[mpich-discuss] Compaq Visual fortran - Re: [mpich2-maint] MPI
    Jayesh Krishna
    jayesh at mcs.anl.gov
    Mon Jan 30 10:39:19 CST 2012
 We do not regularly test MPICH2 with Compaq Visual Fortran. You should be able to use CVF with MPICH2 if you change the default method of passing strings to the convention used by Intel Fortran Compiler ("Length after arguments").
Jayesh
----- Original Message -----
From: "Sergey Voskoboynikov" <voskoboynikov at spbau.ru>
To: mpich2-maint at mcs.anl.gov
Sent: Monday, January 30, 2012 8:36:54 AM
Subject: [mpich2-maint] MPI
Hello!
Is it possible to use MPI with old Compaq Visual Fortran 6.6 ?
There is remark about Visual Fortran 6 in manual
For Visual Fortran 6 use fmpich2s.lib:
·      fmpich2.lib contains all caps cdecl: MPI_INIT
·      fmpich2s.lib contains all caps stdcall: MPI_INIT at 4
·      fmpich2g.lib or fmpich2g.a contain lowercase cdecl: mpi_init__
Visual Fortran 6 is not Compaq Visual Fortran 6.6 ?
Thank you in advance.
Sergey.
mpich2-maint mailing list
mpich2-maint at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/mpich2-maint
