[mpich-discuss] Configure error 77
Darius Buntinas buntinas at mcs.anl.gov
Tue Jul 10 11:24:50 CDT 2012
There are two problems that I see.  The first one, that's causing the failure, is the "-c" option in CFLAGS.  With that flag, the compiler will never create an executable, so configure will always fail.  The build system will add a -c as necessary so you don't need that there.
The second is that you specified g++ as your c preprocessor (CPP).  I think you meant CXX:
  setenv CXX        /usr/local/bin/g++
-d
On Jul 10, 2012, at 9:44 AM, BAKER, MYLES D. (LARC-E302) wrote:
> Dear Pavan,
> I have tried to compile a simple hello world program using
> > $CC $CFLAGS hello.c
> The result is a simple object file hello.o with the following properties:
> hello.o: ELF 64-bit MSB relocatable, 64-bit PowerPC or cisco 7500, version 1 (SYSV), not stripped
> So, these flags don't produce an executable (the -c option in CFLAGS prevents linking).
> The default flags that are sourced look like this:
> # Compiler locations and default flags #
> setenv CC         /usr/local/bin/gcc
> setenv CPP        /usr/local/bin/g++
> setenv CFLAGS     '-c -m64 -mcpu=power6 -DLINUX -D_LP64'
> setenv XLF_ROOT_DIR /SPG_ops/utils/ppc64/xlf/11.1
> setenv XLF	  $XLF_ROOT_DIR/bin/xlf90
> setenv CLOAD	"-m64"
> setenv F90        $XLF
> setenv XLFF90     $XLF
> setenv F90COMP    '-qxlf90=nosignedzero,autodealloc -O2 -qmaxmem=65536 -c -qextname -qsuffix=f=f90 -q64 -qwarn64 -qinit=f90ptr'
> setenv FCOMP      '-qxlf90=nosignedzero,autodealloc -O2 -qmaxmem=32768 -c -qextname -qfixed=80 -q64 -qwarn64'
> setenv F77	$XLF_ROOT_DIR/bin/f77
> setenv FFLAGS     '-O2 -c -qextname -q64 -qwarn64'
> setenv F90LOAD    '-q64 -static'
> setenv F90LIBDIR  "-L$XLF_ROOT_DIR/lib64"
> setenv F90LIB	   "$F90LIBDIR -lxlf90 -lxlfmath -lxl"
> setenv F90SWAP    ''
> setenv LD_LIBRARY_PATH "${XLF_ROOT_DIR}/lib64:${LD_LIBRARY_PATH}"
> #setenv ADA        'gcc'
> #setenv ADACOMP    ''
> We use the FFLAGS when we only need the object code and the F/F90COMP flags when we need an executable file.
> What is MPICH trying to do during these configuration tests? Should I not source the default compilation flags when configuring MPICH?
> Thanks,
> Myles
>>>> [please keep mpich-discuss cc'ed]
>>>> The CFLAGS are causing your C compiler to fail.  This is not an MPICH
>>>> problem.  Try compiling a simple C program with these CFLAGS.
>>>> -- Pavan
>>>> On 07/10/2012 09:19 AM, BAKER, MYLES D. (LARC-E302) wrote:
>>>>> Pavan,
>>>>> Those are the default flags that are used to compile C programs in the
>>>>> software project that I work on. I don't do very much C development and
>>>>> the code that I am developing is not in C, but I would like to refrain
>>>>> from changing those setting if I can. Why is CFLAGS causing this to fail?
>>>>> Thanks,
>>>>> Myles
>>>>> *BAKER, MYLES D. (LARC-E302)*
>>>>> *Mail Stop 420, B1250 R177
>>>>> myles.d.baker at nasa.gov <mailto:myles.d.baker at nasa.gov>
>>>>> LaRC Ext:  x46393
>>>>> On Jul 10, 2012, at 10:11 AM, Pavan Balaji wrote:
>>>>>> It looks like you have CFLAGS and other variables set in your
>>>>>> environment.  Is that intentional?  If not, try unsetting them.
>>>>>> -- Pavan
>>>>>> On 07/10/2012 09:06 AM, BAKER, MYLES D. (LARC-E302) wrote:
>>>>>>> Dear all,
>>>>>>> I am installing mpich2-1.4.1p1 locally on a cluster that I do not have
>>>>>>> root permissions. I am following along with the v1.4.1 installer's
>>>>>>> guide
>>>>>>> and the guidelines posted here:
>>>>>>> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2012-July/012752.html
>>>>>>> After decompressing the file I try to configure the installation
>>>>>>> pointing to the installation directory (tcsh):
>>>>>>>> cd $HOME/mpi/mpich2-1.4.1p1
>>>>>>>> ./configure --prefix=$HOME/mpi/mpich2-1.4.1p1 --enable-shared
>>>>>>> but the configuration fails with the following errors:
>>>>>>> Configuring MPICH2 version 1.4.1p1 with
>>>>>>> '--prefix=/homedir/mdbaker2/mpi/mpich2-1.4.1p1'
>>>>>>> 'CC=/usr/local/bin/gcc' 'CFLAGS=-c -m64 -mcpu=power6 -DLINUX -D_LP64'
>>>>>>> 'CPP=/usr/local/bin/g++' 'F77=/SPG_ops/utils/ppc64/xlf/11.1/bin/f77'
>>>>>>> 'FFLAGS=-O2 -c -qextname -q64 -qwarn64'
>>>>>>> Running on system: Linux tisa2-blue 2.6.16.60-0.42.9-ppc64 #1 SMP Thu
>>>>>>> Jan 28 23:39:37 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
>>>>>>> checking for C compiler default output file name...
>>>>>>> configure: error: in `/homedir/mdbaker2/mpi/mpich2-1.4.1p1':
>>>>>>> configure: error: C compiler cannot create executables
>>>>>>> See `config.log' for more details.
>>>>>>> Most of my development will be done in Fortran so I need the F77
>>>>>>> and F90
>>>>>>> bindings, and my gcc, g++, and gfortran compilers are located in
>>>>>>> /usr/bin. However, I use the IBM XLF compiler so my F77 and F90 env
>>>>>>> variables point to another location, which the configuration executable
>>>>>>> seems to find just fine (the locations match up to my env file).
>>>>>>> In the core tests I see that the error seems to come from my CFLAGS
>>>>>>> variable. Does this correct? Can anyone give me some direction? I have
>>>>>>> attached the full configuration file below.
>>>>>>> Thanks,
>>>>>>> Myles
>>>>>>> Here is the full config.log file:
>>>>>>> This file contains any messages produced by compilers while
>>>>>>> running configure, to aid debugging if configure makes a mistake.
>>>>>>> It was created by configure, which was
>>>>>>> generated by GNU Autoconf 2.63.  Invocation command line was
>>>>>>> $ ./configure --prefix=/homedir/mdbaker2/mpi/mpich2-1.4.1p1
>>>>>>> ## Platform. ##
>>>>>>> hostname = tisa2-blue
>>>>>>> uname -m = ppc64
>>>>>>> uname -r = 2.6.16.60-0.42.9-ppc64
>>>>>>> uname -s = Linux
>>>>>>> uname -v = #1 SMP Thu Jan 28 23:39:37 UTC 2010
>>>>>>> /usr/bin/uname -p = unknown
>>>>>>> /bin/uname -X     = unknown
>>>>>>> /bin/arch              = ppc64
>>>>>>> /usr/bin/arch -k       = unknown
>>>>>>> /usr/convex/getsysinfo = unknown
>>>>>>> /usr/bin/hostinfo      = unknown
>>>>>>> /bin/machine           = unknown
>>>>>>> /usr/bin/oslevel       = unknown
>>>>>>> /bin/universe          = unknown
>>>>>>> PATH: /SPG_ops/utils/univa/bin/lx-ppc64
>>>>>>> PATH: /SPG_ops/utils/ppc64/FileZilla/FileZilla-3.1.0.1/bin
>>>>>>> PATH: /usr/bin
>>>>>>> PATH: /bin
>>>>>>> PATH: /usr/sbin
>>>>>>> PATH: /sbin
>>>>>>> PATH: /usr/games
>>>>>>> PATH: /opt/gnome/bin
>>>>>>> PATH: /usr/bin/X11
>>>>>>> PATH: /usr/lib/mit/bin
>>>>>>> PATH: /usr/lib/mit/sbin
>>>>>>> PATH:
>>>>>>> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/bin/linux
>>>>>>> PATH:
>>>>>>> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/hdf/linux64/HDF4.2r4/bin
>>>>>>> PATH:
>>>>>>> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/zlib/linux64/zlib-1.2.3/zlib/bin
>>>>>>> PATH:
>>>>>>> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/jpeg/linux64/jpeg-6b/bin
>>>>>>> PATH:
>>>>>>> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/hdf5/linux64/hdf5-1.8.3/bin
>>>>>>> PATH:
>>>>>>> /SPG_ops/utils/CERES/TOOLKIT/scf_toolkit5.2.16v1-gcc-xlf/TOOLKIT/szip/linux64/szip-2.1/szip/bin
>>>>>>> PATH: /usr/local/bin
>>>>>>> PATH: /etc
>>>>>>> PATH: /usr/etc
>>>>>>> PATH: /usr/X11/bin
>>>>>>> PATH: /usr/local/bin/
>>>>>>> PATH: /usr/sbin/
>>>>>>> PATH: /usr/local/R/bin/
>>>>>>> PATH: /homedir/mdbaker2/bin
>>>>>>> ## Core tests. ##
>>>>>>> configure:3182: checking for C compiler version
>>>>>>> configure:3190: /usr/local/bin/gcc --version >&5
>>>>>>> gcc (GCC) 4.2.2
>>>>>>> Copyright (C) 2007 Free Software Foundation, Inc.
>>>>>>> This is free software; see the source for copying conditions.  There
>>>>>>> is NO
>>>>>>> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
>>>>>>> PURPOSE.
>>>>>>> configure:3194: $? = 0
>>>>>>> configure:3201: /usr/local/bin/gcc -v >&5
>>>>>>> Using built-in specs.
>>>>>>> Target: powerpc64-linux
>>>>>>> Configured with: ../configure --prefix=/SPG_ops/utils/ppc64
>>>>>>> --build=powerpc64-linux --host=powerpc64-linux --target=powerpc64-linux
>>>>>>> --with-cpu=default64 --with-as=/usr/bin/as --with-ld=/usr/bin/ld
>>>>>>> --enable-threads=posix --enable-shared --enable-__cxa_atexit
>>>>>>> --enable-checking --with-mpfr=/SPG_ops/utils/ppc64
>>>>>>> --enable-languages=c,c++
>>>>>>> Thread model: posix
>>>>>>> gcc version 4.2.2
>>>>>>> configure:3205: $? = 0
>>>>>>> configure:3212: /usr/local/bin/gcc -V >&5
>>>>>>> gcc: '-V' option must have argument
>>>>>>> configure:3216: $? = 1
>>>>>>> configure:3239: checking for C compiler default output file name
>>>>>>> configure:3261: /usr/local/bin/gcc -c -m64 -mcpu=power6 -DLINUX -D_LP64
>>>>>>>    conftest.c   >&5
>>>>>>> configure:3265: $? = 0
>>>>>>> configure:3303: result:
>>>>>>> configure: failed program was:
>>>>>>> | /* confdefs.h.  */
>>>>>>> | #define PACKAGE_NAME ""
>>>>>>> | #define PACKAGE_TARNAME ""
>>>>>>> | #define PACKAGE_VERSION ""
>>>>>>> | #define PACKAGE_STRING ""
>>>>>>> | #define PACKAGE_BUGREPORT ""
>>>>>>> | #define USE_SMP_COLLECTIVES 1
>>>>>>> | /* end confdefs.h.  */
>>>>>>> | int
>>>>>>> | main ()
>>>>>>> |   return 0;
>>>>>>> configure:3309: error: in `/homedir/mdbaker2/mpi/mpich2-1.4.1p1':
>>>>>>> configure:3312: error: C compiler cannot create executables
>>>>>>> ## Cache variables. ##
>>>>>>> ac_cv_env_AR_FLAGS_set=
>>>>>>> ac_cv_env_AR_FLAGS_value=
>>>>>>> ac_cv_env_CCC_set=
>>>>>>> ac_cv_env_CCC_value=
>>>>>>> ac_cv_env_CC_set=set
>>>>>>> ac_cv_env_CC_value=/usr/local/bin/gcc
>>>>>>> ac_cv_env_CFLAGS_set=set
>>>>>>> ac_cv_env_CFLAGS_value='-c -m64 -mcpu=power6 -DLINUX -D_LP64'
>>>>>>> ac_cv_env_CPPFLAGS_set=
>>>>>>> ac_cv_env_CPPFLAGS_value=
>>>>>>> ac_cv_env_CPP_set=set
>>>>>>> ac_cv_env_CPP_value=/usr/local/bin/g++
>>>>>>> ac_cv_env_CXXCPP_set=
>>>>>>> ac_cv_env_CXXCPP_value=
>>>>>>> ac_cv_env_CXXFLAGS_set=
>>>>>>> ac_cv_env_CXXFLAGS_value=
>>>>>>> ac_cv_env_CXX_set=
>>>>>>> ac_cv_env_CXX_value=
>>>>>>> ac_cv_env_F77_set=set
>>>>>>> ac_cv_env_F77_value=/SPG_ops/utils/ppc64/xlf/11.1/bin/f77
>>>>>>> ac_cv_env_FCFLAGS_set=
>>>>>>> ac_cv_env_FCFLAGS_value=
>>>>>>> ac_cv_env_FC_set=
>>>>>>> ac_cv_env_FC_value=
>>>>>>> ac_cv_env_FFLAGS_set=set
>>>>>>> ac_cv_env_FFLAGS_value='-O2 -c -qextname -q64 -qwarn64'
>>>>>>> ac_cv_env_FROM_MPICH2_set=
>>>>>>> ac_cv_env_FROM_MPICH2_value=
>>>>>>> ac_cv_env_LDFLAGS_set=
>>>>>>> ac_cv_env_LDFLAGS_value=
>>>>>>> ac_cv_env_LIBS_set=
>>>>>>> ac_cv_env_LIBS_value=
>>>>>>> ac_cv_env_MPICH2LIB_CFLAGS_set=
>>>>>>> ac_cv_env_MPICH2LIB_CFLAGS_value=
>>>>>>> ac_cv_env_MPICH2LIB_CPPFLAGS_set=
>>>>>>> ac_cv_env_MPICH2LIB_CPPFLAGS_value=
>>>>>>> ac_cv_env_MPICH2LIB_CXXFLAGS_set=
>>>>>>> ac_cv_env_MPICH2LIB_CXXFLAGS_value=
>>>>>>> ac_cv_env_MPICH2LIB_FCFLAGS_set=
>>>>>>> ac_cv_env_MPICH2LIB_FCFLAGS_value=
>>>>>>> ac_cv_env_MPICH2LIB_FFLAGS_set=
>>>>>>> ac_cv_env_MPICH2LIB_FFLAGS_value=
>>>>>>> ac_cv_env_MPICH2LIB_LDFLAGS_set=
>>>>>>> ac_cv_env_MPICH2LIB_LDFLAGS_value=
>>>>>>> ac_cv_env_MPICH2LIB_LIBS_set=
>>>>>>> ac_cv_env_MPICH2LIB_LIBS_value=
>>>>>>> ac_cv_env_build_alias_set=
>>>>>>> ac_cv_env_build_alias_value=
>>>>>>> ac_cv_env_host_alias_set=
>>>>>>> ac_cv_env_host_alias_value=
>>>>>>> ac_cv_env_target_alias_set=
>>>>>>> ac_cv_env_target_alias_value=
>>>>>>> pac_cv_my_conf_dir=/homedir/mdbaker2/mpi/mpich2-1.4.1p1
>>>>>>> ## Output variables. ##
>>>>>>> ABIVERSION='3:3'
>>>>>>> ADDRESS_KIND=''
>>>>>>> ALLOCA=''
>>>>>>> AR=''
>>>>>>> AR_FLAGS=''
>>>>>>> BASH_SHELL=''
>>>>>>> BSEND_OVERHEAD=''
>>>>>>> BUILD_BASH_SCRIPTS=''
>>>>>>> BUILD_DLLS=''
>>>>>>> BUILD_TVDLL=''
>>>>>>> CC='/usr/local/bin/gcc'
>>>>>>> CC_SHL=''
>>>>>>> CC_SHL_DBG=''
>>>>>>> CFLAGS='-c -m64 -mcpu=power6 -DLINUX -D_LP64 '
>>>>>>> CMB_1INT_ALIGNMENT=''
>>>>>>> CMB_STATUS_ALIGNMENT=''
>>>>>>> CONFIGURE_ARGS_CLEAN='--prefix=/homedir/mdbaker2/mpi/mpich2-1.4.1p1'
>>>>>>> CONFIGURE_ARGUMENTS='
>>>>>>> '\''--prefix=/homedir/mdbaker2/mpi/mpich2-1.4.1p1'\''
>>>>>>> '\''CC=/usr/local/bin/gcc'\'' '\''CFLAGS=-c -m64 -mcpu=power6 -DLINUX
>>>>>>> -D_LP64'\'' '\''CPP=/usr/local/bin/g++'\''
>>>>>>> '\''F77=/SPG_ops/utils/ppc64/xlf/11.1/bin/f77'\'' '\''FFLAGS=-O2 -c
>>>>>>> -qextname -q64 -qwarn64'\'''
>>>>>>> CPP='/usr/local/bin/g++'
>>>>>>> CPPFLAGS=' '
>>>>>>> CREATESHLIB=''
>>>>>>> CXX=''
>>>>>>> CXXCPP=''
>>>>>>> CXXFLAGS=' '
>>>>>>> CXX_DEFS=''
>>>>>>> CXX_LINKPATH_SHL=''
>>>>>>> CXX_SHL=''
>>>>>>> C_LINKPATH_SHL=''
>>>>>>> C_LINK_SHL=''
>>>>>>> C_LINK_SHL_DBG=''
>>>>>>> DBG_SHLIB_TYPE=''
>>>>>>> DEFS=''
>>>>>>> DEVICE=''
>>>>>>> DEVICE_ARGS=''
>>>>>>> DEVICE_NAME=''
>>>>>>> DLLIMPORT=''
>>>>>>> DOCTEXT=''
>>>>>>> DOCTEXTSTYLE=''
>>>>>>> ECHO_C=''
>>>>>>> ECHO_N='-n'
>>>>>>> ECHO_T=''
>>>>>>> EGREP=''
>>>>>>> ENABLE_SHLIB=''
>>>>>>> EXEEXT=''
>>>>>>> EXTERNAL_SRC_DIRS=''
>>>>>>> EXTRA_STATUS_DECL=''
>>>>>>> F77='/SPG_ops/utils/ppc64/xlf/11.1/bin/f77'
>>>>>>> F77CPP=''
>>>>>>> F77_COMPLEX16=''
>>>>>>> F77_COMPLEX32=''
>>>>>>> F77_COMPLEX8=''
>>>>>>> F77_INCDIR=''
>>>>>>> F77_INTEGER16=''
>>>>>>> F77_INTEGER1=''
>>>>>>> F77_INTEGER2=''
>>>>>>> F77_INTEGER4=''
>>>>>>> F77_INTEGER8=''
>>>>>>> F77_LIBDIR_LEADER=''
>>>>>>> F77_LINKPATH_SHL=''
>>>>>>> F77_NAME_MANGLE=''
>>>>>>> F77_OTHER_LIBS=''
>>>>>>> F77_REAL16=''
>>>>>>> F77_REAL4=''
>>>>>>> F77_REAL8=''
>>>>>>> F77_SHL=''
>>>>>>> FC=''
>>>>>>> FCCPP=''
>>>>>>> FCEXT=''
>>>>>>> FCFLAGS=' '
>>>>>>> FCINC=''
>>>>>>> FCINCFLAG=''
>>>>>>> FCMODEXT=''
>>>>>>> FCMODINCFLAG=''
>>>>>>> FCMODINCSPEC=''
>>>>>>> FC_LINKPATH_SHL=''
>>>>>>> FC_OTHER_LIBS=''
>>>>>>> FC_SHL=''
>>>>>>> FC_WORK_FILES_ARG=''
>>>>>>> FFLAGS='-O2 -c -qextname -q64 -qwarn64 '
>>>>>>> FGREP=''
>>>>>>> FILE=''
>>>>>>> FINCLUDES=''
>>>>>>> FLIBS=''
>>>>>>> FORTRAN_BINDING=''
>>>>>>> FORTRAN_MPI_OFFSET=''
>>>>>>> FROM_MPICH2='yes'
>>>>>>> FWRAPNAME='fmpich'
>>>>>>> GCC=''
>>>>>>> GNUCXX_MINORVERSION=''
>>>>>>> GNUCXX_VERSION=''
>>>>>>> GREP=''
>>>>>>> HAVE_CXX_EXCEPTIONS=''
>>>>>>> HAVE_ROMIO=''
>>>>>>> INCLUDE_MPICXX_H=''
>>>>>>> INCLUDE_MPIDDEFS_H=''
>>>>>>> INSTALL_DATA=''
>>>>>>> INSTALL_PROGRAM=''
>>>>>>> INSTALL_SCRIPT=''
>>>>>>> KILLALL=''
>>>>>>> LDFLAGS=' '
>>>>>>> LDFLAGS_DEPS=''
>>>>>>> LIBOBJS=''
>>>>>>> LIBS=' '
>>>>>>> LIBTOOL=''
>>>>>>> LIB_DEPS=''
>>>>>>> LTLIBOBJS=''
>>>>>>> MAKE=''
>>>>>>> MAKE_DEPEND_C=''
>>>>>>> MANY_PM=''
>>>>>>> MKDIR_P=''
>>>>>>> MPIBASEMODNAME=''
>>>>>>> MPICC=''
>>>>>>> MPICH2LIB_CFLAGS=''
>>>>>>> MPICH2LIB_CPPFLAGS=''
>>>>>>> MPICH2LIB_CXXFLAGS=''
>>>>>>> MPICH2LIB_FCFLAGS=''
>>>>>>> MPICH2LIB_FFLAGS=''
>>>>>>> MPICH2LIB_LDFLAGS=''
>>>>>>> MPICH2LIB_LIBS=''
>>>>>>> MPICH2_NUMVERSION='10401301'
>>>>>>> MPICH2_RELEASE_DATE='Thu Sep  1 13:53:02 CDT 2011'
>>>>>>> MPICH2_VERSION='1.4.1p1'
>>>>>>> MPICH_TIMER_KIND=''
>>>>>>> MPICONSTMODNAME=''
>>>>>>> MPICXX=''
>>>>>>> MPICXXLIBNAME=''
>>>>>>> MPID_TIMER_TYPE=''
>>>>>>> MPIF77=''
>>>>>>> MPIFC=''
>>>>>>> MPIFLIBNAME=''
>>>>>>> MPIFPMPI=''
>>>>>>> MPILIBNAME=''
>>>>>>> MPIMODNAME=''
>>>>>>> MPIR_CXX_BOOL=''
>>>>>>> MPIR_CXX_COMPLEX=''
>>>>>>> MPIR_CXX_DOUBLE_COMPLEX=''
>>>>>>> MPIR_CXX_LONG_DOUBLE_COMPLEX=''
>>>>>>> MPISIZEOFMODNAME=''
>>>>>>> MPIU_DLL_SPEC_DEF=''
>>>>>>> MPIU_THREAD_LIB_NAME=''
>>>>>>> MPI_2COMPLEX=''
>>>>>>> MPI_2DOUBLE_COMPLEX=''
>>>>>>> MPI_2DOUBLE_PRECISION=''
>>>>>>> MPI_2INT=''
>>>>>>> MPI_2INTEGER=''
>>>>>>> MPI_2REAL=''
>>>>>>> MPI_AINT=''
>>>>>>> MPI_AINT_DATATYPE=''
>>>>>>> MPI_AINT_FMT_DEC_SPEC=''
>>>>>>> MPI_AINT_FMT_HEX_SPEC=''
>>>>>>> MPI_BYTE=''
>>>>>>> MPI_CHAR=''
>>>>>>> MPI_CHARACTER=''
>>>>>>> MPI_COMPLEX16=''
>>>>>>> MPI_COMPLEX32=''
>>>>>>> MPI_COMPLEX8=''
>>>>>>> MPI_COMPLEX=''
>>>>>>> MPI_C_BOOL=''
>>>>>>> MPI_C_DOUBLE_COMPLEX=''
>>>>>>> MPI_C_FLOAT_COMPLEX=''
>>>>>>> MPI_C_LONG_DOUBLE_COMPLEX=''
>>>>>>> MPI_DOUBLE=''
>>>>>>> MPI_DOUBLE_COMPLEX=''
>>>>>>> MPI_DOUBLE_INT=''
>>>>>>> MPI_DOUBLE_PRECISION=''
>>>>>>> MPI_F77_2INT=''
>>>>>>> MPI_F77_AINT=''
>>>>>>> MPI_F77_BYTE=''
>>>>>>> MPI_F77_CHAR=''
>>>>>>> MPI_F77_C_BOOL=''
>>>>>>> MPI_F77_C_COMPLEX=''
>>>>>>> MPI_F77_C_DOUBLE_COMPLEX=''
>>>>>>> MPI_F77_C_FLOAT_COMPLEX=''
>>>>>>> MPI_F77_C_LONG_DOUBLE_COMPLEX=''
>>>>>>> MPI_F77_DOUBLE=''
>>>>>>> MPI_F77_DOUBLE_INT=''
>>>>>>> MPI_F77_FLOAT=''
>>>>>>> MPI_F77_FLOAT_INT=''
>>>>>>> MPI_F77_INT16_T=''
>>>>>>> MPI_F77_INT32_T=''
>>>>>>> MPI_F77_INT64_T=''
>>>>>>> MPI_F77_INT8_T=''
>>>>>>> MPI_F77_INT=''
>>>>>>> MPI_F77_LB=''
>>>>>>> MPI_F77_LONG=''
>>>>>>> MPI_F77_LONG_DOUBLE=''
>>>>>>> MPI_F77_LONG_DOUBLE_INT=''
>>>>>>> MPI_F77_LONG_INT=''
>>>>>>> MPI_F77_LONG_LONG=''
>>>>>>> MPI_F77_LONG_LONG_INT=''
>>>>>>> MPI_F77_OFFSET=''
>>>>>>> MPI_F77_PACKED=''
>>>>>>> MPI_F77_SHORT=''
>>>>>>> MPI_F77_SHORT_INT=''
>>>>>>> MPI_F77_SIGNED_CHAR=''
>>>>>>> MPI_F77_UB=''
>>>>>>> MPI_F77_UINT16_T=''
>>>>>>> MPI_F77_UINT32_T=''
>>>>>>> MPI_F77_UINT64_T=''
>>>>>>> MPI_F77_UINT8_T=''
>>>>>>> MPI_F77_UNSIGNED=''
>>>>>>> MPI_F77_UNSIGNED_CHAR=''
>>>>>>> MPI_F77_UNSIGNED_LONG=''
>>>>>>> MPI_F77_UNSIGNED_LONG_LONG=''
>>>>>>> MPI_F77_UNSIGNED_SHORT=''
>>>>>>> MPI_F77_WCHAR=''
>>>>>>> MPI_FINT=''
>>>>>>> MPI_FLOAT=''
>>>>>>> MPI_FLOAT_INT=''
>>>>>>> MPI_INT16_T=''
>>>>>>> MPI_INT32_T=''
>>>>>>> MPI_INT64_T=''
>>>>>>> MPI_INT8_T=''
>>>>>>> MPI_INT=''
>>>>>>> MPI_INTEGER16=''
>>>>>>> MPI_INTEGER1=''
>>>>>>> MPI_INTEGER2=''
>>>>>>> MPI_INTEGER4=''
>>>>>>> MPI_INTEGER8=''
>>>>>>> MPI_INTEGER=''
>>>>>>> MPI_LB=''
>>>>>>> MPI_LOGICAL=''
>>>>>>> MPI_LONG=''
>>>>>>> MPI_LONG_DOUBLE=''
>>>>>>> MPI_LONG_DOUBLE_INT=''
>>>>>>> MPI_LONG_INT=''
>>>>>>> MPI_LONG_LONG=''
>>>>>>> MPI_MAX_PROCESSOR_NAME=''
>>>>>>> MPI_OFFSET=''
>>>>>>> MPI_OFFSET_DATATYPE=''
>>>>>>> MPI_OFFSET_TYPEDEF=''
>>>>>>> MPI_PACKED=''
>>>>>>> MPI_REAL16=''
>>>>>>> MPI_REAL4=''
>>>>>>> MPI_REAL8=''
>>>>>>> MPI_REAL=''
>>>>>>> MPI_SHORT=''
>>>>>>> MPI_SHORT_INT=''
>>>>>>> MPI_SIGNED_CHAR=''
>>>>>>> MPI_STATUS_SIZE=''
>>>>>>> MPI_UB=''
>>>>>>> MPI_UINT16_T=''
>>>>>>> MPI_UINT32_T=''
>>>>>>> MPI_UINT64_T=''
>>>>>>> MPI_UINT8_T=''
>>>>>>> MPI_UNSIGNED_CHAR=''
>>>>>>> MPI_UNSIGNED_INT=''
>>>>>>> MPI_UNSIGNED_LONG=''
>>>>>>> MPI_UNSIGNED_LONG_LONG=''
>>>>>>> MPI_UNSIGNED_SHORT=''
>>>>>>> MPI_WCHAR=''
>>>>>>> NEEDSPLIB=''
>>>>>>> NO_WEAK_SYM=''
>>>>>>> NO_WEAK_SYM_TARGET=''
>>>>>>> OBJEXT=''
>>>>>>> OFFSET_KIND=''
>>>>>>> PACKAGE_BUGREPORT=''
>>>>>>> PACKAGE_NAME=''
>>>>>>> PACKAGE_STRING=''
>>>>>>> PACKAGE_TARNAME=''
>>>>>>> PACKAGE_VERSION=''
>>>>>>> PATH_SEPARATOR=':'
>>>>>>> PERL=''
>>>>>>> PMPIFLIBNAME=''
>>>>>>> PMPILIBNAME=''
>>>>>>> PROFILE_DEF_MPI=''
>>>>>>> RANLIB=''
>>>>>>> RANLIB_AFTER_INSTALL=''
>>>>>>> REQD=''
>>>>>>> REQI1=''
>>>>>>> REQI2=''
>>>>>>> REQI8=''
>>>>>>> SET_CFLAGS=''
>>>>>>> SET_MAKE=''
>>>>>>> SHELL='/bin/sh'
>>>>>>> SHLIB_EXT=''
>>>>>>> SHLIB_FROM_LO=''
>>>>>>> SHLIB_INSTALL=''
>>>>>>> SIZEOF_FC_CHARACTER=''
>>>>>>> SIZEOF_FC_DOUBLE_PRECISION=''
>>>>>>> SIZEOF_FC_INTEGER=''
>>>>>>> SIZEOF_FC_REAL=''
>>>>>>> SIZEOF_MPI_STATUS=''
>>>>>>> USER_CFLAGS='-c -m64 -mcpu=power6 -DLINUX -D_LP64'
>>>>>>> USER_CPPFLAGS=''
>>>>>>> USER_CXXFLAGS=''
>>>>>>> USER_FCFLAGS=''
>>>>>>> USER_FFLAGS='-O2 -c -qextname -q64 -qwarn64'
>>>>>>> USER_LDFLAGS=''
>>>>>>> USER_LIBS=''
>>>>>>> VPATH=''
>>>>>>> WRAPPER_CFLAGS='-c -m64 -mcpu=power6 -DLINUX -D_LP64 '
>>>>>>> WRAPPER_CPPFLAGS=' '
>>>>>>> WRAPPER_CXXFLAGS=' '
>>>>>>> WRAPPER_FCFLAGS=' '
>>>>>>> WRAPPER_FFLAGS='-O2 -c -qextname -q64 -qwarn64 '
>>>>>>> WRAPPER_LDFLAGS=''
>>>>>>> WRAPPER_LIBS=''
>>>>>>> WTIME_DOUBLE_TYPE=''
>>>>>>> XARGS_NODATA_OPT=''
>>>>>>> ac_ct_CC=''
>>>>>>> ac_ct_CXX=''
>>>>>>> ac_ct_F77=''
>>>>>>> ac_ct_FC=''
>>>>>>> bindings=''
>>>>>>> bindings_dirs=''
>>>>>>> bindir='${exec_prefix}/bin'
>>>>>>> build=''
>>>>>>> build_alias=''
>>>>>>> build_cpu=''
>>>>>>> build_os=''
>>>>>>> build_vendor=''
>>>>>>> datadir='${datarootdir}'
>>>>>>> datarootdir='${prefix}/share'
>>>>>>> debugger_dir=''
>>>>>>> device_name=''
>>>>>>> docdir='${datarootdir}/doc/${PACKAGE}'
>>>>>>> dvidir='${docdir}'
>>>>>>> exec_prefix='NONE'
>>>>>>> host=''
>>>>>>> host_alias=''
>>>>>>> host_cpu=''
>>>>>>> host_os=''
>>>>>>> host_vendor=''
>>>>>>> htmldir='${docdir}'
>>>>>>> includedir='${prefix}/include'
>>>>>>> infodir='${datarootdir}/info'
>>>>>>> libdir='${exec_prefix}/lib'
>>>>>>> libexecdir='${exec_prefix}/libexec'
>>>>>>> localedir='${datarootdir}/locale'
>>>>>>> localstatedir='${prefix}/var'
>>>>>>> logging_dir=''
>>>>>>> logging_name=''
>>>>>>> logging_subdirs=''
>>>>>>> mandir='${datarootdir}/man'
>>>>>>> master_top_builddir=''
>>>>>>> master_top_srcdir=''
>>>>>>> modincdir=''
>>>>>>> mpe_dir=''
>>>>>>> nameserv_name=''
>>>>>>> oldincludedir='/usr/include'
>>>>>>> opadir=''
>>>>>>> other_install_dirs=''
>>>>>>> other_pm_names=''
>>>>>>> pac_prog=''
>>>>>>> pdfdir='${docdir}'
>>>>>>> pm_name=''
>>>>>>> pmi_name=''
>>>>>>> prefix='/homedir/mdbaker2/mpi/mpich2-1.4.1p1'
>>>>>>> program_transform_name='s,x,x,'
>>>>>>> psdir='${docdir}'
>>>>>>> romio_dir=''
>>>>>>> sbindir='${exec_prefix}/sbin'
>>>>>>> sharedstatedir='${prefix}/com'
>>>>>>> subdirs=''
>>>>>>> subsystems=''
>>>>>>> sysconfdir='${prefix}/etc'
>>>>>>> target_alias=''
>>>>>>> ## confdefs.h. ##
>>>>>>> configure: exit 77
>>>>>>> LaRC Ext:  x46393
>>>>>>> _______________________________________________
>>>>>>> mpich-discuss mailing list mpich-discuss at mcs.anl.gov
>>>>>>> <mailto:mpich-discuss at mcs.anl.gov>
>>>>>>> To manage subscription options or unsubscribe:
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
>>>>>> Pavan Balaji
>>>>>> http://www.mcs.anl.gov/~balaji
>>>> Pavan Balaji
>> Pavan Balaji
