[mpich-discuss] Memory leaks using ROMIO
Akram Smaali akram.smaali at gmail.com
Fri Jul 13 02:55:15 CDT 2012
---------- Forwarded message ----------
Date: 2012/7/12
Subject: Re: [mpich-discuss] Memory leaks using ROMIO
To: Jayesh Krishna <jayesh at mcs.anl.gov>
I think that, as Rob latham said, it's caused by ntfs. I was looking into
the source code of ROMIO but i didn't see anything indicating that. I
suppose that the OS doesn't get back the allocated buffer from the user
space.
# Does the system memory decrease after a period of time?
No, it does just at the end.
# Does the memory increase correspond to the amount of data written?
Yes excactly the amount of data written.
# How much does the memory increase?
i use a 5GB file so it increase that much.
# Do you see similar behavior with a simple Windows program
(CreateFileMapping() + WriteFile() + CloseHandle())?
It just happens with the MPI_File_read_at()
2012/7/12 Jayesh Krishna <jayesh at mcs.anl.gov>
> Hi,
>  Windows is known to delay writes even after the user is done with the
> file (I have seen similar issues before. Your problem could be different
> though.).
> Regards,
> Jayesh
> From: "Rob Latham" <robl at mcs.anl.gov>
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, July 12, 2012 11:09:50 AM
> On Thu, Jul 12, 2012 at 01:29:38PM +0200, Akram Smaali wrote:
> > Hello,
> > i'm using mpich2 in a C program that reads several buffers from a data
> text
> > files.
> > I noticed that even when i free the buffer at the end, the global memory
> > usage still increase but the memory usage per process still the same.
> > I changed the MPI_File_read_at() with fseek/fread and the problem has
> > dissapeared.
> > I'm wondering if that i should do some extra instriuctions to avoid that
> > because it seems that  mpi_read allocate an intermediate buffer for
> reading
> > (sieving optimization maybe) from the user space memory and the OS (
> > windosws 7) don't get it back.
> > i'm using MPICH2 1.4 on w windows 7 with NTFS file system.
> It might be an NTFS-specific leak.  I don't see any leaks on my linux
> system (ad_ufs).
> > Thank you for your help.
> > here is my code :
> It would be great if you could make this case more self contained.
> Whatever offsets are in your Dictionary file, put those in an array
> and broadcast that.
> > #include <stdio.h>
> > #include <stdlib.h>
> > #include <mpi.h>
> > #include <omp.h>
> > #include <string.h>
> > #include <time.h>
> > #include "queue.h"
> > #include "KhiopsNativeInterface.h"
> > #include <windows.h>
> > #define maxLength 100000
> > double CPUtime(){ return ((double) clock())/CLOCKS_PER_SEC;}
> > int main(int argc, char* argv []){
> > if(argc != 5) {
> > printf("\t[Dictionary file] [Dictionary] [Input file] [Buffer size]\n");
> > exit(0);
> > char* sDictionaryFileName   = argv[1];
> > char* sDictionaryName =   argv[2];
> > char* filename = argv[3];
> > int Mbuffer =   atoi(argv[4]);
> > int maxBuffer = Mbuffer*1024*1024;
> > int over   = 10000;
> > int rank,numprocess;
> > long int offset;
> > char* buffer;
> > char* opbuffer;
> > double tstart=CPUtime();
> > MPI_Init( &argc, &argv );
> > MPI_Comm_rank( MPI_COMM_WORLD, &rank );
> > /* mpi version */
> > /* open the file*/
> > MPI_File fh;
> > int err;
> >     err = MPI_File_open(MPI_COMM_WORLD, filename, MPI_MODE_RDONLY,
> > MPI_INFO_NULL, &fh);
> >     if (err != MPI_SUCCESS) {
> >         char errstr[MPI_MAX_ERROR_STRING];
> >         int  errlen;
> >         MPI_Error_string(err, errstr, &errlen);
> >         printf("Error at opening file %s (%s)\n",filename,errstr);
> >         MPI_Finalize();
> >         exit(1);
> > // get offsets and buffer size
> > MPI_Offset sfile;
> >     MPI_File_get_size(fh,&sfile);
> >     MPI_Status status;
> >     /* C version */
> > /*FILE* fh;
> > long int sfile;
> >     fh =fopen( filename,"rb");
> >     if (fh==NULL) {
> >         printf("Error at opening file %s\n",filename);
> >         exit(1);
> >     fseek(fh, 0L, SEEK_END);
> >     sfile = ftell(fh);
> >     fseek(fh, 0L, SEEK_SET);*/
> > MPI_Comm_size( MPI_COMM_WORLD, &numprocess );
> > /* number of iterations */
> > long int data_size = (long int)(sfile/(numprocess));
> > int nbIter = data_size/maxBuffer;
> > if(nbIter<=1){
> > nbIter = 1;
> > maxBuffer = data_size;
> > /* offsets */
> > offset = data_size*(rank);
> > long int cursor = offset;
> > char* header;
> > if(rank==0){
> > FILE* fh;
> >     if (fh==NULL) {
> >         exit(1);
> > /* read the header and broadcast it */
> > header = malloc(sizeof(char)*1000);
> > fgets(header,1000,fh);
> > fclose(fh);
> > //broadcast header
> > int sndHeader = strlen(header);
> > //cursor+=sndHeader;
> > int process_counter;
> > for(process_counter=1;process_counter<numprocess;process_counter++){
> > int ierr = MPI_Send(&sndHeader,sizeof(int), MPI_INT, process_counter,
> > 42,MPI_COMM_WORLD);
> > if (ierr != MPI_SUCCESS) {
> > int errclass,resultlen;
> > char err_buffer[MPI_MAX_ERROR_STRING];
> > MPI_Error_class(ierr,&errclass);
> > if (errclass== MPI_ERR_RANK) {
> > fprintf(stderr,"Invalid rank used in MPI send call\n");
> > MPI_Error_string(ierr,err_buffer,&resultlen);
> > fprintf(stderr,err_buffer);
> > MPI_Finalize();
> > MPI_Send(header, sndHeader, MPI_CHAR, process_counter, 43,
> MPI_COMM_WORLD);
> > else{
> >     /* receive the header */
> >     int sizeofHeader;
> > MPI_Status s ;
> > MPI_Recv(&sizeofHeader,sizeof(int),MPI_INT,0,42,MPI_COMM_WORLD,&s);
> > header = malloc (sizeof(char)*sizeofHeader+1);
> > MPI_Recv(header,sizeofHeader,MPI_CHAR,0,43,MPI_COMM_WORLD,&s);
> > /* Synchronization barrier */
> > MPI_Barrier(MPI_COMM_WORLD);
> > int count;
> > opbuffer = malloc(sizeof(char)*maxBuffer);
> > /* C version */
> > //fseek(fh,cursor,SEEK_SET);
> > for(count=0;count<nbIter;count++){
> > if(count==0 && rank==numprocess-1){ //init ring
> > //send the token to p0
> > int token=1;
> > MPI_Send(&token,sizeof(int),MPI_INT,0,55,MPI_COMM_WORLD);
> > //recv
> > int token;
> > int sender;
> > if(rank==0)
> > sender = numprocess-1;
> > else
> > sender=rank-1;
> > MPI_Status s;
> > MPI_Recv(&token,sizeof(int),MPI_INT,sender,55,MPI_COMM_WORLD,&s);
> > fflush(stdout);printf("P%d got the token at %G\n",rank,CPUtime());
> > //read
> > double start=CPUtime();
> > /*double readtime;
> > double sread=CPUtime();//read time*/
> > //read
> > if(token==1){
> > /* MPI version */
> > int err=MPI_File_read_at(fh, cursor,opbuffer,  sizeof(char)*maxBuffer,
> > MPI_CHAR, &status);
> > if(err!=MPI_SUCCESS){
> >         int  errlen;
> >         printf("Error reading file %s (%s)\n",filename,errstr);
> > MPI_Finalize();
> > exit(0);
> > /* C version of read */
> > /*int k=fread(opbuffer,sizeof(char),maxBuffer,fh);
> > if(k==0)
> > perror("fread");*/
> > cursor+=maxBuffer;
> > buffer=opbuffer;
> > else{
> > printf("Error token!\n");
> > token=1;
> > //printf("P%d readtime=%G\n",rank,CPUtime()-sread);
> > //Isend
> > int next = (rank+1)%numprocess;
> > MPI_Send(&token,sizeof(int),MPI_INT,next,55,MPI_COMM_WORLD);
> > //i perform processing buffer here!
> > free(opbuffer);
> > /* mpi version */
> > int er=MPI_File_close(&fh);
> > if(er!=MPI_SUCCESS){
> > printf("Error closing file\n");
> > MPI_Finalize();
> > exit(1);
> > /* c version */
> > //fclose(fh);
> > MPI_Finalize();
> > printf("Global time : %G\n",CPUtime()-tstart);
> > return 0;
> > Best Regards
> > _______________________________________________
> > mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
*Akram SMAALI*
Ingénieur stagiaire à France Télécom R&D
22300 Lannion, France
*mobile: +33 7 51 13 39 11 *
*mail:* akram.smaali at gmail.com
*Akram SMAALI*
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120713/02e2fb70/attachment-0001.html>
