[mpich-discuss] Problem with MPI_File_write_all in Fortran90?
Angel de Vicente
angelv at iac.es
Tue Jul 24 05:16:09 CDT 2012
Rajeev Thakur <thakur at mcs.anl.gov> writes:
> Even in C, the file size should be 40K for a 100*100 integer array, not 118K. 9.8T is generous.
I guess if the system says that "restart is required" after installing a
bunch of new libraries, perhaps it is really required :-) After
restarting, the Fortran code (simplified code, which I attach) behaves
as expected, but now it is the C version that is giving me funny
results.
angelv$$ mpicc -o parallel_i_oc parallel_i_o.c
angelv$$ mpif90 -o parallel_i_of parallel_i_o.f90
angelv$$ rm datafile_c
angelv$$ rm datafile_f
angelv$$ mpiexec -n 4 ./parallel_i_oc
angelv$$ mpiexec -n 4 ./parallel_i_of
angelv$$ od -i datafile_c
0000000 2001 2002 102001 102002
0000020 -2038304232 32707 -1525747176 32711
0000040 202001 202002 302001 302002
0000060 -892304872 32686 -13377000 32668
0000100
angelv$$ od -i datafile_f
0000000 1001 2001 201001 202001
0000020 1002 2002 201002 202002
0000040 101001 102001 301001 302001
0000060 101002 102002 301002 302002
0000100
angelv$$
Do you see any problem with the C code?
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120724/757a7f7f/attachment.c>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120724/757a7f7f/attachment.obj>
?ngel de Vicente
http://www.iac.es/galeria/angelv/
ADVERTENCIA: Sobre la privacidad y cumplimiento de la Ley de Protecci?e Datos, acceda a http://www.iac.es/disclaimer.php
WARNING: For more information on privacy and fulfilment of the Law concerning the Protection of Data, consult http://www.iac.es/disclaimer.php?lang=en
