC     hydra_pmi_proxy-pmip.o
  CC     hydra_pmi_proxy-pmip_cb.o
  CC     hydra_pmi_proxy-pmip_utils.o
  CC     hydra_pmi_proxy-pmip_pmi_v1.o
  CC     hydra_pmi_proxy-pmip_pmi_v2.o
  CC     hydra_pmi_proxy-common.o
  CC     hydra_pmi_proxy-pmi_v2_common.o
  CCLD   hydra_pmi_proxy
  CC     mpiexec.o
  CC     utils.o
  CCLD   mpiexec.hydra
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra'
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm/hydra'
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/pm'
make all-postamble
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/src'
for dir in mpl openpa ; do \
	    (cd $dir && make prefix=/home/luca/mpich2-1.4.1p1 exec_prefix=/home/luca/mpich2-1.4.1p1 \
	    bindir=/home/luca/mpich2-1.4.1p1/bin libdir=/home/luca/mpich2-1.4.1p1/lib \
	    includedir=/home/luca/mpich2-1.4.1p1/include docdir=/home/luca/mpich2-1.4.1p1/share/doc install) ; \
	done
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/mpl'
test -z "/home/luca/mpich2-1.4.1p1/lib" || /bin/mkdir -p "/home/luca/mpich2-1.4.1p1/lib"
 /bin/bash ./libtool   --mode=install /usr/bin/install -c   libmpl.la '/home/luca/mpich2-1.4.1p1/lib'
libtool: install: /usr/bin/install -c .libs/libmpl.lai /home/luca/mpich2-1.4.1p1/lib/libmpl.la
libtool: install: /usr/bin/install -c .libs/libmpl.a /home/luca/mpich2-1.4.1p1/lib/libmpl.a
libtool: install: chmod 644 /home/luca/mpich2-1.4.1p1/lib/libmpl.a
libtool: install: ranlib /home/luca/mpich2-1.4.1p1/lib/libmpl.a
libtool: install: warning: remember to run `libtool --finish /home/luca/mpich2-install/lib'
make[4]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/mpl'
make[3]: Entering directory `/home/luca/mpich2-1.4.1p1/src/openpa'
Making install in src
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/openpa/src'
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/openpa/src'
 /bin/bash ../libtool   --mode=install /usr/bin/install -c   libopa.la '/home/luca/mpich2-1.4.1p1/lib'
libtool: install: /usr/bin/install -c .libs/libopa.lai /home/luca/mpich2-1.4.1p1/lib/libopa.la
libtool: install: /usr/bin/install -c .libs/libopa.a /home/luca/mpich2-1.4.1p1/lib/libopa.a
libtool: install: chmod 644 /home/luca/mpich2-1.4.1p1/lib/libopa.a
libtool: install: ranlib /home/luca/mpich2-1.4.1p1/lib/libopa.a
test -z "/home/luca/mpich2-1.4.1p1/include" || /bin/mkdir -p "/home/luca/mpich2-1.4.1p1/include"
 /usr/bin/install -c -m 644 opa_config.h opa_primitives.h opa_queue.h opa_util.h '/home/luca/mpich2-1.4.1p1/include'
/bin/mkdir -p '/home/luca/mpich2-1.4.1p1/include/primitives'
 /usr/bin/install -c -m 644  primitives/opa_by_lock.h primitives/opa_emulated.h primitives/opa_gcc_ia64.h primitives/opa_gcc_intel_32_64.h primitives/opa_gcc_intel_32_64_barrier.h primitives/opa_gcc_intel_32_64_ops.h primitives/opa_gcc_intel_32_64_p3.h primitives/opa_gcc_intel_32_64_p3barrier.h primitives/opa_gcc_intrinsics.h primitives/opa_gcc_ppc.h primitives/opa_gcc_sicortex.h primitives/opa_nt_intrinsics.h primitives/opa_sun_atomic_ops.h primitives/opa_unsafe.h '/home/luca/mpich2-1.4.1p1/include/primitives'
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/openpa/src'
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/openpa/src'
Making install in test
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/openpa/test'
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/openpa/test'
make[5]: Nothing to be done for `install-exec-am'.
make[5]: Nothing to be done for `install-data-am'.
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/openpa/test'
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/openpa/test'
make[4]: Entering directory `/home/luca/mpich2-1.4.1p1/src/openpa'
make[5]: Entering directory `/home/luca/mpich2-1.4.1p1/src/openpa'
test -z "/home/luca/mpich2-1.4.1p1/share/doc" || /bin/mkdir -p "/home/luca/mpich2-1.4.1p1/share/doc"
 /usr/bin/install -c -m 644 README '/home/luca/mpich2-1.4.1p1/share/doc'
test -z "/home/luca/mpich2-1.4.1p1/lib/pkgconfig" || /bin/mkdir -p "/home/luca/mpich2-1.4.1p1/lib/pkgconfig"
 /usr/bin/install -c -m 644 openpa.pc '/home/luca/mpich2-1.4.1p1/lib/pkgconfig'
make[5]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/openpa'
make[4]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/openpa'
make[3]: Leaving directory `/home/luca/mpich2-1.4.1p1/src/openpa'
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/src'
make[1]: Leaving directory `/home/luca/mpich2-1.4.1p1/src'
make all-postamble
make[1]: Entering directory `/home/luca/mpich2-1.4.1p1'
( cd examples && make )
make[2]: Entering directory `/home/luca/mpich2-1.4.1p1/examples'
../bin/mpicc -I../src/include -I../src/include -c cpi.c
../bin/mpicc   -o cpi cpi.o  -lm
make[2]: Leaving directory `/home/luca/mpich2-1.4.1p1/examples'
Make completed
make[1]: Leaving directory `/home/luca/mpich2-1.4.1p1'
