[mpich-discuss] About using g95 to install MPICH2
謝奇哲 991546107 at stu.nkmu.edu.tw
Mon Jul 23 01:41:17 CDT 2012
Dear MPICH2 developers,
I'm a new user about MPICH2, and using WindosXP, Cygwin and g95.
I used some tools, it will call mpi_init, . So I installed MPICH2-1.4 on my
computers.
And I Used the command
DNAO-7 at DNAO-7-PC /cygdrive/c/cygwin/mpich2-1.4
$./configure F77=g95 FC=g95 --with-pm=smpd 2>&1 | tee c.txt
$make 2>&1 | tee m.txt
$make install 2>&1 | tee mi.txt
$export MPICH2_HOME=/cygdrive/c/cygwin/mpich2-1.4
$export PATH=/cygdrive/c/cygwin/usr/local/bin:$PATH
$export LD_LIBRARY_PATH=/cygdrive/c/cygwin/usr/local/lib:$LD_LIBRARY_PATH
$cd $HOME
DNAO-7 at DNAO-7-PC /cygdrive/c/cygwin/home/
$cd DNAO-7
DNAO-7 at DNAO-7-PC /cygdrive/c/cygwin/home/DNAO-7
$touch .smpd.conf
$echo 「secretword=abcdef」 > .smpd.conf
$chmod 600 .smpd.conf
I could use smpd run the example cpi, but when I used some tools, it didn't
work. Because it didn't find the mpi_init file.
Can anyone give me some advices to solve the problem?
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120723/fcc2221d/attachment-0001.html>
if [ ! -d /usr/local ] ; then mkdir -p /usr/local ; fi
if [ ! -d /usr/local/share ] ; then mkdir -p /usr/local/share ; fi
if [ ! -d /usr/local/share/doc/ ] ; then mkdir -p /usr/local/share/doc/ ; fi
if [ ! -d /usr/local/share/man ] ; then mkdir -p /usr/local/share/man ; fi
if [ ! -d /usr/local/include ] ; then mkdir -p /usr/local/include ; fi
if [ ! -d /usr/local/lib ] ; then mkdir -p /usr/local/lib ; fi
make install-local
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4'
if [ "no" = "yes" ] ; then \
    /usr/bin/install -c -m 644 src/mpi/debugger/libtvmpich2.dll \
		/usr/local/lib/libtvmpich2.dll ; fi
if [ -n "" ] ; then \
    for pm in  /dev/null ; do \
	if [ -d src/pm/$pm ] ; then \
	     (cd src/pm/$pm && \
	make prefix=/usr/local bindir=/usr/local/bin install-alt ) ; \
	fi ; \
    done ; \
fi
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4'
/usr/bin/install -c -m 644  src/include/mpi.h /usr/local/include/mpi.h
/usr/bin/install -c -m 644  ./src/include/mpix.h /usr/local/include/mpix.h
/usr/bin/install -c -m 644  lib/libmpich.a /usr/local/lib/libmpich.a
/usr/bin/install -c -m 644 index.htm /usr/local/share/doc//index.htm
/usr/bin/install -c -m 644 index.htm /usr/local/share/doc//www1/index.htm
/usr/bin/install -c -m 644 MPI.html /usr/local/share/doc//www1/MPI.html
/usr/bin/install -c -m 644 mpicc.html /usr/local/share/doc//www1/mpicc.html
/usr/bin/install -c -m 644 mpicxx.html /usr/local/share/doc//www1/mpicxx.html
/usr/bin/install -c -m 644 mpiexec.html /usr/local/share/doc//www1/mpiexec.html
/usr/bin/install -c -m 644 mpif77.html /usr/local/share/doc//www1/mpif77.html
/usr/bin/install -c -m 644 mpif90.html /usr/local/share/doc//www1/mpif90.html
/usr/bin/install -c -m 644 index.htm /usr/local/share/doc//www3/index.htm
/usr/bin/install -c -m 644 MPI_Abort.html /usr/local/share/doc//www3/MPI_Abort.html
/usr/bin/install -c -m 644 MPI_Accumulate.html /usr/local/share/doc//www3/MPI_Accumulate.html
/usr/bin/install -c -m 644 MPI_Add_error_class.html /usr/local/share/doc//www3/MPI_Add_error_class.html
/usr/bin/install -c -m 644 MPI_Add_error_code.html /usr/local/share/doc//www3/MPI_Add_error_code.html
/usr/bin/install -c -m 644 MPI_Add_error_string.html /usr/local/share/doc//www3/MPI_Add_error_string.html
/usr/bin/install -c -m 644 MPI_Address.html /usr/local/share/doc//www3/MPI_Address.html
/usr/bin/install -c -m 644 MPI_Allgather.html /usr/local/share/doc//www3/MPI_Allgather.html
/usr/bin/install -c -m 644 MPI_Allgatherv.html /usr/local/share/doc//www3/MPI_Allgatherv.html
/usr/bin/install -c -m 644 MPI_Alloc_mem.html /usr/local/share/doc//www3/MPI_Alloc_mem.html
/usr/bin/install -c -m 644 MPI_Allreduce.html /usr/local/share/doc//www3/MPI_Allreduce.html
/usr/bin/install -c -m 644 MPI_Alltoall.html /usr/local/share/doc//www3/MPI_Alltoall.html
/usr/bin/install -c -m 644 MPI_Alltoallv.html /usr/local/share/doc//www3/MPI_Alltoallv.html
/usr/bin/install -c -m 644 MPI_Alltoallw.html /usr/local/share/doc//www3/MPI_Alltoallw.html
/usr/bin/install -c -m 644 MPI_Attr_delete.html /usr/local/share/doc//www3/MPI_Attr_delete.html
/usr/bin/install -c -m 644 MPI_Attr_get.html /usr/local/share/doc//www3/MPI_Attr_get.html
/usr/bin/install -c -m 644 MPI_Attr_put.html /usr/local/share/doc//www3/MPI_Attr_put.html
/usr/bin/install -c -m 644 MPI_Barrier.html /usr/local/share/doc//www3/MPI_Barrier.html
/usr/bin/install -c -m 644 MPI_Bcast.html /usr/local/share/doc//www3/MPI_Bcast.html
/usr/bin/install -c -m 644 MPI_Bsend.html /usr/local/share/doc//www3/MPI_Bsend.html
/usr/bin/install -c -m 644 MPI_Bsend_init.html /usr/local/share/doc//www3/MPI_Bsend_init.html
/usr/bin/install -c -m 644 MPI_Buffer_attach.html /usr/local/share/doc//www3/MPI_Buffer_attach.html
/usr/bin/install -c -m 644 MPI_Buffer_detach.html /usr/local/share/doc//www3/MPI_Buffer_detach.html
/usr/bin/install -c -m 644 MPI_Cancel.html /usr/local/share/doc//www3/MPI_Cancel.html
/usr/bin/install -c -m 644 MPI_Cart_coords.html /usr/local/share/doc//www3/MPI_Cart_coords.html
/usr/bin/install -c -m 644 MPI_Cart_create.html /usr/local/share/doc//www3/MPI_Cart_create.html
/usr/bin/install -c -m 644 MPI_Cart_get.html /usr/local/share/doc//www3/MPI_Cart_get.html
/usr/bin/install -c -m 644 MPI_Cart_map.html /usr/local/share/doc//www3/MPI_Cart_map.html
/usr/bin/install -c -m 644 MPI_Cart_rank.html /usr/local/share/doc//www3/MPI_Cart_rank.html
/usr/bin/install -c -m 644 MPI_Cart_shift.html /usr/local/share/doc//www3/MPI_Cart_shift.html
/usr/bin/install -c -m 644 MPI_Cart_sub.html /usr/local/share/doc//www3/MPI_Cart_sub.html
/usr/bin/install -c -m 644 MPI_Cartdim_get.html /usr/local/share/doc//www3/MPI_Cartdim_get.html
/usr/bin/install -c -m 644 MPI_Close_port.html /usr/local/share/doc//www3/MPI_Close_port.html
/usr/bin/install -c -m 644 MPI_Comm_accept.html /usr/local/share/doc//www3/MPI_Comm_accept.html
/usr/bin/install -c -m 644 MPI_Comm_call_errhandler.html /usr/local/share/doc//www3/MPI_Comm_call_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_compare.html /usr/local/share/doc//www3/MPI_Comm_compare.html
/usr/bin/install -c -m 644 MPI_Comm_connect.html /usr/local/share/doc//www3/MPI_Comm_connect.html
/usr/bin/install -c -m 644 MPI_Comm_create.html /usr/local/share/doc//www3/MPI_Comm_create.html
/usr/bin/install -c -m 644 MPI_Comm_create_errhandler.html /usr/local/share/doc//www3/MPI_Comm_create_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_create_keyval.html /usr/local/share/doc//www3/MPI_Comm_create_keyval.html
/usr/bin/install -c -m 644 MPI_Comm_delete_attr.html /usr/local/share/doc//www3/MPI_Comm_delete_attr.html
/usr/bin/install -c -m 644 MPI_Comm_disconnect.html /usr/local/share/doc//www3/MPI_Comm_disconnect.html
/usr/bin/install -c -m 644 MPI_Comm_dup.html /usr/local/share/doc//www3/MPI_Comm_dup.html
/usr/bin/install -c -m 644 MPI_Comm_free.html /usr/local/share/doc//www3/MPI_Comm_free.html
/usr/bin/install -c -m 644 MPI_Comm_free_keyval.html /usr/local/share/doc//www3/MPI_Comm_free_keyval.html
/usr/bin/install -c -m 644 MPI_Comm_get_attr.html /usr/local/share/doc//www3/MPI_Comm_get_attr.html
/usr/bin/install -c -m 644 MPI_Comm_get_errhandler.html /usr/local/share/doc//www3/MPI_Comm_get_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_get_name.html /usr/local/share/doc//www3/MPI_Comm_get_name.html
/usr/bin/install -c -m 644 MPI_Comm_get_parent.html /usr/local/share/doc//www3/MPI_Comm_get_parent.html
/usr/bin/install -c -m 644 MPI_Comm_group.html /usr/local/share/doc//www3/MPI_Comm_group.html
/usr/bin/install -c -m 644 MPI_Comm_join.html /usr/local/share/doc//www3/MPI_Comm_join.html
/usr/bin/install -c -m 644 MPI_Comm_rank.html /usr/local/share/doc//www3/MPI_Comm_rank.html
/usr/bin/install -c -m 644 MPI_Comm_remote_group.html /usr/local/share/doc//www3/MPI_Comm_remote_group.html
/usr/bin/install -c -m 644 MPI_Comm_remote_size.html /usr/local/share/doc//www3/MPI_Comm_remote_size.html
/usr/bin/install -c -m 644 MPI_Comm_set_attr.html /usr/local/share/doc//www3/MPI_Comm_set_attr.html
/usr/bin/install -c -m 644 MPI_Comm_set_errhandler.html /usr/local/share/doc//www3/MPI_Comm_set_errhandler.html
/usr/bin/install -c -m 644 MPI_Comm_set_name.html /usr/local/share/doc//www3/MPI_Comm_set_name.html
/usr/bin/install -c -m 644 MPI_Comm_size.html /usr/local/share/doc//www3/MPI_Comm_size.html
/usr/bin/install -c -m 644 MPI_Comm_spawn.html /usr/local/share/doc//www3/MPI_Comm_spawn.html
/usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.html /usr/local/share/doc//www3/MPI_Comm_spawn_multiple.html
/usr/bin/install -c -m 644 MPI_Comm_split.html /usr/local/share/doc//www3/MPI_Comm_split.html
/usr/bin/install -c -m 644 MPI_Comm_test_inter.html /usr/local/share/doc//www3/MPI_Comm_test_inter.html
/usr/bin/install -c -m 644 MPI_Dims_create.html /usr/local/share/doc//www3/MPI_Dims_create.html
/usr/bin/install -c -m 644 MPI_Dist_graph_create.html /usr/local/share/doc//www3/MPI_Dist_graph_create.html
/usr/bin/install -c -m 644 MPI_Dist_graph_create_adjacent.html /usr/local/share/doc//www3/MPI_Dist_graph_create_adjacent.html
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors.html /usr/local/share/doc//www3/MPI_Dist_graph_neighbors.html
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors_count.html /usr/local/share/doc//www3/MPI_Dist_graph_neighbors_count.html
/usr/bin/install -c -m 644 MPI_Errhandler_create.html /usr/local/share/doc//www3/MPI_Errhandler_create.html
/usr/bin/install -c -m 644 MPI_Errhandler_free.html /usr/local/share/doc//www3/MPI_Errhandler_free.html
/usr/bin/install -c -m 644 MPI_Errhandler_get.html /usr/local/share/doc//www3/MPI_Errhandler_get.html
/usr/bin/install -c -m 644 MPI_Errhandler_set.html /usr/local/share/doc//www3/MPI_Errhandler_set.html
/usr/bin/install -c -m 644 MPI_Error_class.html /usr/local/share/doc//www3/MPI_Error_class.html
/usr/bin/install -c -m 644 MPI_Error_string.html /usr/local/share/doc//www3/MPI_Error_string.html
/usr/bin/install -c -m 644 MPI_Exscan.html /usr/local/share/doc//www3/MPI_Exscan.html
/usr/bin/install -c -m 644 MPI_File_c2f.html /usr/local/share/doc//www3/MPI_File_c2f.html
/usr/bin/install -c -m 644 MPI_File_call_errhandler.html /usr/local/share/doc//www3/MPI_File_call_errhandler.html
/usr/bin/install -c -m 644 MPI_File_close.html /usr/local/share/doc//www3/MPI_File_close.html
/usr/bin/install -c -m 644 MPI_File_create_errhandler.html /usr/local/share/doc//www3/MPI_File_create_errhandler.html
/usr/bin/install -c -m 644 MPI_File_delete.html /usr/local/share/doc//www3/MPI_File_delete.html
/usr/bin/install -c -m 644 MPI_File_f2c.html /usr/local/share/doc//www3/MPI_File_f2c.html
/usr/bin/install -c -m 644 MPI_File_get_amode.html /usr/local/share/doc//www3/MPI_File_get_amode.html
/usr/bin/install -c -m 644 MPI_File_get_atomicity.html /usr/local/share/doc//www3/MPI_File_get_atomicity.html
/usr/bin/install -c -m 644 MPI_File_get_byte_offset.html /usr/local/share/doc//www3/MPI_File_get_byte_offset.html
/usr/bin/install -c -m 644 MPI_File_get_errhandler.html /usr/local/share/doc//www3/MPI_File_get_errhandler.html
/usr/bin/install -c -m 644 MPI_File_get_group.html /usr/local/share/doc//www3/MPI_File_get_group.html
/usr/bin/install -c -m 644 MPI_File_get_info.html /usr/local/share/doc//www3/MPI_File_get_info.html
/usr/bin/install -c -m 644 MPI_File_get_position.html /usr/local/share/doc//www3/MPI_File_get_position.html
/usr/bin/install -c -m 644 MPI_File_get_position_shared.html /usr/local/share/doc//www3/MPI_File_get_position_shared.html
/usr/bin/install -c -m 644 MPI_File_get_size.html /usr/local/share/doc//www3/MPI_File_get_size.html
/usr/bin/install -c -m 644 MPI_File_get_type_extent.html /usr/local/share/doc//www3/MPI_File_get_type_extent.html
/usr/bin/install -c -m 644 MPI_File_get_view.html /usr/local/share/doc//www3/MPI_File_get_view.html
/usr/bin/install -c -m 644 MPI_File_iread.html /usr/local/share/doc//www3/MPI_File_iread.html
/usr/bin/install -c -m 644 MPI_File_iread_at.html /usr/local/share/doc//www3/MPI_File_iread_at.html
/usr/bin/install -c -m 644 MPI_File_iread_shared.html /usr/local/share/doc//www3/MPI_File_iread_shared.html
/usr/bin/install -c -m 644 MPI_File_iwrite.html /usr/local/share/doc//www3/MPI_File_iwrite.html
/usr/bin/install -c -m 644 MPI_File_iwrite_at.html /usr/local/share/doc//www3/MPI_File_iwrite_at.html
/usr/bin/install -c -m 644 MPI_File_iwrite_shared.html /usr/local/share/doc//www3/MPI_File_iwrite_shared.html
/usr/bin/install -c -m 644 MPI_File_open.html /usr/local/share/doc//www3/MPI_File_open.html
/usr/bin/install -c -m 644 MPI_File_preallocate.html /usr/local/share/doc//www3/MPI_File_preallocate.html
/usr/bin/install -c -m 644 MPI_File_read.html /usr/local/share/doc//www3/MPI_File_read.html
/usr/bin/install -c -m 644 MPI_File_read_all.html /usr/local/share/doc//www3/MPI_File_read_all.html
/usr/bin/install -c -m 644 MPI_File_read_all_begin.html /usr/local/share/doc//www3/MPI_File_read_all_begin.html
/usr/bin/install -c -m 644 MPI_File_read_all_end.html /usr/local/share/doc//www3/MPI_File_read_all_end.html
/usr/bin/install -c -m 644 MPI_File_read_at.html /usr/local/share/doc//www3/MPI_File_read_at.html
/usr/bin/install -c -m 644 MPI_File_read_at_all.html /usr/local/share/doc//www3/MPI_File_read_at_all.html
/usr/bin/install -c -m 644 MPI_File_read_at_all_begin.html /usr/local/share/doc//www3/MPI_File_read_at_all_begin.html
/usr/bin/install -c -m 644 MPI_File_read_at_all_end.html /usr/local/share/doc//www3/MPI_File_read_at_all_end.html
/usr/bin/install -c -m 644 MPI_File_read_ordered.html /usr/local/share/doc//www3/MPI_File_read_ordered.html
/usr/bin/install -c -m 644 MPI_File_read_ordered_begin.html /usr/local/share/doc//www3/MPI_File_read_ordered_begin.html
/usr/bin/install -c -m 644 MPI_File_read_ordered_end.html /usr/local/share/doc//www3/MPI_File_read_ordered_end.html
/usr/bin/install -c -m 644 MPI_File_read_shared.html /usr/local/share/doc//www3/MPI_File_read_shared.html
/usr/bin/install -c -m 644 MPI_File_seek.html /usr/local/share/doc//www3/MPI_File_seek.html
/usr/bin/install -c -m 644 MPI_File_seek_shared.html /usr/local/share/doc//www3/MPI_File_seek_shared.html
/usr/bin/install -c -m 644 MPI_File_set_atomicity.html /usr/local/share/doc//www3/MPI_File_set_atomicity.html
/usr/bin/install -c -m 644 MPI_File_set_errhandler.html /usr/local/share/doc//www3/MPI_File_set_errhandler.html
/usr/bin/install -c -m 644 MPI_File_set_info.html /usr/local/share/doc//www3/MPI_File_set_info.html
/usr/bin/install -c -m 644 MPI_File_set_size.html /usr/local/share/doc//www3/MPI_File_set_size.html
/usr/bin/install -c -m 644 MPI_File_set_view.html /usr/local/share/doc//www3/MPI_File_set_view.html
/usr/bin/install -c -m 644 MPI_File_sync.html /usr/local/share/doc//www3/MPI_File_sync.html
/usr/bin/install -c -m 644 MPI_File_write.html /usr/local/share/doc//www3/MPI_File_write.html
/usr/bin/install -c -m 644 MPI_File_write_all.html /usr/local/share/doc//www3/MPI_File_write_all.html
/usr/bin/install -c -m 644 MPI_File_write_all_begin.html /usr/local/share/doc//www3/MPI_File_write_all_begin.html
/usr/bin/install -c -m 644 MPI_File_write_all_end.html /usr/local/share/doc//www3/MPI_File_write_all_end.html
/usr/bin/install -c -m 644 MPI_File_write_at.html /usr/local/share/doc//www3/MPI_File_write_at.html
/usr/bin/install -c -m 644 MPI_File_write_at_all.html /usr/local/share/doc//www3/MPI_File_write_at_all.html
/usr/bin/install -c -m 644 MPI_File_write_at_all_begin.html /usr/local/share/doc//www3/MPI_File_write_at_all_begin.html
/usr/bin/install -c -m 644 MPI_File_write_at_all_end.html /usr/local/share/doc//www3/MPI_File_write_at_all_end.html
/usr/bin/install -c -m 644 MPI_File_write_ordered.html /usr/local/share/doc//www3/MPI_File_write_ordered.html
/usr/bin/install -c -m 644 MPI_File_write_ordered_begin.html /usr/local/share/doc//www3/MPI_File_write_ordered_begin.html
/usr/bin/install -c -m 644 MPI_File_write_ordered_end.html /usr/local/share/doc//www3/MPI_File_write_ordered_end.html
/usr/bin/install -c -m 644 MPI_File_write_shared.html /usr/local/share/doc//www3/MPI_File_write_shared.html
/usr/bin/install -c -m 644 MPI_Finalize.html /usr/local/share/doc//www3/MPI_Finalize.html
/usr/bin/install -c -m 644 MPI_Finalized.html /usr/local/share/doc//www3/MPI_Finalized.html
/usr/bin/install -c -m 644 MPI_Free_mem.html /usr/local/share/doc//www3/MPI_Free_mem.html
/usr/bin/install -c -m 644 MPI_Gather.html /usr/local/share/doc//www3/MPI_Gather.html
/usr/bin/install -c -m 644 MPI_Gatherv.html /usr/local/share/doc//www3/MPI_Gatherv.html
/usr/bin/install -c -m 644 MPI_Get.html /usr/local/share/doc//www3/MPI_Get.html
/usr/bin/install -c -m 644 MPI_Get_address.html /usr/local/share/doc//www3/MPI_Get_address.html
/usr/bin/install -c -m 644 MPI_Get_count.html /usr/local/share/doc//www3/MPI_Get_count.html
/usr/bin/install -c -m 644 MPI_Get_elements.html /usr/local/share/doc//www3/MPI_Get_elements.html
/usr/bin/install -c -m 644 MPI_Get_processor_name.html /usr/local/share/doc//www3/MPI_Get_processor_name.html
/usr/bin/install -c -m 644 MPI_Get_version.html /usr/local/share/doc//www3/MPI_Get_version.html
/usr/bin/install -c -m 644 MPI_Graph_create.html /usr/local/share/doc//www3/MPI_Graph_create.html
/usr/bin/install -c -m 644 MPI_Graph_get.html /usr/local/share/doc//www3/MPI_Graph_get.html
/usr/bin/install -c -m 644 MPI_Graph_map.html /usr/local/share/doc//www3/MPI_Graph_map.html
/usr/bin/install -c -m 644 MPI_Graph_neighbors.html /usr/local/share/doc//www3/MPI_Graph_neighbors.html
/usr/bin/install -c -m 644 MPI_Graph_neighbors_count.html /usr/local/share/doc//www3/MPI_Graph_neighbors_count.html
/usr/bin/install -c -m 644 MPI_Graphdims_get.html /usr/local/share/doc//www3/MPI_Graphdims_get.html
/usr/bin/install -c -m 644 MPI_Grequest_complete.html /usr/local/share/doc//www3/MPI_Grequest_complete.html
/usr/bin/install -c -m 644 MPI_Grequest_start.html /usr/local/share/doc//www3/MPI_Grequest_start.html
/usr/bin/install -c -m 644 MPI_Group_compare.html /usr/local/share/doc//www3/MPI_Group_compare.html
/usr/bin/install -c -m 644 MPI_Group_difference.html /usr/local/share/doc//www3/MPI_Group_difference.html
/usr/bin/install -c -m 644 MPI_Group_excl.html /usr/local/share/doc//www3/MPI_Group_excl.html
/usr/bin/install -c -m 644 MPI_Group_free.html /usr/local/share/doc//www3/MPI_Group_free.html
/usr/bin/install -c -m 644 MPI_Group_incl.html /usr/local/share/doc//www3/MPI_Group_incl.html
/usr/bin/install -c -m 644 MPI_Group_intersection.html /usr/local/share/doc//www3/MPI_Group_intersection.html
/usr/bin/install -c -m 644 MPI_Group_range_excl.html /usr/local/share/doc//www3/MPI_Group_range_excl.html
/usr/bin/install -c -m 644 MPI_Group_range_incl.html /usr/local/share/doc//www3/MPI_Group_range_incl.html
/usr/bin/install -c -m 644 MPI_Group_rank.html /usr/local/share/doc//www3/MPI_Group_rank.html
/usr/bin/install -c -m 644 MPI_Group_size.html /usr/local/share/doc//www3/MPI_Group_size.html
/usr/bin/install -c -m 644 MPI_Group_translate_ranks.html /usr/local/share/doc//www3/MPI_Group_translate_ranks.html
/usr/bin/install -c -m 644 MPI_Group_union.html /usr/local/share/doc//www3/MPI_Group_union.html
/usr/bin/install -c -m 644 MPI_Ibsend.html /usr/local/share/doc//www3/MPI_Ibsend.html
/usr/bin/install -c -m 644 MPI_Info_create.html /usr/local/share/doc//www3/MPI_Info_create.html
/usr/bin/install -c -m 644 MPI_Info_delete.html /usr/local/share/doc//www3/MPI_Info_delete.html
/usr/bin/install -c -m 644 MPI_Info_dup.html /usr/local/share/doc//www3/MPI_Info_dup.html
/usr/bin/install -c -m 644 MPI_Info_free.html /usr/local/share/doc//www3/MPI_Info_free.html
/usr/bin/install -c -m 644 MPI_Info_get.html /usr/local/share/doc//www3/MPI_Info_get.html
/usr/bin/install -c -m 644 MPI_Info_get_nkeys.html /usr/local/share/doc//www3/MPI_Info_get_nkeys.html
/usr/bin/install -c -m 644 MPI_Info_get_nthkey.html /usr/local/share/doc//www3/MPI_Info_get_nthkey.html
/usr/bin/install -c -m 644 MPI_Info_get_valuelen.html /usr/local/share/doc//www3/MPI_Info_get_valuelen.html
/usr/bin/install -c -m 644 MPI_Info_set.html /usr/local/share/doc//www3/MPI_Info_set.html
/usr/bin/install -c -m 644 MPI_Init.html /usr/local/share/doc//www3/MPI_Init.html
/usr/bin/install -c -m 644 MPI_Init_thread.html /usr/local/share/doc//www3/MPI_Init_thread.html
/usr/bin/install -c -m 644 MPI_Initialized.html /usr/local/share/doc//www3/MPI_Initialized.html
/usr/bin/install -c -m 644 MPI_Intercomm_create.html /usr/local/share/doc//www3/MPI_Intercomm_create.html
/usr/bin/install -c -m 644 MPI_Intercomm_merge.html /usr/local/share/doc//www3/MPI_Intercomm_merge.html
/usr/bin/install -c -m 644 MPI_Iprobe.html /usr/local/share/doc//www3/MPI_Iprobe.html
/usr/bin/install -c -m 644 MPI_Irecv.html /usr/local/share/doc//www3/MPI_Irecv.html
/usr/bin/install -c -m 644 MPI_Irsend.html /usr/local/share/doc//www3/MPI_Irsend.html
/usr/bin/install -c -m 644 MPI_Is_thread_main.html /usr/local/share/doc//www3/MPI_Is_thread_main.html
/usr/bin/install -c -m 644 MPI_Isend.html /usr/local/share/doc//www3/MPI_Isend.html
/usr/bin/install -c -m 644 MPI_Issend.html /usr/local/share/doc//www3/MPI_Issend.html
/usr/bin/install -c -m 644 MPI_Keyval_create.html /usr/local/share/doc//www3/MPI_Keyval_create.html
/usr/bin/install -c -m 644 MPI_Keyval_free.html /usr/local/share/doc//www3/MPI_Keyval_free.html
/usr/bin/install -c -m 644 MPI_Lookup_name.html /usr/local/share/doc//www3/MPI_Lookup_name.html
/usr/bin/install -c -m 644 MPI_Op_commute.html /usr/local/share/doc//www3/MPI_Op_commute.html
/usr/bin/install -c -m 644 MPI_Op_create.html /usr/local/share/doc//www3/MPI_Op_create.html
/usr/bin/install -c -m 644 MPI_Op_free.html /usr/local/share/doc//www3/MPI_Op_free.html
/usr/bin/install -c -m 644 MPI_Open_port.html /usr/local/share/doc//www3/MPI_Open_port.html
/usr/bin/install -c -m 644 MPI_Pack.html /usr/local/share/doc//www3/MPI_Pack.html
/usr/bin/install -c -m 644 MPI_Pack_external.html /usr/local/share/doc//www3/MPI_Pack_external.html
/usr/bin/install -c -m 644 MPI_Pack_external_size.html /usr/local/share/doc//www3/MPI_Pack_external_size.html
/usr/bin/install -c -m 644 MPI_Pack_size.html /usr/local/share/doc//www3/MPI_Pack_size.html
/usr/bin/install -c -m 644 MPI_Pcontrol.html /usr/local/share/doc//www3/MPI_Pcontrol.html
/usr/bin/install -c -m 644 MPI_Probe.html /usr/local/share/doc//www3/MPI_Probe.html
/usr/bin/install -c -m 644 MPI_Publish_name.html /usr/local/share/doc//www3/MPI_Publish_name.html
/usr/bin/install -c -m 644 MPI_Put.html /usr/local/share/doc//www3/MPI_Put.html
/usr/bin/install -c -m 644 MPI_Query_thread.html /usr/local/share/doc//www3/MPI_Query_thread.html
/usr/bin/install -c -m 644 MPI_Recv.html /usr/local/share/doc//www3/MPI_Recv.html
/usr/bin/install -c -m 644 MPI_Recv_init.html /usr/local/share/doc//www3/MPI_Recv_init.html
/usr/bin/install -c -m 644 MPI_Reduce.html /usr/local/share/doc//www3/MPI_Reduce.html
/usr/bin/install -c -m 644 MPI_Reduce_local.html /usr/local/share/doc//www3/MPI_Reduce_local.html
/usr/bin/install -c -m 644 MPI_Reduce_scatter.html /usr/local/share/doc//www3/MPI_Reduce_scatter.html
/usr/bin/install -c -m 644 MPI_Reduce_scatter_block.html /usr/local/share/doc//www3/MPI_Reduce_scatter_block.html
/usr/bin/install -c -m 644 MPI_Register_datarep.html /usr/local/share/doc//www3/MPI_Register_datarep.html
/usr/bin/install -c -m 644 MPI_Request_free.html /usr/local/share/doc//www3/MPI_Request_free.html
/usr/bin/install -c -m 644 MPI_Request_get_status.html /usr/local/share/doc//www3/MPI_Request_get_status.html
/usr/bin/install -c -m 644 MPI_Rsend.html /usr/local/share/doc//www3/MPI_Rsend.html
/usr/bin/install -c -m 644 MPI_Rsend_init.html /usr/local/share/doc//www3/MPI_Rsend_init.html
/usr/bin/install -c -m 644 MPI_Scan.html /usr/local/share/doc//www3/MPI_Scan.html
/usr/bin/install -c -m 644 MPI_Scatter.html /usr/local/share/doc//www3/MPI_Scatter.html
/usr/bin/install -c -m 644 MPI_Scatterv.html /usr/local/share/doc//www3/MPI_Scatterv.html
/usr/bin/install -c -m 644 MPI_Send.html /usr/local/share/doc//www3/MPI_Send.html
/usr/bin/install -c -m 644 MPI_Send_init.html /usr/local/share/doc//www3/MPI_Send_init.html
/usr/bin/install -c -m 644 MPI_Sendrecv.html /usr/local/share/doc//www3/MPI_Sendrecv.html
/usr/bin/install -c -m 644 MPI_Sendrecv_replace.html /usr/local/share/doc//www3/MPI_Sendrecv_replace.html
/usr/bin/install -c -m 644 MPI_Ssend.html /usr/local/share/doc//www3/MPI_Ssend.html
/usr/bin/install -c -m 644 MPI_Ssend_init.html /usr/local/share/doc//www3/MPI_Ssend_init.html
/usr/bin/install -c -m 644 MPI_Start.html /usr/local/share/doc//www3/MPI_Start.html
/usr/bin/install -c -m 644 MPI_Startall.html /usr/local/share/doc//www3/MPI_Startall.html
/usr/bin/install -c -m 644 MPI_Status_set_cancelled.html /usr/local/share/doc//www3/MPI_Status_set_cancelled.html
/usr/bin/install -c -m 644 MPI_Status_set_elements.html /usr/local/share/doc//www3/MPI_Status_set_elements.html
/usr/bin/install -c -m 644 MPI_Test.html /usr/local/share/doc//www3/MPI_Test.html
/usr/bin/install -c -m 644 MPI_Test_cancelled.html /usr/local/share/doc//www3/MPI_Test_cancelled.html
/usr/bin/install -c -m 644 MPI_Testall.html /usr/local/share/doc//www3/MPI_Testall.html
/usr/bin/install -c -m 644 MPI_Testany.html /usr/local/share/doc//www3/MPI_Testany.html
/usr/bin/install -c -m 644 MPI_Testsome.html /usr/local/share/doc//www3/MPI_Testsome.html
/usr/bin/install -c -m 644 MPI_Topo_test.html /usr/local/share/doc//www3/MPI_Topo_test.html
/usr/bin/install -c -m 644 MPI_Type_commit.html /usr/local/share/doc//www3/MPI_Type_commit.html
/usr/bin/install -c -m 644 MPI_Type_contiguous.html /usr/local/share/doc//www3/MPI_Type_contiguous.html
/usr/bin/install -c -m 644 MPI_Type_create_darray.html /usr/local/share/doc//www3/MPI_Type_create_darray.html
/usr/bin/install -c -m 644 MPI_Type_create_hindexed.html /usr/local/share/doc//www3/MPI_Type_create_hindexed.html
/usr/bin/install -c -m 644 MPI_Type_create_hvector.html /usr/local/share/doc//www3/MPI_Type_create_hvector.html
/usr/bin/install -c -m 644 MPI_Type_create_indexed_block.html /usr/local/share/doc//www3/MPI_Type_create_indexed_block.html
/usr/bin/install -c -m 644 MPI_Type_create_keyval.html /usr/local/share/doc//www3/MPI_Type_create_keyval.html
/usr/bin/install -c -m 644 MPI_Type_create_resized.html /usr/local/share/doc//www3/MPI_Type_create_resized.html
/usr/bin/install -c -m 644 MPI_Type_create_struct.html /usr/local/share/doc//www3/MPI_Type_create_struct.html
/usr/bin/install -c -m 644 MPI_Type_create_subarray.html /usr/local/share/doc//www3/MPI_Type_create_subarray.html
/usr/bin/install -c -m 644 MPI_Type_delete_attr.html /usr/local/share/doc//www3/MPI_Type_delete_attr.html
/usr/bin/install -c -m 644 MPI_Type_dup.html /usr/local/share/doc//www3/MPI_Type_dup.html
/usr/bin/install -c -m 644 MPI_Type_extent.html /usr/local/share/doc//www3/MPI_Type_extent.html
/usr/bin/install -c -m 644 MPI_Type_free.html /usr/local/share/doc//www3/MPI_Type_free.html
/usr/bin/install -c -m 644 MPI_Type_free_keyval.html /usr/local/share/doc//www3/MPI_Type_free_keyval.html
/usr/bin/install -c -m 644 MPI_Type_get_attr.html /usr/local/share/doc//www3/MPI_Type_get_attr.html
/usr/bin/install -c -m 644 MPI_Type_get_contents.html /usr/local/share/doc//www3/MPI_Type_get_contents.html
/usr/bin/install -c -m 644 MPI_Type_get_envelope.html /usr/local/share/doc//www3/MPI_Type_get_envelope.html
/usr/bin/install -c -m 644 MPI_Type_get_extent.html /usr/local/share/doc//www3/MPI_Type_get_extent.html
/usr/bin/install -c -m 644 MPI_Type_get_name.html /usr/local/share/doc//www3/MPI_Type_get_name.html
/usr/bin/install -c -m 644 MPI_Type_get_true_extent.html /usr/local/share/doc//www3/MPI_Type_get_true_extent.html
/usr/bin/install -c -m 644 MPI_Type_hindexed.html /usr/local/share/doc//www3/MPI_Type_hindexed.html
/usr/bin/install -c -m 644 MPI_Type_hvector.html /usr/local/share/doc//www3/MPI_Type_hvector.html
/usr/bin/install -c -m 644 MPI_Type_indexed.html /usr/local/share/doc//www3/MPI_Type_indexed.html
/usr/bin/install -c -m 644 MPI_Type_lb.html /usr/local/share/doc//www3/MPI_Type_lb.html
/usr/bin/install -c -m 644 MPI_Type_match_size.html /usr/local/share/doc//www3/MPI_Type_match_size.html
/usr/bin/install -c -m 644 MPI_Type_set_attr.html /usr/local/share/doc//www3/MPI_Type_set_attr.html
/usr/bin/install -c -m 644 MPI_Type_set_name.html /usr/local/share/doc//www3/MPI_Type_set_name.html
/usr/bin/install -c -m 644 MPI_Type_size.html /usr/local/share/doc//www3/MPI_Type_size.html
/usr/bin/install -c -m 644 MPI_Type_struct.html /usr/local/share/doc//www3/MPI_Type_struct.html
/usr/bin/install -c -m 644 MPI_Type_ub.html /usr/local/share/doc//www3/MPI_Type_ub.html
/usr/bin/install -c -m 644 MPI_Type_vector.html /usr/local/share/doc//www3/MPI_Type_vector.html
/usr/bin/install -c -m 644 MPI_Unpack.html /usr/local/share/doc//www3/MPI_Unpack.html
/usr/bin/install -c -m 644 MPI_Unpack_external.html /usr/local/share/doc//www3/MPI_Unpack_external.html
/usr/bin/install -c -m 644 MPI_Unpublish_name.html /usr/local/share/doc//www3/MPI_Unpublish_name.html
/usr/bin/install -c -m 644 MPI_Wait.html /usr/local/share/doc//www3/MPI_Wait.html
/usr/bin/install -c -m 644 MPI_Waitall.html /usr/local/share/doc//www3/MPI_Waitall.html
/usr/bin/install -c -m 644 MPI_Waitany.html /usr/local/share/doc//www3/MPI_Waitany.html
/usr/bin/install -c -m 644 MPI_Waitsome.html /usr/local/share/doc//www3/MPI_Waitsome.html
/usr/bin/install -c -m 644 MPI_Win_call_errhandler.html /usr/local/share/doc//www3/MPI_Win_call_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_complete.html /usr/local/share/doc//www3/MPI_Win_complete.html
/usr/bin/install -c -m 644 MPI_Win_create.html /usr/local/share/doc//www3/MPI_Win_create.html
/usr/bin/install -c -m 644 MPI_Win_create_errhandler.html /usr/local/share/doc//www3/MPI_Win_create_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_create_keyval.html /usr/local/share/doc//www3/MPI_Win_create_keyval.html
/usr/bin/install -c -m 644 MPI_Win_delete_attr.html /usr/local/share/doc//www3/MPI_Win_delete_attr.html
/usr/bin/install -c -m 644 MPI_Win_fence.html /usr/local/share/doc//www3/MPI_Win_fence.html
/usr/bin/install -c -m 644 MPI_Win_free.html /usr/local/share/doc//www3/MPI_Win_free.html
/usr/bin/install -c -m 644 MPI_Win_free_keyval.html /usr/local/share/doc//www3/MPI_Win_free_keyval.html
/usr/bin/install -c -m 644 MPI_Win_get_attr.html /usr/local/share/doc//www3/MPI_Win_get_attr.html
/usr/bin/install -c -m 644 MPI_Win_get_errhandler.html /usr/local/share/doc//www3/MPI_Win_get_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_get_group.html /usr/local/share/doc//www3/MPI_Win_get_group.html
/usr/bin/install -c -m 644 MPI_Win_get_name.html /usr/local/share/doc//www3/MPI_Win_get_name.html
/usr/bin/install -c -m 644 MPI_Win_lock.html /usr/local/share/doc//www3/MPI_Win_lock.html
/usr/bin/install -c -m 644 MPI_Win_post.html /usr/local/share/doc//www3/MPI_Win_post.html
/usr/bin/install -c -m 644 MPI_Win_set_attr.html /usr/local/share/doc//www3/MPI_Win_set_attr.html
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.html /usr/local/share/doc//www3/MPI_Win_set_errhandler.html
/usr/bin/install -c -m 644 MPI_Win_set_name.html /usr/local/share/doc//www3/MPI_Win_set_name.html
/usr/bin/install -c -m 644 MPI_Win_start.html /usr/local/share/doc//www3/MPI_Win_start.html
/usr/bin/install -c -m 644 MPI_Win_test.html /usr/local/share/doc//www3/MPI_Win_test.html
/usr/bin/install -c -m 644 MPI_Win_unlock.html /usr/local/share/doc//www3/MPI_Win_unlock.html
/usr/bin/install -c -m 644 MPI_Win_wait.html /usr/local/share/doc//www3/MPI_Win_wait.html
/usr/bin/install -c -m 644 MPI_Wtick.html /usr/local/share/doc//www3/MPI_Wtick.html
/usr/bin/install -c -m 644 MPI_Wtime.html /usr/local/share/doc//www3/MPI_Wtime.html
/usr/bin/install -c -m 644 MPIX_Group_comm_create.html /usr/local/share/doc//www3/MPIX_Group_comm_create.html
/usr/bin/install -c -m 644 MPI.1 /usr/local/share/man/man1/MPI.1
/usr/bin/install -c -m 644 mpicc.1 /usr/local/share/man/man1/mpicc.1
/usr/bin/install -c -m 644 mpicxx.1 /usr/local/share/man/man1/mpicxx.1
/usr/bin/install -c -m 644 mpiexec.1 /usr/local/share/man/man1/mpiexec.1
/usr/bin/install -c -m 644 mpif77.1 /usr/local/share/man/man1/mpif77.1
/usr/bin/install -c -m 644 mpif90.1 /usr/local/share/man/man1/mpif90.1
/usr/bin/install -c -m 644 MPI_Abort.3 /usr/local/share/man/man3/MPI_Abort.3
/usr/bin/install -c -m 644 MPI_Accumulate.3 /usr/local/share/man/man3/MPI_Accumulate.3
/usr/bin/install -c -m 644 MPI_Add_error_class.3 /usr/local/share/man/man3/MPI_Add_error_class.3
/usr/bin/install -c -m 644 MPI_Add_error_code.3 /usr/local/share/man/man3/MPI_Add_error_code.3
/usr/bin/install -c -m 644 MPI_Add_error_string.3 /usr/local/share/man/man3/MPI_Add_error_string.3
/usr/bin/install -c -m 644 MPI_Address.3 /usr/local/share/man/man3/MPI_Address.3
/usr/bin/install -c -m 644 MPI_Allgather.3 /usr/local/share/man/man3/MPI_Allgather.3
/usr/bin/install -c -m 644 MPI_Allgatherv.3 /usr/local/share/man/man3/MPI_Allgatherv.3
/usr/bin/install -c -m 644 MPI_Alloc_mem.3 /usr/local/share/man/man3/MPI_Alloc_mem.3
/usr/bin/install -c -m 644 MPI_Allreduce.3 /usr/local/share/man/man3/MPI_Allreduce.3
/usr/bin/install -c -m 644 MPI_Alltoall.3 /usr/local/share/man/man3/MPI_Alltoall.3
/usr/bin/install -c -m 644 MPI_Alltoallv.3 /usr/local/share/man/man3/MPI_Alltoallv.3
/usr/bin/install -c -m 644 MPI_Alltoallw.3 /usr/local/share/man/man3/MPI_Alltoallw.3
/usr/bin/install -c -m 644 MPI_Attr_delete.3 /usr/local/share/man/man3/MPI_Attr_delete.3
/usr/bin/install -c -m 644 MPI_Attr_get.3 /usr/local/share/man/man3/MPI_Attr_get.3
/usr/bin/install -c -m 644 MPI_Attr_put.3 /usr/local/share/man/man3/MPI_Attr_put.3
/usr/bin/install -c -m 644 MPI_Barrier.3 /usr/local/share/man/man3/MPI_Barrier.3
/usr/bin/install -c -m 644 MPI_Bcast.3 /usr/local/share/man/man3/MPI_Bcast.3
/usr/bin/install -c -m 644 MPI_Bsend.3 /usr/local/share/man/man3/MPI_Bsend.3
/usr/bin/install -c -m 644 MPI_Bsend_init.3 /usr/local/share/man/man3/MPI_Bsend_init.3
/usr/bin/install -c -m 644 MPI_Buffer_attach.3 /usr/local/share/man/man3/MPI_Buffer_attach.3
/usr/bin/install -c -m 644 MPI_Buffer_detach.3 /usr/local/share/man/man3/MPI_Buffer_detach.3
/usr/bin/install -c -m 644 MPI_Cancel.3 /usr/local/share/man/man3/MPI_Cancel.3
/usr/bin/install -c -m 644 MPI_Cart_coords.3 /usr/local/share/man/man3/MPI_Cart_coords.3
/usr/bin/install -c -m 644 MPI_Cart_create.3 /usr/local/share/man/man3/MPI_Cart_create.3
/usr/bin/install -c -m 644 MPI_Cart_get.3 /usr/local/share/man/man3/MPI_Cart_get.3
/usr/bin/install -c -m 644 MPI_Cart_map.3 /usr/local/share/man/man3/MPI_Cart_map.3
/usr/bin/install -c -m 644 MPI_Cart_rank.3 /usr/local/share/man/man3/MPI_Cart_rank.3
/usr/bin/install -c -m 644 MPI_Cart_shift.3 /usr/local/share/man/man3/MPI_Cart_shift.3
/usr/bin/install -c -m 644 MPI_Cart_sub.3 /usr/local/share/man/man3/MPI_Cart_sub.3
/usr/bin/install -c -m 644 MPI_Cartdim_get.3 /usr/local/share/man/man3/MPI_Cartdim_get.3
/usr/bin/install -c -m 644 MPI_Close_port.3 /usr/local/share/man/man3/MPI_Close_port.3
/usr/bin/install -c -m 644 MPI_Comm_accept.3 /usr/local/share/man/man3/MPI_Comm_accept.3
/usr/bin/install -c -m 644 MPI_Comm_call_errhandler.3 /usr/local/share/man/man3/MPI_Comm_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_compare.3 /usr/local/share/man/man3/MPI_Comm_compare.3
/usr/bin/install -c -m 644 MPI_Comm_connect.3 /usr/local/share/man/man3/MPI_Comm_connect.3
/usr/bin/install -c -m 644 MPI_Comm_create.3 /usr/local/share/man/man3/MPI_Comm_create.3
/usr/bin/install -c -m 644 MPI_Comm_create_errhandler.3 /usr/local/share/man/man3/MPI_Comm_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_create_keyval.3 /usr/local/share/man/man3/MPI_Comm_create_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_delete_attr.3 /usr/local/share/man/man3/MPI_Comm_delete_attr.3
/usr/bin/install -c -m 644 MPI_Comm_disconnect.3 /usr/local/share/man/man3/MPI_Comm_disconnect.3
/usr/bin/install -c -m 644 MPI_Comm_dup.3 /usr/local/share/man/man3/MPI_Comm_dup.3
/usr/bin/install -c -m 644 MPI_Comm_free.3 /usr/local/share/man/man3/MPI_Comm_free.3
/usr/bin/install -c -m 644 MPI_Comm_free_keyval.3 /usr/local/share/man/man3/MPI_Comm_free_keyval.3
/usr/bin/install -c -m 644 MPI_Comm_get_attr.3 /usr/local/share/man/man3/MPI_Comm_get_attr.3
/usr/bin/install -c -m 644 MPI_Comm_get_errhandler.3 /usr/local/share/man/man3/MPI_Comm_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_get_name.3 /usr/local/share/man/man3/MPI_Comm_get_name.3
/usr/bin/install -c -m 644 MPI_Comm_get_parent.3 /usr/local/share/man/man3/MPI_Comm_get_parent.3
/usr/bin/install -c -m 644 MPI_Comm_group.3 /usr/local/share/man/man3/MPI_Comm_group.3
/usr/bin/install -c -m 644 MPI_Comm_join.3 /usr/local/share/man/man3/MPI_Comm_join.3
/usr/bin/install -c -m 644 MPI_Comm_rank.3 /usr/local/share/man/man3/MPI_Comm_rank.3
/usr/bin/install -c -m 644 MPI_Comm_remote_group.3 /usr/local/share/man/man3/MPI_Comm_remote_group.3
/usr/bin/install -c -m 644 MPI_Comm_remote_size.3 /usr/local/share/man/man3/MPI_Comm_remote_size.3
/usr/bin/install -c -m 644 MPI_Comm_set_attr.3 /usr/local/share/man/man3/MPI_Comm_set_attr.3
/usr/bin/install -c -m 644 MPI_Comm_set_errhandler.3 /usr/local/share/man/man3/MPI_Comm_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Comm_set_name.3 /usr/local/share/man/man3/MPI_Comm_set_name.3
/usr/bin/install -c -m 644 MPI_Comm_size.3 /usr/local/share/man/man3/MPI_Comm_size.3
/usr/bin/install -c -m 644 MPI_Comm_spawn.3 /usr/local/share/man/man3/MPI_Comm_spawn.3
/usr/bin/install -c -m 644 MPI_Comm_spawn_multiple.3 /usr/local/share/man/man3/MPI_Comm_spawn_multiple.3
/usr/bin/install -c -m 644 MPI_Comm_split.3 /usr/local/share/man/man3/MPI_Comm_split.3
/usr/bin/install -c -m 644 MPI_Comm_test_inter.3 /usr/local/share/man/man3/MPI_Comm_test_inter.3
/usr/bin/install -c -m 644 MPI_Dims_create.3 /usr/local/share/man/man3/MPI_Dims_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create.3 /usr/local/share/man/man3/MPI_Dist_graph_create.3
/usr/bin/install -c -m 644 MPI_Dist_graph_create_adjacent.3 /usr/local/share/man/man3/MPI_Dist_graph_create_adjacent.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors.3 /usr/local/share/man/man3/MPI_Dist_graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Dist_graph_neighbors_count.3 /usr/local/share/man/man3/MPI_Dist_graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Errhandler_create.3 /usr/local/share/man/man3/MPI_Errhandler_create.3
/usr/bin/install -c -m 644 MPI_Errhandler_free.3 /usr/local/share/man/man3/MPI_Errhandler_free.3
/usr/bin/install -c -m 644 MPI_Errhandler_get.3 /usr/local/share/man/man3/MPI_Errhandler_get.3
/usr/bin/install -c -m 644 MPI_Errhandler_set.3 /usr/local/share/man/man3/MPI_Errhandler_set.3
/usr/bin/install -c -m 644 MPI_Error_class.3 /usr/local/share/man/man3/MPI_Error_class.3
/usr/bin/install -c -m 644 MPI_Error_string.3 /usr/local/share/man/man3/MPI_Error_string.3
/usr/bin/install -c -m 644 MPI_Exscan.3 /usr/local/share/man/man3/MPI_Exscan.3
/usr/bin/install -c -m 644 MPI_File_c2f.3 /usr/local/share/man/man3/MPI_File_c2f.3
/usr/bin/install -c -m 644 MPI_File_call_errhandler.3 /usr/local/share/man/man3/MPI_File_call_errhandler.3
/usr/bin/install -c -m 644 MPI_File_close.3 /usr/local/share/man/man3/MPI_File_close.3
/usr/bin/install -c -m 644 MPI_File_create_errhandler.3 /usr/local/share/man/man3/MPI_File_create_errhandler.3
/usr/bin/install -c -m 644 MPI_File_delete.3 /usr/local/share/man/man3/MPI_File_delete.3
/usr/bin/install -c -m 644 MPI_File_f2c.3 /usr/local/share/man/man3/MPI_File_f2c.3
/usr/bin/install -c -m 644 MPI_File_get_amode.3 /usr/local/share/man/man3/MPI_File_get_amode.3
/usr/bin/install -c -m 644 MPI_File_get_atomicity.3 /usr/local/share/man/man3/MPI_File_get_atomicity.3
/usr/bin/install -c -m 644 MPI_File_get_byte_offset.3 /usr/local/share/man/man3/MPI_File_get_byte_offset.3
/usr/bin/install -c -m 644 MPI_File_get_errhandler.3 /usr/local/share/man/man3/MPI_File_get_errhandler.3
/usr/bin/install -c -m 644 MPI_File_get_group.3 /usr/local/share/man/man3/MPI_File_get_group.3
/usr/bin/install -c -m 644 MPI_File_get_info.3 /usr/local/share/man/man3/MPI_File_get_info.3
/usr/bin/install -c -m 644 MPI_File_get_position.3 /usr/local/share/man/man3/MPI_File_get_position.3
/usr/bin/install -c -m 644 MPI_File_get_position_shared.3 /usr/local/share/man/man3/MPI_File_get_position_shared.3
/usr/bin/install -c -m 644 MPI_File_get_size.3 /usr/local/share/man/man3/MPI_File_get_size.3
/usr/bin/install -c -m 644 MPI_File_get_type_extent.3 /usr/local/share/man/man3/MPI_File_get_type_extent.3
/usr/bin/install -c -m 644 MPI_File_get_view.3 /usr/local/share/man/man3/MPI_File_get_view.3
/usr/bin/install -c -m 644 MPI_File_iread.3 /usr/local/share/man/man3/MPI_File_iread.3
/usr/bin/install -c -m 644 MPI_File_iread_at.3 /usr/local/share/man/man3/MPI_File_iread_at.3
/usr/bin/install -c -m 644 MPI_File_iread_shared.3 /usr/local/share/man/man3/MPI_File_iread_shared.3
/usr/bin/install -c -m 644 MPI_File_iwrite.3 /usr/local/share/man/man3/MPI_File_iwrite.3
/usr/bin/install -c -m 644 MPI_File_iwrite_at.3 /usr/local/share/man/man3/MPI_File_iwrite_at.3
/usr/bin/install -c -m 644 MPI_File_iwrite_shared.3 /usr/local/share/man/man3/MPI_File_iwrite_shared.3
/usr/bin/install -c -m 644 MPI_File_open.3 /usr/local/share/man/man3/MPI_File_open.3
/usr/bin/install -c -m 644 MPI_File_preallocate.3 /usr/local/share/man/man3/MPI_File_preallocate.3
/usr/bin/install -c -m 644 MPI_File_read.3 /usr/local/share/man/man3/MPI_File_read.3
/usr/bin/install -c -m 644 MPI_File_read_all.3 /usr/local/share/man/man3/MPI_File_read_all.3
/usr/bin/install -c -m 644 MPI_File_read_all_begin.3 /usr/local/share/man/man3/MPI_File_read_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_all_end.3 /usr/local/share/man/man3/MPI_File_read_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_at.3 /usr/local/share/man/man3/MPI_File_read_at.3
/usr/bin/install -c -m 644 MPI_File_read_at_all.3 /usr/local/share/man/man3/MPI_File_read_at_all.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_begin.3 /usr/local/share/man/man3/MPI_File_read_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_read_at_all_end.3 /usr/local/share/man/man3/MPI_File_read_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_read_ordered.3 /usr/local/share/man/man3/MPI_File_read_ordered.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_begin.3 /usr/local/share/man/man3/MPI_File_read_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_read_ordered_end.3 /usr/local/share/man/man3/MPI_File_read_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_read_shared.3 /usr/local/share/man/man3/MPI_File_read_shared.3
/usr/bin/install -c -m 644 MPI_File_seek.3 /usr/local/share/man/man3/MPI_File_seek.3
/usr/bin/install -c -m 644 MPI_File_seek_shared.3 /usr/local/share/man/man3/MPI_File_seek_shared.3
/usr/bin/install -c -m 644 MPI_File_set_atomicity.3 /usr/local/share/man/man3/MPI_File_set_atomicity.3
/usr/bin/install -c -m 644 MPI_File_set_errhandler.3 /usr/local/share/man/man3/MPI_File_set_errhandler.3
/usr/bin/install -c -m 644 MPI_File_set_info.3 /usr/local/share/man/man3/MPI_File_set_info.3
/usr/bin/install -c -m 644 MPI_File_set_size.3 /usr/local/share/man/man3/MPI_File_set_size.3
/usr/bin/install -c -m 644 MPI_File_set_view.3 /usr/local/share/man/man3/MPI_File_set_view.3
/usr/bin/install -c -m 644 MPI_File_sync.3 /usr/local/share/man/man3/MPI_File_sync.3
/usr/bin/install -c -m 644 MPI_File_write.3 /usr/local/share/man/man3/MPI_File_write.3
/usr/bin/install -c -m 644 MPI_File_write_all.3 /usr/local/share/man/man3/MPI_File_write_all.3
/usr/bin/install -c -m 644 MPI_File_write_all_begin.3 /usr/local/share/man/man3/MPI_File_write_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_all_end.3 /usr/local/share/man/man3/MPI_File_write_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_at.3 /usr/local/share/man/man3/MPI_File_write_at.3
/usr/bin/install -c -m 644 MPI_File_write_at_all.3 /usr/local/share/man/man3/MPI_File_write_at_all.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_begin.3 /usr/local/share/man/man3/MPI_File_write_at_all_begin.3
/usr/bin/install -c -m 644 MPI_File_write_at_all_end.3 /usr/local/share/man/man3/MPI_File_write_at_all_end.3
/usr/bin/install -c -m 644 MPI_File_write_ordered.3 /usr/local/share/man/man3/MPI_File_write_ordered.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_begin.3 /usr/local/share/man/man3/MPI_File_write_ordered_begin.3
/usr/bin/install -c -m 644 MPI_File_write_ordered_end.3 /usr/local/share/man/man3/MPI_File_write_ordered_end.3
/usr/bin/install -c -m 644 MPI_File_write_shared.3 /usr/local/share/man/man3/MPI_File_write_shared.3
/usr/bin/install -c -m 644 MPI_Finalize.3 /usr/local/share/man/man3/MPI_Finalize.3
/usr/bin/install -c -m 644 MPI_Finalized.3 /usr/local/share/man/man3/MPI_Finalized.3
/usr/bin/install -c -m 644 MPI_Free_mem.3 /usr/local/share/man/man3/MPI_Free_mem.3
/usr/bin/install -c -m 644 MPI_Gather.3 /usr/local/share/man/man3/MPI_Gather.3
/usr/bin/install -c -m 644 MPI_Gatherv.3 /usr/local/share/man/man3/MPI_Gatherv.3
/usr/bin/install -c -m 644 MPI_Get.3 /usr/local/share/man/man3/MPI_Get.3
/usr/bin/install -c -m 644 MPI_Get_address.3 /usr/local/share/man/man3/MPI_Get_address.3
/usr/bin/install -c -m 644 MPI_Get_count.3 /usr/local/share/man/man3/MPI_Get_count.3
/usr/bin/install -c -m 644 MPI_Get_elements.3 /usr/local/share/man/man3/MPI_Get_elements.3
/usr/bin/install -c -m 644 MPI_Get_processor_name.3 /usr/local/share/man/man3/MPI_Get_processor_name.3
/usr/bin/install -c -m 644 MPI_Get_version.3 /usr/local/share/man/man3/MPI_Get_version.3
/usr/bin/install -c -m 644 MPI_Graph_create.3 /usr/local/share/man/man3/MPI_Graph_create.3
/usr/bin/install -c -m 644 MPI_Graph_get.3 /usr/local/share/man/man3/MPI_Graph_get.3
/usr/bin/install -c -m 644 MPI_Graph_map.3 /usr/local/share/man/man3/MPI_Graph_map.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors.3 /usr/local/share/man/man3/MPI_Graph_neighbors.3
/usr/bin/install -c -m 644 MPI_Graph_neighbors_count.3 /usr/local/share/man/man3/MPI_Graph_neighbors_count.3
/usr/bin/install -c -m 644 MPI_Graphdims_get.3 /usr/local/share/man/man3/MPI_Graphdims_get.3
/usr/bin/install -c -m 644 MPI_Grequest_complete.3 /usr/local/share/man/man3/MPI_Grequest_complete.3
/usr/bin/install -c -m 644 MPI_Grequest_start.3 /usr/local/share/man/man3/MPI_Grequest_start.3
/usr/bin/install -c -m 644 MPI_Group_compare.3 /usr/local/share/man/man3/MPI_Group_compare.3
/usr/bin/install -c -m 644 MPI_Group_difference.3 /usr/local/share/man/man3/MPI_Group_difference.3
/usr/bin/install -c -m 644 MPI_Group_excl.3 /usr/local/share/man/man3/MPI_Group_excl.3
/usr/bin/install -c -m 644 MPI_Group_free.3 /usr/local/share/man/man3/MPI_Group_free.3
/usr/bin/install -c -m 644 MPI_Group_incl.3 /usr/local/share/man/man3/MPI_Group_incl.3
/usr/bin/install -c -m 644 MPI_Group_intersection.3 /usr/local/share/man/man3/MPI_Group_intersection.3
/usr/bin/install -c -m 644 MPI_Group_range_excl.3 /usr/local/share/man/man3/MPI_Group_range_excl.3
/usr/bin/install -c -m 644 MPI_Group_range_incl.3 /usr/local/share/man/man3/MPI_Group_range_incl.3
/usr/bin/install -c -m 644 MPI_Group_rank.3 /usr/local/share/man/man3/MPI_Group_rank.3
/usr/bin/install -c -m 644 MPI_Group_size.3 /usr/local/share/man/man3/MPI_Group_size.3
/usr/bin/install -c -m 644 MPI_Group_translate_ranks.3 /usr/local/share/man/man3/MPI_Group_translate_ranks.3
/usr/bin/install -c -m 644 MPI_Group_union.3 /usr/local/share/man/man3/MPI_Group_union.3
/usr/bin/install -c -m 644 MPI_Ibsend.3 /usr/local/share/man/man3/MPI_Ibsend.3
/usr/bin/install -c -m 644 MPI_Info_create.3 /usr/local/share/man/man3/MPI_Info_create.3
/usr/bin/install -c -m 644 MPI_Info_delete.3 /usr/local/share/man/man3/MPI_Info_delete.3
/usr/bin/install -c -m 644 MPI_Info_dup.3 /usr/local/share/man/man3/MPI_Info_dup.3
/usr/bin/install -c -m 644 MPI_Info_free.3 /usr/local/share/man/man3/MPI_Info_free.3
/usr/bin/install -c -m 644 MPI_Info_get.3 /usr/local/share/man/man3/MPI_Info_get.3
/usr/bin/install -c -m 644 MPI_Info_get_nkeys.3 /usr/local/share/man/man3/MPI_Info_get_nkeys.3
/usr/bin/install -c -m 644 MPI_Info_get_nthkey.3 /usr/local/share/man/man3/MPI_Info_get_nthkey.3
/usr/bin/install -c -m 644 MPI_Info_get_valuelen.3 /usr/local/share/man/man3/MPI_Info_get_valuelen.3
/usr/bin/install -c -m 644 MPI_Info_set.3 /usr/local/share/man/man3/MPI_Info_set.3
/usr/bin/install -c -m 644 MPI_Init.3 /usr/local/share/man/man3/MPI_Init.3
/usr/bin/install -c -m 644 MPI_Init_thread.3 /usr/local/share/man/man3/MPI_Init_thread.3
/usr/bin/install -c -m 644 MPI_Initialized.3 /usr/local/share/man/man3/MPI_Initialized.3
/usr/bin/install -c -m 644 MPI_Intercomm_create.3 /usr/local/share/man/man3/MPI_Intercomm_create.3
/usr/bin/install -c -m 644 MPI_Intercomm_merge.3 /usr/local/share/man/man3/MPI_Intercomm_merge.3
/usr/bin/install -c -m 644 MPI_Iprobe.3 /usr/local/share/man/man3/MPI_Iprobe.3
/usr/bin/install -c -m 644 MPI_Irecv.3 /usr/local/share/man/man3/MPI_Irecv.3
/usr/bin/install -c -m 644 MPI_Irsend.3 /usr/local/share/man/man3/MPI_Irsend.3
/usr/bin/install -c -m 644 MPI_Is_thread_main.3 /usr/local/share/man/man3/MPI_Is_thread_main.3
/usr/bin/install -c -m 644 MPI_Isend.3 /usr/local/share/man/man3/MPI_Isend.3
/usr/bin/install -c -m 644 MPI_Issend.3 /usr/local/share/man/man3/MPI_Issend.3
/usr/bin/install -c -m 644 MPI_Keyval_create.3 /usr/local/share/man/man3/MPI_Keyval_create.3
/usr/bin/install -c -m 644 MPI_Keyval_free.3 /usr/local/share/man/man3/MPI_Keyval_free.3
/usr/bin/install -c -m 644 MPI_Lookup_name.3 /usr/local/share/man/man3/MPI_Lookup_name.3
/usr/bin/install -c -m 644 MPI_Op_commute.3 /usr/local/share/man/man3/MPI_Op_commute.3
/usr/bin/install -c -m 644 MPI_Op_create.3 /usr/local/share/man/man3/MPI_Op_create.3
/usr/bin/install -c -m 644 MPI_Op_free.3 /usr/local/share/man/man3/MPI_Op_free.3
/usr/bin/install -c -m 644 MPI_Open_port.3 /usr/local/share/man/man3/MPI_Open_port.3
/usr/bin/install -c -m 644 MPI_Pack.3 /usr/local/share/man/man3/MPI_Pack.3
/usr/bin/install -c -m 644 MPI_Pack_external.3 /usr/local/share/man/man3/MPI_Pack_external.3
/usr/bin/install -c -m 644 MPI_Pack_external_size.3 /usr/local/share/man/man3/MPI_Pack_external_size.3
/usr/bin/install -c -m 644 MPI_Pack_size.3 /usr/local/share/man/man3/MPI_Pack_size.3
/usr/bin/install -c -m 644 MPI_Pcontrol.3 /usr/local/share/man/man3/MPI_Pcontrol.3
/usr/bin/install -c -m 644 MPI_Probe.3 /usr/local/share/man/man3/MPI_Probe.3
/usr/bin/install -c -m 644 MPI_Publish_name.3 /usr/local/share/man/man3/MPI_Publish_name.3
/usr/bin/install -c -m 644 MPI_Put.3 /usr/local/share/man/man3/MPI_Put.3
/usr/bin/install -c -m 644 MPI_Query_thread.3 /usr/local/share/man/man3/MPI_Query_thread.3
/usr/bin/install -c -m 644 MPI_Recv.3 /usr/local/share/man/man3/MPI_Recv.3
/usr/bin/install -c -m 644 MPI_Recv_init.3 /usr/local/share/man/man3/MPI_Recv_init.3
/usr/bin/install -c -m 644 MPI_Reduce.3 /usr/local/share/man/man3/MPI_Reduce.3
/usr/bin/install -c -m 644 MPI_Reduce_local.3 /usr/local/share/man/man3/MPI_Reduce_local.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter.3 /usr/local/share/man/man3/MPI_Reduce_scatter.3
/usr/bin/install -c -m 644 MPI_Reduce_scatter_block.3 /usr/local/share/man/man3/MPI_Reduce_scatter_block.3
/usr/bin/install -c -m 644 MPI_Register_datarep.3 /usr/local/share/man/man3/MPI_Register_datarep.3
/usr/bin/install -c -m 644 MPI_Request_free.3 /usr/local/share/man/man3/MPI_Request_free.3
/usr/bin/install -c -m 644 MPI_Request_get_status.3 /usr/local/share/man/man3/MPI_Request_get_status.3
/usr/bin/install -c -m 644 MPI_Rsend.3 /usr/local/share/man/man3/MPI_Rsend.3
/usr/bin/install -c -m 644 MPI_Rsend_init.3 /usr/local/share/man/man3/MPI_Rsend_init.3
/usr/bin/install -c -m 644 MPI_Scan.3 /usr/local/share/man/man3/MPI_Scan.3
/usr/bin/install -c -m 644 MPI_Scatter.3 /usr/local/share/man/man3/MPI_Scatter.3
/usr/bin/install -c -m 644 MPI_Scatterv.3 /usr/local/share/man/man3/MPI_Scatterv.3
/usr/bin/install -c -m 644 MPI_Send.3 /usr/local/share/man/man3/MPI_Send.3
/usr/bin/install -c -m 644 MPI_Send_init.3 /usr/local/share/man/man3/MPI_Send_init.3
/usr/bin/install -c -m 644 MPI_Sendrecv.3 /usr/local/share/man/man3/MPI_Sendrecv.3
/usr/bin/install -c -m 644 MPI_Sendrecv_replace.3 /usr/local/share/man/man3/MPI_Sendrecv_replace.3
/usr/bin/install -c -m 644 MPI_Ssend.3 /usr/local/share/man/man3/MPI_Ssend.3
/usr/bin/install -c -m 644 MPI_Ssend_init.3 /usr/local/share/man/man3/MPI_Ssend_init.3
/usr/bin/install -c -m 644 MPI_Start.3 /usr/local/share/man/man3/MPI_Start.3
/usr/bin/install -c -m 644 MPI_Startall.3 /usr/local/share/man/man3/MPI_Startall.3
/usr/bin/install -c -m 644 MPI_Status_set_cancelled.3 /usr/local/share/man/man3/MPI_Status_set_cancelled.3
/usr/bin/install -c -m 644 MPI_Status_set_elements.3 /usr/local/share/man/man3/MPI_Status_set_elements.3
/usr/bin/install -c -m 644 MPI_Test.3 /usr/local/share/man/man3/MPI_Test.3
/usr/bin/install -c -m 644 MPI_Test_cancelled.3 /usr/local/share/man/man3/MPI_Test_cancelled.3
/usr/bin/install -c -m 644 MPI_Testall.3 /usr/local/share/man/man3/MPI_Testall.3
/usr/bin/install -c -m 644 MPI_Testany.3 /usr/local/share/man/man3/MPI_Testany.3
/usr/bin/install -c -m 644 MPI_Testsome.3 /usr/local/share/man/man3/MPI_Testsome.3
/usr/bin/install -c -m 644 MPI_Topo_test.3 /usr/local/share/man/man3/MPI_Topo_test.3
/usr/bin/install -c -m 644 MPI_Type_commit.3 /usr/local/share/man/man3/MPI_Type_commit.3
/usr/bin/install -c -m 644 MPI_Type_contiguous.3 /usr/local/share/man/man3/MPI_Type_contiguous.3
/usr/bin/install -c -m 644 MPI_Type_create_darray.3 /usr/local/share/man/man3/MPI_Type_create_darray.3
/usr/bin/install -c -m 644 MPI_Type_create_hindexed.3 /usr/local/share/man/man3/MPI_Type_create_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_create_hvector.3 /usr/local/share/man/man3/MPI_Type_create_hvector.3
/usr/bin/install -c -m 644 MPI_Type_create_indexed_block.3 /usr/local/share/man/man3/MPI_Type_create_indexed_block.3
/usr/bin/install -c -m 644 MPI_Type_create_keyval.3 /usr/local/share/man/man3/MPI_Type_create_keyval.3
/usr/bin/install -c -m 644 MPI_Type_create_resized.3 /usr/local/share/man/man3/MPI_Type_create_resized.3
/usr/bin/install -c -m 644 MPI_Type_create_struct.3 /usr/local/share/man/man3/MPI_Type_create_struct.3
/usr/bin/install -c -m 644 MPI_Type_create_subarray.3 /usr/local/share/man/man3/MPI_Type_create_subarray.3
/usr/bin/install -c -m 644 MPI_Type_delete_attr.3 /usr/local/share/man/man3/MPI_Type_delete_attr.3
/usr/bin/install -c -m 644 MPI_Type_dup.3 /usr/local/share/man/man3/MPI_Type_dup.3
/usr/bin/install -c -m 644 MPI_Type_extent.3 /usr/local/share/man/man3/MPI_Type_extent.3
/usr/bin/install -c -m 644 MPI_Type_free.3 /usr/local/share/man/man3/MPI_Type_free.3
/usr/bin/install -c -m 644 MPI_Type_free_keyval.3 /usr/local/share/man/man3/MPI_Type_free_keyval.3
/usr/bin/install -c -m 644 MPI_Type_get_attr.3 /usr/local/share/man/man3/MPI_Type_get_attr.3
/usr/bin/install -c -m 644 MPI_Type_get_contents.3 /usr/local/share/man/man3/MPI_Type_get_contents.3
/usr/bin/install -c -m 644 MPI_Type_get_envelope.3 /usr/local/share/man/man3/MPI_Type_get_envelope.3
/usr/bin/install -c -m 644 MPI_Type_get_extent.3 /usr/local/share/man/man3/MPI_Type_get_extent.3
/usr/bin/install -c -m 644 MPI_Type_get_name.3 /usr/local/share/man/man3/MPI_Type_get_name.3
/usr/bin/install -c -m 644 MPI_Type_get_true_extent.3 /usr/local/share/man/man3/MPI_Type_get_true_extent.3
/usr/bin/install -c -m 644 MPI_Type_hindexed.3 /usr/local/share/man/man3/MPI_Type_hindexed.3
/usr/bin/install -c -m 644 MPI_Type_hvector.3 /usr/local/share/man/man3/MPI_Type_hvector.3
/usr/bin/install -c -m 644 MPI_Type_indexed.3 /usr/local/share/man/man3/MPI_Type_indexed.3
/usr/bin/install -c -m 644 MPI_Type_lb.3 /usr/local/share/man/man3/MPI_Type_lb.3
/usr/bin/install -c -m 644 MPI_Type_match_size.3 /usr/local/share/man/man3/MPI_Type_match_size.3
/usr/bin/install -c -m 644 MPI_Type_set_attr.3 /usr/local/share/man/man3/MPI_Type_set_attr.3
/usr/bin/install -c -m 644 MPI_Type_set_name.3 /usr/local/share/man/man3/MPI_Type_set_name.3
/usr/bin/install -c -m 644 MPI_Type_size.3 /usr/local/share/man/man3/MPI_Type_size.3
/usr/bin/install -c -m 644 MPI_Type_struct.3 /usr/local/share/man/man3/MPI_Type_struct.3
/usr/bin/install -c -m 644 MPI_Type_ub.3 /usr/local/share/man/man3/MPI_Type_ub.3
/usr/bin/install -c -m 644 MPI_Type_vector.3 /usr/local/share/man/man3/MPI_Type_vector.3
/usr/bin/install -c -m 644 MPI_Unpack.3 /usr/local/share/man/man3/MPI_Unpack.3
/usr/bin/install -c -m 644 MPI_Unpack_external.3 /usr/local/share/man/man3/MPI_Unpack_external.3
/usr/bin/install -c -m 644 MPI_Unpublish_name.3 /usr/local/share/man/man3/MPI_Unpublish_name.3
/usr/bin/install -c -m 644 MPI_Wait.3 /usr/local/share/man/man3/MPI_Wait.3
/usr/bin/install -c -m 644 MPI_Waitall.3 /usr/local/share/man/man3/MPI_Waitall.3
/usr/bin/install -c -m 644 MPI_Waitany.3 /usr/local/share/man/man3/MPI_Waitany.3
/usr/bin/install -c -m 644 MPI_Waitsome.3 /usr/local/share/man/man3/MPI_Waitsome.3
/usr/bin/install -c -m 644 MPI_Win_call_errhandler.3 /usr/local/share/man/man3/MPI_Win_call_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_complete.3 /usr/local/share/man/man3/MPI_Win_complete.3
/usr/bin/install -c -m 644 MPI_Win_create.3 /usr/local/share/man/man3/MPI_Win_create.3
/usr/bin/install -c -m 644 MPI_Win_create_errhandler.3 /usr/local/share/man/man3/MPI_Win_create_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_create_keyval.3 /usr/local/share/man/man3/MPI_Win_create_keyval.3
/usr/bin/install -c -m 644 MPI_Win_delete_attr.3 /usr/local/share/man/man3/MPI_Win_delete_attr.3
/usr/bin/install -c -m 644 MPI_Win_fence.3 /usr/local/share/man/man3/MPI_Win_fence.3
/usr/bin/install -c -m 644 MPI_Win_free.3 /usr/local/share/man/man3/MPI_Win_free.3
/usr/bin/install -c -m 644 MPI_Win_free_keyval.3 /usr/local/share/man/man3/MPI_Win_free_keyval.3
/usr/bin/install -c -m 644 MPI_Win_get_attr.3 /usr/local/share/man/man3/MPI_Win_get_attr.3
/usr/bin/install -c -m 644 MPI_Win_get_errhandler.3 /usr/local/share/man/man3/MPI_Win_get_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_get_group.3 /usr/local/share/man/man3/MPI_Win_get_group.3
/usr/bin/install -c -m 644 MPI_Win_get_name.3 /usr/local/share/man/man3/MPI_Win_get_name.3
/usr/bin/install -c -m 644 MPI_Win_lock.3 /usr/local/share/man/man3/MPI_Win_lock.3
/usr/bin/install -c -m 644 MPI_Win_post.3 /usr/local/share/man/man3/MPI_Win_post.3
/usr/bin/install -c -m 644 MPI_Win_set_attr.3 /usr/local/share/man/man3/MPI_Win_set_attr.3
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.3 /usr/local/share/man/man3/MPI_Win_set_errhandler.3
/usr/bin/install -c -m 644 MPI_Win_set_name.3 /usr/local/share/man/man3/MPI_Win_set_name.3
/usr/bin/install -c -m 644 MPI_Win_start.3 /usr/local/share/man/man3/MPI_Win_start.3
/usr/bin/install -c -m 644 MPI_Win_test.3 /usr/local/share/man/man3/MPI_Win_test.3
/usr/bin/install -c -m 644 MPI_Win_unlock.3 /usr/local/share/man/man3/MPI_Win_unlock.3
/usr/bin/install -c -m 644 MPI_Win_wait.3 /usr/local/share/man/man3/MPI_Win_wait.3
/usr/bin/install -c -m 644 MPI_Wtick.3 /usr/local/share/man/man3/MPI_Wtick.3
/usr/bin/install -c -m 644 MPI_Wtime.3 /usr/local/share/man/man3/MPI_Wtime.3
/usr/bin/install -c -m 644 MPIX_Group_comm_create.3 /usr/local/share/man/man3/MPIX_Group_comm_create.3
if [ -s src/mpi/romio/include/mpiof.h ] ; then /usr/bin/install -c -m 644  src/mpi/romio/include/mpiof.h /usr/local/include/mpiof.h ; fi
if [ -s src/mpi/romio/include/mpio.h ] ; then /usr/bin/install -c -m 644  src/mpi/romio/include/mpio.h /usr/local/include/mpio.h ; fi
if [ -s lib/libmpich.a ] ; then /usr/bin/install -c -m 644  lib/libmpich.a /usr/local/lib/libmpich.a ; fi
if [ -s lib/libmpichcxx.a ] ; then /usr/bin/install -c -m 644  lib/libmpichcxx.a /usr/local/lib/libmpichcxx.a ; fi
if [ -s lib/libfmpich.a ] ; then /usr/bin/install -c -m 644  lib/libfmpich.a /usr/local/lib/libfmpich.a ; fi
if [ -s lib/libpmpich.a ] ; then /usr/bin/install -c -m 644  lib/libpmpich.a /usr/local/lib/libpmpich.a ; fi
if [ -s lib/libmpichf90.a ] ; then /usr/bin/install -c -m 644  lib/libmpichf90.a /usr/local/lib/libmpichf90.a ; fi
if [ -s lib/libmpich.dll ] ; then false -version-info 3:0 --mode=install  lib/libmpich.dll /usr/local/lib/libmpich.dll ; fi
if [ -s lib/libpmpich.dll ] ; then false -version-info 3:0 --mode=install  lib/libpmpich.dll /usr/local/lib/libpmpich.dll ; fi
if [ -s lib/libfmpich.dll ] ; then false -version-info 3:0 --mode=install  lib/libfmpich.dll /usr/local/lib/libfmpich.dll ; fi
if [ -s lib/libmpichf90.dll ] ; then false -version-info 3:0 --mode=install  lib/libmpichf90.dll /usr/local/lib/libmpichf90.dll ; fi
if [ -s lib/libmpichcxx.dll ] ; then false -version-info 3:0 --mode=install  lib/libmpichcxx.dll /usr/local/lib/libmpichcxx.dll ; fi
if [ -s ./doc/userguide/user.pdf ] ; then /usr/bin/install -c -m 644  ./doc/userguide/user.pdf /usr/local/share/doc//user.pdf ; fi
if [ -s ./doc/installguide/install.pdf ] ; then /usr/bin/install -c -m 644  ./doc/installguide/install.pdf /usr/local/share/doc//install.pdf ; fi
if [ -s ./doc/smpd/smpd_pmi.pdf ] ; then /usr/bin/install -c -m 644  ./doc/smpd/smpd_pmi.pdf /usr/local/share/doc//smpd_pmi.pdf ; fi
if [ -s ./doc/logging/logging.pdf ] ; then /usr/bin/install -c -m 644  ./doc/logging/logging.pdf /usr/local/share/doc//logging.pdf ; fi
(cd src/env && make INSTALL_STRIP_FLAG= PACKAGE= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
if [ ! -d /usr/local ] ; then mkdir -p /usr/local ; fi
if [ ! -d /usr/local/bin ] ; then mkdir -p /usr/local/bin ; fi
/usr/bin/install -c   mpich2version /usr/local/bin/mpich2version
/usr/bin/install -c  mpicc /usr/local/bin/mpicc
if [ ! -d /usr/local/etc ] ; then mkdir -p /usr/local/etc ; fi
/usr/bin/install -c -m 644  mpixxx_opts.conf /usr/local/etc/mpixxx_opts.conf
/usr/bin/install -c -m 644  mpicc.conf /usr/local/etc/mpicc.conf
if [ -s mpicxx ] ; then /usr/bin/install -c  mpicxx /usr/local/bin/mpicxx ; fi
if [ -s mpif77 ] ; then /usr/bin/install -c  mpif77 /usr/local/bin/mpif77 ; fi
if [ -s mpif90 ] ; then /usr/bin/install -c  mpif90 /usr/local/bin/mpif90 ; fi
if [ -s mpicxx.conf ] ; then /usr/bin/install -c -m 644  mpicxx.conf /usr/local/etc/mpicxx.conf ; fi
if [ -s mpif77.conf ] ; then /usr/bin/install -c -m 644  mpif77.conf /usr/local/etc/mpif77.conf ; fi
if [ -s mpif90.conf ] ; then /usr/bin/install -c -m 644  mpif90.conf /usr/local/etc/mpif90.conf ; fi
make prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install-postamble
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
if [ -x /usr/local/bin/mpicxx ] ; then \
    cd /usr/local/bin && ln -f -s mpicxx mpic++ ; fi
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
(cd src/packaging/pkgconfig && make INSTALL_STRIP_FLAG= PACKAGE= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/pkgconfig'
if [ ! -d /usr/local/lib/pkgconfig ] ; then mkdir -p /usr/local/lib/pkgconfig ; fi
if [ -s mpich2-c.pc ] ; then /usr/bin/install -c -m 644  mpich2-c.pc /usr/local/lib/pkgconfig/mpich2-c.pc ; fi
if [ -s mpich2-cxx.pc ] ; then /usr/bin/install -c -m 644  mpich2-cxx.pc /usr/local/lib/pkgconfig/mpich2-cxx.pc ; fi
if [ -s mpich2-f77.pc ] ; then /usr/bin/install -c -m 644  mpich2-f77.pc /usr/local/lib/pkgconfig/mpich2-f77.pc ; fi
if [ -s mpich2-f90.pc ] ; then /usr/bin/install -c -m 644  mpich2-f90.pc /usr/local/lib/pkgconfig/mpich2-f90.pc ; fi
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/pkgconfig'
(cd src/packaging/envmods && make INSTALL_STRIP_FLAG= PACKAGE= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install)
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/envmods'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/envmods'
for dir in  src/binding/f77 src/binding/f90 src/binding/cxx - ; do \
	if [ "$dir" = "-" ] ; then break ; fi ;\
	(cd $dir && make INSTALL_STRIP_FLAG= PACKAGE= prefix=/usr/local exec_prefix=/usr/local bindir=/usr/local/bin libdir=/usr/local/lib includedir=/usr/local/include install) ;\
done
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
if [ ! -d /usr/local/include ] ; then mkdir -p /usr/local/include ; fi
/usr/bin/install -c -m 644  mpif.h /usr/local/include/mpif.h
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
/usr/bin/install -c -m 644  mpi.mod /usr/local/include/mpi.mod
/usr/bin/install -c -m 644  mpi_constants.mod /usr/local/include/mpi_constants.mod
/usr/bin/install -c -m 644  mpi_base.mod /usr/local/include/mpi_base.mod
/usr/bin/install -c -m 644  mpi_sizeofs.mod /usr/local/include/mpi_sizeofs.mod
if [ ! -d /usr/local/lib ] ; then mkdir -p /usr/local/lib ; fi
/usr/bin/install -c -m 644  libmpichf90.a /usr/local/lib/libmpichf90.a
if [ -s mpimod.pcl ] ; then /usr/bin/install -c -m 644  mpimod.pcl /usr/local/include/mpimod.pcl ; fi
if [ -s mpimod.pc ] ; then /usr/bin/install -c -m 644  mpimod.pc /usr/local/include/mpimod.pc ; fi
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/cxx'
/usr/bin/install -c -m 644  mpicxx.h /usr/local/include/mpicxx.h
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/cxx'
for dir in  src/mpl src/openpa src/pm/smpd src/mpe2 - ; do \
done
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
test -z "/usr/local/lib" || /usr/bin/mkdir -p "/usr/local/lib"
 /bin/sh ./libtool   --mode=install /usr/bin/install -c   libmpl.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libmpl.lai /usr/local/lib/libmpl.la
libtool: install: /usr/bin/install -c .libs/libmpl.a /usr/local/lib/libmpl.a
libtool: install: chmod 644 /usr/local/lib/libmpl.a
libtool: install: ranlib /usr/local/lib/libmpl.a
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
Making install in src
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
 /bin/sh ../libtool   --mode=install /usr/bin/install -c   libopa.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libopa.lai /usr/local/lib/libopa.la
libtool: install: /usr/bin/install -c .libs/libopa.a /usr/local/lib/libopa.a
libtool: install: chmod 644 /usr/local/lib/libopa.a
libtool: install: ranlib /usr/local/lib/libopa.a
test -z "/usr/local/include" || /usr/bin/mkdir -p "/usr/local/include"
 /usr/bin/install -c -m 644 opa_config.h opa_primitives.h opa_queue.h opa_util.h '/usr/local/include'
/usr/bin/mkdir -p '/usr/local/include/primitives'
 /usr/bin/install -c -m 644  primitives/opa_by_lock.h primitives/opa_emulated.h primitives/opa_gcc_ia64.h primitives/opa_gcc_intel_32_64.h primitives/opa_gcc_intel_32_64_barrier.h primitives/opa_gcc_intel_32_64_ops.h primitives/opa_gcc_intel_32_64_p3.h primitives/opa_gcc_intel_32_64_p3barrier.h primitives/opa_gcc_intrinsics.h primitives/opa_gcc_ppc.h primitives/opa_gcc_sicortex.h primitives/opa_nt_intrinsics.h primitives/opa_sun_atomic_ops.h primitives/opa_unsafe.h '/usr/local/include/primitives'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
Making install in test
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
test -z "/usr/local/share/doc/openpa" || /usr/bin/mkdir -p "/usr/local/share/doc/openpa"
 /usr/bin/install -c -m 644 README '/usr/local/share/doc/openpa'
test -z "/usr/local/lib/pkgconfig" || /usr/bin/mkdir -p "/usr/local/lib/pkgconfig"
 /usr/bin/install -c -m 644 openpa.pc '/usr/local/lib/pkgconfig'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd'
/usr/bin/install -c   mpiexec /usr/local/bin/mpiexec
/usr/bin/install -c   smpd /usr/local/bin/smpd
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpe2'
Installing MPE2 include files to /usr/local/include
Replacing existing file /usr/local/include/clog_commset.h...
Replacing existing file /usr/local/include/clog_const.h...
Replacing existing file /usr/local/include/clog_inttypes.h...
Replacing existing file /usr/local/include/clog_uuid.h...
Replacing existing file /usr/local/include/mpe.h...
Replacing existing file /usr/local/include/mpe_callstack.h...
Replacing existing file /usr/local/include/mpe_graphics.h...
Replacing existing file /usr/local/include/mpe_graphicsf.h...
Replacing existing file /usr/local/include/mpe_log.h...
Replacing existing file /usr/local/include/mpe_log_thread.h...
Replacing existing file /usr/local/include/mpe_logf.h...
Replacing existing file /usr/local/include/mpe_misc.h...
Installing MPE2 libraries to /usr/local/lib
Replacing existing file /usr/local/lib/libampe.a...
Replacing existing file /usr/local/lib/liblmpe.a...
Replacing existing file /usr/local/lib/libmpe.a...
Replacing existing file /usr/local/lib/libmpe_collchk.a...
Replacing existing file /usr/local/lib/libmpe_f2cmpi.a...
Replacing existing file /usr/local/lib/libmpe_nompi.a...
Replacing existing file /usr/local/lib/libmpe_nompi_null.a...
Replacing existing file /usr/local/lib/libmpe_null.a...
Replacing existing file /usr/local/lib/libtmpe.a...
Replacing existing file /usr/local/lib/mpe_prof.o...
Installing MPE2 utility programs to /usr/local/bin
Replacing existing file /usr/local/bin/bt2line...
Replacing existing file /usr/local/bin/check_callstack.exe...
Replacing existing file /usr/local/bin/clog2_join.exe...
Replacing existing file /usr/local/bin/clog2_print.exe...
Replacing existing file /usr/local/bin/clog2_repair.exe...
Installing MPE2 configuration files to /usr/local/etc
Installing MPE2 system utility programs to /usr/local/sbin
Replacing existing file /usr/local/sbin/mpecheckinstall...
Replacing existing file /usr/local/share/examples_logging/comm1_isr.c...
Replacing existing file /usr/local/share/examples_logging/comm1_isr_loop.c...
Replacing existing file /usr/local/share/examples_logging/comm2_connect_accept.c...
Replacing existing file /usr/local/share/examples_logging/comm2_spawn_child.c...
Replacing existing file /usr/local/share/examples_logging/comm2_spawn_parent.c...
Replacing existing file /usr/local/share/examples_logging/cpi.c...
Replacing existing file /usr/local/share/examples_logging/cpilog.c...
Replacing existing file /usr/local/share/examples_logging/cpilog_pack.c...
Replacing existing file /usr/local/share/examples_logging/fcomm1_isr.f...
Replacing existing file /usr/local/share/examples_logging/fpilog.f...
Replacing existing file /usr/local/share/examples_logging/fpilog_pack.F...
Replacing existing file /usr/local/share/examples_logging/iotest.c...
Replacing existing file /usr/local/share/examples_logging/log_cost.c...
Replacing existing file /usr/local/share/examples_logging/Makefile...
Replacing existing file /usr/local/share/examples_logging/openmp_mpilog.F...
Replacing existing file /usr/local/share/examples_logging/openmp_sendrecv.c...
Replacing existing file /usr/local/share/examples_logging/pthread_allreduce.c...
Replacing existing file /usr/local/share/examples_logging/pthread_sendrecv.c...
Replacing existing file /usr/local/share/examples_logging/pthread_sendrecv_user.c...
Replacing existing file /usr/local/share/examples_logging/srtest.c...
Replacing existing file /usr/local/share/examples_graphics/cpi.c...
Replacing existing file /usr/local/share/examples_graphics/cxgraphics.c...
Replacing existing file /usr/local/share/examples_graphics/fxgraphics.f...
Replacing existing file /usr/local/share/examples_graphics/Makefile...
Replacing existing file /usr/local/share/examples_collchk/composite.c...
Replacing existing file /usr/local/share/examples_collchk/Makefile...
Replacing existing file /usr/local/share/examples_collchk/scatterv.c...
Replacing existing file /usr/local/share/examples_collchk/time_allreduce.c...
Replacing existing file /usr/local/share/examples_collchk/time_alltoallv.c...
Replacing existing file /usr/local/share/examples_collchk/time_alltoallv0.c...
Replacing existing file /usr/local/share/examples_collchk/time_bcast.c...
Replacing existing file /usr/local/share/examples_collchk/wrong_composite.c...
Replacing existing file /usr/local/share/examples_collchk/wrong_int_byte.c...
Replacing existing file /usr/local/share/examples_collchk/wrong_reals.f...
Replacing existing file /usr/local/share/examples_collchk/wrong_root.c...
Replacing existing file /usr/local/share/examples_collchk/wrong_scatterv.c...
Installing MPE2 man to /usr/local/share/man
Replacing existing file /usr/local/share/man/man4/MPE_Add_RGB_color.4...
Replacing existing file /usr/local/share/man/man4/MPE_CaptureFile.4...
Replacing existing file /usr/local/share/man/man4/MPE_Close_graphics.4...
Replacing existing file /usr/local/share/man/man4/MPE_Comm_global_rank.4...
Replacing existing file /usr/local/share/man/man4/MPE_Decomp1d.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_comm_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_comm_state.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_info_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_info_state.4...
Replacing existing file /usr/local/share/man/man4/MPE_Describe_state.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_circle.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_line.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_logic.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_point.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_points.4...
Replacing existing file /usr/local/share/man/man4/MPE_Draw_string.4...
Replacing existing file /usr/local/share/man/man4/MPE_Errors_call_debugger.4...
Replacing existing file /usr/local/share/man/man4/MPE_Fill_circle.4...
Replacing existing file /usr/local/share/man/man4/MPE_Fill_rectangle.4...
Replacing existing file /usr/local/share/man/man4/MPE_Finish_log.4...
Replacing existing file /usr/local/share/man/man4/MPE_Get_mouse_press.4...
Replacing existing file /usr/local/share/man/man4/MPE_GetHostName.4...
Replacing existing file /usr/local/share/man/man4/MPE_GetTags.4...
Replacing existing file /usr/local/share/man/man4/MPE_Iget_mouse_press.4...
Replacing existing file /usr/local/share/man/man4/MPE_Init_log.4...
Replacing existing file /usr/local/share/man/man4/MPE_Initialized_logging.4...
Replacing existing file /usr/local/share/man/man4/MPE_IO_Stdout_to_file.4...
Replacing existing file /usr/local/share/man/man4/MPE_Line_thickness.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_bare_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_comm_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_comm_receive.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_comm_send.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_get_event_number.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_get_solo_eventID.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_get_state_eventIDs.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_info_event.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_merged_logfilename.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_pack.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_receive.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_send.4...
Replacing existing file /usr/local/share/man/man4/MPE_Log_sync_clocks.4...
Replacing existing file /usr/local/share/man/man4/MPE_Make_color_array.4...
Replacing existing file /usr/local/share/man/man4/MPE_Num_colors.4...
Replacing existing file /usr/local/share/man/man4/MPE_Open_graphics.4...
Replacing existing file /usr/local/share/man/man4/MPE_ReturnTags.4...
Replacing existing file /usr/local/share/man/man4/MPE_Seq_begin.4...
Replacing existing file /usr/local/share/man/man4/MPE_Seq_end.4...
Replacing existing file /usr/local/share/man/man4/MPE_Signals_call_debugger.4...
Replacing existing file /usr/local/share/man/man4/MPE_Start_log.4...
Replacing existing file /usr/local/share/man/man4/MPE_Stop_log.4...
Replacing existing file /usr/local/share/man/man4/MPE_TagsEnd.4...
Replacing existing file /usr/local/share/man/man4/MPE_Update.4...
Installing MPE2 html to /usr/local/share/doc/
Replacing existing file /usr/local/share/doc//www4/libmpe.cit...
Replacing existing file /usr/local/share/doc//www4/MPE_Add_RGB_color.html...
Replacing existing file /usr/local/share/doc//www4/MPE_CaptureFile.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Close_graphics.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Comm_global_rank.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Decomp1d.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_comm_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_comm_state.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_info_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_info_state.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Describe_state.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_circle.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_line.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_logic.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_point.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_points.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Draw_string.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Errors_call_debugger.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Fill_circle.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Fill_rectangle.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Finish_log.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Get_mouse_press.html...
Replacing existing file /usr/local/share/doc//www4/MPE_GetHostName.html...
Replacing existing file /usr/local/share/doc//www4/MPE_GetTags.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Iget_mouse_press.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Init_log.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Initialized_logging.html...
Replacing existing file /usr/local/share/doc//www4/MPE_IO_Stdout_to_file.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Line_thickness.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_bare_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_comm_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_comm_receive.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_comm_send.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_get_event_number.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_get_solo_eventID.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_get_state_eventIDs.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_info_event.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_merged_logfilename.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_pack.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_receive.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_send.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Log_sync_clocks.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Make_color_array.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Num_colors.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Open_graphics.html...
Replacing existing file /usr/local/share/doc//www4/MPE_ReturnTags.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Seq_begin.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Seq_end.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Signals_call_debugger.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Start_log.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Stop_log.html...
Replacing existing file /usr/local/share/doc//www4/MPE_TagsEnd.html...
Replacing existing file /usr/local/share/doc//www4/MPE_Update.html...
Installed MPE2 in /usr/local
/usr/local/sbin/mpeuninstall may be used to remove the installation
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpe2'
Configuring MPICH2 version 1.4 with  'F77=g95' 'FC=g95' '--with-pm=smpd'
Running on system: CYGWIN_NT-6.1-WOW64 DNAO-7-PC 1.7.15(0.260/5/3) 2012-05-09 10:25 i686 Cygwin
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.exe
checking for suffix of executables... .exe
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking build system type... i686-pc-cygwin
checking host system type... i686-pc-cygwin
checking for grep that handles long lines and -e... /usr/bin/grep
checking for fgrep... /usr/bin/grep -F
Executing mpich2prereq in /cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3 with
Executing mpich2prereq in /cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis
configure: ===== configuring src/mpl =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/mpl/configure  'F77=g95' 'FC=g95' '--with-pm=smpd' --disable-option-checking
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking how to print strings... printf
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /usr/bin/sed
checking for egrep... /usr/bin/grep -E
checking for ld used by gcc... /usr/i686-pc-cygwin/bin/ld.exe
checking if the linker (/usr/i686-pc-cygwin/bin/ld.exe) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 8192
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert i686-pc-cygwin file names to i686-pc-cygwin format... func_convert_file_noop
checking how to convert i686-pc-cygwin file names to toolchain format... func_convert_file_noop
checking for /usr/i686-pc-cygwin/bin/ld.exe option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... file_magic ^x86 archive import|^x86 DLL
checking for dlltool... dlltool
checking how to associate runtime and link libraries... func_cygming_dll_for_implib
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... no
checking if : is a manifest tool... no
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -DDLL_EXPORT -DPIC
checking if gcc PIC flag -DDLL_EXPORT -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/i686-pc-cygwin/bin/ld.exe) supports shared libraries... yes
checking dynamic linker characteristics... Win32 ld.exe
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking for variable argument list macro functionality... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... no
checking valgrind/valgrind.h presence... no
checking for valgrind/valgrind.h... no
checking valgrind/memcheck.h usability... no
checking valgrind/memcheck.h presence... no
checking for valgrind/memcheck.h... no
checking helgrind.h usability... no
checking helgrind.h presence... no
checking for helgrind.h... no
checking valgrind/helgrind.h usability... no
checking valgrind/helgrind.h presence... no
checking for valgrind/helgrind.h... no
checking drd.h usability... no
checking drd.h presence... no
checking for drd.h... no
checking valgrind/drd.h usability... no
checking valgrind/drd.h presence... no
checking for valgrind/drd.h... no
checking whether the valgrind headers are broken or too old... yes
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for strncmp... yes
checking whether strncmp needs a declaration... no
checking for putenv... yes
checking whether putenv needs a declaration... no
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating localdefs
config.status: creating include/config.h
config.status: include/config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h defines
config.status: include/mplconfig.h is unchanged
configure: ===== done with src/mpl configure =====
configure: ===== configuring src/openpa =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/openpa/configure --with-atomic-primitives=auto_allow_emulation 'F77=g95' 'FC=g95' '--with-pm=smpd' --disable-option-checking
checking for gcc... (cached) gcc
checking whether to enable assertions... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for inline... inline
checking for pthread_create in -lpthread... yes
checking for pthread_yield... yes
checking if 100 threads can be run at once... yes
checking size of void *... 4
checking size of int... 4
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 primitives... yes
checking for support for gcc x86 primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: src/config.h is unchanged
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
config.status: src/opa_config.h is unchanged
configure: ===== done with src/openpa configure =====
sourcing /cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd/mpich2prereq
sourcing /cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd/setup_pm
RUNNING SETUP FOR THE SMPD PROCESS MANAGER
RUNNING SETUP FOR THE SMPD SOCK INTERFACE
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O2... yes
checking whether C compiler option -O2 works with an invalid prototype program... yes
checking whether routines compiled with -O2 can be linked with ones compiled without -O2... yes
checking for type of weak symbol alias support... pragma weak accepted but does not work (probably creates two non-weak entries)
no
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute__ ((weak_import)) allowed... yes
checking whether __attribute__((weak,alias(...))) allowed... no
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether g95 accepts -g... yes
checking whether Fortran 77 compiler accepts option -O2... yes
checking how to get verbose linking output from g95... -v
checking for Fortran 77 libraries of g95...  -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1 -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/lib/gcc// -L/lib// -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/lib// -lf95 -lm -lws2_32 -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32
checking whether g95 accepts the FLIBS found by autoconf... yes
checking whether gcc links with FLIBS found by autoconf... yes
checking whether Fortran 77 and C objects are compatible... yes
checking for linker for Fortran main program... Use Fortran to link programs
checking for Fortran 77 name mangling... lower 2uscore
checking for libraries to link Fortran main with C stdio routines... none
checking whether Fortran init will work with C... yes
checking whether we are using the GNU Fortran compiler... yes
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (g95    ) works... yes
checking whether the Fortran 90 compiler (g95    ) is a cross-compiler... no
checking whether Fortran 90 compiler works with Fortran 77 compiler... yes
checking whether Fortran 77 accepts ! for comments... yes
checking for include directory flag for Fortran... -I
checking for Fortran 77 flag for library directories... -L
checking whether Fortran 77 compiler processes .F files with C preprocessor... yes
checking whether we are using the GNU Fortran compiler... (cached) yes
checking whether g95 accepts -g... (cached) yes
checking for Fortran 90 module extension... mod
checking for Fortran 90 module include flag... -I
checking whether Fortran 90 compiler accepts option -O2... yes
checking whether Fortran 90 compiler processes .F90 files with C preprocessor... yes
checking what libraries are needed to link Fortran90 programs with C routines that use stdio... none
checking for Fortran 90 compiler vendor... gnu
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking whether the C++ compiler c++ can build an executable... yes
checking whether C++ compiler works with string... yes
checking whether the compiler supports exceptions... yes
checking whether the compiler recognizes bool as a built-in type... yes
checking whether the compiler implements namespaces... yes
checking whether <iostream> available... yes
checking whether the compiler implements the namespace std... yes
checking whether <math> available... no
checking for GNU g++ version... 4 . 5
checking whether C++ compiler accepts option -O2... yes
checking for perl... /usr/bin/perl
checking for killall... no
checking whether install works... yes
checking whether install breaks libraries... no
checking whether mkdir -p works... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for bash... /usr/bin/bash
checking whether /usr/bin/bash supports arrays... yes
checking for doctext... false
checking for location of doctext style files... unavailable
checking for working volatile... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether gcc supports __func__... yes
Using gcc to determine dependencies
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... eight
checking for max C struct floating point alignment... four
checking for max C struct alignment of structs with doubles... eight
checking for max C struct floating point alignment with long doubles... four
configure: WARNING: Structures containing long doubles may be aligned differently from structures with floats or longs.  MPICH2 does not handle this case automatically and you should avoid assumed extents for structures containing float types.
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking size of char... 1
checking size of unsigned char... 1
checking size of short... 2
checking size of unsigned short... 2
checking size of unsigned int... 4
checking size of long... 4
checking size of unsigned long... 4
checking size of long long... 8
checking size of unsigned long long... 8
checking size of float... 4
checking size of double... 8
checking size of long double... 12
checking for ANSI C header files... (cached) yes
checking size of wchar_t... 2
checking size of float_int... 8
checking size of double_int... 16
checking size of long_int... 8
checking size of short_int... 8
checking size of two_int... 8
checking size of long_double_int... 16
checking sys/bitypes.h usability... no
checking sys/bitypes.h presence... no
checking for sys/bitypes.h... no
checking inttypes.h usability... yes
checking inttypes.h presence... yes
checking stdint.h usability... yes
checking stdint.h presence... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking stdbool.h usability... yes
checking stdbool.h presence... yes
checking for stdbool.h... yes
checking complex.h usability... yes
checking complex.h presence... yes
checking for complex.h... yes
checking size of _Bool... 1
checking size of float _Complex... 8
checking size of double _Complex... 16
checking size of long double _Complex... 24
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking for size of Fortran type integer... 4
checking for size of Fortran type real... 4
checking for size of Fortran type double precision... 8
checking whether integer*1 is supported... yes
checking whether integer*2 is supported... yes
checking whether integer*4 is supported... yes
checking whether integer*8 is supported... yes
checking whether integer*16 is supported... no
checking whether real*4 is supported... yes
checking whether real*8 is supported... yes
checking whether real*16 is supported... yes
checking for C type matching Fortran integer... int
checking for size of MPI_Status... 20
checking for values of Fortran logicals... True is 1 and False is 0
checking for BSD/POSIX style global symbol lister... no
checking for multiple __attribute__((alias)) support... yes
checking the minimum alignment of Fortran common block of 1 integers... 4
checking the minimum alignment of Fortran common block of 5 integers... 4, too small! reset to 32
checking for Fortran 90 integer kind for 4-byte integers... 4
checking for Fortran 90 integer kind for 8-byte integers... 8
checking if real*8 is supported in Fortran 90... yes
checking size of bool... 1
checking how to run the C++ preprocessor... c++ -E
checking complex usability... yes
checking complex presence... yes
checking for complex... yes
checking size of Complex... 8
checking size of DoubleComplex... 16
checking size of LongDoubleComplex... 24
checking if char * pointers use byte addresses... yes
checking for alignment restrictions on ... no
checking for alignment restrictions on int32_t... no
checking size of MPIR_Bsend_data_t... 56
checking for gcc __asm__ and pentium cmpxchgl instruction... yes
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... no
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking stdlib.h usability... yes
checking stdlib.h presence... yes
checking sys/types.h usability... yes
checking sys/types.h presence... yes
checking string.h usability... yes
checking string.h presence... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stddef.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking unistd.h usability... yes
checking unistd.h presence... yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/uio.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for strncasecmp... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... no
checking whether strerror_r needs a declaration... no
checking for qsort... yes
checking for va_copy... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for fdopen... yes
checking whether fdopen needs a declaration... yes
checking for clock_gettime... yes
checking for clock_getres... yes
checking for gethrtime... no
checking for mach_absolute_time... no
checking for gettimeofday... yes
checking for library containing clock_gettime... none required
checking for library containing clock_getres... none required
checking whether struct timespec is defined in time.h... yes
checking for CLOCK_REALTIME defined in time.h... yes
sourcing /cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/setup_channel
RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
checking for pthread_key_create in -lpthread... yes
checking for pthread_key_create... yes
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE_NP... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK_NP... no
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK... yes
checking for thread local storage specifier... __thread
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking for sched_yield... yes
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking for getpid... yes
checking for sched_setaffinity... no
checking for sched_getaffinity... no
checking for bindprocessor... no
checking for thread_policy_set... no
configure: ===== configuring src/mpid/ch3 =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/configure  'F77=g95' 'FC=g95' '--with-pm=smpd' --disable-option-checking
RUNNING CONFIGURE FOR CH3 DEVICE
checking for sys/types.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking uuid/uuid.h usability... yes
checking uuid/uuid.h presence... yes
checking for uuid/uuid.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for unistd.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking whether CPP accepts variable length argument lists... yes
checking whether we can use struct ifconf... yes
configure: ===== configuring channels/nemesis =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/configure  'F77=g95' 'FC=g95' '--with-pm=smpd' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' --disable-option-checking
RUNNING CONFIGURE FOR THE NEMESIS CHANNEL
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking for netinet/in.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for signal... yes
checking for rand... yes
checking for srand... yes
checking for OpenPA atomic primitive availability... yes
checking for mmap... yes
checking for munmap... yes
configure: Using a memory-mapped file for shared memory
checking whether struct hostent contains h_addr_list... yes
checking knem_io.h usability... no
checking knem_io.h presence... no
checking for knem_io.h... no
config.status: creating nemesis/Makefile
config.status: creating nemesis/src/Makefile
config.status: creating nemesis/utils/Makefile
config.status: creating nemesis/utils/replacements/Makefile
config.status: creating nemesis/utils/monitor/Makefile
config.status: creating nemesis/netmod/Makefile
config.status: creating nemesis/netmod/elan/Makefile
config.status: creating nemesis/netmod/gm/Makefile
config.status: creating nemesis/netmod/mx/Makefile
config.status: creating nemesis/netmod/tcp/Makefile
config.status: creating nemesis/netmod/psm/Makefile
config.status: creating nemesis/netmod/newmad/Makefile
config.status: creating nemesis/netmod/none/Makefile
config.status: creating nemesis/include/mpid_nem_net_module_defs.h
config.status: creating nemesis/src/mpid_nem_net_array.c
config.status: creating include/mpidi_ch3i_nemesis_conf.h
config.status: include/mpidi_ch3i_nemesis_conf.h is unchanged
configure: ===== done with channels/nemesis configure =====
config.status: creating util/Makefile
config.status: creating channels/Makefile
config.status: creating util/ftb/Makefile
config.status: creating include/mpid_thread.h
config.status: creating include/mpidi_ch3_conf.h
config.status: include/mpidi_ch3_conf.h is unchanged
config.status: executing default-1 commands
copying ./../common/thread/mpid_thread_mpe.c to src/mpid_thread.c
configure: ===== done with src/mpid/ch3 configure =====
configure: ===== configuring src/pm/smpd/sock =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd/sock/configure  'F77=g95' 'FC=g95' '--with-pm=smpd' --disable-option-checking
RUNNING CONFIGURE FOR THE SMPD SOCK INTERFACE
configure: ===== configuring poll =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd/sock/poll/configure  'F77=g95' 'FC=g95' '--with-pm=smpd' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' --disable-option-checking
RUNNING CONFIGURE FOR THE POLL IMPLEMENTATION OF SOCK
checking for poll... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking poll.h usability... yes
checking poll.h presence... yes
checking for poll.h... yes
checking sys/poll.h usability... yes
checking sys/poll.h presence... yes
checking for sys/poll.h... yes
checking if struct poll is defined... yes
checking if a simple program using poll() can be compiled... yes
checking whether bit fields work in ip.h... no
Adding -D_NO_BITFIELDS to CFLAGS
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking whether socklen_t is defined (in sys/socket.h if present)... yes
config.status: creating smpdu_socki_conf.h
config.status: smpdu_socki_conf.h is unchanged
configure: ===== done with poll configure =====
config.status: creating smpdu_sock_conf.h
config.status: smpdu_sock_conf.h is unchanged
configure: ===== done with src/pm/smpd/sock configure =====
configure: ===== configuring src/mpi/romio =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/configure  'F77=g95' 'FC=g95' '--with-pm=smpd' --disable-option-checking
Configuring with args F77=g95 FC=g95 --with-pm=smpd --disable-option-checking
checking for architecture... i686
configure: WARNING: Unknown architecture ... proceeding anyway
ROMIO home directory is /cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio
checking for memalign... yes
checking Fortran external names
Fortran externals are lower case and have two trailing underscores
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking for int large enough for pointers... yes
checking for Fortran 90 KIND parameter for 8-byte integers...  8
checking that we can use integer*8 to declare MPI_DISPLACMENT_CURRENT... yes
Overriding Array test for MPICH2
checking for weak symbol support... pragma weak
checking that weak symbols are visible to other files... no
no
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
configure: WARNING: File locks may not work with NFS.  See the Installation and
users manual for instructions on testing and if necessary fixing this
checking for library containing aio_write... no
checking for library containing pthread_create... none required
checking for library containing aio_write... (cached) no
checking if aio.h exists and can be compiled... no
checking if sys/aio.h exists and can be compiled... no
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for large file defines... no
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... no
checking for large file defines... none
checking spi/kernel_interface.h usability... no
checking spi/kernel_interface.h presence... no
checking for spi/kernel_interface.h... no
checking for Kernel_GetMemorySize... no
setting SYSDEP_INC to
setting CC to gcc
setting F77 to g95
setting TEST_CC to /cygdrive/c/cygwin/mpich2-1.4/bin/mpicc
setting TEST_F77 to /cygdrive/c/cygwin/mpich2-1.4/bin/mpif77
setting CFLAGS to    -O2  -DFORTRANDOUBLEUNDERSCORE -DHAVE_ROMIOCONF_H
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_bgl/Makefile
config.status: creating adio/ad_bglockless/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating adio/ad_lustre/Makefile
config.status: creating adio/ad_zoidfs/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating common/dataloop/Makefile
config.status: creating adio/include/romioconf.h
configure: ===== done with src/mpi/romio configure =====
configure: ===== configuring src/pmi/smpd =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/pmi/smpd/configure  'F77=g95' 'FC=g95' '--with-pm=smpd' --disable-option-checking
RUNNING CONFIGURE FOR THE SMPD PMI
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking mach-o/dyld.h usability... no
checking mach-o/dyld.h presence... no
checking for mach-o/dyld.h... no
checking for dlopen... yes
checking for NSLinkModule... no
checking for library containing dlopen... none required
smpd_sock_name = poll
config.status: creating pmiconf.h
config.status: pmiconf.h is unchanged
configure: ===== done with src/pmi/smpd configure =====
configure: ===== configuring src/pm/smpd =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd/configure  'F77=g95' 'FC=g95' '--with-pm=smpd' --disable-option-checking
checking sys/wait.h usability... yes
checking sys/wait.h presence... yes
checking for sys/wait.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking math.h usability... yes
checking math.h presence... yes
checking for math.h... yes
checking termios.h usability... yes
checking termios.h presence... yes
checking for termios.h... yes
checking md5.h usability... no
checking md5.h presence... no
checking for md5.h... no
checking openssl/md5.h usability... yes
checking openssl/md5.h presence... yes
checking for openssl/md5.h... yes
checking for sigaction... yes
checking for setenv... yes
checking for md5_calc... no
checking for library containing uuid_generate... -luuid
checking for poll stdin capability... yes
checking for library containing MD5... -lcrypto
checking for MD5... yes
checking for library containing md5_calc... no
checking for md5_calc function... no
config.status: creating smpdconf.h
config.status: smpdconf.h is unchanged
configure: ===== done with src/pm/smpd configure =====
configure: ===== configuring src/mpe2 =====
configure: executing: /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/configure  'F77=g95' 'FC=g95' '--with-pm=smpd' --disable-option-checking
Configuring MPE Profiling System with  'F77=g95' 'FC=g95' '--with-pm=smpd' '--disable-option-checking' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread       -lcrypto -luuid -lpthread     ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2
checking gnumake... yes using --no-print-directory
checking BSD 4.4 make... no - whew
checking OSF V3 make... no
This MPE build is part of the MPICH2 build
checking for leftover Makefiles in subpackages ...  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/graphics" "src/collchk" cleaned
checking whether MPI_CC has been set ... /cygdrive/c/cygwin/mpich2-1.4/bin/mpicc
checking whether MPI_F77 has been set ... /cygdrive/c/cygwin/mpich2-1.4/bin/mpif77
checking for Fortran 77 libraries of g95...  -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1 -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/lib/gcc// -L/lib// -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/lib// -lpthread -lcrypto -luuid -lf95 -lm -lws2_32 -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32
checking whether C can link with  -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1 -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/lib/gcc// -L/lib// -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/lib// -lpthread -lcrypto -luuid -lf95 -lm -lws2_32 -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32... yes
checking for linker for Fortran main programs... Use Fortran to link programs
checking for Fortran 77 name mangling... lower doubleunderscore
checking what libraries are needed to link Fortran programs with C routines that use stdio... none
config.status: creating sbin/mpetestlink
config.status: creating sbin/mpetestexec
config.status: creating sbin/mpetestexeclog
config.status: creating sbin/mpeinstall
config.status: creating sbin/mpecheckinstall
config.status: WARNING:  'sbin/mpecheckinstall.in' seems to ignore the --datarootdir setting
config.status: creating sbin/mpecheckbuild
config.status: creating etc/mpe_help.conf
config.status: creating etc/mpe_f77env.conf
config.status: creating mpe_conf.h
=== configuring in src/misc (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/misc)
configure: running /bin/sh ./configure --disable-option-checking '--prefix=/usr/local'  'F77=g95' 'FC=g95' '--with-pm=smpd' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread       -lcrypto -luuid -lpthread     ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' --cache-file=/dev/null --srcdir=.
Configuring MPE Miscellaneous Library with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' '--with-pm=smpd' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread       -lcrypto -luuid -lpthread     ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/misc
checking whether gcc and cc understand -c and -o together... yes
checking for dbx... no
checking for gdb... /usr/bin/gdb
checking for sysinfo... yes
checking for uname... yes
checking for gethostbyname... yes
checking sys/systeminfo.h usability... no
checking sys/systeminfo.h presence... no
checking for sys/systeminfo.h... no
checking for sighandler_t... yes
checking for kill... yes
checking whether kill needs a declaration... no
config.status: creating src/dbxerr.c
config.status: creating mpe_misc_conf.h
=== configuring in src/callstack (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/callstack)
Configuring MPE CallStack Library with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' '--with-pm=smpd' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread       -lcrypto -luuid -lpthread     ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/callstack
checking execinfo.h usability... no
checking execinfo.h presence... no
checking for execinfo.h... no
checking ucontext.h usability... no
checking ucontext.h presence... no
checking for ucontext.h... no
checking whether fdopen needs a declaration... no
config.status: creating include/mpe_callstack.h
config.status: creating etc/mpe_callstack_ldflags.conf
config.status: creating bin/bt2line
config.status: creating mpe_callstack_conf.h
=== configuring in src/logging (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/logging)
Configuring MPE Logging Library and Tools with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' '--with-pm=smpd' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread       -lcrypto -luuid -lpthread     ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/logging
checking for header that defines C99 integer types, intXX_t ... <stdint.h>
checking whether <inttypes.h> defines the PRIdXX macros ... yes
checking if <stdint.h> can be behind system headers ... yes
checking for address-sized integer ... CLOG_int32_t
checking for srand48... yes
checking whether srand48 needs a declaration... no
checking for lrand48... yes
checking whether lrand48 needs a declaration... no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for O_LARGEFILE for open() ... no
checking for O_BINARY for open() ... yes
checking for pthread_mutex_lock in -lpthread... yes
config.status: creating include/clog_inttypes.h
config.status: creating include/mpi_null.h
config.status: creating include/mpe_log_thread.h
config.status: creating etc/mpe_log.conf
config.status: creating etc/mpe_nolog.conf
config.status: creating etc/mpe_log_postlib.conf
config.status: creating mpe_logging_conf.h
=== configuring in src/wrappers (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/wrappers)
Configuring MPE Wrapper Libraries For MPI with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' '--with-pm=smpd' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread       -lcrypto -luuid -lpthread     ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/wrappers
checking for stdarg is correct... yes
checking if compiler accepts prototypes ... yes
checking for safe PMPI invocations ... no
checking for the value of MPI_STATUS_SIZE ... 5
config.status: creating etc/mpe_mpilog.conf
config.status: creating etc/mpe_mpitrace.conf
config.status: creating mpe_wrappers_conf.h
=== configuring in src/graphics (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/graphics)
Configuring MPE X Graphics Library with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' '--with-pm=smpd' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread       -lcrypto -luuid -lpthread     ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/graphics
checking for X... libraries , headers
checking for long pointer... no
checking for system... yes
config.status: creating contrib/life/Makefile
config.status: creating contrib/mandel/Makefile
config.status: creating contrib/mastermind/Makefile
config.status: creating contrib/test/Makefile
config.status: creating etc/mpe_mpianim.conf
config.status: creating etc/mpe_graphics.conf
config.status: creating mpe_graphics_conf.h
=== configuring in src/collchk (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/collchk)
Configuring MPE Collective and Datatype Checking Library with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' '--with-pm=smpd' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread       -lcrypto -luuid -lpthread     ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/collchk
config.status: creating etc/mpe_mpicheck.conf
config.status: creating mpe_collchk_conf.h
=== configuring in src/slog2sdk (/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/slog2sdk)
checking for current directory name... /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/src/slog2sdk
Configuring SLOG2SDK with  '--disable-option-checking' '--prefix=/usr/local' 'F77=g95' 'FC=g95' '--with-pm=smpd' 'MPI_CC=/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc' 'MPI_F77=/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread       -lcrypto -luuid -lpthread     ' 'CPPFLAGS= -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=.'
checking if CLASSPATH is set... no, good to go
checking for java in user's PATH... not found
configure: WARNING:  No Java Virtual Machine can be found anywhere!
MPE2:  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/graphics" "src/collchk" have been configured
configure: ===== done with src/mpe2 configure =====
checking size of OPA_ptr_t... 4
checking the sizeof MPI_Offset... 8
checking whether the Fortran Offset type works with Fortran 77... yes
checking whether the Fortran Offset type works with Fortran 90... yes
Running Configure for Fortran 90 Type routines
configure: WARNING: unrecognized options: --with-pm
checking for the precision and range of reals...  6 , 37
checking for the precision and range of double precision...  15 , 307
checking for the range of integer...  9
checking for available integer kinds...  2 , 1, 4 , 2, 9 , 4, 18 , 8,
checking for available integer ranges...  {  2 , 1 , 1 }, {  4 , 2 , 2 }, {  9 , 4 , 4 }, {  18 , 8 , 8 },
config.status: creating mpif90model.h
config.status: creating src/include/Makefile
config.status: creating src/include/mpich2info.h
config.status: creating mpich2-doxygen
config.status: creating src/include/mpichtimer.h
config.status: creating src/binding/Makefile
config.status: creating src/binding/cxx/Makefile
config.status: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/f77/Makefile
config.status: creating src/binding/f77/mpif.h
config.status: creating src/binding/f77/setbotf.f
config.status: creating src/binding/f77/setbot.c
config.status: creating src/binding/f90/Makefile
config.status: creating src/binding/f90/mpi_sizeofs.f90
config.status: creating src/binding/f90/mpi_base.f90
config.status: creating src/packaging/Makefile
config.status: creating src/packaging/pkgconfig/mpich2-c.pc
config.status: creating src/packaging/pkgconfig/mpich2-cxx.pc
config.status: creating src/packaging/pkgconfig/mpich2-f77.pc
config.status: creating src/packaging/pkgconfig/mpich2-f90.pc
config.status: creating src/packaging/pkgconfig/Makefile
config.status: creating src/packaging/envmods/mpich2.module
config.status: WARNING:  'src/packaging/envmods/mpich2.module.in' seems to ignore the --datarootdir setting
config.status: creating src/packaging/envmods/Makefile
config.status: creating src/env/mpixxx_opts.conf
config.status: creating src/env/mpicc
config.status: creating src/env/mpicc.conf
config.status: creating src/env/mpicc.bash
config.status: creating src/env/mpicxx
config.status: creating src/env/mpicxx.conf
config.status: creating src/env/mpicxx.bash
config.status: creating src/env/mpif77
config.status: creating src/env/mpif77.conf
config.status: creating src/env/mpif77.bash
config.status: creating src/env/mpif90
config.status: creating src/env/mpif90.conf
config.status: creating src/env/mpif90.bash
config.status: creating src/env/Makefile
config.status: creating src/util/createshlib
config.status: creating src/mpi/Makefile
config.status: creating src/mpi/attr/Makefile
config.status: creating src/mpi/coll/Makefile
config.status: creating src/mpi/comm/Makefile
config.status: creating src/mpi/datatype/Makefile
config.status: creating src/mpi/debugger/Makefile
config.status: creating src/mpi/errhan/Makefile
config.status: creating src/mpi/group/Makefile
config.status: creating src/mpi/init/Makefile
config.status: creating src/mpi/misc/Makefile
config.status: creating src/mpi/pt2pt/Makefile
config.status: creating src/mpi/rma/Makefile
config.status: creating src/mpi/spawn/Makefile
config.status: creating src/mpi/timer/Makefile
config.status: creating src/mpi/topo/Makefile
config.status: creating src/mpix/Makefile
config.status: creating src/mpix/comm/Makefile
config.status: creating src/mpid/Makefile
config.status: creating src/mpid/common/Makefile
config.status: creating src/mpid/common/datatype/Makefile
config.status: creating src/mpid/common/datatype/dataloop/Makefile
config.status: creating src/pm/Makefile
config.status: creating src/pmi/Makefile
config.status: creating src/pmi/smpd/Makefile
config.status: creating src/nameserv/Makefile
config.status: creating src/nameserv/file/Makefile
config.status: creating src/nameserv/mpd/Makefile
config.status: creating src/nameserv/pmi/Makefile
config.status: creating src/nameserv/test/Makefile
config.status: creating src/util/Makefile
config.status: creating src/util/info/Makefile
config.status: creating src/util/instrm/Makefile
config.status: creating src/util/thread/Makefile
config.status: creating src/util/mem/Makefile
config.status: creating src/util/msgs/Makefile
config.status: creating src/util/param/Makefile
config.status: creating src/util/dbg/Makefile
config.status: creating src/util/dbg/getfuncstack
config.status: creating src/util/osserv/Makefile
config.status: creating src/util/procmap/Makefile
config.status: creating src/util/other/Makefile
config.status: creating src/include/mpi.h
config.status: creating test/util/Makefile
config.status: creating test/basic/Makefile
config.status: creating test/commands/Makefile
config.status: creating test/commands/cmdtests
config.status: creating test/mpid/Makefile
config.status: creating test/mpid/ch3/Makefile
config.status: creating test/util/timer/Makefile
config.status: creating examples/Makefile
config.status: creating examples/f77/Makefile
config.status: creating examples/f90/Makefile
config.status: creating examples/cxx/Makefile
config.status: creating src/util/logging/Makefile
config.status: creating src/util/logging/common/Makefile
config.status: creating doc/Makefile
config.status: creating doc/mansrc/Makefile
config.status: creating doc/mansrc/createhtmlindex
config.status: creating doc/refman/Makefile
config.status: creating doc/installguide/Makefile
config.status: creating doc/userguide/Makefile
config.status: creating doc/logging/Makefile
config.status: creating doc/design/Makefile
config.status: creating doc/smpd/Makefile
config.status: creating doc/windev/Makefile
config.status: creating src/include/mpichconf.h
config.status: executing default-2 commands
config.status: executing default-3 commands
config.status: executing default-4 commands
config.status: executing default-5 commands
config.status: executing default-6 commands
config.status: executing default-7 commands
config.status: executing default-8 commands
config.status: executing default-9 commands
config.status: executing default-10 commands
config.status: executing default-11 commands
config.status: executing default-12 commands
=== configuring in test/mpi (/cygdrive/c/cygwin/mpich2-1.4/test/mpi)
configure: running /bin/sh ./configure --disable-option-checking '--prefix=/usr/local'  'F77=g95' 'FC=g95' '--with-pm=smpd' --cache-file=/dev/null --srcdir=.
RUNNING CONFIGURE FOR MPI TESTS
checking whether the C compiler works... yes
checking for C compiler default output file name... a.exe
checking for suffix of executables... .exe
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether /cygdrive/c/cygwin/mpich2-1.4/bin/mpicc accepts -g... yes
checking for /cygdrive/c/cygwin/mpich2-1.4/bin/mpicc option to accept ISO C89... none needed
checking for grep that handles long lines and -e... /usr/bin/grep
checking for fgrep... /usr/bin/grep -F
checking how to run the C preprocessor... /cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -E
checking for egrep... /usr/bin/grep -E
checking for library containing pthread_barrier_init... no
checking for pthread_create... yes
checking for pthread_barrier_init... no
checking for pthread_barrier_wait... no
checking for major version of MPI... 2
checking for minor version of MPI... 2
checking whether /cygdrive/c/cygwin/mpich2-1.4/bin/mpif77 accepts -g... yes
checking how to get verbose linking output from /cygdrive/c/cygwin/mpich2-1.4/bin/mpif77... -v
checking for Fortran 77 libraries of /cygdrive/c/cygwin/mpich2-1.4/bin/mpif77...  -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1 -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/ -L/usr/lib/gcc// -L/lib// -L/usr/local/bin/../lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/local/lib/gcc-lib/i686-pc-cygwin/4.1.1/// -L/usr/lib// -lf95 -lm -lws2_32 -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32
checking for Fortran libraries needed for getarg... none needed
checking whether Fortran 77 supports Cray-style pointer... no
checking whether /cygdrive/c/cygwin/mpich2-1.4/bin/mpif90 accepts -g... yes
checking whether the Fortran 90 compiler (/cygdrive/c/cygwin/mpich2-1.4/bin/mpif90  -nativelinking  ) works... yes
checking whether the Fortran 90 compiler (/cygdrive/c/cygwin/mpich2-1.4/bin/mpif90  -nativelinking  ) is a cross-compiler... no
checking for Fortran flag needed to accept free-form source... none
checking whether Fortran 90 supports Cray-style pointer... no
checking whether /cygdrive/c/cygwin/mpich2-1.4/bin/mpicxx accepts -g... yes
checking whether MPI_2DOUBLE_COMPLEX is available... no
checking whether MPI_2COMPLEX is available... no
checking for C integer type of address size... int
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating rma/Makefile
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/errhan/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating threads/init/Makefile
config.status: creating threads/spawn/Makefile
config.status: creating errors/Makefile
config.status: creating errors/attr/Makefile
config.status: creating errors/basic/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/faults/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f90/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating threads/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
config.status: creating include/mpitestconf.h
config.status: include/mpitestconf.h is unchanged
Configuration completed.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120723/fcc2221d/attachment-0001.obj>
Beginning make
Using variables CC='gcc' CFLAGS='   -O2' LDFLAGS=' ' F77='g95' FFLAGS='  -O2' FC='g95' FCFLAGS='  -O2' CXX='c++' CXXFLAGS='  -O2' AR='ar' CPP='gcc -E' CPPFLAGS=' -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpl/include -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/locks -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers -I/cygdrive/c/cygwin/mpich2-1.4/src/util/wrappers'
make all-local
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
Making all in src
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make  all-am
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
Making all in test
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[1]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype/dataloop'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype/dataloop'
make all-local
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common/datatype'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/common'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/src'
  CC              mpid_nem_net_array.c
  AR cr ../../../../../../../lib/libmpich.a mpid_nem_net_array.o
  RANLIB          libmpich.a
date > .libstamp0
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/src'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[7]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
make[8]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[8]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[7]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/nemesis'
make[6]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/src'
make[6]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis/src'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels/nemesis'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/channels'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/src'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/src'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/util'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3/util'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid/ch3'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpid'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/attr'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/attr'
make[4]: `.libstamp2' is up to date.
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/attr'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/attr'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/coll'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/coll'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/coll'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/coll'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/comm'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/comm'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/comm'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/comm'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/datatype'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/datatype'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/datatype'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/datatype'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/errhan'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/errhan'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/errhan'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/errhan'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/group'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/group'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/group'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/group'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/init'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/init'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/init'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/init'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/misc'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/misc'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/misc'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/misc'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/pt2pt'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/pt2pt'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/pt2pt'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/pt2pt'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/rma'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/rma'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/rma'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/rma'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/spawn'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/spawn'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/spawn'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/spawn'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/timer'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/timer'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/timer'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/timer'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/topo'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/topo'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/topo'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/topo'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio'
make mpiolib
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio'
compiling ROMIO in directory mpi-io
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io'
compiling ROMIO in directory adio/common
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/common'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/common'
compiling ROMIO in directory mpi-io/glue/mpich2
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/glue/mpich2'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/mpi-io/glue/mpich2'
compiling ROMIO in directory adio/ad_testfs
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/ad_testfs'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/ad_testfs'
compiling ROMIO in directory adio/ad_ufs
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/ad_ufs'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/ad_ufs'
compiling ROMIO in directory adio/ad_nfs
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/ad_nfs'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio/adio/ad_nfs'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio'
building profiling interface in directory mpi-io
ar cr /cygdrive/c/cygwin/mpich2-1.4/lib/libmpich.a _close.o _read.o _open.o _get_extent.o  _write.o _set_view.o _seek.o _read_at.o _prealloc.o  _iread.o _iwrite.o  _get_posn.o  _delete.o _read_all.o _get_bytoff.o  _read_atall.o _iread_at.o _iwrite_at.o _get_group.o _get_amode.o  _write_all.o _write_at.o _write_atall.o _get_view.o  _fsync.o _get_atom.o _set_atom.o _set_size.o _get_size.o  _file_f2c.o _file_c2f.o  _set_info.o _get_info.o  _rd_atallb.o _rd_atalle.o _read_allb.o _read_alle.o _wr_atallb.o  _wr_atalle.o _write_allb.o _write_alle.o  _get_posn_sh.o _iread_sh.o _read_sh.o _write_sh.o  _iwrite_sh.o _seek_sh.o _read_ord.o _read_orde.o _write_ordb.o  _read_ordb.o _write_ord.o _write_orde.o _register_datarep.o
ranlib /cygdrive/c/cygwin/mpich2-1.4/lib/libmpich.a
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi/romio'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpi'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpix'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpix/comm'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpix/comm'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpix'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/mem'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/mem'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/info'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/info'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/info'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/info'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/msgs'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/msgs'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/instrm'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/instrm'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/thread'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/thread'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/dbg'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/dbg'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/param'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/param'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/osserv'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/osserv'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/procmap'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/procmap'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/other'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/other'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/nameserv'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/nameserv/file'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/nameserv/file'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/nameserv'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
  CC              setbot.c
  F77             setbotf.f
  AR cr ../../../lib/libmpich.a setbot.o setbotf.o
  RANLIB          libmpich.a
date > .libstamp2
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
make[4]: `.libstamp4' is up to date.
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f77'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
rm -f mpifnoext.h
sed -e 's/^C/\!/g' -e '/EXTERNAL/d' \
                -e '/REAL\*8/d' \
	-e '/DOUBLE PRECISION/d' \
	-e '/MPI_WTICK/d' ../f77/mpif.h > mpifnoext.h
g95 -O2 -I. -c ./mpi_constants.f90
g95 -O2 -I. -c mpi_sizeofs.f90
g95 -O2 -I. -c mpi_base.f90
g95 -O2 -I. -c ./mpi.f90
  AR cr libmpichf90.a mpi.o mpi_constants.o mpi_sizeofs.o mpi_base.o
  RANLIB          libmpichf90.a
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
make all-postamble
if [ -s libmpichf90.a ] ; then \
   cp -p libmpichf90.a ../../../lib ; fi
if [ -s libmpichf90.la ] ; then \
   cp -p libmpichf90.la ../../../lib ; fi
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/f90'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/cxx'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding/cxx'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/binding'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/env'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/pkgconfig'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/pkgconfig'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/envmods'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging/envmods'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/packaging'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpe2'
make --no-print-directory  build_lib_bin
**** Making src/misc ....
make --no-print-directory  mpe_debug_objs
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi.a
gcc -I.. -I../include  -I../../.. -I../../../include -O2  -DMPE_NOMPI -o mpehname.no -c mpehname.c
mpehname.c: In function 「MPE_GetHostName」:
mpehname.c:59:16: 警告:初始化丟棄了指標目的類型的限定
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi.a mpehname.no
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe.a
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I../../.. -I../../../include   -o decomp.po -c decomp.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I../../.. -I../../../include   -o mpe_seq.po -c mpe_seq.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I../../.. -I../../../include   -o dbxerr.po -c dbxerr.c
dbxerr.c: In function 「MPE_DefaultHandler」:
dbxerr.c:429:1: 錯誤:expected 「=」, 「,」, 「;」, 「asm」 or 「__attribute__」 before 「{」 token
dbxerr.c:459:1: 錯誤:expected 「=」, 「,」, 「;」, 「asm」 or 「__attribute__」 before 「{」 token
dbxerr.c:408:6: 錯誤:引數 「sig」 與原型不符
dbxerr.c:407:6: 錯誤:prototype declaration
dbxerr.c:475:1: 錯誤:expected 「{」 at end of input
Makefile:82: recipe for target `dbxerr.po' failed
make[7]: *** [dbxerr.po] Error 1
Makefile:111: recipe for target `default' failed
make[6]: *** [default] Error 2
Makefile:43: recipe for target `build_lib_bin' failed
make[5]: *** [build_lib_bin] Error 2
Makefile:26: recipe for target `all' failed
make[4]: *** [all] Error 2
**** Making src/callstack ....
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -o iterator.po -c iterator.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -o fancyprint.po -c fancyprint.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include -O2  -o iterator.no -c iterator.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include -O2  -o fancyprint.no -c fancyprint.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi.a iterator.no fancyprint.no
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe.a iterator.po fancyprint.po
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/check_callstack.exe
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include -O2  -o check_callstack.no -c check_callstack.c
cp -f check_callstack.no mpe2tmp.o
gcc  -O2  -o /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/check_callstack.exe mpe2tmp.o \
                         -L/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib -lmpe_nompi
**** Making src/logging ....
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpi_null.no -c mpi_null.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_util.no -c clog_util.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_timer.no -c clog_timer.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_uuid.no -c clog_uuid.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_commset.no -c clog_commset.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_preamble.no -c clog_preamble.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_record.no -c clog_record.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_sync.no -c clog_sync.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_block.no -c clog_block.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_buffer.no -c clog_buffer.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_merger.no -c clog_merger.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_cache.no -c clog_cache.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_joiner.no -c clog_joiner.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog.no -c clog.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log_thread.no -c mpe_log_thread.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log.no -c mpe_log.c
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_log_null.no -c mpe_log_null.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o mpe_log_null.po -c mpe_log_null.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_util.po -c clog_util.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_timer.po -c clog_timer.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_uuid.po -c clog_uuid.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_commset.po -c clog_commset.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_preamble.po -c clog_preamble.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_record.po -c clog_record.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_sync.po -c clog_sync.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_block.po -c clog_block.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_buffer.po -c clog_buffer.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_merger.po -c clog_merger.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_cache.po -c clog_cache.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog_joiner.po -c clog_joiner.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o clog.po -c clog.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o mpe_log_thread.po -c mpe_log_thread.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o mpe_log.po -c mpe_log.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi.a mpi_null.no clog_util.no clog_timer.no clog_uuid.no clog_commset.no clog_preamble.no clog_record.no clog_sync.no clog_block.no clog_buffer.no clog_merger.no clog_cache.no clog_joiner.no clog.no mpe_log_thread.no mpe_log.no
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o mpe_logf.no -c mpe_logf.c
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi_null.a
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi_null.a mpi_null.no mpe_log_null.no
make[8]: `mpe_logf.no' is up to date.
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi_null.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_null.a
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_null.a mpe_log_null.po
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include   -o mpe_logf.po -c mpe_logf.c
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_null.a
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe.a clog_util.po clog_timer.po clog_uuid.po clog_commset.po clog_preamble.po clog_record.po clog_sync.po clog_block.po clog_buffer.po clog_merger.po clog_cache.po clog_joiner.po clog.po mpe_log_thread.po mpe_log.po
make[8]: `mpe_logf.po' is up to date.
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/clog2_print.exe  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/clog2_join.exe  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/clog2_repair.exe
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_print.no -c clog_print.c
cp -f clog_print.no mpe2tmp1.o
gcc  -O2  -o /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/clog2_print.exe mpe2tmp1.o \
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_join.no -c clog_join.c
cp -f clog_join.no mpe2tmp2.o
gcc  -O2  -o /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/clog2_join.exe mpe2tmp2.o \
gcc -I.. -I../../..  -I../include -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include -I../../../include -O2  -DCLOG_NOMPI -o clog_repair.no -c clog_repair.c
cp -f clog_repair.no mpe2tmp3.o
gcc  -O2  -o /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/bin/clog2_repair.exe mpe2tmp3.o \
**** Making src/wrappers ....
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c log_mpi_util.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c log_mpi_core.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c trace_mpi_core.c
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/liblmpe.a
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/liblmpe.a log_mpi_util.o log_mpi_core.o
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/liblmpe.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libtmpe.a
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libtmpe.a trace_mpi_core.o
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libtmpe.a
/cygdrive/c/cygwin/mpich2-1.4/bin/mpif77   -c mpi_f2c_consts.f
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c mpe_proff.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_f2cmpi.a mpi_f2c_consts.o log_mpi_util.o mpe_proff.o
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_f2cmpi.a
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/mpe_prof.o
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c mpe_prof.c
make --no-print-directory  linktest_all
make --no-print-directory  linktest_C
make --no-print-directory  linktest_F77
**** Making src/graphics ....
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o mpe_graphics.no -c mpe_graphics.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xcolor.no -c xcolor.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xframe.no -c xframe.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xinit.no -c xinit.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xwmap.no -c xwmap.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xmouse.no -c xmouse.c
gcc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include  -O2  -DMPE_NOMPI -o xkey.no -c xkey.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o mpe_graphics.po -c mpe_graphics.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xcolor.po -c xcolor.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xframe.po -c xframe.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xinit.po -c xinit.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xwmap.po -c xwmap.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xmouse.po -c xmouse.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xkey.po -c xkey.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o visual_mess.po -c visual_mess.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_nompi.a mpe_graphics.no xcolor.no xframe.no xinit.no xwmap.no xmouse.no xkey.no
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe.a mpe_graphics.po xcolor.po xframe.po xinit.po xwmap.po xmouse.po xkey.po
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o mpe_graphicsf.po -c mpe_graphicsf.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include    -o xmousef.po -c xmousef.c
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libampe.a
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libampe.a visual_mess.po
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libampe.a
**** Making src/collchk ....
make --no-print-directory  /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_collchk.a
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c err_han.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c is_init.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c check_buff.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c check_dims.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c check_graph.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c check_size.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_amode.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_call.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_dtype.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_high_low.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_int.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_local_leader.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_op.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_root.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_tag.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_datarep.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c same_whence.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c allgather.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c allgatherv.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c allreduce.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c alltoall.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c alltoallv.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c barrier.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c bcast.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c cart_create.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c cart_map.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c gather.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c gatherv.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c graph_create.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c graph_map.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c init.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c intercomm_create.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c intercomm_merge.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c reduce.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c reduce_scatter.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c scan.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c scatter.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c scatterv.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c finalize.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c exscan.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c alltoallw.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_open.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_preallocate.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_all_begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_all.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_all_end.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_at_all_begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_at_all.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_at_all_end.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_ordered_begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_ordered.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_read_ordered_end.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_seek_shared.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_set_atomicity.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_set_size.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_set_view.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_all_begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_all.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_all_end.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_at_all_begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_at_all.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_at_all_end.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_ordered_begin.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_ordered.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c file_write_ordered_end.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c add_fh.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c get_fh.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c win_create.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c win_fence.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c add_win.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c get_win.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_accept.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_connect.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_create.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_disconnect.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_dup.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_spawn.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_spawn_multiple.c
/cygdrive/c/cygwin/mpich2-1.4/bin/mpicc -I.. -I../include  -I/cygdrive/c/cygwin/mpich2-1.4/src/mpe2/include  -I../../.. -I../../../include   -c comm_split.c
ar cr /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_collchk.a *.o
ranlib /cygdrive/c/cygwin/mpich2-1.4/src/mpe2/lib/libmpe_collchk.a
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpe2'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pmi'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pmi/smpd'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pmi/smpd'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pmi'
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/mem'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/util/mem'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd/sock'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd/sock/poll'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd/sock/poll'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd/sock'
make all-local
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd'
gcc -O2   -o mpiexec mpiexec.o mp_parse_command_line.o \
mp_parse_oldconfig.o mpiexec_rsh.o  -L../../../lib -L/cygdrive/c/cygwin/mpich2-1.4/lib -lmpich \
-lmpl -lcrypto -luuid -lpthread
gcc -O2   -o smpd smpd.o smpd_cmd_args.o smpd_watchprocs.o  \
-L../../../lib -L/cygdrive/c/cygwin/mpich2-1.4/lib -lmpich -lmpl -lcrypto -luuid -lpthread
make all-postamble
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd'
make[5]: Nothing to be done for `all-postamble'.
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm/smpd'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/pm'
make all-postamble
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src'
for dir in mpl openpa ; do \
    (cd $dir && make prefix=/cygdrive/c/cygwin/mpich2-1.4 exec_prefix=/cygdrive/c/cygwin/mpich2-1.4 \
    bindir=/cygdrive/c/cygwin/mpich2-1.4/bin libdir=/cygdrive/c/cygwin/mpich2-1.4/lib \
    includedir=/cygdrive/c/cygwin/mpich2-1.4/include docdir=/cygdrive/c/cygwin/mpich2-1.4/share/doc install) ; \
done
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
test -z "/cygdrive/c/cygwin/mpich2-1.4/lib" || /usr/bin/mkdir -p "/cygdrive/c/cygwin/mpich2-1.4/lib"
 /bin/sh ./libtool   --mode=install /usr/bin/install -c   libmpl.la '/cygdrive/c/cygwin/mpich2-1.4/lib'
libtool: install: /usr/bin/install -c .libs/libmpl.lai /cygdrive/c/cygwin/mpich2-1.4/lib/libmpl.la
libtool: install: /usr/bin/install -c .libs/libmpl.a /cygdrive/c/cygwin/mpich2-1.4/lib/libmpl.a
libtool: install: chmod 644 /cygdrive/c/cygwin/mpich2-1.4/lib/libmpl.a
libtool: install: ranlib /cygdrive/c/cygwin/mpich2-1.4/lib/libmpl.a
libtool: install: warning: remember to run `libtool --finish /usr/local/lib'
make[4]: Nothing to be done for `install-data-am'.
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/mpl'
make[3]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
Making install in src
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
 /bin/sh ../libtool   --mode=install /usr/bin/install -c   libopa.la '/cygdrive/c/cygwin/mpich2-1.4/lib'
libtool: install: /usr/bin/install -c .libs/libopa.lai /cygdrive/c/cygwin/mpich2-1.4/lib/libopa.la
libtool: install: /usr/bin/install -c .libs/libopa.a /cygdrive/c/cygwin/mpich2-1.4/lib/libopa.a
libtool: install: chmod 644 /cygdrive/c/cygwin/mpich2-1.4/lib/libopa.a
libtool: install: ranlib /cygdrive/c/cygwin/mpich2-1.4/lib/libopa.a
test -z "/cygdrive/c/cygwin/mpich2-1.4/include" || /usr/bin/mkdir -p "/cygdrive/c/cygwin/mpich2-1.4/include"
 /usr/bin/install -c -m 644 opa_config.h opa_primitives.h opa_queue.h opa_util.h '/cygdrive/c/cygwin/mpich2-1.4/include'
/usr/bin/mkdir -p '/cygdrive/c/cygwin/mpich2-1.4/include/primitives'
 /usr/bin/install -c -m 644  primitives/opa_by_lock.h primitives/opa_emulated.h primitives/opa_gcc_ia64.h primitives/opa_gcc_intel_32_64.h primitives/opa_gcc_intel_32_64_barrier.h primitives/opa_gcc_intel_32_64_ops.h primitives/opa_gcc_intel_32_64_p3.h primitives/opa_gcc_intel_32_64_p3barrier.h primitives/opa_gcc_intrinsics.h primitives/opa_gcc_ppc.h primitives/opa_gcc_sicortex.h primitives/opa_nt_intrinsics.h primitives/opa_sun_atomic_ops.h primitives/opa_unsafe.h '/cygdrive/c/cygwin/mpich2-1.4/include/primitives'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/src'
Making install in test
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[5]: Nothing to be done for `install-exec-am'.
make[5]: Nothing to be done for `install-data-am'.
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa/test'
make[4]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[5]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
test -z "/cygdrive/c/cygwin/mpich2-1.4/share/doc" || /usr/bin/mkdir -p "/cygdrive/c/cygwin/mpich2-1.4/share/doc"
 /usr/bin/install -c -m 644 README '/cygdrive/c/cygwin/mpich2-1.4/share/doc'
test -z "/cygdrive/c/cygwin/mpich2-1.4/lib/pkgconfig" || /usr/bin/mkdir -p "/cygdrive/c/cygwin/mpich2-1.4/lib/pkgconfig"
 /usr/bin/install -c -m 644 openpa.pc '/cygdrive/c/cygwin/mpich2-1.4/lib/pkgconfig'
make[5]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[4]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[3]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src/openpa'
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src'
make[1]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/src'
make all-postamble
( cd examples && make )
make[2]: Entering directory `/cygdrive/c/cygwin/mpich2-1.4/examples'
../bin/mpicc   -o cpi cpi.o  -lm
make[2]: Leaving directory `/cygdrive/c/cygwin/mpich2-1.4/examples'
Make completed
