[mpich-discuss] unable to connect in 2 windows machines
Jayesh Krishna
jayesh at mcs.anl.gov
Tue Jul 17 16:35:08 CDT 2012
What is the output that you get when you run cpi (mpiexec -hosts 2 10.222.233.223 10.222.233.189 C:\Progra~1\MPICH2\examples\cpi.exe)?
Jayesh
----- Original Message -----
From: "Sinta Kartika Maharani" <sintakm114080010 at gmail.com>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Monday, July 16, 2012 10:53:37 PM
Subject: Re: [mpich-discuss] unable to connect in 2 windows machines
Hi.
I have recompile the code.
I have copy the same executable on both machine.
The OS on the both machine is Win7 Ultimate 32 bit.
But still have the same error
Any suggestion?
2012/7/12 Jayesh Krishna <jayesh at mcs.anl.gov>:
> Hi,
> The extra information is helpful in debugging. Thanks.
> Did you re-compile the code and copy the same executable on both the machines?
> Are both machines 64-bit (or 32-bit)? MPICH2 jobs do not work across 32-bit and 64-bit machines.
> Regards,
> Jayesh
> To: mpich-discuss at mcs.anl.gov
> Sent: Monday, July 9, 2012 9:23:12 AM
> Subject: [mpich-discuss] unable to connect in 2 windows machines
> Hi. I'm sorry if I'm asking too many times. :)
> I'm getting problem when trying to executes a program in 2 windows
> machines. I've following the rules below :
> 1. The both machines have the same username and password.
> 2. Both machines have the same version of mpich2, 1.4.1p1
> 3. The ping works fine (the ip numbers : 10.222.233.223 and 10.222.233.189)
> 4. no firewalls in both machines.
> 5. The registering and validating process is successful.
> 6. from 10.222.233.223
> C:\Program Files\MPICH2\bin>mpiexec -hosts 2 10.222.233.223
> 10.222.233.189 hostname
> sinta-PC
> sinta-PC
> from 10.222.233.189
> sinta-PC
> sinta-PC
> 7. the domain and username : sinta-pc/sinta
> But when try executing :
> 10.222.233.189 konvensional random 4
> Fatal error in MPI_Init: Other MPI error, error stack:
> MPIR_Init_thread(392).................:
> MPID_Init(139)........................: channel initialization failed
> MPIDI_CH3_Init(38)....................:
> MPID_nem_init(196)....................:
> MPIDI_CH3I_Seg_commit(366)............:
> MPIU_SHMW_Hnd_deserialize(324)........:
> MPIU_SHMW_Seg_open(863)...............:
> MPIU_SHMW_Seg_create_attach_templ(763): unable to allocate shared
> memory - OpenFileMapping The system cannot find the file specified.
> job aborted:
> rank: node: exit code[: error message]
> 0: 10.222.233.223: 123
> 1: 10.222.233.189: 1: process 1 exited without calling finalize
> any suggestions?
> Thanks anyway
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
