[mpich-discuss] some problems about using g95 installing mpich2
謝奇哲 991546107 at stu.nkmu.edu.tw
Thu Jul 26 04:29:12 CDT 2012
I'm sorry if I'm asking too many times.
I'm a new user about MPICH2, and using WindosXP, Cygwin and g95.
Then I install MPICH2-1.4 on two computers.
When I configure, I use option --with-pm=smpd, and I completed install.
I can use smpd, and run teh examples cpi.
But I'm in mpich2-1.4/test file make testing, I get different problems on
two computers.
1)
Looking in ./spawn/testlist
Unexpected output in taskmaster: Fatal error in MPI_Init: Invalid port,
error stack:
Unexpected output in taskmaster: MPIR_Init_thread(388).............:
Unexpected output in taskmaster: MPID_Init(264)....................:
spawned process group was unable to connect back to the parent on port
<tag=0 description=user001 port=2634 ifname=10.1.10.108 >
Unexpected output in taskmaster: MPID_Comm_connect(191)............:
Unexpected output in taskmaster: MPIDI_Comm_connect(546)...........: Named
port tag=0 description=user001 port=2634 ifname=10.1.10.108  does not exist
Unexpected output in taskmaster: MPIDI_Comm_connect(401)...........:
Unexpected output in taskmaster: MPIC_Sendrecv(192)................:
Unexpected output in taskmaster: MPIC_Wait(540)....................:
Unexpected output in taskmaster: MPIDI_CH3I_Progress(402)..........:
Unexpected output in taskmaster: MPID_nem_mpich2_blocking_recv(905):
Unexpected output in taskmaster: MPID_nem_tcp_connpoll(1838).......:
Unexpected output in taskmaster: state_c_tmpvcsent_handler(1264)...:
Failure during connection protocol
Unexpected output in taskmaster: recv_cmd_pkt(739).................: read
from socket failed - Connection reset by peer
Unexpected output in taskmaster: job aborted:
Unexpected output in taskmaster: rank: node: exit code[: error message]
Unexpected output in taskmaster: 0: user001: 1: process 0 exited without
calling finalize
Unexpected output in taskmaster: mpiexec terminated job due to 600 second
timeout.
Program taskmaster exited without No Errors
Unexpected output in disconnect_reconnect: Fatal error in MPI_Comm_connect:
Invalid port, error stack:
Unexpected output in disconnect_reconnect: MPI_Comm_connect(127)..:
MPI_Comm_connect(port="", MPI_INFO_NULL, root=0, MPI_COMM_WORLD,
newcomm=0x22ac48) failed
Unexpected output in disconnect_reconnect: MPID_Comm_connect(191).:
Unexpected output in disconnect_reconnect: MPIDI_Comm_connect(412): Named
port  does not exist
MPI_Comm_connect(127).............: MPI_Comm_connect(port="tag=0
description=user001 port=3378 ifname=10.1.10.108 ", MPI_INFO_NULL, root=0,
MPI_COMM_WORLD, newcomm=0x22ac48) failed
MPIDI_Comm_connect(546)...........: Named port tag=0 description=user001
port=3378 ifname=10.1.10.108  does not exist
state_c_tmpvcsent_handler(1264)...: Failure during connection protocol
recv_cmd_pkt(739).................: read from socket failed - Connection
reset by peer
port  does not exist
Unexpected output in disconnect_reconnect: job aborted:
Unexpected output in disconnect_reconnect: rank: node: exit code[: error
message]
Unexpected output in disconnect_reconnect: 0: user001: 1: process 0 exited
without calling finalize
Unexpected output in disconnect_reconnect: 1: user001: 1: process 1 exited
Unexpected output in disconnect_reconnect: 2: user001: 1: process 2 exited
Unexpected output in disconnect_reconnect: mpiexec terminated job due to
180 second timeout.
Program disconnect_reconnect exited without No Errors
2)
Looking in ./attr/testlist
Unexpected output in attric: Fatal error in MPI_Init_thread: Other MPI
error, error stack:
Unexpected output in attric: MPIR_Init_thread(388).................:
Unexpected output in attric: MPID_Init(139)........................:
channel initialization failed
Unexpected output in attric: MPIDI_CH3_Init(38)....................:
Unexpected output in attric: MPID_nem_init(196)....................:
Unexpected output in attric: MPIDI_CH3I_Seg_commit(366)............:
Unexpected output in attric: MPIU_SHMW_Hnd_deserialize(324)........:
Unexpected output in attric: MPIU_SHMW_Seg_open(863)...............:
Unexpected output in attric: MPIU_SHMW_Seg_create_attach_templ(637): open
failed - Device or resource busy
error, error stack:
Unexpected output in attric: MPIDI_CH3I_Seg_commit(369)............:
Unexpected output in attric: MPIU_SHMW_Seg_attach(925).............:
failed - No such file or directory
Unexpected output in attric: op_read error on left context: Error = -1
Unexpected output in attric: unable to read the cmd header on the left
context, Error = -1
Unexpected output in attric: .
Unexpected output in attric: mpiexec terminated job due to 180 second
timeout.
Program attric exited without No Errors
The two computer are the same computer hardware. And I use the same method
installing.
Can anyone give me some advices to solve the problem?
Best regards,
Chi-Che Hsieh
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120726/d9d385ed/attachment-0001.html>
