[mpich-discuss] fence vs. lock-unlock
Jie Chen
jiechen at mcs.anl.gov
Mon Jul 9 01:10:40 CDT 2012
I am using one sided communications lock-unlock and see something that I do not understand.
In the normal case (using fence), my code block looks something like this (rank is my process id, nproc is the total number of processes):
for i = 0 to nproc-1
-- fence
-- MPI_Get something from process (rank+i)%nproc
-- fence
-- computation
end
The time line for the above operations looks like the following, which is completely normal (- means computation, * means communication including fence and MPI_Get):
proc 0: *--------*--------*--------*--------
proc 1: *--------*--------*--------*--------
proc 2: *--------*--------*--------*--------
proc 3: *--------*--------*--------*--------
The above illustration shows perfect computation load balance, for simplicity.
However, when I change the two fences by lock and unlock, the time line looks like the following
proc 0: *--------**********--------*--------**********--------
proc 1: *--------*--------**********--------*--------
proc 2: *--------*******************--------*--------*--------
proc 3: *--------*--------**********--------**********--------
The problem here is that sometimes the communication takes a very long time to finish. In particular, this is attributed to the MPI_Win_unlock call that will not return until the target process has finished one round of computation.
I do not understand why the unlock (or perhaps the actual data transfer) is so time consuming. The figures here show balanced computational work load. When the work load is not balanced, I thought the lock/unlock mechanism was better than using fence because it avoids barriers. But according to experiments, it appears that having barriers is better than none. Is this caused by the implementation of MPI_Win_unlock or the hardware?
Jie Chen
Mathematics and Computer Science Division
Argonne National Laboratory
Address: 9700 S Cass Ave, Bldg 240, Lemont, IL 60439
Phone: (630) 252-3313
Email: jiechen at mcs.anl.gov
Homepage: http://www.mcs.anl.gov/~jiechen
