[mpich-discuss] MPICH2 installation failure
    Paul Duteïs
    gridzfix at hotmail.com
    Tue Jan 31 19:59:45 CST 2012
Alright... Now for some reasons I'm not getting the same error although I didn't change anything.
I'm getting instead:
[linux-hpws.site:02238] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file runtime/orte_init.c at line 125
It looks like orte_init failed for some reason; your parallel process is
likely to abort.  There are many reasons that a parallel process can
fail during orte_init; some of which are due to configuration or
environment problems.  This failure appears to be an internal failure;
here's some additional information (which may only be relevant to an
Open MPI developer):
  orte_ess_base_select failed
  --> Returned value Not found (-13) instead of ORTE_SUCCESS
[linux-hpws.site:02238] [[INVALID],INVALID] ORTE_ERROR_LOG: Not found in file orterun.c at line 543
I don't get this at all :(
> From: thakur at mcs.anl.gov
> Date: Tue, 31 Jan 2012 19:45:59 -0600
> To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] MPICH2 installation failure
> You need to set up passwordless ssh.
> On Jan 31, 2012, at 7:21 PM, Ed Pataky wrote:
> > I can ssh  with a password
> > On Tuesday, January 31, 2012, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
> > > Can you ssh to your own machine? Can you run
> > > % ssh "your-machine-name" date
> > > Rajeev
> > > On Jan 31, 2012, at 12:05 PM, Duteïs, Paul wrote:
> > >> Good evening,
> > >> For some reasons I can't get MPICH2 to install correctly on my Opensuse 12.1 system.
> > >> Everything goes smoothly until I try the first following test
> > >> mpiexec -n 2 ./examples/cpi
> > >> where it says
> > >> ssh: Could not resolve hostname linux-hpws.site: Name or service not known
> > >> and just crashes.
> > >> Could you help me with whatever is wrong? I've joined the log files.
> > >> Best Regards,
> > >> Paul Duteïs
> > >> <logfiles.tar.gz>_______________________________________________
> > >> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> > >> To manage subscription options or unsubscribe:
> > >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20120201/313dceff/attachment.htm>
